Old 5th November 2009, 00:10   #3781  |  Link
shabadaus
hi all,
I have a big problem with my ps3 usa.
I have coded a high def mkv video in avchd using multiAVCHD, with the menu using the ntsc option.
when I play the avchd in ps3, the menu run very well, when select the film, the ps3 seems to play the video,
but in the screen there is nothing.
The same avchd in a LG BluRay player run very well.
could you help me.
tank you, in advance
ps - sorry for my bad english
shabadaus is offline   Reply With Quote
Old 5th November 2009, 00:15   #3782  |  Link
koutou
Hi and thanks for this great tool.
I was wondering what settings are you guys using for uncropping. I read that simple 1 pass would do the job, but how is quality affected compared to the original? Have you tried a comparison to the original mkv in a big screen with a projector? I tried various modes and then with mediainfo I can see that each mode has different parameters which are very different to the original mkv. Is this changing the original mkv entirely like being a different encode? I'm really worried about quality. In such a case, which mode should I use?
Thank you for your feedback.
koutou is offline   Reply With Quote
Old 5th November 2009, 09:10   #3783  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
@shabadaus: Can you check if your video is PAL (25.000fps) and that you're using the latest multiAVCHD build. Also - can you post your log?
@koutou: Transcoding/uncropping in both multiAVCHD and uncropMKV means "full reencode" of the video with x264 encoder. Of course it will have different 'settings' than the original. "1 pass", "1 pass Turbo" are good choices. You need to do your own test to see if you can see the difference in quality.
Dean
Old 5th November 2009, 17:19   #3784  |  Link
shabadaus
tank Dean for your tool.
yes the video encoded was in pal format 25fps and the build use is 715. I can't post the log because I have discarged it after the encode procedure.
My ps3 is ntsc, but i am in Italy. What is the procedure to create a avchd for my ps3 using pal video?
Ciao e grazie for your help
Shabadaus
Old 5th November 2009, 17:23   #3785  |  Link
deank
deank's Avatar
Build 715 should slowdown the video from 25fps to 23.976.
1) Go to AUTHOR tab and select NTSC tv system
2) Load the file
3) Click START and then "Playstation 3"
You should see a line in the log that multiAVCHD is performing NTSC slowdown.
Let me know if it works.
Old 5th November 2009, 18:28   #3786  |  Link
shabadaus
dean, but in this way, if I understood, the program creates a directory to put in removible usb disk or pen. if I have to create an avchd to play in ps3, I must to burn a dvd with the direrctories create with the ps3 tag?
Old 5th November 2009, 18:30   #3787  |  Link
deank
deank's Avatar
Yeah, okay.. then just use "AVCHD for optical media" button.
Before you burn the output BDMV folder make sure to check the log for the slowdown lines I mentioned earlier.
Old 5th November 2009, 19:33   #3788  |  Link
shabadaus
Dean,
using the ntsc down in ps3 tag the result avchd copied on usb support is played on my ps3, but there is a
loss of synchronization between audio and video.
The conversion from pal to ntsc works only on video? if the answer is yes, do you know some prog that converts audio and video from pal to ntsc?
Shabadaus
Old 5th November 2009, 19:48   #3789  |  Link
deank
deank's Avatar
It should work for both video and audio. Unless you give me more info - I can't help you. The log should show using eac3to for audio slowdown.
Old 6th November 2009, 13:37   #3790  |  Link
deank
deank's Avatar
Build 716:
* Few small fixes and "Media" tab changes:
"Transcode" button is now available directly in MEDIA TAB. Clicking it will open "Title properties" and if transcode is available for the selected file, "Transcode" window will automatically appear, too.
Don't forget that you can open title properties by:
Selecting the file/title in the list and
* Clicking "EDIT"
* Clicking the info-line just below the file list
* Clicking "TRANSCODE" button
or
* Just clicking the title name in the "Compilation" box
I wonder how it is so many people NEVER got to the extended properties of a title ("Title properties" window).
Dean
Old 6th November 2009, 13:50   #3791  |  Link
Music Fan
Because we don't see at the first time that we can click on the file names in the compilation box. It doesn't look interactive.
Music Fan is offline   Reply With Quote
Old 6th November 2009, 14:48   #3792  |  Link
Beatnut
Hi Dean, could my 64 Bit OS be the reasen for the fact that i cant make chapter thumbs?
Beatnut is offline   Reply With Quote
Old 6th November 2009, 14:52   #3793  |  Link
deank
deank's Avatar
The reason is that you computer cannot properly decode .m2ts files. I'd suggest you to uninstall haali splitter and when installing it back to tick MPEG-PS and MPEG-TS checkboxes.
You can test if it is okay by importing a M2TS file in multiAVCHD and check if you can see preview in Title properties / Transcode. If you have a preview with m2ts files there - you will get the thumbnails, too.
Dean
Old 6th November 2009, 15:41   #3794  |  Link
Beatnut
Preview works, with a single .mts file, and when adding an AVCHD folder, so multiple m2ts files in 1 title works too.
But when i press start, and it tries to make a menu at the end of the process. still gives these errors.
[15:26:50] Initialising...
[15:26:50] Checking for new version...
[15:26:50] You have the latest build.
[15:26:50] Consistency check finished!
[15:26:50] Initialization finished. multiAVCHD is ready!
[15:26:50] 309 days since multiAVCHD was published.
[15:26:50] 162 people supported it with donations
[15:26:50] and you are the 819418 one to launch the program...
[15:26:50] Support multiAVCHD to extend its features and keep it going!
[15:26:50] multiAVCHD.dat version: [03000706]
[15:28:12] Log started for multiAVCHD v3.0 (build 716)
[15:28:12] Selected output mode: Playstation 3 (USB/SDHC/MS)
[15:28:12] Processing one title...
[15:28:12] Existing E:\testtttstst\AVCHD-20091106-145012\AVCHD\ cannot be used as destination folder!
[15:28:12] Output will be written to: E:\testtttstst\AVCHD-20091106-145012\AVCHD-20091106-152812
[15:28:12] Processing (E:\Geconverteerde films\Earth\AVCHD\BDMV\STREAM\00001.MTS)...
[15:28:13] Detected frame reference count: 4 (max:4).
[15:28:13] Detected video: ID#4113:V_MPEG4/ISO/AVC 1920x1080, fps=23.976, ref=4
[15:28:13] Adding DTS audio track (ID#4352)
[15:28:13] Total of 2 tracks found in this file.
[15:28:13] Creating clip and playlist info (tsMuxeR)...
[15:28:13] Media split set at 4010MiB point...
        tsMuxeR (Version 1.10.6) output:
Decoding H264 stream (track 1): Profile: High@4.1  Resolution: 1920:1080p  Frame rate: 23.976
H.264 stream does not contain fps field. Muxing fps=23.976
Decoding DTS stream (track 2): Bitrate: 1536Kbps  Sample Rate: 48KHz  Channels: 5.1
B-pyramid level 1 detected. Shift DTS to 2 frames
Processed 53903 video frames
Creation of Blu-ray playlist
Creation of Blu-ray stream info and seek index
Mux successful complete.
Muxing time: 1 min 18 sec
        tsMuxeR meta:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr  --custom-chapters=00:00:00.000;00:03:07.000;00:06:14.000;00:09:22.000;00:12:29.000;00:15:36.000;00:18:44.000;00:21:51.000;00:24:58.000;00:28:06.000;00:31:13.000;00:34:20.000;00:37:27.000  --split-size=4010MiB  --vbv-len=500
V_MPEG4/ISO/AVC, "E:\Geconverteerde films\Earth\AVCHD\BDMV\STREAM\00001.MTS", insertSEI, contSPS, track=4113, fps=23.976
A_DTS, "E:\Geconverteerde films\Earth\AVCHD\BDMV\STREAM\00001.MTS", track=4352, lang=und, timeshift=0ms
[15:29:30] Setting resolution (1080p).
[15:29:30] Media transfer: 00000 -> 00000.m2ts
[15:29:30] Processing playlist...
[15:29:30] Title #1 added: "00001"
[15:29:30] Verifying title...
[15:29:37] Title has: 1 audio tracks and 0 subtitle tracks
[15:29:37] Preparing authoring information...
[15:29:37] Creating PAL top menu.
[15:29:37] Authoring menu (PAL).
[15:29:38] Creating menu backgrounds for 1 titles (SLI)...
[15:29:38] Trying to use Directshow first...
[15:29:44] Directshow spliter/decoder failed! (TBG)
[15:29:47] Using 12 thumbnail/chapter links for title #1...
[15:30:18] Creating video backgrounds for SLI menu completed.
[15:30:22] Compiling menu pages...
[15:30:38] Authoring custom menu completed.
[15:30:38] Setting menu for 1 titles...
[15:30:38] Go to menu after last title.
[15:30:39] Setting menu properties...
[15:30:39] Selected TV system: [PAL]
[15:30:39] Processing clip (CPI/CLPI) files...
[15:30:39] Completed.
[15:30:39] Setting FAT compatible 8.3 filenames...
[15:30:39] Done!
[15:30:40] Saving multiAVCHD quick-load project (mpf):
[15:30:40] E:\testtttstst\AVCHD-20091106-145012\AVCHD-20091106-152812\multiAVCHD.mpf (OK!)
        Compilation summary:
        Format: Playstation 3 (USB/SDHC/MS)
        1. 00001                                    [00:37:28]
        Overall duration : 00:37:28
        Output size      : 4001 MiB (3.907 GiB)
[15:30:40] E:\testtttstst\AVCHD-20091106-145012\AVCHD-20091106-152812 folder created (AVCHD/Blu-ray output)!
[15:30:40] Copy E:\testtttstst\AVCHD-20091106-145012\AVCHD-20091106-152812 to root of USB stick/disk or MemoryStick card or to X:\PRIVATE\ of SDHC/SD/MMC card.
[15:30:40] You may now remove temp folder (E:\tempavchd\).
[15:30:40] Your compilation contains 0hrs 37min 28sec of video material.
[15:30:40] multiAVCHD finished in 148 seconds (00:02:28)!
[15:30:40] End of log.
[15:32:29] MAKER/Equipment ID: NERO.
[15:32:29] Created: 08/08/2007 00:54:53
[15:32:29] *** 1. AVCHD
[15:32:43] Added 1 AVCHD compatible folder(s).
[15:32:54] MAKER/Equipment ID: NERO.
[15:32:54] Created: 08/08/2007 00:54:53
[15:32:54] *** 1. AVCHD
[15:33:07] Added 1 AVCHD compatible folder(s).
[15:35:48] Log started for multiAVCHD v3.0 (build 716)
[15:35:48] Selected output mode: Playstation 3 (USB/SDHC/MS)
[15:35:48] Processing one title...
[15:35:49] Existing E:\testtttstst\AVCHD-20091106-145012\AVCHD\ cannot be used as destination folder!
[15:35:49] Output will be written to: E:\testtttstst\AVCHD-20091106-145012\AVCHD-20091106-153549
[15:35:49] Processing imported AVCHD/Blu-ray playlist...
[15:35:50] "Move transitional files" option is ignored!
[15:35:50] Input folder contents will be copied instead.
[15:35:50] Media transfer: 00001 -> 00000.m2ts
[15:35:50] Using user poster for title thumbnail (Earth.jpg)
[15:37:25] Media transfer: 00002 -> 00001.m2ts
[15:37:25] Using user poster for title thumbnail (Earth.jpg)
[15:38:51] Media transfer: 00003 -> 00002.m2ts
[15:38:51] Using user poster for title thumbnail (Earth.jpg)
[15:40:02] Processing playlist...
[15:40:02] Title #1 added: "Earth"
[15:40:02] Verifying title...
[15:40:17] Title has: 1 audio tracks and 0 subtitle tracks
[15:40:17] Preparing authoring information...
[15:40:17] Creating PAL top menu.
[15:40:17] Authoring menu (PAL).
[15:40:19] Creating menu backgrounds for 1 titles (SLI)...
[15:40:19] Trying to use Directshow first...
[15:40:20] Using 12 thumbnail/chapter links for title #1...
[15:40:22] Error creating thumbnail for chapter 1 (title #1)! Retrying...
[15:40:23] Second try failed, too! Retrying...
[15:40:25] Error creating thumbnail for chapter 2 (title #1)! Retrying...
[15:40:26] Second try failed, too! Retrying...
[15:40:30] Error creating thumbnail for chapter 3 (title #1)! Retrying...
[15:40:31] Second try failed, too! Retrying...
[15:40:35] Error creating thumbnail for chapter 4 (title #1)! Retrying...
[15:40:36] Second try failed, too! Retrying...
[15:40:40] Error creating thumbnail for chapter 5 (title #1)! Retrying...
[15:40:41] Second try failed, too! Retrying...
[15:40:45] Error creating thumbnail for chapter 6 (title #1)! Retrying...
[15:40:47] Second try failed, too! Retrying...
[15:40:51] Error creating thumbnail for chapter 7 (title #1)! Retrying...
[15:40:53] Second try failed, too! Retrying...
[15:40:56] Error creating thumbnail for chapter 8 (title #1)! Retrying...
[15:40:57] Second try failed, too! Retrying...
[15:41:01] Error creating thumbnail for chapter 9 (title #1)! Retrying...
[15:41:03] Second try failed, too! Retrying...
[15:41:07] Error creating thumbnail for chapter 10 (title #1)! Retrying...
[15:41:08] Second try failed, too! Retrying...
[15:41:12] Error creating thumbnail for chapter 11 (title #1)! Retrying...
[15:41:13] Second try failed, too! Retrying...
[15:41:16] Error creating thumbnail for chapter 12 (title #1)! Retrying...
[15:41:18] Second try failed, too! Retrying...
[15:41:20] Creating video backgrounds for SLI menu completed.
[15:41:24] Compiling menu pages...
[15:41:29] Authoring custom menu completed.
[15:41:29] Setting menu for 1 titles...
[15:41:29] Go to menu after last title.
[15:41:29] Setting menu properties...
[15:41:29] Selected TV system: [PAL]
[15:41:29] Processing clip (CPI/CLPI) files...
[15:41:29] Completed.
[15:41:29] Setting FAT compatible 8.3 filenames...
[15:41:29] Done!
[15:41:31] Saving multiAVCHD quick-load project (mpf):
[15:41:31] E:\testtttstst\AVCHD-20091106-145012\AVCHD-20091106-153549\multiAVCHD.mpf (OK!)
        1. Earth                                    [01:39:42]
        Overall duration : 01:39:42
        Output size      : 11323 MiB (11.058 GiB)
[15:41:31] E:\testtttstst\AVCHD-20091106-145012\AVCHD-20091106-153549 folder created (AVCHD/Blu-ray output)!
[15:41:31] Copy E:\testtttstst\AVCHD-20091106-145012\AVCHD-20091106-153549 to root of USB stick/disk or MemoryStick card or to X:\PRIVATE\ of SDHC/SD/MMC card.
[15:41:31] You may now remove temp folder (E:\tempavchd\).
[15:41:31] Your compilation contains 1hrs 39min 42sec of video material.
[15:41:31] multiAVCHD finished in 342 seconds (00:05:42)!
[15:41:31] End of log.
Old 6th November 2009, 15:44   #3795  |  Link
deank
deank's Avatar
I meant the LITTLE PREVIEW BOX on the left-top (where you see multiavchd.deanbg.com) - it should show a frame from your video.
3x3 preview works, because mplayer is used, not directshow and this won't help you. It may help if you uncheck [x] Use directshow option in Menu TAB...
You should see it like this:
Dean
Old 6th November 2009, 16:00   #3796  |  Link
Beatnut
I guess i'll have to deal with it , unchecking use directshow didn't do the trick either.
ah well...
Old 6th November 2009, 16:02   #3797  |  Link
deank
deank's Avatar
Last week I installed Windows7 64bit JUST to try if multiAVCHD will work properly and I had no problems with it.
What I did was to install ffdshow, avisynth and haali splitter - nothing else and the clean install of win7 worked with multiAVCHD as a charm with the first try.
If you have some weird codec packs installed - uninstall them and start again (if you have the nerves).
Old 6th November 2009, 16:56   #3798  |  Link
Beatnut
when i look into installed programs, (i dont know what it its called in english) it only shows ffdshow avisynth and haali media splitter, no other codec packs. btw, how come i do can make a menu from a single m2ts file and not from a folder.
Old 6th November 2009, 16:58   #3799  |  Link
deank
deank's Avatar
You seem to use 'poster' images, which make it work. If you can't get the chapter thumbnails to be created then you can't get 'title thumbnails' to be created either.
Frankly, I have no ideas how to solve your troubles at the moment.
Old 7th November 2009, 09:45   #3800  |  Link
WildTexasChef
multiAVCHD just finished processing. The other computer running BD-Rebuilder on a different VC-1 movie... is still running. ETA on that is another 64 hours. IF that is actually true. IT will have taken it almost 3.5 days to process. A total of the 64 it has left, but the 22 hours it has allready been processing! I knew there was a reason why I only use one comptuer to process video. I hope it doesn't take as long if I can get it to run on my video system.
One step forward... one step back.
It converted the VC-1 Video to H.264 like I wanted...Yipeee! Finally! & the video even played just fine (At least on the computer it did. Don't know about the BD390 or TiVo yet. Will check on that later).
NOW the problem is... the resulting M2TS file it created has a massive Audio/Video Synch problem to it. Whats up with that?
What I am trying now is this.. I am demuxing the h.264 file from the M2TS file it created, and then I will remux with the original AC3 file that was demuxed from the original M2TS file off the Blu-ray. It probably won't work, but since it only takes about 15 min to demux and remux I thought I would give it a try & of course that didn't work either. The Audio/Video synch is all out of wack.
Any ideas now on either how to get multiAVCH to do it correctly, or to fix the issue by other means?
WTC
WildTexasChef is offline   Reply With Quote
