Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD Rebuilder
Old 2nd May 2012, 06:34   #15061  |  Link
NightHawkGuy
Originally Posted by techno1 View Post
I noticed in Windows Task Manager I'm running the x264.exe *32 version and not the 64bit version. I already have a x264-64.exe in the Tool folder. How can I make BD-RB use the 64bit version? It used to use the 64bit version in the past.
Thats completely normal - since only the 32bit version can use avisynth filters since its 32bit.
The 64bit version of x264 is only used if external filters are not used, in LAVF mode.
NightHawkGuy is offline   Reply With Quote
Old 2nd May 2012, 18:53   #15062  |  Link
techno1
Thank you Ch3vr0n and NightHawkGuy for your responses!
I selected the LAVF option and now see x264-64.exe running. Is there an advantage to using internal vs. external filters?
techno1 is offline   Reply With Quote
Old 2nd May 2012, 21:58   #15063  |  Link
NightHawkGuy
some formats (like interlaced vc-1) may have problems with LAVF and some features such as resizing require avisynth filters and therefore need to use the standard 32bit (nonLAVF) method.
under windows 7 64bit, i find that non-LAVF is often faster in any case with a 6core AMD CPU.
i'd suggest trying an encode both ways and see which is faster on your particular system.
Old 4th May 2012, 03:48   #15064  |  Link
techno1
Okay, I turned LAVF on and timed a rebuild of Limitless. x264-64.exe was running at 99%. It took 4.18 hours including time to create an ISO.
Then I unchecked the LAVF option and let it run again. However, x264-64.exe STILL ran at 99%. Not the *32 version as before. This time it took 5.13 hours including time to create an ISO. I'm also running and AMD 6 core CPU.
Obviously I want to enable the LAVF option in the future. It seems there is some latch function that only wants to run the 64 bit version now, with or without the LAVF option.
Old 4th May 2012, 10:05   #15065  |  Link
hifreak
I tried 2 movies yesterday Alien 3 and Alien 4. Before that I successfully reencoded Alien and Aliens 2, but these 2 I got video aborted, can it be the new X264?
[17:57:38] BD Rebuilder v0.40.09 (beta)
[17:57:38] BEGIN - BATCH SEQUENCE
[17:57:38] PROCESSING BATCH FILE [23]
[05-03-12] BD Rebuilder v0.40.09 (beta)
[17:57:39] Source: ALIEN_3
- Input BD size: 25,51 GB
- Approximate total content: [02:24:52.641]
- Target BD size: 22,95 GB
- Windows Version: 6.1 [7601]
- MOVIE-ONLY mode enabled
- Quality: High Quality (Default), Two Pass
- Decoding/Frame serving: X264/LAVF
[17:57:40] PHASE ONE, Encoding
- [17:57:40] Processing: VID_00750 (1 of 27)
- [17:57:40] Extracting A/V streams [VID_00750]
- [18:05:39] Reencoding video [VID_00750]
- Rate/Length: 23,976fps, 5.029 frames
- Bitrate: 16.275 Kbs
- [18:05:39] Reencoding: VID_00750, Pass 1 of 2
- [18:07:14] Reencoding: VID_00750, Pass 2 of 2
- [18:10:05] Video Encode complete
- [18:10:05] Processing audio tracks
- [18:10:05] Processing: VID_00752 (2 of 27)
- [18:10:05] Extracting A/V streams [VID_00752]
- [18:11:02] Reencoding video [VID_00752]
- Rate/Length: 23,976fps, 16.081 frames
- Bitrate: 16.469 Kbs
- [18:11:02] Reencoding: VID_00752, Pass 1 of 2
- [18:15:24] Reencoding: VID_00752, Pass 2 of 2
- [18:26:44] Video Encode complete
- [18:26:44] Processing: VID_00753 (3 of 27)
- [18:26:44] Extracting A/V streams [VID_00753]
- [18:26:54] Reencoding video [VID_00753]
- Rate/Length: 23,976fps, 2.334 frames
- Bitrate: 16.554 Kbs
- [18:26:54] Reencoding: VID_00753, Pass 1 of 2
- [18:27:32] Reencoding: VID_00753, Pass 2 of 2
- [18:29:16] Video Encode complete
- [18:29:16] Processing: VID_00754 (4 of 27)
- [18:29:16] Extracting A/V streams [VID_00754]
- [18:29:27] Reencoding video [VID_00754]
- Rate/Length: 23,976fps, 2.355 frames
- Bitrate: 16.291 Kbs
- [18:29:27] Reencoding: VID_00754, Pass 1 of 2
- [18:30:05] Reencoding: VID_00754, Pass 2 of 2
- [18:31:46] Video Encode complete
- [18:31:46] Processing: VID_00755 (5 of 27)
- [18:31:46] Extracting A/V streams [VID_00755]
- [18:32:20] Reencoding video [VID_00755]
- Rate/Length: 23,976fps, 9.314 frames
- Bitrate: 16.293 Kbs
- [18:32:20] Reencoding: VID_00755, Pass 1 of 2
- [18:34:55] Reencoding: VID_00755, Pass 2 of 2
- [18:41:33] Video Encode complete
- [18:41:33] Processing: VID_00756 (6 of 27)
- [18:41:33] Extracting A/V streams [VID_00756]
- [18:42:45] Reencoding video [VID_00756]
- Rate/Length: 23,976fps, 19.151 frames
- Bitrate: 16.341 Kbs
- [18:42:45] Reencoding: VID_00756, Pass 1 of 2
- [18:48:13] Reencoding: VID_00756, Pass 2 of 2
- [19:01:51] Video Encode complete
- [19:01:51] Processing: VID_00757 (7 of 27)
- [19:01:51] Extracting A/V streams [VID_00757]
- [19:02:01] Reencoding video [VID_00757]
- Rate/Length: 23,976fps, 2.053 frames
- Bitrate: 16.568 Kbs
- [19:02:01] Reencoding: VID_00757, Pass 1 of 2
- [19:02:36] Reencoding: VID_00757, Pass 2 of 2
- [19:04:03] Video Encode complete
- [19:04:03] Processing: VID_00758 (8 of 27)
- [19:04:03] Extracting A/V streams [VID_00758]
- [19:04:17] Reencoding video [VID_00758]
- Rate/Length: 23,976fps, 3.281 frames
- Bitrate: 16.140 Kbs
- [19:04:17] Reencoding: VID_00758, Pass 1 of 2
- [19:05:14] Reencoding: VID_00758, Pass 2 of 2
- [19:07:35] Video Encode complete
- [19:07:35] Processing: VID_00759 (9 of 27)
- [19:07:35] Extracting A/V streams [VID_00759]
- [19:07:53] Reencoding video [VID_00759]
- Rate/Length: 23,976fps, 3.243 frames
- Bitrate: 16.237 Kbs
- [19:07:53] Reencoding: VID_00759, Pass 1 of 2
- [19:08:51] Reencoding: VID_00759, Pass 2 of 2
- [19:11:07] Video Encode complete
- [19:11:07] Processing: VID_00760 (10 of 27)
- [19:11:07] Extracting A/V streams [VID_00760]
- [19:11:47] Reencoding video [VID_00760]
- Rate/Length: 23,976fps, 12.286 frames
- Bitrate: 16.383 Kbs
- [19:11:47] Reencoding: VID_00760, Pass 1 of 2
- [19:15:11] Reencoding: VID_00760, Pass 2 of 2
- [19:24:00] Video Encode complete
- [19:24:00] Processing: VID_00761 (11 of 27)
- [19:24:00] Extracting A/V streams [VID_00761]
- [19:24:24] Reencoding video [VID_00761]
- Rate/Length: 23,976fps, 6.950 frames
- Bitrate: 16.468 Kbs
- [19:24:24] Reencoding: VID_00761, Pass 1 of 2
- [19:26:22] Reencoding: VID_00761, Pass 2 of 2
- [19:31:32] Video Encode complete
- [19:31:32] Processing: VID_00762 (12 of 27)
- [19:31:32] Extracting A/V streams [VID_00762]
- [19:31:47] Reencoding video [VID_00762]
- Rate/Length: 23,976fps, 3.597 frames
- Bitrate: 16.348 Kbs
- [19:31:47] Reencoding: VID_00762, Pass 1 of 2
- Encode failed. Aborting.
- BD-Rebuilder v0.40.09 (beta)
- AVISYNTH Version: 2.5.8.0, Ok
- HAALI Splitter: 1.9.42.1, Ok
- FFDSHOW: 3882, Ok
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[19:56:45] - Failed video encode, aborted
[19:56:45] PROCESSING BATCH FILE [24]
[19:56:53] Source: ALIEN_RESURRECTION
- Input BD size: 29,41 GB
- Approximate total content: [01:56:08.669]
[19:56:54] PHASE ONE, Encoding
- [19:56:54] Processing: VID_00750 (1 of 13)
- [19:56:54] Extracting A/V streams [VID_00750]
[19:59:00]PHASE ONE aborted by user request
[19:59:00] BATCH ABORTED...
[19:59:00] END - BATCH SEQUENCE
[19:59:32] Source: ALIEN_3
- Resuming from previously started job.
[19:59:33] PHASE ONE, Encoding
- [19:59:33] Processing: VID_00762 (12 of 27)
- [19:59:33] Reencoding video [VID_00762]
- Bitrate: 21.015 Kbs
- [19:59:33] Reencoding: VID_00762, Pass 1 of 2
- FFDSHOW: 3882, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[19:59:34] - Failed video encode, aborted
[20:01:57] Source: ALIEN_RESURRECTION
[20:02:01] PHASE ONE, Encoding
- [20:02:01] Processing: VID_00750 (1 of 13)
- [20:02:01] Extracting A/V streams [VID_00750]
- [20:09:46] Reencoding video [VID_00750]
- Rate/Length: 23,976fps, 6.779 frames
- Bitrate: 21.469 Kbs
- [20:09:46] Reencoding: VID_00750, Pass 1 of 2
- [20:11:42] Reencoding: VID_00750, Pass 2 of 2
- [20:17:06] Video Encode complete
- [20:17:07] Processing audio tracks
- [20:17:07] Processing: VID_00701 (2 of 13)
- [20:17:07] Extracting A/V streams [VID_00701]
- [20:17:20] Reencoding video [VID_00701]
- Rate/Length: 23,976fps, 2.085 frames
- Bitrate: 21.283 Kbs
- [20:17:20] Reencoding: VID_00701, Pass 1 of 2
- [20:18:01] Reencoding: VID_00701, Pass 2 of 2
- [20:19:42] Video Encode complete
- [20:19:42] Processing: VID_00751 (3 of 13)
- [20:19:42] Extracting A/V streams [VID_00751]
- [20:21:51] Reencoding video [VID_00751]
- Rate/Length: 23,976fps, 25.970 frames
- Bitrate: 21.229 Kbs
- [20:21:51] Reencoding: VID_00751, Pass 1 of 2
- [20:29:40] Reencoding: VID_00751, Pass 2 of 2
- FFDSHOW: 3882, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[20:59:03] - Failed video encode, aborted
hifreak is offline   Reply With Quote
Old 4th May 2012, 15:48   #15066  |  Link
Capsbackup
I would try without LAVF selected to see if your results change. Also, try just one at a time rather than "Batch".
Capsbackup is offline   Reply With Quote
Old 4th May 2012, 19:37   #15067  |  Link
hifreak
Ok Will try what you suggested without batch lavf
Old 6th May 2012, 13:27   #15068  |  Link
jdobbs
@hifreak
I'd take a look at any/all system stability factors. The fact that several AVC sources have successfully encoded before having issues leads one to believe it isn't configuration related. Check out anything that might lead to overheating.
Website: www.jdobbs.net
Old 6th May 2012, 14:43   #15069  |  Link
hautem
BD-Rebuilder works great 99.99% of the time for me on full backup BD's, but every once in a while I hit a brick wall and the "Chinatown" Blu-ray is one of them. Burned the backup only to find out later when watching that at around 1:29:00 into the movie, the audio synch goes out by about 500ms (audio is before the video - corresponding video is around 500ms late) and it stays that way from around 1:29:00 to the end of the film. Audio sync is fine from the beginning up to that point. I'm going on my 7th re-encode trying to figure out what's going on and every single re-encode has that late timing at the same mark.
All BD-Rebuilder system programs are compliant/set correctly using Inspect.exe
BD-Rebuilder encoder settings are Good (Very Fast) - One Pass (ABR) Encoding
Movie is one .m2ts file (00800.m2ts) MPEG-4 (AVC). The original .m2ts file plays fine on my PC via MPC as well as the original Blu-ray disc on a stand-alone Sony BDP-S480.
Out-of-sync re-encodes are confirmed on my PC using either MPC or VLC.
After the 1st bad encode, ripped the original disc a 2nd time using AnyDVDHD 7.0.4.0
Both the original 5.1 main audio and (mono) tracks are TRUE-HD. Initial encode was set to "do not convert/reencode" checked (default) to extract cores.
Commentary track is 2-channel AC3 and ironically the only one that stays in sync from beginning to end
With "do not convert/reencode" checked, tried "Keeping the HD audio..." checked. That's worked before on "multi"-.m2ts movies where I would hear audio interruptions at file transitions on my Sony BDP-S480 when HD audio was down-converted - didn't work here.
Tried just keeping the (mono) TRUE-HD audio track - still the same
Tried substituting the x264.exe converter from the previous version of BD-Rebuilder (BD-RBV04008 - x264 - v2164), but still the same thing. Tried the newest x264 version (2197) - still the same
After one of the encodes, tried extracting the original main TRUE-HD 5.1 track via tsMuxeR 1.10.6, down-converted to AC3, demuxed the re-encode and replaced/muxed to .m2ts with the original down-converted extraction - still the same.
Things I haven't tried yet are movie-only and "do not convert/reencode" unchecked, which I figured was pointless since the core is at 640kbps anyway and that the tsMuxeR 1.10.6 experiment didn't work. If anyone has a clue
Thanks...
hautem is offline   Reply With Quote
Old 6th May 2012, 16:09   #15070  |  Link
hautem
Still looking into this "Chinatown" thing and not sure how much of a bearing it has, but when looking at the various files using MediaInfo in PBCore 1.2 view:
00800.m2ts (original file) - <formatDuration>02:10:32.520</formatDuration>
00800.m2ts (re-encoded file) - <formatDuration>02:10:31.782</formatDuration>
with the re-encoded .m2ts file being slightly longer by 262ms
In BDeditv0.17b (not that familiar with how to read BDedit info. - from the playlist tab for 00800.mpls):
00800.m2ts (original file) - 02:10:32.824
00800.m2ts (re-encoded file) - 02:10:31.782
The corresponding extracted AC3 core files in the WORKFILES folder of my latest re-encode in MediaInfo:
00800.track_4352.ac3 (main movie track) - <formatDuration>02:10:31.328</formatDuration>
00800.track_4357.ac3 (commentary track) - <formatDuration>02:10:31.808</formatDuration>
where the audio file lengths are different - by right around the amount I've been guesstimating - 480ms
Maybe I'll try ditching the audio commentary track.
Old 6th May 2012, 16:15   #15071  |  Link
hautem
Typo in that last entry...
In BDeditv0.17b:
00800.m2ts (original file) - should have been 02:10:31.824 instead of 02:10:32.824
Old 6th May 2012, 18:03   #15072  |  Link
bluerip
Hi Guys,
I tried the movie Immortals (Krieg der Götter) in German.
Got this error.
[05.06.12] BD Rebuilder v0.40.09 (beta)
[12:40:49] Source: KRIEG_DER_GOETTER
- Input BD size: 18,97 GB
- Approximate total content: [01:50:43.678]
- MOVIE-ONLY/ALTERNATE OUTPUT mode enabled
- Mode: MKV Container, 1920x1080, 640Kbs DD5.1
- Decoding/Frame serving: DirectShow
- Audio Settings: AC3=0 DTS=0 HD=0 Kbs=448
[12:40:50] PHASE ONE, Encoding
- [12:40:50] Processing: VID_00084 (1 of 2)
- [12:40:50] Extracting A/V streams [VID_00084]
- [13:04:05] Reencoding video [VID_00084]
- Rate/Length: 23,976fps, 159.264 frames
- Bitrate: 4.848 Kbs
- [13:04:05] Reencoding: VID_00084, Pass 1 of 2
- [14:44:39] Reencoding: VID_00084, Pass 2 of 2
- [18:32:02] Video Encode complete
- [18:32:03] Processing audio tracks
- Track 4352 (deu): Reencoding audio to AC3...
- [18:32:04] Processing audio tracks
- ERROR in attempt to reencode audio (AFTEN) [AUD_00084_4352.AVS]
[18:32:05] - Failed to reencode audio, aborted
Who can help?
bluerip is offline   Reply With Quote
Old 6th May 2012, 20:02   #15073  |  Link
jceden35
Having Trouble with Backing up my 3D Blurays
I've used BD-Rebuilder for quite some time and really never had an issue......Unitl recently I've never really gotten an error that I couldn't figure out. I've been backing up my collection of Blurays for a while now (whenever I get a chance) and have always been realitvely successful. However using the latest Beta Ver. 40.09 I'm unable to successfully back up my 3D versions of my collection. Here's basically what happens:
I put my original in and run AnyDvd/HD and it will play (do this to test). I then rip the entire disc to an ISO. I then mount the ISO and run it again (while AnyDvd/HD is in the background) and play it to again make sure it plays while mounted in the ISO format. I then turnoff AnyDvd/HD and run BD-Rebuilder. The software see's the movie and I check off the few options like 25GB file and turn into an ISO using Image Burn...........
Here's where the mystery comes. It does everything like normal, doesn't come up with any errors and then creates an ISO via Image Burn........However when I either burn to a Disc or Mount it as an Image when it has been compressed under 25GB the image will not play either in my PS3 (under a year old with newest firmware) or on my media PC using PowerDVD 11 (latest update). In the PC it tries to load forever and on the Media PC running PowerDVD 11 Ultra it says that "Cyberlink Power DVD could not read a file on this disc, playback will stop"
Any other Bluray I back up in my collection will playback fine. It is only the 3D blurays that are having the error/problems.
Any Ideas.........?
Rig Specs:
Bluray Burner: LG GBW-H20L
Processor FX-8120
Hard Drives 128GB Kingston SSD & Hitachi 1TB Sata II ATA
Memory: 16GB Dual Channel
jceden35 is offline   Reply With Quote
Old 6th May 2012, 20:11   #15074  |  Link
CV91913
I had exactly the same problem at exactly the same place. If you watch the movie carefully at that point in the movie, there is a very slight freeze in the video but the audio is not effected. So...from that point on the audio leads the video. I was able to finally get the movie to backup without the problem (after many tries with various audio settings.) I used BDRB directly on the original BluRay disc. I loaded AnyDVD and did movie only build directly from the BluRay. It took a bit longer but it did work. Not too sure why. HTH.
Last edited by CV91913; 6th May 2012 at 23:41. Reason: Responded to wrong person...included origninal quote
CV91913 is offline   Reply With Quote
Old 6th May 2012, 22:24   #15075  |  Link
jdobbs
Originally Posted by CV91913 View Post
jceden35...
That has to mean the rip didn't go straight when it was copied to hard drive. Not sure how that could happen -- I've never experienced it myself.
Old 6th May 2012, 23:35   #15076  |  Link
CV91913
Yep...it was a first for me too. I re-ripped it but the problem existed in the original even though the original would play with the slight freeze...but it did not screw up the sound. Go figa.
Old 7th May 2012, 05:49   #15077  |  Link
hautem
@CV91913 and @jdobbs - thanks much for the feedback, but it's been such a long time that I've had a bad original disc, I'd forgotten that it can cause this type of problem. The 3rd and 4th rips to my hard drive showed noticeable pixelization in the lower section of the frame at 01:29:01 when playing the original .m2ts file on MPC-HC (VLC is apparently more forgiving as is my stand-alone player). Odd that the pixelization wasn't visible on the 1st and 2nd rips. I'll have to see about getting a replacement disc.
Thanks...
Old 8th May 2012, 16:09   #15078  |  Link
The_Unknown
As the log indicates, I would suggest you reset "Remove Short Titles" and "Remove Annoying Adverts" in AnyDVD to off, and rerip. Those settings are considered "preprocessing" and is likely the source of your problem -- or at least a contributing factor. If you want to remove those types of things, I would suggest you do so within BD-RB.
Concerning this I have to say that the option "Remove Annoying Adverts" never caused problems with any BD Rebuilding (I've done about 80 rebuilts). It's rather "Remove Short Titles" which causes the trouble.
The_Unknown is offline   Reply With Quote
Old 8th May 2012, 20:38   #15079  |  Link
jdobbs
I've had issues reported with both, and that's why I can't support bug reports when either of them is set... Sorry.
Old 11th May 2012, 23:13   #15080  |  Link
[SLiM]D12
I know this is gonna sound weird, but hear me out. I know we can convert the DTS streams to AC3 and whatnot. Do we have options to convert to PCM? I've converted my audio to PCM and when i mux back into my m2ts file, the audio doesn't play. I know there's more to it, changing mpls files or whatever, just looking for some help.
[SLiM]
[SLiM]D12 is offline   Reply With Quote
