Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD Rebuilder
Old 6th August 2010, 18:47   #9061  |  Link
drmih
Originally Posted by nick9461 View Post
The latest version of DVDFab(7.0.9.0) failed on Star Trek Season 2 Disk 1, I will try 'The Da Vinci Code' next.
From my recollections none of the Star Trek series discs have PiP, and therefore not DTS Express. They do have branching versions to pick up the old or new graphics.
I have tried:
The Mummy
Mummy Returns
Terminator 2 - Ultimate
Terminator Salvation
All worked so far.
drmih is offline   Reply With Quote
Old 6th August 2010, 19:01   #9062  |  Link
A.Fenderson
I'm pretty sure some of the Star Trek TOS discs have DTS Express while others don't--it may break down by season, not sure.
A.Fenderson is offline   Reply With Quote
Old 6th August 2010, 19:24   #9063  |  Link
drmih
I've done them all with bd-rb and if they had dts express it couldn't have been done.
Just checked my Region B ST S2D1 and it has DTS-HD MA 7.1 and Dolby 2.0.
I also understood that DTS-Express was only used for PiP.
Old 6th August 2010, 23:44   #9064  |  Link
nick9461
Star Trek US version Season 2 Disk 1 has pip with DTS Express - for Episode Amok Time only. The other disks also have pip for only one episode per disk.
Back to DVDFab, it failed with the Da Vinci Code. The pip is there but no sound.
I have other movies with DTS Express, but I have wasted too much time on this. Must have been a prank, or someone is mental.
nick9461 is offline   Reply With Quote
Old 7th August 2010, 08:10   #9065  |  Link
rippn
So far I've done:
Perfect:
Green Zone (U Control PiP)
Groundhog Day (Standard PiP)
Repo Men (U Control PiP)
Sherlock Holmes (Maximum Movie Mode)
Issues:
Clash of the Titans (Maximum Movie Mode) (works great in my JVC player, PS3 all video stops starts stops starts, in power dvd it shows a weird scrambled window where the pip should be and in total media theater 3 it really acts weird like it's rewinding 5 frames then going forward 10, none of this happens with the retail copy)
Twilight (Standard PiP) (works great but turns on a subtitle when showing the school sign, even when PiP is off, I posted on their forums about this, I believe it has to do with the program removing UOPs even when this is turned off)
I'm currently redoing Clash of the Titans and doing Terminator Salvation.
But I think jdobbs would probably prefer we didn't talk about dvdfab as this is the DVD/BD Rebuilder forum.
rippn is offline   Reply With Quote
Old 7th August 2010, 08:16   #9066  |  Link
rippn
If your testing in a software player and running sound out of a SPDIF/TOSlink/Digital Out, especially in powerdvd, you need to change the sound output mode to "DTS Mixing" in order to hear the sound in PiP even on retail copies.
Old 7th August 2010, 10:42   #9067  |  Link
drmih
Okay - I have checked the discs in detail and DVDFab isn't handling DTS Express - it's just throwing it away like bd-rb. When I compared the streams from 'The Mummy' with TsMuxer, the original gives the usual message about an unsupported track, whereas the new one doesn't. There are no extra tracks (they haven't converted it to another 'non-compliant' format), so given all the limitations of DVDFab, it's not going to help with these types of disc.
Old 7th August 2010, 13:13   #9068  |  Link
jdobbs
I just don't see the point. Even if it did handle DTS Express -- that wouldn't change the fact that it would still have to be processed by BD-RB.
Let's stay on-topic with BD-RB.
Website: www.jdobbs.net
Old 7th August 2010, 18:21   #9069  |  Link
AGKnotUser
For 34.06 and earlier: New settings not saved to old project file
If I try to save new settings to an existing Project file, the settings don't get saved. I have to delete the existing file to save the new settings.
AGKnotUser is offline   Reply With Quote
Old 7th August 2010, 19:46   #9070  |  Link
drmih
I think that the person who mentioned it thought it might give you an insight how to do it if they (dvdfab) were successful. However, if it worked it would only have needed bd-rb to go to bd-5/9, as they do bd-25 as full disc - only anything lower is avchd.
Old 8th August 2010, 02:28   #9071  |  Link
discoballs
The Descent Part 2
Have a problem with full backup of The Descent Part 2. Bd rebuilder selects Aud_001 LPCM Multi-Ch English so as I wanted Aud_002 DTS-HD XLL Multi-Ch English I changed the selection to that and the sound goes out of sync all the way through. Tried 001 LPCM and the sound is in sync. Have tried a few different versions and all the same. This is the 1st of 60+ to have problems. Any ideas?
discoballs is offline   Reply With Quote
Old 8th August 2010, 13:49   #9072  |  Link
8ternity
8ternity's Avatar
Hello,
I've got to report for the version 34.06 a major error for conversion of SHERLOCK HOLMES. The exported project all makes mosaics to all bonus features. I have to report also that the conversion with the version 34.04 works #1.
Here snapshot and detailed informations:
Too much caracters to paste here has a code... so i upload a txt file that can be downloaded for both conversion (34.04 and 34.06 conversion)
http://rapidshare.com/files/41174146...4_and_3406.txt
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating.
8ternity is offline   Reply With Quote
Old 8th August 2010, 14:00   #9073  |  Link
jdobbs
Hmmm, don't think I've done any work there, but I'll check it out.
Old 8th August 2010, 14:02   #9074  |  Link
jdobbs
I'm not familiar with that one. I'll see if I can find it.
Old 8th August 2010, 14:04   #9075  |  Link
jdobbs
Originally Posted by 8ternity View Post
Hello,
Interesting. I did the US version of "Sherlock Holmes" with no issue whatsoever. It sure looks like a playback/frameserving issue. You may want to try reinstalling BD-RB and all helper apps from scratch.
Old 8th August 2010, 18:20   #9076  |  Link
KarstenS
I have a little problem with Monters vs. Aliens. I reencoded it as full disk. For main movie I selected one audio track: german dd 5.1 (there is only one german track). Rebuilding run fine. Now, when I want to play this, it plays, but I get crackled sound. I get the german sound and the audio comment at same time, but it sounds like changing between them frame by frame.
Sorry. Deleted the log already. Should check the movie before deleting them. I know.
KarstenS is offline   Reply With Quote
Old 8th August 2010, 18:33   #9077  |  Link
Capsbackup
What are you playing back the movie with, software player like TMT3, PowerDVD or standalone or PS3?
Capsbackup is offline   Reply With Quote
Old 8th August 2010, 18:38   #9078  |  Link
KarstenS
TMT3. But that should not matter. As I selected only one audio track to keep in the main movie file, there should be no audio comment at all.
I can post my settings, if it helps:
[Options]
MODE=0
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=0
AUDIO_TO_KEEP=deu;eng;ger;
SUBS_TO_KEEP=all
SD_CONVERT=1
COLOR_BOOST=0
RESIZE_1080=0
DEINTERLACE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=0
REMOVE_WORKFILES=1
FULL_AVCHD=0
REMOVE_OUTPUT=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=15000
OPEN_GOP=1
MOVIE_ONLY_LOOP=1
USE_FILTERS=0
TARGET_SIZE=15000
SHUTDOWN_SLEEP=1
[Paths]
SOURCE_PATH=E:\
WORKING_PATH=D:\Video\
Drive E is the BD-ROM.
And the Inspect:
- Windows Version: 6.1 [7600]
- AVISYNTH Version: 2.5.8.0, Ok
- HAALI Splitter:  Ok
- FFDSHOW: 3516, not recommended version
- WIN7 preferred AVC CODEC:  Ok
- WIN7 preferred VC-1 CODEC:  Ok
- WIN7 preferred MPEG2 CODEC:  Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec":  Ok
- FFDSHOW AVC set to "libavcodec":  Ok
- BD Rebuilder v0.34.0.6, Ok
- X264:  Ok
- AFTEN:  Ok
- FAAC:  Ok
- MP4BOX:  Ok
- WAVI:  Ok
- TSMUXER:  Ok
Old 8th August 2010, 19:24   #9079  |  Link
Capsbackup
This is definately an issue with TMT3! Does your backup also have PiP?
If you have PowerDVD, and could use IMGBurn to create an image of your backup, then load that image with Virtual clone or Daemon and play it with PowerDVD you will find there is no problem.
Better yet, if you could burn it to disc and play it on a standalone, you will also find no audio issues.
Old 8th August 2010, 19:33   #9080  |  Link
HWK
HWK's Avatar
[Options]
MODE=0
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=0
SUBS_TO_KEEP=all
SD_CONVERT=1
COLOR_BOOST=0
RESIZE_1080=0
DEINTERLACE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=0
REMOVE_WORKFILES=1
FULL_AVCHD=0
REMOVE_OUTPUT=0
AUDIO_TRACK_LIMIT=1
OPEN_GOP=1
MOVIE_ONLY_LOOP=1
USE_FILTERS=0
TARGET_SIZE=15000
SHUTDOWN_SLEEP=1
[Paths]
SOURCE_PATH=E:\
And the Inspect:
- X264:  Ok
- AFTEN:  Ok
- FAAC:  Ok
- MP4BOX:  Ok
- WAVI:  Ok
- TSMUXER:  Ok
Your FFDSHOW is not a correct version. That might cause problem for Bd-Rebuilder.
HWK is offline   Reply With Quote
