Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD Rebuilder
Old 26th October 2011, 10:40   #13361  |  Link
colinhunt
Did a quick Full Backup of Battle: Los Angeles (CEE) using 1-pass CRF and "Faster" preset. Playing the BD-RE on a Philips 9500 right now; PiP video and audio are fine. The player has some problems reading a BD-RE (my 9500 won't play most BD-R discs...) which is causing some pauses in the movie. I'll verify on another player later today the pauses are not in the encode.
colinhunt is offline   Reply With Quote
Old 26th October 2011, 11:14   #13362  |  Link
drmih
Originally Posted by colinhunt View Post
So far the glitching has been limited to discs that use VC-1 for both main and secondary video... right?
Just checking it does seem to be the case that they are VC1 / VC1. I was thrown by The Thing, which is also VC1 / VC1. However checking it was just over bd-25 and the main movie wasn't re-encoded. Therefore the only one which is okay is Harry Potter which was AVC / AVC.
I've just done Animal House (a Universal title) to bd-9. Again suffering from glitches / blocks but I wouldn't say any worse than a bd-25 disc.
Just for clarification, are you also seeing the glitches in the main video? On some discs I'm even seeing glitches in the menus - on my bd-9 version of Animal House I see lots of blocks on the Universal planet sequence at the start, then on the language selection page and then the 'blu-ray disc' menu leading up to the main selection.
drmih is offline   Reply With Quote
Old 26th October 2011, 12:12   #13363  |  Link
colinhunt
Yes, on VC1 / VC1 discs. Glitching that could be described as severe blocking, both on main and secondary video. Haven't seen it on any AVC/AVC discs, so far.
I haven't been paying attention to menu background video, but I will from now on. All my tests have been for BD25.
Old 26th October 2011, 16:24   #13364  |  Link
jdobbs
Originally Posted by color43 View Post
I used the new DTS Express switch to backup Star Trek The Original Series season 1 disc 1. The disc uses seamless branching and has a PIP for commentary. The PIP commentary with DTS-E audio plays fine on my Sony BDP-S370 player.
There are two minor issues though
1. The discs use two angles to show the updated special effects and the original footage. If I have the PIP commentary ON and change the angle, it causes my player to either freeze up or skip to another scene. This doesn't happen on the original in the exact same spot.
2. I burned a BD-R using ImgBurn and it reported some messages about the M2TS files I haven't seen before:
These are really minor though, I can finally backup my Star Trek Blu-rays with the PIP audio commentary intact, thanks JDOBBS.
I 10:18:25 Write Speed Successfully Set! - Effective: 17,980 KB/s (4x)
I 10:18:25 Advanced Settings - Force HT: No, Online HT: No, OverSpeed: No, SmartBurn: Yes
I 10:18:51 Filling Buffer... (40 MB)
I 10:18:52 Writing LeadIn...
I 10:18:53 Writing Session 1 of 1... (1 Track, LBA: 0 - 12080927)
I 10:18:53 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 12080927)
I 10:19:21 M2TS File: \BDMV\STREAM\00003.m2ts
I 10:19:21 Reset CPI flag in 149 packets (00: 479597, 01: 149, 10: 0, 11: 0, Total: 479746, Bad Sync: 0)
I 10:20:02 M2TS File: \BDMV\STREAM\00008.m2ts
I 10:20:02 Reset CPI flag in 1077 packets (00: 1236797, 01: 1077, 10: 0, 11: 0, Total: 1237874, Bad Sync: 0)
I 10:20:12 M2TS File: \BDMV\STREAM\00009.m2ts
I 10:20:12 Reset CPI flag in 323 packets (00: 978331, 01: 323, 10: 0, 11: 0, Total: 978654, Bad Sync: 0)
I 10:21:50 M2TS File: \BDMV\STREAM\00014.m2ts
I 10:21:50 Reset CPI flag in 7882 packets (00: 5397008, 01: 7882, 10: 0, 11: 0, Total: 5404890, Bad Sync: 0)
I 10:23:09 M2TS File: \BDMV\STREAM\00021.m2ts
I 10:23:09 Reset CPI flag in 169 packets (00: 635205, 01: 169, 10: 0, 11: 0, Total: 635374, Bad Sync: 0)
I 10:24:14 M2TS File: \BDMV\STREAM\00023.m2ts
I 10:24:14 Reset CPI flag in 4369 packets (00: 4456654, 01: 4369, 10: 0, 11: 0, Total: 4461023, Bad Sync: 0)
I 10:41:50 Synchronising Cache...
I 10:41:53 Closing Track...
I 10:41:54 Finalising Disc...
The CPI definitely gets changed by the DTS-Express code. When the DTS Express is added to the M2TS the SPN values change and the table has to be updated. I'll look and see if there is something goofy happening there. The fact that there is PiP and Angles might make a difference.
Website: www.jdobbs.net
Old 26th October 2011, 17:06   #13365  |  Link
drmih
I can confirm that I have seen the same messages from IMGBurn when burning bd-25 of discs to test the PiP functionality. I assumed that it was a disc issue rather than BD-RB, as I ran IMGburn independently.
Old 26th October 2011, 21:17   #13366  |  Link
SquallMX
Special SeeD
Me too (Robin Hood):
I 10:39:29 Reset CPI flag in 2772 packets (00: 3354986, 01: 2772, 10: 0, 11: 0, Total: 3357758, Bad Sync: 0)
I 10:39:49 M2TS File: \BDMV\STREAM\50138.m2ts
I 10:39:49 Reset CPI flag in 414 packets (00: 931852, 01: 414, 10: 0, 11: 0, Total: 932266, Bad Sync: 0)
I 10:40:01 M2TS File: \BDMV\STREAM\50139.m2ts
I 10:40:01 Reset CPI flag in 246 packets (00: 565095, 01: 246, 10: 0, 11: 0, Total: 565341, Bad Sync: 0)
I 10:42:31 M2TS File: \BDMV\STREAM\50140.m2ts
I 10:42:31 Reset CPI flag in 10448 packets (00: 7022766, 01: 10448, 10: 0, 11: 0, Total: 7033214, Bad Sync: 0)
I 10:42:51 M2TS File: \BDMV\STREAM\50141.m2ts
I 10:42:51 Reset CPI flag in 407 packets (00: 532771, 01: 407, 10: 0, 11: 0, Total: 533178, Bad Sync: 0)
I 10:43:08 M2TS File: \BDMV\STREAM\50142.m2ts
I 10:43:08 Reset CPI flag in 431 packets (00: 779495, 01: 431, 10: 0, 11: 0, Total: 779926, Bad Sync: 0)
I 10:44:27 M2TS File: \BDMV\STREAM\50143.m2ts
I 10:44:27 Reset CPI flag in 4069 packets (00: 3732552, 01: 4069, 10: 0, 11: 0, Total: 3736621, Bad Sync: 0)
I 10:45:37 M2TS File: \BDMV\STREAM\50145.m2ts
I 10:45:37 Reset CPI flag in 3834 packets (00: 3280668, 01: 3834, 10: 0, 11: 0, Total: 3284502, Bad Sync: 0)
I 10:46:40 M2TS File: \BDMV\STREAM\50146.m2ts
I 10:46:40 Reset CPI flag in 3571 packets (00: 2929663, 01: 3571, 10: 0, 11: 0, Total: 2933234, Bad Sync: 0)
I 10:50:12 M2TS File: \BDMV\STREAM\50147.m2ts
I 10:50:12 Reset CPI flag in 8037 packets (00: 9934445, 01: 8037, 10: 0, 11: 0, Total: 9942482, Bad Sync: 0)
I 10:51:04 M2TS File: \BDMV\STREAM\50148.m2ts
I 10:51:04 Reset CPI flag in 3101 packets (00: 2458033, 01: 3101, 10: 0, 11: 0, Total: 2461134, Bad Sync: 0)
I 10:53:14 M2TS File: \BDMV\STREAM\50149.m2ts
I 10:53:14 Reset CPI flag in 6929 packets (00: 6055545, 01: 6929, 10: 0, 11: 0, Total: 6062474, Bad Sync: 0)
I 10:53:58 M2TS File: \BDMV\STREAM\50150.m2ts
I 10:53:58 Reset CPI flag in 866 packets (00: 2062732, 01: 866, 10: 0, 11: 0, Total: 2063598, Bad Sync: 0)
I 10:54:14 M2TS File: \BDMV\STREAM\50151.m2ts
I 10:54:14 Reset CPI flag in 272 packets (00: 742014, 01: 272, 10: 0, 11: 0, Total: 742286, Bad Sync: 0)
I 10:54:32 M2TS File: \BDMV\STREAM\50152.m2ts
I 10:54:32 Reset CPI flag in 548 packets (00: 886710, 01: 548, 10: 0, 11: 0, Total: 887258, Bad Sync: 0)
I 10:56:27 M2TS File: \BDMV\STREAM\50154.m2ts
I 10:56:27 Reset CPI flag in 6211 packets (00: 5359351, 01: 6211, 10: 0, 11: 0, Total: 5365562, Bad Sync: 0)
I 10:57:14 M2TS File: \BDMV\STREAM\50155.m2ts
I 10:57:14 Reset CPI flag in 1970 packets (00: 1800944, 01: 1970, 10: 0, 11: 0, Total: 1802914, Bad Sync: 0)
I 10:58:23 M2TS File: \BDMV\STREAM\50156.m2ts
I 10:58:23 Reset CPI flag in 3255 packets (00: 3219500, 01: 3255, 10: 0, 11: 0, Total: 3222755, Bad Sync: 0)
I 11:01:09 M2TS File: \BDMV\STREAM\50157.m2ts
I 11:01:09 Reset CPI flag in 8308 packets (00: 7786578, 01: 8308, 10: 0, 11: 0, Total: 7794886, Bad Sync: 0)
I 11:04:22 M2TS File: \BDMV\STREAM\50158.m2ts
I 11:04:22 Reset CPI flag in 11321 packets (00: 9000565, 01: 11321, 10: 0, 11: 0, Total: 9011886, Bad Sync: 0)
I 11:04:31 M2TS File: \BDMV\STREAM\50160.m2ts
I 11:04:31 Reset CPI flag in 255 packets (00: 420059, 01: 255, 10: 0, 11: 0, Total: 420314, Bad Sync: 0)
I 11:04:52 M2TS File: \BDMV\STREAM\50163.m2ts
I 11:04:52 Reset CPI flag in 299 packets (00: 439279, 01: 299, 10: 0, 11: 0, Total: 439578, Bad Sync: 0)
I 11:05:13 M2TS File: \BDMV\STREAM\50164.m2ts
I 11:05:13 Reset CPI flag in 1508 packets (00: 964462, 01: 1508, 10: 0, 11: 0, Total: 965970, Bad Sync: 0)
I 11:05:23 M2TS File: \BDMV\STREAM\50165.m2ts
I 11:05:23 Reset CPI flag in 576 packets (00: 477718, 01: 576, 10: 0, 11: 0, Total: 478294, Bad Sync: 0)
I 11:06:57 M2TS File: \BDMV\STREAM\50166.m2ts
I 11:06:57 Reset CPI flag in 6148 packets (00: 4393175, 01: 6148, 10: 0, 11: 0, Total: 4399323, Bad Sync: 0)
I 11:08:06 M2TS File: \BDMV\STREAM\50167.m2ts
I 11:08:06 Reset CPI flag in 4679 packets (00: 3249875, 01: 4679, 10: 0, 11: 0, Total: 3254554, Bad Sync: 0)
I 11:08:21 M2TS File: \BDMV\STREAM\50168.m2ts
I 11:08:21 Reset CPI flag in 239 packets (00: 695395, 01: 239, 10: 0, 11: 0, Total: 695634, Bad Sync: 0)
I 11:08:48 M2TS File: \BDMV\STREAM\50169.m2ts
I 11:08:48 Reset CPI flag in 237 packets (00: 1264677, 01: 237, 10: 0, 11: 0, Total: 1264914, Bad Sync: 0)
I 11:09:02 M2TS File: \BDMV\STREAM\50170.m2ts
I 11:09:02 Reset CPI flag in 243 packets (00: 650095, 01: 243, 10: 0, 11: 0, Total: 650338, Bad Sync: 0)
I 11:09:30 M2TS File: \BDMV\STREAM\50171.m2ts
I 11:09:30 Reset CPI flag in 539 packets (00: 1316427, 01: 539, 10: 0, 11: 0, Total: 1316966, Bad Sync: 0)
I 11:09:43 M2TS File: \BDMV\STREAM\50172.m2ts
I 11:09:43 Reset CPI flag in 269 packets (00: 584805, 01: 269, 10: 0, 11: 0, Total: 585074, Bad Sync: 0)
I 11:10:16 M2TS File: \BDMV\STREAM\50176.m2ts
I 11:10:16 Reset CPI flag in 1582 packets (00: 810692, 01: 1582, 10: 0, 11: 0, Total: 812274, Bad Sync: 0)
I 11:10:30 M2TS File: \BDMV\STREAM\50177.m2ts
I 11:10:30 Reset CPI flag in 445 packets (00: 674429, 01: 445, 10: 0, 11: 0, Total: 674874, Bad Sync: 0)
I 11:11:05 M2TS File: \BDMV\STREAM\50178.m2ts
I 11:11:05 Reset CPI flag in 1386 packets (00: 1626184, 01: 1386, 10: 0, 11: 0, Total: 1627570, Bad Sync: 0)
I 11:11:20 M2TS File: \BDMV\STREAM\50179.m2ts
I 11:11:20 Reset CPI flag in 339 packets (00: 696107, 01: 339, 10: 0, 11: 0, Total: 696446, Bad Sync: 0)
I 11:11:44 M2TS File: \BDMV\STREAM\50182.m2ts
I 11:11:44 Reset CPI flag in 305 packets (00: 517397, 01: 305, 10: 0, 11: 0, Total: 517702, Bad Sync: 0)
I 11:12:33 M2TS File: \BDMV\STREAM\50183.m2ts
I 11:12:33 Reset CPI flag in 1848 packets (00: 2268374, 01: 1848, 10: 0, 11: 0, Total: 2270222, Bad Sync: 0)
I 11:12:43 M2TS File: \BDMV\STREAM\50184.m2ts
I 11:12:43 Reset CPI flag in 468 packets (00: 493934, 01: 468, 10: 0, 11: 0, Total: 494402, Bad Sync: 0)
I 11:14:25 M2TS File: \BDMV\STREAM\50185.m2ts
I 11:14:25 Reset CPI flag in 4296 packets (00: 4779942, 01: 4296, 10: 0, 11: 0, Total: 4784238, Bad Sync: 0)
I 11:16:00 M2TS File: \BDMV\STREAM\50186.m2ts
I 11:16:00 Reset CPI flag in 5120 packets (00: 4430638, 01: 5120, 10: 0, 11: 0, Total: 4435758, Bad Sync: 0)
I 11:16:43 M2TS File: \BDMV\STREAM\50188.m2ts
I 11:16:43 Reset CPI flag in 533 packets (00: 1681673, 01: 533, 10: 0, 11: 0, Total: 1682206, Bad Sync: 0)
I 11:17:41 M2TS File: \BDMV\STREAM\50189.m2ts
I 11:17:41 Reset CPI flag in 2602 packets (00: 2712304, 01: 2602, 10: 0, 11: 0, Total: 2714906, Bad Sync: 0)
I 11:18:41 M2TS File: \BDMV\STREAM\50190.m2ts
I 11:18:41 Reset CPI flag in 2264 packets (00: 2830130, 01: 2264, 10: 0, 11: 0, Total: 2832394, Bad Sync: 0)
I 11:18:55 M2TS File: \BDMV\STREAM\50191.m2ts
I 11:18:55 Reset CPI flag in 151 packets (00: 663483, 01: 151, 10: 0, 11: 0, Total: 663634, Bad Sync: 0)
I 11:19:41 M2TS File: \BDMV\STREAM\50192.m2ts
I 11:19:41 Reset CPI flag in 1788 packets (00: 1735778, 01: 1788, 10: 0, 11: 0, Total: 1737566, Bad Sync: 0)
I 11:20:11 M2TS File: \BDMV\STREAM\50195.m2ts
I 11:20:11 Reset CPI flag in 323 packets (00: 804515, 01: 323, 10: 0, 11: 0, Total: 804838, Bad Sync: 0)
I 11:20:38 M2TS File: \BDMV\STREAM\50196.m2ts
I 11:20:38 Reset CPI flag in 567 packets (00: 1261603, 01: 567, 10: 0, 11: 0, Total: 1262170, Bad Sync: 0)
I 11:21:12 M2TS File: \BDMV\STREAM\50197.m2ts
I 11:21:12 Reset CPI flag in 727 packets (00: 1586587, 01: 727, 10: 0, 11: 0, Total: 1587314, Bad Sync: 0)
SquallMX is offline   Reply With Quote
Old 26th October 2011, 21:26   #13367  |  Link
jdobbs
@SquallMX
I'm not seeing this. Does your output have angles also? What disc is it? Any special settings in IMGBURN?
Old 26th October 2011, 21:38   #13368  |  Link
Ch3vr0n
I havent seen messages of that type either
Ch3vr0n is offline   Reply With Quote
Old 26th October 2011, 22:05   #13369  |  Link
SquallMX
Special SeeD
@SquallMX
Yes, is Robin Hood (the one with Russell Crown), contains theatrical and director's cut using multiangles and has a PiP containing interviews with Ridley Scott, more specifically is the G52 edition (for Latin America and Eastern Europe) with 10 audio tracks and 25 subtitles. The US release is similar in specs but with only 4 audio tracks and 6 subtitles.
I'm using ImgBurn 2.5.6.0 with "Reset 'Copy Permission Indicator' Flag" checked, I will burn the disc without to see if anything changes.
Old 26th October 2011, 22:10   #13370  |  Link
jdobbs
Ok. Good. I'm getting ready to run that one right now.
I have "Reset Copy Permission Indicator" set on mine too. I think that is the default -- or at least I don't remember ever setting it.
Old 26th October 2011, 22:11   #13371  |  Link
colinhunt
Simply untick that "Reset 'Copy Permission Indicator' Flag" box under Options and you won't see those messages anymore. I haven't seen any adverse effects from unticking the box.
Old 26th October 2011, 22:16   #13372  |  Link
drmih
I have seen that on the only two discs I burnt to bd-re.
Harry Potter 7-1
I 19:54:01 Operation Started!
I 19:54:01 Building Image Tree...
I 19:54:03 Calculating Totals...
I 19:54:03 Preparing Image...
I 19:54:03 Contents: 511 Files, 25 Folders
I 19:54:03 Content Type: BD Video
I 19:54:03 Data Type: MODE1/2048
I 19:54:04 File System(s): UDF (2.50)
I 19:54:04 Volume Label: Harry Potter and the Deathly Hallows Part 1
I 19:54:04 Size: 23,920,311,566 bytes
I 19:54:04 Sectors: 11,680,112
I 19:54:04 Image Size: 23,923,982,336 bytes
I 19:54:04 Image Sectors: 11,681,632
I 19:54:05 Operation Successfully Completed! - Duration: 00:00:03
I 19:54:05 Operation Started!
I 19:54:05 Source File: -==/\/[BUILD IMAGE]\/\==-
I 19:54:05 Source File Sectors: 11,681,632 (MODE1/2048)
I 19:54:05 Source File Size: 23,923,982,336 bytes
I 19:54:05 Source File Volume Identifier: Harry Potter and the Deathly Hallows Part 1
I 19:54:05 Source File Volume Set Identifier: 3F599EC000B23CF0
I 19:54:05 Source File Application Identifier: ImgBurn v2.5.6.0
I 19:54:05 Source File Implementation Identifier: ImgBurn
I 19:54:05 Source File File System(s): UDF (2.50)
I 19:54:05 Destination Device: [1:0:0] HL-DT-ST BD-RE  GGW-H20L YL07 (F:) (ATA)
I 19:54:05 Destination Media Type: BD-RE (Disc ID: SONY-ES1-002)
I 19:54:05 Destination Media Supported Write Speeds: 2x
I 19:54:05 Destination Media Sectors: 12,219,392
I 19:54:05 Write Mode: BD
I 19:54:05 Write Type: DAO
I 19:54:05 Write Speed: MAX
I 19:54:05 BD-RE FastWrite: No
I 19:54:05 Link Size: Auto
I 19:54:05 Lock Volume: Yes
I 19:54:05 Test Mode: No
I 19:54:05 OPC: No
I 19:54:05 BURN-Proof: Enabled
I 19:54:05 Write Speed Successfully Set! - Effective: 8,992 KB/s (2x)
I 19:54:05 Filling Buffer... (40 MB)
I 19:54:11 Writing LeadIn...
I 19:54:20 Writing Session 1 of 1... (1 Track, LBA: 0 - 11681631)
I 19:54:20 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 11681631)
I 19:55:57 M2TS File: \BDMV\STREAM\00011.m2ts
I 19:55:57 Reset CPI flag in 381 packets (00: 1229933, 01: 381, 10: 0, 11: 0, Total: 1230314, Bad Sync: 0)
I 19:56:59 M2TS File: \BDMV\STREAM\00018.m2ts
I 19:56:59 Reset CPI flag in 128 packets (00: 526614, 01: 128, 10: 0, 11: 0, Total: 526742, Bad Sync: 0)
I 19:57:11 M2TS File: \BDMV\STREAM\00021.m2ts
I 19:57:11 Reset CPI flag in 200 packets (00: 676678, 01: 200, 10: 0, 11: 0, Total: 676878, Bad Sync: 0)
I 19:57:54 M2TS File: \BDMV\STREAM\00023.m2ts
I 19:57:54 Reset CPI flag in 1521 packets (00: 2012949, 01: 1521, 10: 0, 11: 0, Total: 2014470, Bad Sync: 0)
I 19:58:07 M2TS File: \BDMV\STREAM\00027.m2ts
I 19:58:07 Reset CPI flag in 267 packets (00: 716311, 01: 267, 10: 0, 11: 0, Total: 716578, Bad Sync: 0)
I 19:59:05 M2TS File: \BDMV\STREAM\00028.m2ts
I 19:59:05 Reset CPI flag in 2583 packets (00: 3109507, 01: 2583, 10: 0, 11: 0, Total: 3112090, Bad Sync: 0)
I 19:59:18 M2TS File: \BDMV\STREAM\00030.m2ts
I 19:59:18 Reset CPI flag in 588 packets (00: 407290, 01: 588, 10: 0, 11: 0, Total: 407878, Bad Sync: 0)
I 20:00:23 M2TS File: \BDMV\STREAM\00031.m2ts
I 20:00:23 Reset CPI flag in 3923 packets (00: 3469927, 01: 3923, 10: 0, 11: 0, Total: 3473850, Bad Sync: 0)
I 20:00:30 M2TS File: \BDMV\STREAM\00032.m2ts
I 20:00:30 Reset CPI flag in 264 packets (00: 384486, 01: 264, 10: 0, 11: 0, Total: 384750, Bad Sync: 0)
I 20:01:26 M2TS File: \BDMV\STREAM\00033.m2ts
I 20:01:26 Reset CPI flag in 3687 packets (00: 2996879, 01: 3687, 10: 0, 11: 0, Total: 3000566, Bad Sync: 0)
I 20:01:33 M2TS File: \BDMV\STREAM\00034.m2ts
I 20:01:33 Reset CPI flag in 153 packets (00: 389397, 01: 153, 10: 0, 11: 0, Total: 389550, Bad Sync: 0)
I 20:01:42 M2TS File: \BDMV\STREAM\00035.m2ts
I 20:01:42 Reset CPI flag in 261 packets (00: 446525, 01: 261, 10: 0, 11: 0, Total: 446786, Bad Sync: 0)
I 20:01:58 M2TS File: \BDMV\STREAM\00036.m2ts
I 20:01:58 Reset CPI flag in 339 packets (00: 906127, 01: 339, 10: 0, 11: 0, Total: 906466, Bad Sync: 0)
I 20:02:11 M2TS File: \BDMV\STREAM\00037.m2ts
I 20:02:11 Reset CPI flag in 221 packets (00: 673845, 01: 221, 10: 0, 11: 0, Total: 674066, Bad Sync: 0)
I 20:02:17 M2TS File: \BDMV\STREAM\00038.m2ts
I 20:02:17 Reset CPI flag in 251 packets (00: 337927, 01: 251, 10: 0, 11: 0, Total: 338178, Bad Sync: 0)
I 20:02:56 M2TS File: \BDMV\STREAM\00039.m2ts
I 20:02:56 Reset CPI flag in 1012 packets (00: 2095322, 01: 1012, 10: 0, 11: 0, Total: 2096334, Bad Sync: 0)
I 20:03:08 M2TS File: \BDMV\STREAM\00040.m2ts
I 20:03:08 Reset CPI flag in 197 packets (00: 605905, 01: 197, 10: 0, 11: 0, Total: 606102, Bad Sync: 0)
I 20:03:22 M2TS File: \BDMV\STREAM\00042.m2ts
I 20:03:22 Reset CPI flag in 188 packets (00: 507374, 01: 188, 10: 0, 11: 0, Total: 507562, Bad Sync: 0)
I 20:04:18 M2TS File: \BDMV\STREAM\00043.m2ts
I 20:04:18 Reset CPI flag in 3353 packets (00: 3024857, 01: 3353, 10: 0, 11: 0, Total: 3028210, Bad Sync: 0)
I 20:04:41 M2TS File: \BDMV\STREAM\00044.m2ts
I 20:04:41 Reset CPI flag in 514 packets (00: 1238692, 01: 514, 10: 0, 11: 0, Total: 1239206, Bad Sync: 0)
I 20:05:05 M2TS File: \BDMV\STREAM\00045.m2ts
I 20:05:05 Reset CPI flag in 503 packets (00: 1292515, 01: 503, 10: 0, 11: 0, Total: 1293018, Bad Sync: 0)
I 20:05:27 M2TS File: \BDMV\STREAM\00046.m2ts
I 20:05:27 Reset CPI flag in 247 packets (00: 1138675, 01: 247, 10: 0, 11: 0, Total: 1138922, Bad Sync: 0)
I 20:05:36 M2TS File: \BDMV\STREAM\00049.m2ts
I 20:05:36 Reset CPI flag in 241 packets (00: 490077, 01: 241, 10: 0, 11: 0, Total: 490318, Bad Sync: 0)
I 20:05:46 M2TS File: \BDMV\STREAM\00050.m2ts
I 20:05:46 Reset CPI flag in 403 packets (00: 544491, 01: 403, 10: 0, 11: 0, Total: 544894, Bad Sync: 0)
I 20:06:39 M2TS File: \BDMV\STREAM\00051.m2ts
I 20:06:39 Reset CPI flag in 1926 packets (00: 2838744, 01: 1926, 10: 0, 11: 0, Total: 2840670, Bad Sync: 0)
I 20:07:11 M2TS File: \BDMV\STREAM\00052.m2ts
I 20:07:11 Reset CPI flag in 617 packets (00: 1770613, 01: 617, 10: 0, 11: 0, Total: 1771230, Bad Sync: 0)
I 20:08:00 M2TS File: \BDMV\STREAM\00054.m2ts
I 20:08:00 Reset CPI flag in 2487 packets (00: 2305171, 01: 2487, 10: 0, 11: 0, Total: 2307658, Bad Sync: 0)
I 20:08:10 M2TS File: \BDMV\STREAM\00059.m2ts
I 20:08:10 Reset CPI flag in 344 packets (00: 574896, 01: 344, 10: 0, 11: 0, Total: 575240, Bad Sync: 0)
I 20:08:46 M2TS File: \BDMV\STREAM\00060.m2ts
I 20:08:46 Reset CPI flag in 2190 packets (00: 1939840, 01: 2190, 10: 0, 11: 0, Total: 1942030, Bad Sync: 0)
I 20:09:41 M2TS File: \BDMV\STREAM\00061.m2ts
I 20:09:41 Reset CPI flag in 2544 packets (00: 2912070, 01: 2544, 10: 0, 11: 0, Total: 2914614, Bad Sync: 0)
I 20:09:51 M2TS File: \BDMV\STREAM\00062.m2ts
I 20:09:51 Reset CPI flag in 226 packets (00: 526916, 01: 226, 10: 0, 11: 0, Total: 527142, Bad Sync: 0)
I 20:10:08 M2TS File: \BDMV\STREAM\00063.m2ts
I 20:10:08 Reset CPI flag in 345 packets (00: 949889, 01: 345, 10: 0, 11: 0, Total: 950234, Bad Sync: 0)
I 20:11:34 M2TS File: \BDMV\STREAM\00065.m2ts
I 20:11:34 Reset CPI flag in 4927 packets (00: 4293529, 01: 4927, 10: 0, 11: 0, Total: 4298456, Bad Sync: 0)
I 20:12:08 M2TS File: \BDMV\STREAM\00067.m2ts
I 20:12:08 Reset CPI flag in 494 packets (00: 1395196, 01: 494, 10: 0, 11: 0, Total: 1395690, Bad Sync: 0)
I 20:12:44 M2TS File: \BDMV\STREAM\00068.m2ts
I 20:12:44 Reset CPI flag in 612 packets (00: 1924566, 01: 612, 10: 0, 11: 0, Total: 1925178, Bad Sync: 0)
I 20:13:54 M2TS File: \BDMV\STREAM\00069.m2ts
I 20:13:54 Reset CPI flag in 4801 packets (00: 3715521, 01: 4801, 10: 0, 11: 0, Total: 3720322, Bad Sync: 0)
I 20:14:35 M2TS File: \BDMV\STREAM\00070.m2ts
I 20:14:35 Reset CPI flag in 1791 packets (00: 2220835, 01: 1791, 10: 0, 11: 0, Total: 2222626, Bad Sync: 0)
I 20:15:13 M2TS File: \BDMV\STREAM\00071.m2ts
I 20:15:13 Reset CPI flag in 1276 packets (00: 2042425, 01: 1276, 10: 0, 11: 0, Total: 2043701, Bad Sync: 0)
I 20:15:32 M2TS File: \BDMV\STREAM\00072.m2ts
I 20:15:32 Reset CPI flag in 441 packets (00: 1013213, 01: 441, 10: 0, 11: 0, Total: 1013654, Bad Sync: 0)
I 20:15:45 M2TS File: \BDMV\STREAM\00073.m2ts
I 20:15:45 Reset CPI flag in 475 packets (00: 680346, 01: 475, 10: 0, 11: 0, Total: 680821, Bad Sync: 0)
I 20:16:29 M2TS File: \BDMV\STREAM\00074.m2ts
I 20:16:29 Reset CPI flag in 2079 packets (00: 2367031, 01: 2079, 10: 0, 11: 0, Total: 2369110, Bad Sync: 0)
I 20:17:07 M2TS File: \BDMV\STREAM\00079.m2ts
I 20:17:07 Reset CPI flag in 1814 packets (00: 2023544, 01: 1814, 10: 0, 11: 0, Total: 2025358, Bad Sync: 0)
I 20:17:29 M2TS File: \BDMV\STREAM\00082.m2ts
I 20:17:29 Reset CPI flag in 245 packets (00: 535301, 01: 245, 10: 0, 11: 0, Total: 535546, Bad Sync: 0)
I 20:17:38 M2TS File: \BDMV\STREAM\00083.m2ts
I 20:17:38 Reset CPI flag in 307 packets (00: 490855, 01: 307, 10: 0, 11: 0, Total: 491162, Bad Sync: 0)
I 20:18:14 M2TS File: \BDMV\STREAM\00084.m2ts
I 20:18:14 Reset CPI flag in 1378 packets (00: 1899972, 01: 1378, 10: 0, 11: 0, Total: 1901350, Bad Sync: 0)
I 20:18:27 M2TS File: \BDMV\STREAM\00085.m2ts
I 20:18:27 Reset CPI flag in 240 packets (00: 738330, 01: 240, 10: 0, 11: 0, Total: 738570, Bad Sync: 0)
I 20:18:33 M2TS File: \BDMV\STREAM\00086.m2ts
I 20:18:33 Reset CPI flag in 204 packets (00: 328694, 01: 204, 10: 0, 11: 0, Total: 328898, Bad Sync: 0)
I 20:20:19 M2TS File: \BDMV\STREAM\00087.m2ts
I 20:20:19 Reset CPI flag in 5127 packets (00: 5682079, 01: 5127, 10: 0, 11: 0, Total: 5687206, Bad Sync: 0)
I 20:20:31 M2TS File: \BDMV\STREAM\00088.m2ts
I 20:20:31 Reset CPI flag in 229 packets (00: 631105, 01: 229, 10: 0, 11: 0, Total: 631334, Bad Sync: 0)
I 20:22:06 M2TS File: \BDMV\STREAM\00089.m2ts
I 20:22:06 Reset CPI flag in 4765 packets (00: 5133737, 01: 4765, 10: 0, 11: 0, Total: 5138502, Bad Sync: 0)
I 20:22:54 M2TS File: \BDMV\STREAM\00093.m2ts
I 20:22:54 Reset CPI flag in 2585 packets (00: 2524245, 01: 2585, 10: 0, 11: 0, Total: 2526830, Bad Sync: 0)
I 20:23:13 M2TS File: \BDMV\STREAM\00096.m2ts
I 20:23:13 Reset CPI flag in 412 packets (00: 999062, 01: 412, 10: 0, 11: 0, Total: 999474, Bad Sync: 0)
I 20:23:24 M2TS File: \BDMV\STREAM\00097.m2ts
I 20:23:24 Reset CPI flag in 413 packets (00: 601897, 01: 413, 10: 0, 11: 0, Total: 602310, Bad Sync: 0)
I 20:23:30 M2TS File: \BDMV\STREAM\00098.m2ts
I 20:23:30 Reset CPI flag in 458 packets (00: 317512, 01: 458, 10: 0, 11: 0, Total: 317970, Bad Sync: 0)
I 20:23:42 M2TS File: \BDMV\STREAM\00099.m2ts
I 20:23:42 Reset CPI flag in 191 packets (00: 689619, 01: 191, 10: 0, 11: 0, Total: 689810, Bad Sync: 0)
I 20:23:55 M2TS File: \BDMV\STREAM\00100.m2ts
I 20:23:55 Reset CPI flag in 221 packets (00: 684361, 01: 221, 10: 0, 11: 0, Total: 684582, Bad Sync: 0)
I 20:24:08 M2TS File: \BDMV\STREAM\00101.m2ts
I 20:24:08 Reset CPI flag in 229 packets (00: 699901, 01: 229, 10: 0, 11: 0, Total: 700130, Bad Sync: 0)
I 20:24:18 M2TS File: \BDMV\STREAM\00102.m2ts
I 20:24:18 Reset CPI flag in 194 packets (00: 534535, 01: 194, 10: 0, 11: 0, Total: 534729, Bad Sync: 0)
I 20:24:26 M2TS File: \BDMV\STREAM\00103.m2ts
I 20:24:26 Reset CPI flag in 371 packets (00: 438019, 01: 371, 10: 0, 11: 0, Total: 438390, Bad Sync: 0)
I 20:24:38 M2TS File: \BDMV\STREAM\00104.m2ts
I 20:24:38 Reset CPI flag in 320 packets (00: 627990, 01: 320, 10: 0, 11: 0, Total: 628310, Bad Sync: 0)
I 20:24:55 M2TS File: \BDMV\STREAM\00105.m2ts
I 20:24:55 Reset CPI flag in 389 packets (00: 886443, 01: 389, 10: 0, 11: 0, Total: 886832, Bad Sync: 0)
I 20:26:01 M2TS File: \BDMV\STREAM\00106.m2ts
I 20:26:01 Reset CPI flag in 1933 packets (00: 2107265, 01: 1933, 10: 0, 11: 0, Total: 2109198, Bad Sync: 0)
I 20:26:07 M2TS File: \BDMV\STREAM\00108.m2ts
I 20:26:07 Reset CPI flag in 328 packets (00: 354922, 01: 328, 10: 0, 11: 0, Total: 355250, Bad Sync: 0)
I 20:26:33 M2TS File: \BDMV\STREAM\00109.m2ts
I 20:26:33 Reset CPI flag in 1412 packets (00: 1406194, 01: 1412, 10: 0, 11: 0, Total: 1407606, Bad Sync: 0)
I 20:27:03 M2TS File: \BDMV\STREAM\00110.m2ts
I 20:27:03 Reset CPI flag in 835 packets (00: 1583627, 01: 835, 10: 0, 11: 0, Total: 1584462, Bad Sync: 0)
I 20:27:27 M2TS File: \BDMV\STREAM\00113.m2ts
I 20:27:27 Reset CPI flag in 1057 packets (00: 1312993, 01: 1057, 10: 0, 11: 0, Total: 1314050, Bad Sync: 0)
I 20:27:34 M2TS File: \BDMV\STREAM\00114.m2ts
I 20:27:34 Reset CPI flag in 103 packets (00: 372002, 01: 103, 10: 0, 11: 0, Total: 372105, Bad Sync: 0)
I 20:27:49 M2TS File: \BDMV\STREAM\00115.m2ts
I 20:27:49 Reset CPI flag in 305 packets (00: 798653, 01: 305, 10: 0, 11: 0, Total: 798958, Bad Sync: 0)
I 20:29:05 M2TS File: \BDMV\STREAM\00117.m2ts
I 20:29:05 Reset CPI flag in 5463 packets (00: 4060091, 01: 5463, 10: 0, 11: 0, Total: 4065554, Bad Sync: 0)
I 20:29:12 M2TS File: \BDMV\STREAM\00119.m2ts
I 20:29:12 Reset CPI flag in 176 packets (00: 412769, 01: 176, 10: 0, 11: 0, Total: 412945, Bad Sync: 0)
I 20:30:26 M2TS File: \BDMV\STREAM\00121.m2ts
I 20:30:26 Reset CPI flag in 3730 packets (00: 3930168, 01: 3730, 10: 0, 11: 0, Total: 3933898, Bad Sync: 0)
I 20:30:38 M2TS File: \BDMV\STREAM\00122.m2ts
I 20:30:38 Reset CPI flag in 98 packets (00: 623152, 01: 98, 10: 0, 11: 0, Total: 623250, Bad Sync: 0)
I 20:30:59 M2TS File: \BDMV\STREAM\00124.m2ts
I 20:30:59 Reset CPI flag in 497 packets (00: 928213, 01: 497, 10: 0, 11: 0, Total: 928710, Bad Sync: 0)
I 20:31:29 M2TS File: \BDMV\STREAM\00125.m2ts
I 20:31:29 Reset CPI flag in 1641 packets (00: 1613761, 01: 1641, 10: 0, 11: 0, Total: 1615402, Bad Sync: 0)
I 20:31:40 M2TS File: \BDMV\STREAM\00126.m2ts
I 20:31:40 Reset CPI flag in 237 packets (00: 591337, 01: 237, 10: 0, 11: 0, Total: 591574, Bad Sync: 0)
I 20:32:40 M2TS File: \BDMV\STREAM\00127.m2ts
I 20:32:40 Reset CPI flag in 3333 packets (00: 3215861, 01: 3333, 10: 0, 11: 0, Total: 3219194, Bad Sync: 0)
I 20:32:53 M2TS File: \BDMV\STREAM\00131.m2ts
I 20:32:53 Reset CPI flag in 165 packets (00: 448517, 01: 165, 10: 0, 11: 0, Total: 448682, Bad Sync: 0)
I 20:33:15 M2TS File: \BDMV\STREAM\00133.m2ts
I 20:33:15 Reset CPI flag in 537 packets (00: 1173289, 01: 537, 10: 0, 11: 0, Total: 1173826, Bad Sync: 0)
I 20:33:19 M2TS File: \BDMV\STREAM\00135.m2ts
I 20:33:19 Reset CPI flag in 203 packets (00: 255127, 01: 203, 10: 0, 11: 0, Total: 255330, Bad Sync: 0)
I 20:33:28 Synchronising Cache...
I 20:33:29 Exporting Graph Data...
I 20:33:29 Graph Data File: C:\Users\HL-DT-ST_BD-RE_GGW-H20L_YL07_25-OCTOBER-2011_19-54_SONY-ES1-002_MAX.ibg
I 20:33:29 Export Successfully Completed!
I 20:33:29 Operation Successfully Completed! - Duration: 00:39:23
I 20:33:29 Average Write Rate: 9,950 KB/s (2.2x) - Maximum Write Rate: 10,830 KB/s (2.4x)
Old 26th October 2011, 22:17   #13373  |  Link
drmih
Terminator 2 - Ultimate Edition
I 21:37:35 Operation Started!
I 21:37:35 Building Image Tree...
I 21:37:36 Calculating Totals...
I 21:37:36 Preparing Image...
I 21:37:36 Contents: 1,419 Files, 47 Folders
I 21:37:36 Content Type: BD Video
I 21:37:36 Data Type: MODE1/2048
I 21:37:36 File System(s): UDF (2.50)
I 21:37:36 Volume Label: Terminator 2
I 21:37:36 Size: 23,883,412,251 bytes
I 21:37:36 Sectors: 11,662,640
I 21:37:36 Image Size: 23,892,262,912 bytes
I 21:37:36 Image Sectors: 11,666,144
I 21:37:38 Operation Successfully Completed! - Duration: 00:00:03
I 21:37:38 Operation Started!
I 21:37:38 Source File: -==/\/[BUILD IMAGE]\/\==-
I 21:37:38 Source File Sectors: 11,666,144 (MODE1/2048)
I 21:37:38 Source File Size: 23,892,262,912 bytes
I 21:37:38 Source File Volume Identifier: Terminator 2
I 21:37:38 Source File Volume Set Identifier: 3F59ACB100B1FC90
I 21:37:38 Source File Application Identifier: ImgBurn v2.5.6.0
I 21:37:38 Source File Implementation Identifier: ImgBurn
I 21:37:38 Source File File System(s): UDF (2.50)
I 21:37:38 Destination Device: [1:0:0] HL-DT-ST BD-RE  GGW-H20L YL07 (F:) (ATA)
I 21:37:38 Destination Media Type: BD-RE (Disc ID: SONY-ES1-002)
I 21:37:38 Destination Media Supported Write Speeds: 2x
I 21:37:38 Destination Media Sectors: 12,219,392
I 21:37:38 Write Mode: BD
I 21:37:38 Write Type: DAO
I 21:37:38 Write Speed: MAX
I 21:37:38 BD-RE FastWrite: No
I 21:37:38 Link Size: Auto
I 21:37:38 Lock Volume: Yes
I 21:37:38 Test Mode: No
I 21:37:38 OPC: No
I 21:37:38 BURN-Proof: Enabled
I 21:37:38 Write Speed Successfully Set! - Effective: 8,992 KB/s (2x)
I 21:37:38 Filling Buffer... (40 MB)
I 21:37:51 Writing LeadIn...
I 21:38:00 Writing Session 1 of 1... (1 Track, LBA: 0 - 11666143)
I 21:38:00 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 11666143)
I 21:40:44 M2TS File: \BDMV\STREAM\00000.m2ts
I 21:40:44 Reset CPI flag in 7500 packets (00: 8929656, 01: 7500, 10: 0, 11: 0, Total: 8937156, Bad Sync: 0)
I 21:40:59 M2TS File: \BDMV\STREAM\00001.m2ts
I 21:40:59 Reset CPI flag in 494 packets (00: 804550, 01: 494, 10: 0, 11: 0, Total: 805044, Bad Sync: 0)
I 21:41:22 M2TS File: \BDMV\STREAM\00002.m2ts
I 21:41:22 Reset CPI flag in 1662 packets (00: 1193862, 01: 1662, 10: 0, 11: 0, Total: 1195524, Bad Sync: 0)
I 21:41:58 M2TS File: \BDMV\STREAM\00006.m2ts
I 21:41:58 Reset CPI flag in 980 packets (00: 1683190, 01: 980, 10: 0, 11: 0, Total: 1684170, Bad Sync: 0)
I 21:42:06 M2TS File: \BDMV\STREAM\00007.m2ts
I 21:42:06 Reset CPI flag in 241 packets (00: 442883, 01: 241, 10: 0, 11: 0, Total: 443124, Bad Sync: 0)
I 21:46:16 M2TS File: \BDMV\STREAM\00008.m2ts
I 21:46:16 Reset CPI flag in 13912 packets (00: 13381516, 01: 13912, 10: 0, 11: 0, Total: 13395428, Bad Sync: 0)
I 21:46:33 M2TS File: \BDMV\STREAM\00010.m2ts
I 21:46:33 Reset CPI flag in 470 packets (00: 933950, 01: 470, 10: 0, 11: 0, Total: 934420, Bad Sync: 0)
I 21:46:52 M2TS File: \BDMV\STREAM\00011.m2ts
I 21:46:52 Reset CPI flag in 747 packets (00: 1035775, 01: 747, 10: 0, 11: 0, Total: 1036522, Bad Sync: 0)
I 21:47:08 M2TS File: \BDMV\STREAM\00012.m2ts
I 21:47:08 Reset CPI flag in 421 packets (00: 848207, 01: 421, 10: 0, 11: 0, Total: 848628, Bad Sync: 0)
I 21:47:38 M2TS File: \BDMV\STREAM\00013.m2ts
I 21:47:38 Reset CPI flag in 1901 packets (00: 1617431, 01: 1901, 10: 0, 11: 0, Total: 1619332, Bad Sync: 0)
I 21:48:05 M2TS File: \BDMV\STREAM\00014.m2ts
I 21:48:05 Reset CPI flag in 1268 packets (00: 1431352, 01: 1268, 10: 0, 11: 0, Total: 1432620, Bad Sync: 0)
I 21:48:28 M2TS File: \BDMV\STREAM\00015.m2ts
I 21:48:28 Reset CPI flag in 897 packets (00: 1226267, 01: 897, 10: 0, 11: 0, Total: 1227164, Bad Sync: 0)
I 21:49:55 M2TS File: \BDMV\STREAM\00016.m2ts
I 21:49:55 Reset CPI flag in 4271 packets (00: 4679165, 01: 4271, 10: 0, 11: 0, Total: 4683436, Bad Sync: 0)
I 21:50:09 M2TS File: \BDMV\STREAM\00017.m2ts
I 21:50:09 Reset CPI flag in 1175 packets (00: 733373, 01: 1175, 10: 0, 11: 0, Total: 734548, Bad Sync: 0)
I 22:16:06 M2TS File: \BDMV\STREAM\00018.m2ts
I 22:16:06 Reset CPI flag in 6926 packets (00: 6642926, 01: 6926, 10: 0, 11: 0, Total: 6649852, Bad Sync: 0)
I 22:16:22 M2TS File: \BDMV\STREAM\00019.m2ts
I 22:16:22 Reset CPI flag in 445 packets (00: 827863, 01: 445, 10: 0, 11: 0, Total: 828308, Bad Sync: 0)
I 22:20:17 M2TS File: \BDMV\STREAM\00020.m2ts
I 22:20:17 Reset CPI flag in 14075 packets (00: 12591337, 01: 14075, 10: 0, 11: 0, Total: 12605412, Bad Sync: 0)
I 22:20:27 M2TS File: \BDMV\STREAM\00021.m2ts
I 22:20:27 Reset CPI flag in 607 packets (00: 555197, 01: 607, 10: 0, 11: 0, Total: 555804, Bad Sync: 0)
I 22:21:19 M2TS File: \BDMV\STREAM\00022.m2ts
I 22:21:19 Reset CPI flag in 3657 packets (00: 2825835, 01: 3657, 10: 0, 11: 0, Total: 2829492, Bad Sync: 0)
I 22:21:52 M2TS File: \BDMV\STREAM\00023.m2ts
I 22:21:52 Reset CPI flag in 2373 packets (00: 1758071, 01: 2373, 10: 0, 11: 0, Total: 1760444, Bad Sync: 0)
I 22:23:03 M2TS File: \BDMV\STREAM\00024.m2ts
I 22:23:03 Reset CPI flag in 4617 packets (00: 3778803, 01: 4617, 10: 0, 11: 0, Total: 3783420, Bad Sync: 0)
I 22:23:09 M2TS File: \BDMV\STREAM\00025.m2ts
I 22:23:09 Reset CPI flag in 428 packets (00: 357080, 01: 428, 10: 0, 11: 0, Total: 357508, Bad Sync: 0)
I 22:23:33 M2TS File: \BDMV\STREAM\00026.m2ts
I 22:23:33 Reset CPI flag in 998 packets (00: 1285110, 01: 998, 10: 0, 11: 0, Total: 1286108, Bad Sync: 0)
I 22:23:40 M2TS File: \BDMV\STREAM\00027.m2ts
I 22:23:40 Reset CPI flag in 226 packets (00: 331058, 01: 226, 10: 0, 11: 0, Total: 331284, Bad Sync: 0)
I 22:26:12 M2TS File: \BDMV\STREAM\00030.m2ts
I 22:26:12 Reset CPI flag in 9538 packets (00: 8182138, 01: 9538, 10: 0, 11: 0, Total: 8191676, Bad Sync: 0)
I 22:26:46 M2TS File: \BDMV\STREAM\00031.m2ts
I 22:26:46 Reset CPI flag in 1730 packets (00: 1806682, 01: 1730, 10: 0, 11: 0, Total: 1808412, Bad Sync: 0)
I 22:27:29 M2TS File: \BDMV\STREAM\00032.m2ts
I 22:27:29 Reset CPI flag in 4105 packets (00: 2339123, 01: 4105, 10: 0, 11: 0, Total: 2343228, Bad Sync: 0)
I 22:37:14 M2TS File: \BDMV\STREAM\00208.m2ts
I 22:37:14 Reset CPI flag in 1128 packets (00: 1614836, 01: 1128, 10: 0, 11: 0, Total: 1615964, Bad Sync: 0)
I 22:37:27 M2TS File: \BDMV\STREAM\00210.m2ts
I 22:37:27 Reset CPI flag in 488 packets (00: 541394, 01: 488, 10: 0, 11: 0, Total: 541882, Bad Sync: 0)
I 22:37:41 M2TS File: \BDMV\STREAM\00212.m2ts
I 22:37:41 Reset CPI flag in 217 packets (00: 348099, 01: 217, 10: 0, 11: 0, Total: 348316, Bad Sync: 0)
I 22:37:57 M2TS File: \BDMV\STREAM\00213.m2ts
I 22:37:57 Reset CPI flag in 421 packets (00: 452039, 01: 421, 10: 0, 11: 0, Total: 452460, Bad Sync: 0)
I 22:38:32 M2TS File: \BDMV\STREAM\00217.m2ts
I 22:38:32 Reset CPI flag in 1427 packets (00: 1628065, 01: 1427, 10: 0, 11: 0, Total: 1629492, Bad Sync: 0)
I 22:38:39 M2TS File: \BDMV\STREAM\00218.m2ts
I 22:38:39 Reset CPI flag in 323 packets (00: 345633, 01: 323, 10: 0, 11: 0, Total: 345956, Bad Sync: 0)
I 22:39:02 M2TS File: \BDMV\STREAM\00219.m2ts
I 22:39:02 Reset CPI flag in 1483 packets (00: 1247209, 01: 1483, 10: 0, 11: 0, Total: 1248692, Bad Sync: 0)
I 22:39:23 M2TS File: \BDMV\STREAM\00220.m2ts
I 22:39:23 Reset CPI flag in 633 packets (00: 1091483, 01: 633, 10: 0, 11: 0, Total: 1092116, Bad Sync: 0)
I 22:40:06 M2TS File: \BDMV\STREAM\00221.m2ts
I 22:40:06 Reset CPI flag in 2439 packets (00: 2329773, 01: 2439, 10: 0, 11: 0, Total: 2332212, Bad Sync: 0)
I 22:40:32 Synchronising Cache...
I 22:40:34 Exporting Graph Data...
I 22:40:34 Graph Data File: C:\Users\HL-DT-ST_BD-RE_GGW-H20L_YL07_25-OCTOBER-2011_21-37_SONY-ES1-002_MAX.ibg
I 22:40:34 Export Successfully Completed!
I 22:40:34 Operation Successfully Completed! - Duration: 01:02:55
I 22:40:34 Average Write Rate: 6,218 KB/s (1.4x) - Maximum Write Rate: 11,192 KB/s (2.5x)
Old 27th October 2011, 04:54   #13374  |  Link
color43
I just ran a new encode with my Star Trek BD's. This time I used Season 1 Disc 3 which has four episodes. Two have a PIP commentary track with DTS-E. The disc uses seamless branching and has two angles. I'm getting the M2TS message in ImgBurn and switching the angle while the PIP is on causes issues. The PIP and DTS-E audio play fine as long as the angle is not changed during playback. This time I have all the log files:
imgburn log
http://pastebin.com/dpvDTEYg
bd-rebuilder.log
http://pastebin.com/TUcFDfPX
star_trek_s1d3.ini
http://pastebin.com/CCawJ3rK
bd-rebuilder.ini
http://pastebin.com/2fX06Hzi
color43 is offline   Reply With Quote
Old 27th October 2011, 19:58   #13375  |  Link
sonate
To J dobbs
Frequent and continuous pixilation and image breakup on title "Inception" on latest build of BD Rebuilder. 39.02 Source is VC-1. Never had this happen before on any title, any source or build.
Defects are obvious when played on Cyberlink PowerDVD software player, Sony BDPs300 and Sharp BD-HP70u from the burned BD-25 .
Playing the mounted iso has defects in the exact same places as playing from burned disc on the cyberlink software .
Playing the original BD shows none of the defects and playing a mounted image of the ANYdvd rip is also clean.
Also, another title "Of Gods and men" which was a MPEG-4 (AVC) source was run with BD reb 39.02 without the problems previously described.
I'm presently running the same job "Inception) VC-1 source on 39.01 and comparing the VID_xxxxx.AVS.264's to the 39.02 files by playing them in the cyberlink player, I'm finding no pixilation or breakup in the avs.264's created in the older version. Compression ratio is aprox 40g/24g. I'm expecting the resulting burned BD-25 will be fine as well
sonate is offline   Reply With Quote
Old 28th October 2011, 08:30   #13376  |  Link
colinhunt
Just realized I've used x264's internal LAVF for every VC-1 encoded title. Perhaps this is a bug introduced in the new build of x264? I'm going to run another backup of Animal House using FFDshow instead of LAVF.
Old 28th October 2011, 13:04   #13377  |  Link
sonate
I'm looking at the .inf and .ini and I'm seeing "USE_LAVF=0" in either case.
Is there another way to tell if that has happened?
Old 28th October 2011, 13:21   #13378  |  Link
colinhunt
Well, this is very interesting... because the second backup of Animal House finished a moment ago, and viewing the output on PDVD11 I can't see the severe blocking artefact in either main or secondary video. I simply unticked the "Use LAVF" box under BD-RB settings and made sure FFDShow was configured correctly for VC-1. I'll burn the data on a BD-RE next for testing on stand-alones.
Old 28th October 2011, 13:24   #13379  |  Link
drmih
I haven't changed any of my settings (but checking LAVF seems to be the default) and only get 'blocking' on PiP titles which are VC1/VC1 - I have done none PiP titles with the latest version and they are okay.
Just done Green Lantern (which is AVC / AVC PiP) to bd-9 - works fine on pc using TMT but not on any standalone players (panasonic won't play bd-9). Also got the 'Reset CPI flag' when burning the disc.
Old 28th October 2011, 14:11   #13380  |  Link
sonate
To Drmih and Colinhunt
Thank you both for your input.
I've noticed that you update to a newer version, the settings are retained. I don't think I ever had the LAVF setting checked, as I think early on when I first experienced the inability to recode to AC3, I tried to find all the advice I could about the settings in general. Seems as I recall I unchecked it from the start. But then again, I never had a video problem. No burning problems either. Only audio and I still can't get it to work which is too bad because I have an extras feature I would really like to burn to a 4.7 DVD.
Just tested the "Inception" with 39.01 and everything is fine. Can swear that I didn't have LAVF checked in 39.02
