Thread Tools Display Modes
Old 26th December 2008, 09:30   #1  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
multiAVCHD - author AVCHD/Blu-ray for Blu-ray players, camcoders & Viera TV or HD-DVD
Another contribution to doom9 users:
If you like the application and find it useful, support the author for further improvements.
* Guide
* Home
* Official support forum
* Donate - multiAVCHD page
* Donate - direct Paypal
Download links (nullsoft installer):
Mirror#1 (rapidshare.com): Latest version
Mirror#2 (videohelp.com) : Latest version
Mirror#3 (rapidshare.com): Latest version
AviSynth 2.58 (required for custom menu)
Mirror #1: Download from sourceforge.
::: Setup / archive contents :::
::: Full version history :::
Supported input FILE formats:
For video titles:
* MKV - matroska containter
* TS, M2TS, MTS - transport stream files
* AVI (DivX/XviD/AVC) - re-encoding/uncropping required for DivX/XviD
* FLV (Flash video) - re-encoding required
* WMV (HD) - re-encoding required
* 264 - H.264 (AVC) elementary stream (video only)
* M2V - MPEG-2 elementary stream (video only)
* VC1 - VC-1 elementary stream (video only)
* MPG (MPEG) - MPEG-2 video files
* IFO - DVD playlists
* VOB - DVD video segment files
* EVO - HD-DVD video segment files
* MOD - Camcoder MPEG-2 recordings
* MOV - AVC/HDV3 encoded + AC3/PCM/AAC audio (rename MOV to MP4 if processing fails!)
* MP4 - Apple / Quicktime (may work only for AVC encoded video - no Sorenson and other weird codecs)
* MPLS/MPL - Blu-ray playlist files / AVCHD playlists / multiAVCHD playlists
* TRP - DVR recordings
+ SRT, SSA/ASS, PGC, VOBSUB, microDVD SUB subtitle tracks
+ AC3 (TrueHD, EAC3), DTS, DTS-HD (MA/HRA), PCM, LPCM, WAV, MP2, MP3, OGG, VORBIS, FLAC and AAC audio tracks
For audio titles: (available only when "Add audio titles" button is used)
* AC3, DTS, DTSHD, WAV, PCM, LPCM, MP2, MP3, FLAC and Meridian MLP audio files
* CUE, M3U, WPL playlists (cue-sheet/playlist import works only with drag-drop of a CUE/M3U/WPL file)
Supported input FOLDER formats:
* BDMV - Blu-ray disc folder
* BDMV / AVCHD - AVCHD folder structure (from AVCHD disc, AVCHD camcoder or multiAVCHD)
* VIDEO_TS - DVD disc folder
* HVDVD_TS - HD-DVD disc folder
* MPEG2 folder - folder containing ONLY MPG files (for join mode)
* M2TS/MTS folder - folder containing ONLY m2ts or mts files (for join mode)
* any folder except these above - all compatible files will be loaded as titles
Supported output / authoring formats:
* Blu-ray (with menu)
* AVCHD for optical media (DVD and Blu-ray discs) (with menu)
* AVCHD for solid media (USB, SD, SDHC, Memory Stick) (with menu, except for Panasonic modes)
* SD_VIDEO for SDHC MPEG-2 compatible players (Panasonic BDP/Viera) (no menu)
* HD-DVD for DVD-R/RW for HD-DVD players compatible with 3xDVD (no menu)
Notes:
* Make sure you're using NTFS drives for TEMP and DESTINATION when processing larger files
* Make sure you have AviSynth, ffdshow and Haali Media Splitter installed
* Make sure you have enough free space in your TEMP and DESTINATION drives
* Always read carefully all messages in the LOG TAB - they'll help you to find the problem when you encounter one
* Really - just follow these notes!
Old 26th December 2008, 13:53   #2  |  Link
zoner
I've got a question, i finally burned a compilation of 3 eps to test your GUI and as i burned them as UDF 2.5 i noticed the PS3 recognized it as DATA DISC.
So, is it because of the 8.3 filenames? or because of the missing folders that the GUI isnt implenting(META,BOJO...)
also, the compilation plays great on TotalMedia Theatre without any problems.
zoner is offline   Reply With Quote
Old 26th December 2008, 14:23   #3  |  Link
zoner
i just burned it twice now.
first, i only added the missing folders, that resulted with a DATA DISC by my PS3
second, i added the missing folders and also renamed all the files to their normal state(no 8.3) and it worked
so you'll probably have to make the 8.3 rename an option not a must, and since i didn't burn it with only the rename, i don't know if those missing empty folders are vital or not.
Old 26th December 2008, 17:49   #4  |  Link
~bT~
н∂-ƒαиαтι¢
do i need to download the torrent again or just replace the .exe?
Old 26th December 2008, 17:58   #5  |  Link
~bT~
н∂-ƒαиαтι¢
there is no such file created.
Old 26th December 2008, 18:50   #6  |  Link
zoner
great job this proggie is great
Old 26th December 2008, 18:54   #7  |  Link
~bT~
н∂-ƒαиαтι¢
^ that makes sense. i had the first beta rar. downloading the new one. cheers again.
Old 26th December 2008, 20:50   #8  |  Link
~bT~
н∂-ƒαиαтι¢
^ this is moving so fast i cant keep up cheers!
Old 26th December 2008, 22:15   #9  |  Link
zoner
i've got a question, can you make it possible to load the subs from your GUI?
i mean if i've got an mkv and a srt on another file you can direct it to mux with those setting and the mkv...
Old 26th December 2008, 23:04   #10  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Next version will include the needed settings for tsmuxer and some other options...
I guess I'll test it tomorrow and will publish it.
Font size and offset are not correct.
Look.
1080 / 720 = 1.5
so 60 * 1.5 = 90 - correct value for 1080p
52 * 1.5 = 78 - correct offset for 1080p
Personally for 720p I use 48 font size , offset 64 , Tahoma , border 2
for 1080p I use 72 , 96 , ...
4 GiB = 4096 MiB (not 4000) You can safely use 4096 because tsmuxer never cuts above limit.
Old 26th December 2008, 23:18   #11  |  Link
nwg
Thanks for this. I have been looking for something that does more than one file for ages.
nwg is offline   Reply With Quote
Old 27th December 2008, 03:52   #12  |  Link
OrigCasshern
OrigCasshern's Avatar
deank, this is just great. Outstanding, really.
OrigCasshern is offline   Reply With Quote
Old 27th December 2008, 05:35   #13  |  Link
nwg
I am not sure this is working for me.
I want to put seven 720p mkv movie trailers on a disc ranging up to 100MB each. The temp directories look ok but the final avchd directory only has 3 files totalling 116MB.
Old 27th December 2008, 09:35   #14  |  Link
G_M_C
Look.
1080 / 720 = 1.5
I do hope those settings are put a a .INI somewhere, cause these settings are not right (for me). Those high offsets put the subtitles much too high imho. In fact for a 1080p BD i use Verdana, size 65, border 3 and offset of only 24. My subs stay firmly at the bottom of my screen, OUTSIDE of the 2.40:1 picture (in the border that is).
G_M_C is offline   Reply With Quote
Old 27th December 2008, 11:48   #15  |  Link
nwg
It's working great now. The problem was the source files. I forgot to convert the audio to something avchd likes.
Old 28th December 2008, 04:38   #16  |  Link
~bT~
н∂-ƒαиαтι¢
^ looking forward to it dean. any chance u can add a progress % for current file and overall progress % please?
cheers!
ps. can u also add tahoma font option?
pps. oh, and the donate link doesn't work..
Old 28th December 2008, 14:21   #17  |  Link
Deathman
tried this a few times but no matter what i do i get a unsupported disc format when i try to play in powerdvd 8. if i make an avchd from just one of the files it plays fine... any ideas?
Deathman is offline   Reply With Quote
Old 28th December 2008, 15:54   #18  |  Link
~bT~
н∂-ƒαиαтι¢
^ works here too on ps3 and showtime.
late edit: request:
choose destination of output.
Old 28th December 2008, 17:15   #19  |  Link
Deepstar
yes, autoupdate work!
Deepstar is offline   Reply With Quote
Old 29th December 2008, 12:54   #20  |  Link
SeeMoreDigital
Life looks better in HDTV
SeeMoreDigital's Avatar
I'd like to see if the menu structure works with my Panasonic TV. Is somebody here able to provide a smallish sample file?
Still confused about anamorphic images? Then look here! | Main Encoding Interests: Hardware device playback | My Gear |
avchd, blu-ray hd-dvd, mkv, multiavchd
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
