Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD Rebuilder
Old 16th January 2011, 08:51   #11001  |  Link
Crocluvr92
@omegaman7
" He started the thread, and designed the application. The very first post on this thread. Page 1 "
The instructions tell me what programs to Download, but NOT the proper versions for BD Rebuilder v0.37.01 (beta)
- BD-Rebuilder v0.37.01 (beta)
- Windows Version: 6.1 [7600]
- AVISYNTH Version: 2.5.8.0, Ok
- HAALI Splitter: Isn't recommended version
- FFDSHOW: 2527, not recommended version
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set incorrectly: [0]
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Can someone please tell me what the proper versions of Haali Splitter and FFDSHOW to get for this version of BD Rebuilder?
Crocluvr92 is offline   Reply With Quote
Old 16th January 2011, 11:35   #11002  |  Link
Sharc
Originally Posted by Crocluvr92 View Post
@omegaman7
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
You have to download from the links in the first post and you will get the required and approved versions automatically.
Old 16th January 2011, 11:42   #11003  |  Link
BZeeme
The words "FFDSHOW" and "Haali Matroska Splitter" are links to
http://www.jdobbs.net/freeware/ffdsh...0319_clsid.exe (version is rev3326)
and
http://www.jdobbs.net/freeware/MatroskaSplitter.exe
BZeeme is offline   Reply With Quote
Old 16th January 2011, 11:48   #11004  |  Link
Crocluvr92
Thanks you guys! I should buy you both an E-Beer! LOL
Old 16th January 2011, 12:13   #11005  |  Link
Sharc
Cheers, but I guess it's jdobbs who deserves a few more beers .....
Old 16th January 2011, 12:59   #11006  |  Link
Sharc
Originally Posted by colinhunt View Post
It's output as 1080i25? Since BD has no support for 1080p25 and some movies are shot in 25fps here in Europe, authoring shops tend to encode progressive frames but flag them as 1080i25 to get round the limitation.
That's similar to DVD I assume: Progressive frames encoded/flagged as interlaced.
I would assume that such sources can be encoded as progressive by x264 using '--fake-interlaced'. I do this for DVD backups for example, and they play without issues on my SONY S360.
Encoding as interlaced with '--tff' (MBAFF) should also work, but in this case '--weightp' is not supported if I remember correctly.
It's more difficult when downscaling to 720. Blu-ray accepts progressive 23.976, 24.000, 50.000, 59.940 only, but not 25. So either one can apply frame duplication for 25fps progressive material, or apply '--pulldown double' which would be more efficient. I tried the latter without success. It seems that tsmuxer has a problem with it (frame playback sequence). Maybe someone else has a different experience. It's however going beyond the scope of this thread.
Old 16th January 2011, 17:05   #11007  |  Link
jdobbs
BD Rebuilder v0.37.03 (beta)
I have updated the first post of this thread with a link to a new release of BD-RB (v0.37.03). Changes for this release:
- Corrected an error in which pulldown could be
  incorrectly applied to a hybrid source.
- Fixed an error in which BFF (bottom field first)
  MPEG-2 sources may not be correctly identified.
- Corrected an error in which 24fps sources that
  were rebuilt for movie-only were not using the
  correct muxing rate and as a result did not
  have audio synchronization.
- Fixed a bug in which setting DEINTERLACE and
  IVTC concurrently would cause an incorrect AVS
  to be generated on a source with pulldown. As a
  result, a nonsensical framerate and audio sync
  problems would occur.
- Corrected the ALTERNATE/DVD output so it will
  properly handle 24fps sources.
- Changed actions in combinations of resizing SD
  to 1080p in combination with IVTC.
- Updated the included version of X264.EXE to the
  latest release (r1867).
- Updated the included version of X264-64.EXE to
  the latest release (r1867).
- Other minor corrections and cosmetic fixes.
Website: www.jdobbs.net
Old 16th January 2011, 17:10   #11008  |  Link
jdobbs
If you select the "Deinterlace" option in the SETUP dialog the "--fake-interlaced" flag will be used for both 29.97fps and 25fps sources.
Old 17th January 2011, 01:57   #11009  |  Link
HWK
HWK's Avatar
@omegaman7
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
If you go back to first post. This is First point on thread.
1. Download and install FFDSHOW and the Haali Matroska Splitter. They are required for BD-RB to work and are free. After the install, run "Video Decoder Configuration" for FFDSHOW from the "START/Programs" menu, and make sure MPEG2 decoding is enabled. Do the same using "Audio Decoder Configuration" to ensure "Uncompressed" is set to "All Supported".
In that very post you will find two program you need. I have highlighted them here.
HWK is offline   Reply With Quote
Old 17th January 2011, 02:26   #11010  |  Link
Voyeurism
I've just tried the latest build with New Moon, and the audio is still out of sync. I haven't tried Benjamin Button again yet, but assume the problem will still be there for that disc too.
Voyeurism is offline   Reply With Quote
Old 17th January 2011, 03:25   #11011  |  Link
jdobbs
Tried it how? I'm not a mind reader... movie-only, full backup, Alternate output, DVD?
If you want things to get fixed you have to take the extra 30 seconds needed to describe your issue. You also can't expect me to start digging back through the pages to see what happened last time you posted. I went through all 7 of your previous posts and you have yet to have posted a single LOG, INF, or INI file. To me that's as much as saying "Ignore my post".
C'mon, throw me a bone here.
Old 17th January 2011, 03:41   #11012  |  Link
Voyeurism
.INF
[Status]
LABEL=TWILIGHT_NEW_MOON
VERSION=v0.37.03 (beta)
SOURCE_SIZE=35177097216
SOURCE_VIDEO_SIZE=35177097216
TARGET_SIZE=4686086144
REDUCTION=.133214122678337
RESIZE_1080=0
AUDIO_TO_KEEP=eng
SUBS_TO_KEEP=all
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=0
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00000]
AUDIO=110
PGS=1
M2TS_TARGET=4686086144
RATE=3449
NSTART=27000000
NEND=379838880
NSIZE=3574161408
FLINK=0
MLINK=0
.LOG
[20:12:04] BD Rebuilder v0.37.03 (beta)
  - Source:  TWILIGHT_NEW_MOON
  - Input BD size: 32.76 GB
  - Approximate total content: [02:10:38.831]
  - Target BD size: 4.36 GB
  - MOVIE-ONLY mode enabled
  - Auto Quality: High Quality (Default), Two Pass
  - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
[20:12:05] PHASE ONE, Encoding
 - [20:12:05] Extracting A/V streams [VID_00000]
 - [20:27:09] Reencoding: VID_00000 (1 of 1)
 - [20:27:09] Collecting video information
   - Rate/Length: 23.976fps, 187,944 frames
   - Bitrate: 3,449 Kbs
 - [20:27:09] Reencoding: VID_00000, Pass 1 of 2
 - [21:39:15] Reencoding: VID_00000, Pass 2 of 2
 - [23:42:48] Video Encode complete
 - [23:42:49] Reencoding audio tracks (if req'd)
 - [23:46:10] Multiplexing M2TS
[23:47:03]PHASE ONE complete
[23:47:03]PHASE TWO - Rebuild Started
 - [23:47:03] Rebuilding AVCHD file Structure
[23:49:23] - Encode and Rebuild complete
[23:49:23]JOB: TWILIGHT_NEW_MOON finished.
.INI
[Options]
MODE=1
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=1
VERSION=0.37.0.3
[Paths]
SOURCE_PATH=M:\
WORKING_PATH=J:\BD_REBUILDER\
Sorry if I'm not posting the required information - let me know if there is anything else you require.
Old 17th January 2011, 05:24   #11013  |  Link
jdobbs
What are you using to play it back? Sometimes software players can cause desync. It's been a long, long time since a standard backup of an AVC HD source in movie-only has had sync problems. Can you also run INSPECT.EXE and post the results?
I'll pick up a copy of NEW_MOON and give it a test run.
Old 17th January 2011, 08:07   #11014  |  Link
Voyeurism
Inspect.exe
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter:  Ok
- FFDSHOW: 3326, Ok
- FFDSHOW VC-1 set incorrectly: [1]
- BD Rebuilder v0.37.0.3, Ok
- X264:  Ok
- AFTEN:  Ok
- FAAC:  Ok
- MP4BOX:  Ok
- WAVI:  Ok
- TSMUXER:  Ok
I originally noticed the sync while watching a burned copy of the rebuilt BD5, played back on my PS3. Since I noticed it, I have been using VLC after the rebuild to play the m2ts file that BD-RB outputs so that I can check the audio before burning to disc.
Since first noticing the sync problem I've done about 4-5 rebuilds of other discs using exactly the same settings (I assume - I never touch any of them) which have worked without any sync problems. "New Moon" and "The Curious Case of Benjamin Button" are the only discs I've experienced it with so far.
Old 17th January 2011, 15:32   #11015  |  Link
L4a-Thompson
i get a bug by mplex here the log
- Input BD size: 33,90 GB
- Approximate total content: [02:58:09.623]
- MOVIE-ONLY/ALTERNATE OUTPUT mode enabled
- AVS Filtering is enabled
- Mode: DVD-9, 720x480/576, AC3 Audio
- Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
[19:19:27] PHASE ONE, Encoding
- [19:19:27] Extracting A/V streams [VID_00000]
- [19:37:10] Reencoding: VID_00000 (1 of 1)
- [19:37:10] Collecting video information
- Rate/Length: 23,976fps, 256.294 frames
- Bitrate: 5.182 Kbs
- [07:10:08] Video Encode complete
- [07:10:08] Reencoding audio tracks (if req'd)
- [07:25:57] Multiplexing M2TS
[07:25:57]PHASE ONE complete
[07:25:57]PHASE TWO - Rebuild Started
- [07:25:57] Rebuilding stream 00000 [1 of 1]
- [07:25:57] Building ALTERNATE OUTPUT Structure
- [07:29:27] Starting MPLEX.
- [07:29:27] MovieOnlyRebuild() 00053 2904
[15:28:08] - Aborted at user request
L4a-Thompson is offline   Reply With Quote
Old 17th January 2011, 15:40   #11016  |  Link
Ch3vr0n
@L4a-Thompson : what does inspect.exe say for you ?
Ch3vr0n is offline   Reply With Quote
Old 17th January 2011, 16:08   #11017  |  Link
L4a-Thompson
- FFDSHOW: 3326, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Old 17th January 2011, 16:52   #11018  |  Link
Capsbackup
@jdobbs;
I can confirm on my end that BD-RBV03703 corrects the IVTC/DECOMB problem on mpeg2 files that could make the audio go out of sync.
I see the avs created reflects (Telecide(order=1) Decimate() ).
Suprising to me is that the visual quality is improved noticeably on what is a pretty low quality original, and is better than just keeping it interlaced or using Decomb to deinterlace it. ( pending the original source! )
So congrats and thank you for such a quick find and fix.
Capsbackup is offline   Reply With Quote
Old 17th January 2011, 17:26   #11019  |  Link
jdobbs
Originally Posted by Capsbackup View Post
@jdobbs;
Cool, thanks!
Old 17th January 2011, 19:41   #11020  |  Link
jdobbs
@jdobbs;
Just as a note, I'm including SmoothDeinterlacer() as an option for deinterlacing in the next release. I've found that on some sources it can make a considerable difference. I've also added a deinterlacing option that leaves the source alone -- but adds "fake-interlaced" to the command line for sources that are actually progressive but are marked as interlaced to meet the standard.
