Old 15th April 2009, 10:25   #2141  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
@navycrow: That's good.
@jdeiro: No, nothing about LID's is added or changed for many builds.
@desray: Importing mpls is useful, because multiAVCHD cannot SPLIT bdmv/avchd input folders. If you import mpls file you can get something like 'movie-only' copy of your Blu-ray disc on USB or in 4GiB FAT32 compatible chunks... etc.
Some small changes in 524:
* Count of output audio tracks extended to 16 (was 10)
* Count of output subtitle tracks extended to 16 (was 10)
* Possible fix for users with Avisynth not being detected properly
Old 15th April 2009, 12:24   #2142  |  Link
desray
Home Theater Freak
desray's Avatar
I see...thanks for enlightening me. And navycrow, congrats to your success in making it work!
desray is offline   Reply With Quote
Old 15th April 2009, 12:47   #2143  |  Link
navycrow
Yes it works well now but....
i think there is a problem with the identification of language tag when importing LPMS playlist
Here is what multiAVCHD detect :
[13:35:49] Detected video: V_MPEG4/ISO/AVC (TID#4113)
[13:35:49] Detected resolution: 1920x1080
[13:35:49] Detected audio: A_LPCM (TID#4352 / language: und)
[13:35:49] Detected audio: A_AC3 (TID#4353 / language: eng)
[13:35:49] Detected audio: A_AC3 (TID#4354 / language: eng)
[13:35:49] Detected audio: A_DTS (TID#4355 / language: fra)
[13:35:49] Detected audio: A_AC3 (TID#4356 / language: ita)
[13:35:49] Detected audio: A_DTS (TID#4357 / language: ita)
[13:35:49] Detected audio: A_AC3 (TID#4358 / language: deu)
[13:35:49] Detected subtitles: S_HDMV/PGS (TID#4608 / language: deu)
[13:35:49] Detected subtitles: S_HDMV/PGS (TID#4609 / language: eng)
[13:35:49] Detected subtitles: S_HDMV/PGS (TID#4610 / language: eng)
[13:35:49] Detected subtitles: S_HDMV/PGS (TID#4611 / language: fra)
[13:35:49] Detected subtitles: S_HDMV/PGS (TID#4612 / language: fra)
[13:35:49] Detected subtitles: S_HDMV/PGS (TID#4613 / language: ita)
[13:35:49] Detected subtitles: S_HDMV/PGS (TID#4614 / language: ita)
[13:35:49] Detected subtitles: S_HDMV/PGS (TID#4615 / language: deu)
[13:35:49] Detected media file: 00000.m2ts
Here is what i should have :
soundtracks and subtitles are shifted
1st audio track which should be ENG -> become UND
3rd wich should be FRA -> become ENG
etc... and the same for subtitles
navycrow is offline   Reply With Quote
Old 15th April 2009, 13:12   #2144  |  Link
deank
deank's Avatar
@navycrow: Sorry for that... Just restart your multiAVCHD - it should update itself and get the fix. Please let me know if it worked this time.
Old 15th April 2009, 13:28   #2145  |  Link
navycrow
the log seems to report good tags now. i test it and give the feedback but it looks better.
Old 15th April 2009, 13:32   #2146  |  Link
ramonchin
Hi Deank!
Don't forget DTS to AC3 option please.
ramonchin is offline   Reply With Quote
Old 15th April 2009, 14:31   #2147  |  Link
deank
deank's Avatar
It is added.... and will work for MKV/MP4/MOV files.
So with this option now (in Audio / Subtitles) and with the other (HD audio to AC3) you can enable avchd-compliant audio mode.
MKV files with HD audio or with DTS audio will get their audio converted to LPCM or AC3 - formats which are a standard in AVCHD specs.
Old 15th April 2009, 16:12   #2148  |  Link
schlaufer
schlaufer's Avatar
Hi deank,
during my attempt to rebuild my HD DVD of Bourne Ultimatum as BD with the help of multiAVCHD, I've noticed a few things worth mentioning:
1. Off-by-1-bug when loading MPLS:
When I load a playlist for a movie with multiple sub-titles in different languages, the language codes are assigned wrong by multiAVCHD. The sequence deu-deu-eng-eng ist turned into unk-deu-deu-eng
2. Menu bug with PowerDVD 7 (may be PowerDVD or multiAVCHD related)
The XMB-menu works fine the first time I select a movie/chapter from it. But when I select menu from running movie, I can't navigate the menu any longer. I need to press STOP and start the BD again in order to be able to navigate.
3. Non-US-Chars in filenames bug.
If one of the BD directory structures is placed below a directory with a non-US char (in this particular case A-Umlaut), the file name is not correctly passed to tsMuxer. Not a big issue, but one has to be careful in naming directories.
4. Issues with MPEG2/480i extras
The extras are encoded in MPEG2 and have a resolution of 480i. TsMuxer muxes them fine and I can play the resulting m2ts w/o any issues in VLC, but when I play the corresponding movie in PD7, the image remains black (the chapter thumbnails are created fine, though). I can't remember, if I had the force/fixe resolution switch on in multiAVCHD, this may be the source of the problem.
5. DaemonTools/PD7 size issue
Not at all related to multiAVCHD but may cause grieve to others, so I mention it:
During testing, I create BD images with ImgBurn and mount them with Daemon Tools Lite to play them with PD7. There are at two conditions when PowerDVD refuses to recognise the mounted image:
a) the size of the image is smaller than 8.5GB (DVD9) or
b) I have a blank in the volume label of the image.
So far, thanks for the program and keep up with development at breath-taking pace!
schlaufer is offline   Reply With Quote
Old 15th April 2009, 16:30   #2149  |  Link
deank
deank's Avatar
Originally Posted by schlaufer View Post
Hi deank,
It was fixed earlier today in build 525.
PowerDVD is not the best software to test with and I do not support any problems which one may have while using multiAVCHD and testing/using PDVD. multiAVCHD is (mostly) for hardware players.
Try to use VirtualCloneDrive (or something alike).. not Daemon tools for mounting the iso. Other users reported problems with DTools and the inability of PDVD to play such .iso files.
Dean
p.s. (edit) A small test that can prove me right or wrong is to use the same .iso that PDVD has problems with and burn it to DVD/BD (depending on the options you used in multiAVCHD), play it in some stand-alone-player (SAP) and compare the results.
Old 15th April 2009, 16:41   #2150  |  Link
desray
Home Theater Freak
desray's Avatar
Hi deank, I am wondering can you add a shutdown the PC feature on multiAVCHD after processing the files?
Old 15th April 2009, 16:43   #2151  |  Link
deank
deank's Avatar
I can but I will not... multiAVCHD usually takes 5 to 30 minutes to complete its job and while it's still under heavy development I'd rather have users watching what it is doing, instead of going for a beer or to bed
Old 15th April 2009, 17:00   #2152  |  Link
desray
Home Theater Freak
desray's Avatar
Ok.
Old 15th April 2009, 19:35   #2153  |  Link
schlaufer
schlaufer's Avatar
I have no SAP as I am using an HTPC with an LG-Bluray/HD-DVD drive for watching my Hires movies.
Imho, a HTPC with PD7 (dis-)qualifies itself as an SAP as the PS3 does - it's a Von Neuman machine running software to play Blu-Ray movies. And I can watch all of my commercial BD w/o any issues.
I've explicitly mentioned PD7 as software, as it may issues others do not have. The test, if the multiAVCHD XMB-menu is still working after starting a movie (and jumping to the top-menu) can be easily exercised by anybody who has burnt a DVD/BD with multiple movies and chapters - I just want here results and point possible issues.
If someone with an SAP is willing to perform a test on the MPEG2/480i material, I can provide a 2min sample (57MB), just drop me a PN.
And regarding Daemon Tools/PD7 - I've read various messages in this forum referring to the problem, but none tracking it down. It's as easy if I wrote: if the disk is large enough (greater than a DL-DVD) it works, otherwise not. This was just a hint to other testers.
Old 15th April 2009, 19:43   #2154  |  Link
ramonchin
[QUOTE=deank;1274254]It is added.... and will work for MKV/MP4/MOV files.
MKV files with HD audio or with DTS audio will get their audio converted to LPCM or AC3 - formats which are a standard in AVCHD specs.]
Thanks Deank
Old 15th April 2009, 19:51   #2155  |  Link
deank
deank's Avatar
Imho, a HTPC with PD7 (dis-)qualifies itself as an SAP as the PS3 does - it's a Von Neuman machine.
You can't compare PS3 with any software player. PS3 BD/AVCHD player is almost as having sony bdp player aside.
I did more than 100 compilations and never had problems with menu or its visualisation (using DVD or USB).
Examine your log tab because sometimes there are errors which affect menu creation.
Old 15th April 2009, 20:05   #2156  |  Link
schlaufer
schlaufer's Avatar
Maybe I've expressed myself not clear enough:
The menu works fine when I start the BD the first time.
But when switch to the menu from a running movie I can't navigate the menu any longer.
Nevertheless, here is the log (timestamps omitted to match the 16k limit). I can't spot any error
Log started for multiAVCHD  v2.5 (build 525)
Processing 11 input files/folders.
Converting PLAYLIST to AVCHD (J:\BDMV\PLAYLIST\00000.mpls).
Generating meta file for tsMuxer...
M2TS stream split set at 31999MiB...
Detected video: V_MS/VFW/WVC1 (TID#4113)
Detected audio: A_AC3 (TID#4352 / language: und)
Detected audio: A_AC3 (TID#4353 / language: ger)
Detected subtitles: S_HDMV/PGS (TID#4608 / language: eng)
Detected subtitles: S_HDMV/PGS (TID#4609 / language: ger)
Detected subtitles: S_HDMV/PGS (TID#4610 / language: ger)
Detected subtitles: S_HDMV/PGS (TID#4611 / language: ger)
Detected subtitles: S_HDMV/PGS (TID#4612 / language: ger)
Detected subtitles: S_HDMV/PGS (TID#4613 / language: eng)
Detected subtitles: S_HDMV/PGS (TID#4614 / language: eng)
Detected chapter mark: 00:00:00.000;00:04:01.000;00:09:44.533;00:13:55.365;00:20:59.583
Detected chapter mark: 00:27:49.365;00:31:43.950;00:38:41.114;00:43:48.114;00:49:58.916
Detected chapter mark: 00:58:08.282;01:05:30.833;01:10:30.666;01:15:44.033;01:20:31.114
Detected chapter mark: 01:25:02.166;01:31:28.283;01:35:51.533;01:42:04.698;01:46:00.000
Creating Blu-ray folders (tsMuxeR)...
Done!
CLPI transfer: F:\_TEMP\20090415-193334-7948\BDMV\CLIPINF\00000.clpi -> F:\AVCHD_BOURNE\BDMV\CLIPINF\00000.clpi
M2TS transfer: F:\_TEMP\20090415-193334-7948\BDMV\STREAM\00000.m2ts -> F:\AVCHD_BOURNE\BDMV\STREAM\00000.m2ts
MPLS transfer: F:\_TEMP\20090415-193334-7948\BDMV\PLAYLIST\00000.mpls -> F:\AVCHD_BOURNE\BDMV\PLAYLIST\00000.mpls
Will use chapter marks: 00:00:00.000;00:04:01.000;00:09:44.533;00:13:55.365;00:20:59.583;00:27:49.365;00:31:43.950;00:38:41.114;00:43:48.114;00:49:58.916;00:58:08.282;01:05:30.833;01:10:30.666;01:15:44.033;01:20:31.114;01:25:02.166;01:31:28.283;01:35:51.533;01:42:04.698;01:46:00.000;
Converting to AVCHD (D:\Bourne III\Deleted Scenes-uncropped.mkv).
meta line: A_AC3, "D:\Bourne III\Deleted Scenes-uncropped.mkv", track=1, lang=eng
Detected audio: ID#1:A_AC3:audio (48000Hz/2ch) Language: eng
Detected video: ID#2:V_MPEG4/ISO/AVC:720x480 29.970fps (AR:1.5)
Adding subtitles (Deleted Scenes-uncropped.0.deu.sup) (deu)
Adding subtitles (Deleted Scenes-uncropped.1.eng.sup) (eng)
Searching for original chapters (mediainfo)...
Checking for external chapters (D:\Bourne III\Deleted Scenes-uncropped.txt)...
Using external chapters...
Detected frame reference count: 3 (max:24).
Compliant with L4.1 for 720x480p.
Creating Blu-ray folders (tsMuxer)...
Done!
CLPI transfer: F:\_TEMP\20090415-194703-1431\BDMV\CLIPINF\00000.clpi -> F:\AVCHD_BOURNE\BDMV\CLIPINF\00001.clpi
M2TS transfer: F:\_TEMP\20090415-194703-1431\BDMV\STREAM\00000.m2ts -> F:\AVCHD_BOURNE\BDMV\STREAM\00001.m2ts
MPLS transfer: F:\_TEMP\20090415-194703-1431\BDMV\PLAYLIST\00000.mpls -> F:\AVCHD_BOURNE\BDMV\PLAYLIST\00001.mpls
Will use chapter marks: 00:00:00.000;00:01:27.000;00:03:21.000;00:04:19.000;00:05:03.000;00:06:12.500;00:07:43.750;00:09:19.200;00:10:13.500;00:11:47.500;
Converting PLAYLIST to AVCHD (D:\Bourne III\Berlin\BDMV\PLAYLIST\00000.mpls).
Detected resolution: 720x480.
Detected video: V_MPEG-2 (TID#4113)
Detected audio: A_AC3 (TID#4352 / language: eng)
Detected subtitles: S_HDMV/PGS (TID#4608 / language: ger)
Detected chapter mark: 00:00:00.000;00:05:00.000
Done!
CLPI transfer: F:\_TEMP\20090415-194717-3769\BDMV\CLIPINF\00000.clpi -> F:\AVCHD_BOURNE\BDMV\CLIPINF\00002.clpi
M2TS transfer: F:\_TEMP\20090415-194717-3769\BDMV\STREAM\00000.m2ts -> F:\AVCHD_BOURNE\BDMV\STREAM\00002.m2ts
MPLS transfer: F:\_TEMP\20090415-194717-3769\BDMV\PLAYLIST\00000.mpls -> F:\AVCHD_BOURNE\BDMV\PLAYLIST\00002.mpls
Will use chapter marks: 00:00:00.000;00:05:00.000;
Converting PLAYLIST to AVCHD (D:\Bourne III\London\BDMV\PLAYLIST\00000.mpls).
Done!
CLPI transfer: F:\_TEMP\20090415-194731-4720\BDMV\CLIPINF\00000.clpi -> F:\AVCHD_BOURNE\BDMV\CLIPINF\00003.clpi
M2TS transfer: F:\_TEMP\20090415-194731-4720\BDMV\STREAM\00000.m2ts -> F:\AVCHD_BOURNE\BDMV\STREAM\00003.m2ts
MPLS transfer: F:\_TEMP\20090415-194731-4720\BDMV\PLAYLIST\00000.mpls -> F:\AVCHD_BOURNE\BDMV\PLAYLIST\00003.mpls
Will use chapter marks: 00:00:01;00:05:00;00:10:00;00:15:00;00:20:00;00:25:00;00:30:00;00:35:00;00:40:00;00:45:00;00:50:00;00:55:00;01:00:00;01:05:00;01:10:00;01:15:00;01:20:00;01:25:00;01:30:00;01:35:00;01:40:00;01:45:00;01:50:00;01:55:00;02:00:00;02:05:00;02:10:00;02:15:00;02:20:00;02:25:00;02:30:00;02:35:00;02:40:00;02:45:00;02:50:00;02:55:00;03:00:00;03:05:00;03:10:00;03:15:00;03:20:00;03:25:00;03:30:00;03:35:00;03:40:00;03:45:00;03:50:00;03:55:00;
Converting PLAYLIST to AVCHD (D:\Bourne III\Madrid\BDMV\PLAYLIST\00000.mpls).
Done!
CLPI transfer: F:\_TEMP\20090415-194736-4341\BDMV\CLIPINF\00000.clpi -> F:\AVCHD_BOURNE\BDMV\CLIPINF\00004.clpi
M2TS transfer: F:\_TEMP\20090415-194736-4341\BDMV\STREAM\00000.m2ts -> F:\AVCHD_BOURNE\BDMV\STREAM\00004.m2ts
MPLS transfer: F:\_TEMP\20090415-194736-4341\BDMV\PLAYLIST\00000.mpls -> F:\AVCHD_BOURNE\BDMV\PLAYLIST\00004.mpls
Converting PLAYLIST to AVCHD (D:\Bourne III\New York\BDMV\PLAYLIST\00000.mpls).
Done!
CLPI transfer: F:\_TEMP\20090415-194741-5076\BDMV\CLIPINF\00000.clpi -> F:\AVCHD_BOURNE\BDMV\CLIPINF\00005.clpi
M2TS transfer: F:\_TEMP\20090415-194741-5076\BDMV\STREAM\00000.m2ts -> F:\AVCHD_BOURNE\BDMV\STREAM\00005.m2ts
MPLS transfer: F:\_TEMP\20090415-194741-5076\BDMV\PLAYLIST\00000.mpls -> F:\AVCHD_BOURNE\BDMV\PLAYLIST\00005.mpls
Converting PLAYLIST to AVCHD (D:\Bourne III\Paris\BDMV\PLAYLIST\00000.mpls).
Done!
CLPI transfer: F:\_TEMP\20090415-194753-175\BDMV\CLIPINF\00000.clpi -> F:\AVCHD_BOURNE\BDMV\CLIPINF\00006.clpi
M2TS transfer: F:\_TEMP\20090415-194753-175\BDMV\STREAM\00000.m2ts -> F:\AVCHD_BOURNE\BDMV\STREAM\00006.m2ts
MPLS transfer: F:\_TEMP\20090415-194753-175\BDMV\PLAYLIST\00000.mpls -> F:\AVCHD_BOURNE\BDMV\PLAYLIST\00006.mpls
Converting PLAYLIST to AVCHD (D:\Bourne III\Tangier\BDMV\PLAYLIST\00000.mpls).
Done!
CLPI transfer: F:\_TEMP\20090415-194758-4919\BDMV\CLIPINF\00000.clpi -> F:\AVCHD_BOURNE\BDMV\CLIPINF\00007.clpi
M2TS transfer: F:\_TEMP\20090415-194758-4919\BDMV\STREAM\00000.m2ts -> F:\AVCHD_BOURNE\BDMV\STREAM\00007.m2ts
MPLS transfer: F:\_TEMP\20090415-194758-4919\BDMV\PLAYLIST\00000.mpls -> F:\AVCHD_BOURNE\BDMV\PLAYLIST\00007.mpls
Converting PLAYLIST to AVCHD (D:\Bourne III\Rooftop\BDMV\PLAYLIST\00000.mpls).
Done!
CLPI transfer: F:\_TEMP\20090415-194804-7785\BDMV\CLIPINF\00000.clpi -> F:\AVCHD_BOURNE\BDMV\CLIPINF\00008.clpi
M2TS transfer: F:\_TEMP\20090415-194804-7785\BDMV\STREAM\00000.m2ts -> F:\AVCHD_BOURNE\BDMV\STREAM\00008.m2ts
MPLS transfer: F:\_TEMP\20090415-194804-7785\BDMV\PLAYLIST\00000.mpls -> F:\AVCHD_BOURNE\BDMV\PLAYLIST\00008.mpls
Converting PLAYLIST to AVCHD (D:\Bourne III\Rumpeln\BDMV\PLAYLIST\00000.mpls).
Done!
CLPI transfer: F:\_TEMP\20090415-194811-6296\BDMV\CLIPINF\00000.clpi -> F:\AVCHD_BOURNE\BDMV\CLIPINF\00009.clpi
M2TS transfer: F:\_TEMP\20090415-194811-6296\BDMV\STREAM\00000.m2ts -> F:\AVCHD_BOURNE\BDMV\STREAM\00009.m2ts
MPLS transfer: F:\_TEMP\20090415-194811-6296\BDMV\PLAYLIST\00000.mpls -> F:\AVCHD_BOURNE\BDMV\PLAYLIST\00009.mpls
Converting PLAYLIST to AVCHD (D:\Bourne III\Test Drive\BDMV\PLAYLIST\00000.mpls).
Done!
CLPI transfer: F:\_TEMP\20090415-194818-5159\BDMV\CLIPINF\00000.clpi -> F:\AVCHD_BOURNE\BDMV\CLIPINF\00010.clpi
M2TS transfer: F:\_TEMP\20090415-194818-5159\BDMV\STREAM\00000.m2ts -> F:\AVCHD_BOURNE\BDMV\STREAM\00010.m2ts
MPLS transfer: F:\_TEMP\20090415-194818-5159\BDMV\PLAYLIST\00000.mpls -> F:\AVCHD_BOURNE\BDMV\PLAYLIST\00010.mpls
Preparing authoring information...
Creating NTSC top menu.
Authoring menu (NTSC).
Creating menu backgrounds for 11 titles (XMB)...
Trying to use Directshow first...
Creating video backgrounds for XMB menu completed.
Authoring custom menu completed.
Setting menu for 11 titles...
Setting menu properties...
Processing clip (CPI/CLPI) files...
Completed.
Done!
F:\AVCHD_BOURNE folder created!
Burn its CONTENTS to BD-R/RE UDF 2.50/2.60 disc!
Launching ImgBurn...
You may now remove temp folder (F:\_TEMP\).
Your compilation contains 2hrs 56min 52sec of video material.
End of log.
Old 15th April 2009, 21:19   #2157  |  Link
navycrow
i've tested the MPLS import since the bugfix and now i confirm its ok with my first movie (king Arthur).
But there is two other problem.
1) With King Arthur movie :
I don't know why. With this movie the menu is not correctly generated (no XMB menu and no thumbnail although the options are checked and the log report there is 0 titles in the menu)
When i play it, i have the basic menu with no thumbnail, if i click ok, the movie start and play without problem
Here is the log :
[14:25:00] Log started for multiAVCHD v2.5 (build 525)
[14:25:00] Processing 1 input file/folder.
[14:25:00] Converting PLAYLIST to AVCHD (E:\Le Roi Arthur\BDMV\PLAYLIST\00000.mpls).
[14:25:00] Generating meta file for tsMuxer...
[14:25:00] M2TS stream split set at 3999MiB...
[14:25:01] Detected resolution: 1920x1080
[14:25:01] Detected video: V_MPEG4/ISO/AVC (TID#4113)
[14:25:01] Detected audio: A_LPCM (TID#4352 / language: eng)
[14:25:01] Detected audio: A_AC3 (TID#4353 / language: eng)
[14:25:01] Detected audio: A_AC3 (TID#4354 / language: fra)
[14:25:01] Detected audio: A_DTS (TID#4355 / language: ita)
[14:25:01] Detected audio: A_AC3 (TID#4356 / language: ita)
[14:25:01] Detected audio: A_DTS (TID#4357 / language: deu)
[14:25:01] Detected audio: A_AC3 (TID#4358 / language: deu)
[14:25:01] Detected subtitles: S_HDMV/PGS (TID#4608 / language: eng)
[14:25:01] Detected subtitles: S_HDMV/PGS (TID#4609 / language: eng)
[14:25:01] Detected subtitles: S_HDMV/PGS (TID#4610 / language: fra)
[14:25:01] Detected subtitles: S_HDMV/PGS (TID#4611 / language: fra)
[14:25:01] Detected subtitles: S_HDMV/PGS (TID#4612 / language: ita)
[14:25:01] Detected subtitles: S_HDMV/PGS (TID#4613 / language: ita)
[14:25:01] Detected subtitles: S_HDMV/PGS (TID#4614 / language: deu)
[14:25:01] Detected subtitles: S_HDMV/PGS (TID#4615 / language: deu)
[14:25:01] Detected media file: 00000.m2ts
[14:25:01] Detected chapter mark: 00:00:00.000;00:05:00.000;00:10:00.000;00:15:00.000;00:20:00.000
[14:25:01] Detected chapter mark: 00:25:00.000;00:30:00.000;00:35:00.000;00:40:00.000;00:45:00.000
[14:25:01] Detected chapter mark: 00:50:00.000;00:55:00.000;01:00:00.000;01:05:00.000;01:10:00.000
[14:25:01] Detected chapter mark: 01:15:00.000;01:20:00.000;01:25:00.000;01:30:00.000;01:35:00.000
[14:25:01] Detected chapter mark: 01:40:00.000;01:45:00.000;01:50:00.000;01:55:00.000;02:00:00.000
[14:25:01] Detected chapter mark: 02:05:00.000;02:10:00.000;02:15:00.000;02:20:00.000
[14:25:01] Creating Blu-ray folders (tsMuxeR)...
[14:53:09] Done!
[14:53:13] CLPI transfer: C:\TEMP\20090415-142501-5717\BDMV\CLIPINF\00000.clpi -> F:\AVCHD\BDMV\CLIPINF\00000.clpi
[14:53:14] M2TS transfer: C:\TEMP\20090415-142501-5717\BDMV\STREAM\00000.m2ts -> F:\AVCHD\BDMV\STREAM\00000.m2ts
[15:00:47] CLPI transfer: C:\TEMP\20090415-142501-5717\BDMV\CLIPINF\00001.clpi -> F:\AVCHD\BDMV\CLIPINF\00001.clpi
[15:00:48] M2TS transfer: C:\TEMP\20090415-142501-5717\BDMV\STREAM\00001.m2ts -> F:\AVCHD\BDMV\STREAM\00001.m2ts
[15:04:09] CLPI transfer: C:\TEMP\20090415-142501-5717\BDMV\CLIPINF\00002.clpi -> F:\AVCHD\BDMV\CLIPINF\00002.clpi
[15:04:09] M2TS transfer: C:\TEMP\20090415-142501-5717\BDMV\STREAM\00002.m2ts -> F:\AVCHD\BDMV\STREAM\00002.m2ts
[15:07:51] CLPI transfer: C:\TEMP\20090415-142501-5717\BDMV\CLIPINF\00003.clpi -> F:\AVCHD\BDMV\CLIPINF\00003.clpi
[15:07:51] M2TS transfer: C:\TEMP\20090415-142501-5717\BDMV\STREAM\00003.m2ts -> F:\AVCHD\BDMV\STREAM\00003.m2ts
[15:10:43] CLPI transfer: C:\TEMP\20090415-142501-5717\BDMV\CLIPINF\00004.clpi -> F:\AVCHD\BDMV\CLIPINF\00004.clpi
[15:10:43] M2TS transfer: C:\TEMP\20090415-142501-5717\BDMV\STREAM\00004.m2ts -> F:\AVCHD\BDMV\STREAM\00004.m2ts
[15:13:51] CLPI transfer: C:\TEMP\20090415-142501-5717\BDMV\CLIPINF\00005.clpi -> F:\AVCHD\BDMV\CLIPINF\00005.clpi
[15:13:51] M2TS transfer: C:\TEMP\20090415-142501-5717\BDMV\STREAM\00005.m2ts -> F:\AVCHD\BDMV\STREAM\00005.m2ts
[15:17:05] CLPI transfer: C:\TEMP\20090415-142501-5717\BDMV\CLIPINF\00006.clpi -> F:\AVCHD\BDMV\CLIPINF\00006.clpi
[15:17:05] M2TS transfer: C:\TEMP\20090415-142501-5717\BDMV\STREAM\00006.m2ts -> F:\AVCHD\BDMV\STREAM\00006.m2ts
[15:20:00] CLPI transfer: C:\TEMP\20090415-142501-5717\BDMV\CLIPINF\00007.clpi -> F:\AVCHD\BDMV\CLIPINF\00007.clpi
[15:20:00] M2TS transfer: C:\TEMP\20090415-142501-5717\BDMV\STREAM\00007.m2ts -> F:\AVCHD\BDMV\STREAM\00007.m2ts
[15:23:05] CLPI transfer: C:\TEMP\20090415-142501-5717\BDMV\CLIPINF\00008.clpi -> F:\AVCHD\BDMV\CLIPINF\00008.clpi
[15:23:06] M2TS transfer: C:\TEMP\20090415-142501-5717\BDMV\STREAM\00008.m2ts -> F:\AVCHD\BDMV\STREAM\00008.m2ts
[15:26:03] CLPI transfer: C:\TEMP\20090415-142501-5717\BDMV\CLIPINF\00009.clpi -> F:\AVCHD\BDMV\CLIPINF\00009.clpi
[15:26:03] M2TS transfer: C:\TEMP\20090415-142501-5717\BDMV\STREAM\00009.m2ts -> F:\AVCHD\BDMV\STREAM\00009.m2ts
[15:26:43] MPLS transfer: C:\TEMP\20090415-142501-5717\BDMV\PLAYLIST\00000.mpls -> F:\AVCHD\BDMV\PLAYLIST\00000.mpls
[15:26:44] Preparing authoring information...
[15:26:44] Creating NTSC top menu.
[15:26:44] Authoring menu (NTSC).
[15:26:50] Creating menu backgrounds for 0 titles (XMB)...
[15:26:50] Creating video backgrounds for XMB menu completed.
[15:26:57] Authoring custom menu completed.
[15:26:57] Setting menu for 1 titles...
[15:26:58] Setting menu properties...
[15:26:58] Processing clip (CPI/CLPI) files...
[15:26:58] Completed.
[15:26:58] Creating FAT32 compatible 8.3 filenames...
[15:26:59] Done!
[15:26:59] F:\AVCHD folder created!
[15:26:59] Copy F:\AVCHD to root of USB drive/disk or MemoryStick card.
[15:26:59] Copy F:\AVCHD to X:\PRIVATE\ of SD/MMC card.
2) The other problem affect my second movie : Changeling
The m2ts contains 3 video tracks (the movie+2 commentaries tracks). When importing the MPLS file, multiAVCHD seems to keep the 1st video track (commentary) when the good one is the third (movie).
When playing, i have only the commentary video track on screen. No movie.
Here is the specs of the m2ts :
Addentum :
i have noticed a little bug in the Menu tag -> Visual Settings -> Background. The value seems not be saved correctly. When a value is selected and the program is closed. The next time the program is launched, another value appears.
Old 16th April 2009, 11:08   #2158  |  Link
deank
deank's Avatar
@navycrow:
I found a major bug which affected MPLS import and other things. It is fixed in build 526.
About the background - it is not a bug - I set it to randomly change on start.
Video track is also fixed now...
@schlaufer: There is a slider in Menu tab - Frames to encode. Try with higher values to see what works for you. And update your multiAVCHD.
Old 16th April 2009, 13:10   #2159  |  Link
navycrow
Since the bugfixes in build 526.
My first movie is 100% perfect. Great work deank !
I'm actually trying to import the second movie (with the 3 video tracks). Feedback in a moment....
i have a question :
When i use an AVCHD movie alone created by TSMuxer or MKV2VOB. It's played by the PS3 according my language and subtitles preferences. In my case, FRENCH language and FRENCH subtitles (if necessary).
But when i use the multiAVCHD compilation. The PS3 play the first AUDIO track and the first SUBTITLES (if activated).
Is there a way to make multiAVCHD to respect the LANG et SUB prefs?
Old 16th April 2009, 13:37   #2160  |  Link
deank
deank's Avatar
What happens if you uncheck the option [x] Force subtitle track #1 in Audio/Subtitles tab?
Please post the multiAVCHD log of your second movie (with 3 video tracks) when you're done with it. Thanks.
