Old 2nd January 2009, 14:09   #101  |  Link
~bT~
н∂-αиαтι
oh, btw.. i selected yellow for subs yesterday and it was white.. the code for yellow in your prog is diff from JAMAT.
JAMAT = 720p-fontcolor=0xFFFF00
MulTiAVCHD = 720p-fontcolor=0x0000FFFF
Old 2nd January 2009, 14:33   #102  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
I took the value from tsMuxer... Changed it now to a bit different and it shows nice yellow now.
Old 2nd January 2009, 17:40   #103  |  Link
deank
deank's Avatar
@asherungar, @odin24: any results on the NTSC version?
Old 2nd January 2009, 17:42   #104  |  Link
bigggt
Do you just drag the whole AVCHD folder to a usb and the PS3 should be able to play it
I get a black screen for about 1 minute and then it goes back to the XMB bar
i am in Canada so i don't know if its the PAL menu or not,anyway i downloaded the ntsc version(The menu is Pal and i can't change it)and i get the same thing
i am not even sure how to play AVCHD from usb so this post could be useless
thanks
bigggt is offline   Reply With Quote
Old 2nd January 2009, 17:43   #105  |  Link
Krawhitham
Canada is NTSC
Krawhitham is offline   Reply With Quote
Old 2nd January 2009, 17:46   #106  |  Link
bigggt
Originally Posted by Krawhitham View Post
Canada is NTSC
I know
i assume that the ntsc version is default but since it says PAL in the dropdown box i wasn't sure
Old 2nd January 2009, 17:47   #107  |  Link
deank
deank's Avatar
Yes, that't right - copy to root of your usb drive.
I don't know how you could determine if menu is PAL or NTSC. It is coded in NTSC format in the ntsc version. Do you use HDMI connection from your PS3 to your TV?
edit: PAL system in drop-down is disabled and not affecting anything... it is just a gui addon that is not used for now.
Old 2nd January 2009, 18:00   #108  |  Link
bigggt
thanks
I tested with a different .mkv and now it works on the ntsc version ,the first mkv was transformers that i made from HD DVD using ripbot and the second is just a 20 second clip using the same evo file
i will test the 20 second clip with the pal version to see if works
edit
multiAVCHD pal version skips the menu and goes right into the first movie
Old 2nd January 2009, 18:36   #109  |  Link
Krawhitham
Originally Posted by deank View Post
I added NTSC link in first post:
multiAVCHD_NTSC.rar
Please share the results.
Dean
Worked from DVD disc
Old 2nd January 2009, 18:48   #110  |  Link
deank
deank's Avatar
Thanks to both of you, really!
So, now I must find a way to mux interactive track (IGS) with menu (AVC video + AC3 audio) and we'll have custom menus.
Old 2nd January 2009, 19:44   #111  |  Link
odin24
odin24's Avatar
Location: The Great North (the better half of North America)
I just tested on 1 mkv... that's all that I had at the moment. It works fine creating a AVCHD, tested on a USB stick.
Really, this is the first time I used it... pretty slick!
odin24 is offline   Reply With Quote
Old 2nd January 2009, 22:02   #112  |  Link
zoner
Well, i think i've found some kind of bug, i got the latest build and i've made a 3 titles avchd from 3 mkvs.
only the first 2 menu links are good, 3rd link gives me nothing.
all the process went well and all files are in the structure as well.
zoner is offline   Reply With Quote
Old 2nd January 2009, 22:38   #113  |  Link
deank
deank's Avatar
You can PM me the LOG... I guess some of the MKVs are not tsMuxer friendly.
I guess, I'll add some error counter at the end of the log.
If mkv's are missing that means that tsmuxer was unable to detect/remux some of the MKVs selected.
Please let me know of your case, zoner.
p.s. Do you see the third MKV somewhere in the MTSs in the output folder?
... p.s.X And something else... Do you see somewhere in log "Setting menu for XXX titles..."? XXX should reflect the real count - i.e. tsmuxer's output + avchd folders (if you didn't touch cut start/end settings).
Dean
Old 3rd January 2009, 02:57   #114  |  Link
~bT~
н∂-αиαтι
that is most likely the cause as i have found out thru trials.
Old 3rd January 2009, 11:28   #115  |  Link
deank
deank's Avatar
In latest build (92) I added error checking on tsmuxer's output.
Also warning is issued if video height is not avchd compliant (720 or 1080).
Fixed playlist files generated by tsmuxer with ID:MPLS0200, now set to MPLS0100.
Old 3rd January 2009, 18:08   #116  |  Link
~bT~
н∂-αиαтι
^ 480 & 576 is also compliant
Old 3rd January 2009, 18:17   #117  |  Link
deank
deank's Avatar
I was thinking if to add these... I will add both so no warnings for videos with 480/576.
Old 3rd January 2009, 19:07   #118  |  Link
~bT~
н∂-αиαтι
updates not working...
Checking...
Downloading...
URL: http://multiavchd.deanbg.com/multiavchd.exe
HttpSendRequest error
HttpQueryInfo: 12019
Error! (0)
Old 3rd January 2009, 19:14   #119  |  Link
deank
deank's Avatar
I should probably add mirror servers in multiUPDATE.exe. Sorry, my server is heavily loaded. It is okay now.
Old 3rd January 2009, 20:10   #120  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
Hi Dean,
Is there any possibility you could provide an option to directly "Add Transport Streams", ie: something like this: -
