Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD Rebuilder
Old 22nd August 2009, 15:12   #4721  |  Link
jdobbs
Originally Posted by PurpleMan View Post
Well, I've found a bug!!
Trying to do Batman Begins, and it looks like BD-Rebuilder (0.28.03) is mixing the secondary video with the primary one.
It says it's encoding the secondary, using the secondary bitrate, but actually encoding the primary. here is the INF:
[Status]
LABEL=BATMAN_BEGINS
VERSION=v0.28.03 (beta)
SOURCE_SIZE=40040045985
SOURCE_VIDEO_SIZE=36168726528
TARGET_SIZE=25165824000
REDUCTION=.588754611708954
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
BACKUP_MODE=0
QUICK=0
ENCODE_STEP=2
[00000]
AUDIO=0100001
PGS=11111111111111111111111111111111
M2TS_TARGET=14224421144
RATE=8190
As you can see in the images, the secondary video is 480p while the primary is 1080p, yet when BD-RB claims to encode the secondary (with a low 8mbit rate) it actually encodes the 1080p primary (I've also verified using the lastcmd.txt that the AVS it encodes is indeed of the primary, not secondary).
Hope this is helpful!
I'll look, but I think it's probably just reporting it wrong. In the BD-RB tables the secondary is a subelement of the primary. I think the attributes are being reported from the primary. But stranger things have happened.
The secondary is encoded immediately before the primary, so it's probable that by the time you look at LASTCMD.TXT you're seeing the command for the primary. Can you playback the output of the secondary encode and see if it is 480p?
Website: www.jdobbs.net
Old 22nd August 2009, 15:29   #4722  |  Link
PurpleMan
No, it's definitely doing it wrong.
I checked the lastcmd.txt, it is in fact encoding the PRIMARY video using the bitrate that's supposed to be for the secondary (8mbit).
and it's the first thing that's being encoded. so if you say the 2nd track should've been done BEFORE the the primary one, then it confirms that there is indeed a problem, because the primary one is the first one being encoded (with wrong bitrate).
Edit: actually, hold on that report. I wanna test again to make sure I'm not misleading you. I'll report back.
PurpleMan is offline   Reply With Quote
Old 22nd August 2009, 16:20   #4723  |  Link
Furiousflea
I'm pretty sure your getting it mixed up, as jdobbs has said it doesn't distinguish between the video tracks in the m2ts, so it looks like it's only encoding one track. I have done batman begins with the version prior to 0.28.03 so if there does turn out to be a problem jdobbs use that for reference.
Furiousflea is offline   Reply With Quote
Old 22nd August 2009, 16:25   #4724  |  Link
Furiousflea
I'm still looking at this -- but 00002.MPLS very definitely violates the BD standard. The offset to the data block (ext_data_start_address) in the first ExtensionData() entry is required by the specification to be on a dword boundary -- and it isn't. In fact the data_block_start_address itself must also start on a dword boundary and doesn't. I'll have to see if there is a way to correct it -- but the error is very definitely on the disc, not in BD Rebuilder.
Interesting...I'm quite sure I distinctly remember doing a full backup a couple of months ago without the PiP function and didn't receive the error at rebuild. Maybe need to relax some setting for this disc alone...on other hand maybe that's abit messy. Anyways, cheers for looking into it.
Old 22nd August 2009, 16:27   #4725  |  Link
Capsbackup
@PurpleMan;
I'm not sure if this can help, but I also recently did a full movie backup to BD-25 of this movie with BD-RBV02803, and though I have deleted my files, my finished 00000.m2ts file was 14.5 GB. I kept the Dolby True HD and one 640kbps AC3 audio track as well as the DD Plus secondary audio. I seem to remember BD-RB had a bitrate set to approx. 9800kbps for the 1080P file.
BD-RB settings were:
High Quality(Default); Custom Target Size(23450 MB); Keep HD Audio.
All two-pass (Quicker Encode for Extras was NOT selected).
Total BD size finished 22.5 GB.
I am curious, if you burn your backup to BD-R/RE media and play it back on a standalone, does the movie have the audio in sync?
Mine was off by 250ms, very noticeable and not enjoyable to watch. It took some adjusting to finally get the audio in sync, but the backup looks great!
Capsbackup is offline   Reply With Quote
Old 22nd August 2009, 16:43   #4726  |  Link
leChameleon
Originally Posted by Furiousflea View Post
2. Install "VC1 Tweaker (Haali)" 64bit version.
As there seem to be many versions of this posted can you point me to the correct one? I've tried a few but either they do not install properly either error or are not listed in GraphStudio.
leChameleon is offline   Reply With Quote
Old 22nd August 2009, 17:24   #4727  |  Link
jdobbs
I believe you are mistaken. I just looked at it. The attributes of the secondary tracks are not even displayed. You are looking at the command for the primary track.
The only way to tell is to do what I asked -- look at the actual video that was encoded for the secondary track. I've just finished testing several -- and it is being done correctly.
Old 22nd August 2009, 17:28   #4728  |  Link
jdobbs
I'm glad I took the time to check this one out. I found what was caused it. Even though the table was very definitely authored incorrectly by the BD standard -- that wasn't what was causing the error. I was incrementing an index incorrectly. On most sources it wouldn't matter because there is only one entry in that table -- but in Pinnochio it had a couple hundred.
You wouldn't have gotten the error on one of the old versions because this was fairly new code. Of course on the older versions the PiP wouldn't have worked...
Good catch. Thanks.
Old 22nd August 2009, 20:22   #4729  |  Link
jdobbs
BD Rebuilder v0.28.04 (beta)
I've just updated the links in the first post of this thread to a new version of BD Rebuilder (0.28.04). Changes in this release:
- Changed the default behavior for handling
  PiP/secondary audio/video.  PROCESS_SECONDARY
  now defaults to "1" (true) and full backups will
  include secondary audio/video.
- Fixed an error related to PiP and extension data
  tables in which some timestamp entries may not have
  been updated.
- Fixed possible "CorrectMPLS()00006 2408" that may
  occur during rebuild.
- Added a specialized hidden setting that is meant
  for special circumstances. "HDDVD_COMPLIANT=1" in
  the "[Options]" area of the INI will force certain
  parameters to be used and will limit bitrate to
  that legal for HD-DVD playback.  Note:  This does
  NOT mean you can playback your output on an HD-DVD
  player.  It only means the stream will be encoded
  in a way that is compliant for certain post BD-RB
  software packages to use it in creating HD-DVDs.
  If selecting this option with BD-25, it is likely
  you will undersize due to bitrate constraints.
- Added code to better select the movie-only MPLS.
  Now when there are two large MPLSs within 10% of
  each other, the default is the 2nd largest (which
  is generally the non-extended or non-commentary
  version).  You should still check the "Alternate
  Movie-Only Playlist" just to be sure.
- Corrected an error in the CRF prediction routine.
- Updated X264.EXE to the most recent version (r1222)
- Other minor corrections and cosmetic fixes.
Old 22nd August 2009, 21:00   #4730  |  Link
setarip_old
setarip_old's Avatar
@jdobbs
"HDDVD_COMPIANT=1"
THANK YOU ;>}
setarip_old is offline   Reply With Quote
Old 22nd August 2009, 21:04   #4731  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
Will "compLiant" also work? :-P
Old 22nd August 2009, 21:36   #4732  |  Link
GaPony
That's a different update..
GaPony is offline   Reply With Quote
Old 22nd August 2009, 23:24   #4733  |  Link
jdobbs
Originally Posted by setarip_old View Post
@jdobbs
THANK YOU ;>}
Hmmm.... maybe that's why I write so little documentation. It's "HDDVD_COMPLIANT". You don't know how many times I've misspelled it "COMPLAINT"...
Old 22nd August 2009, 23:48   #4734  |  Link
Chiamos
Now see what some people have done to some of your train of thought.
Chiamos is offline   Reply With Quote
Old 22nd August 2009, 23:53   #4735  |  Link
Capsbackup
Vocabulary... very overrated!! Thats why I just say " do what I think, not what I say".
Well, I think we know what you meant anyway. Thanks for the new update.
Old 23rd August 2009, 00:01   #4736  |  Link
jdobbs
Originally Posted by focuspuller View Post
Firstly, as far as the problem I had, I was able to solve it. I simply reinstalled avisynth and everything is working again.
Related to the attempt to copy 12 Monkeys, still no go. And I tried it on a different computer, with Vista. So for the record "it's not windows 7". If I turn it into an ISO it works but there is something about this disc that simply won't work.
Now, I don't know if your post is directed toward me, but as far as your post goes, I can understand where you're coming from. You have stated that you don't support 7, but I wasn't aware of that until now.
And now I'm getting the same error on Vista.
Either way, other then this one disc, I have no problem. I enjoy using this program, and will continue to do so. I'm also very grateful for your hard work and support.
So grateful that you rated it a "1" for value for the money (I guess free isn't cheap enough) and "1" for functionality on VIDEOHELP.COM? I guess the fact that it is the ONLY program existing that does full backups of BDs to BD-25 today while still in beta doesn't get any points for functionality.
I don't think I'd hold my breath the next time you ask me for support of your "beta testing"...
Old 23rd August 2009, 00:02   #4737  |  Link
setarip_old
@jdobbs
That's on a par with all of the Christmas stories that take place in a "manager" ;>}.
The important thing is that we all "new whut jew railee ment" - and thank you for your efforts...
Old 23rd August 2009, 00:20   #4738  |  Link
MikeyBK
MikeyBK's Avatar
Don't mind the naysayers JD... you and your great software is most appreciated by the overwhelming majority. I know that I am extremely grateful to you for BD-RB.... and I know that I speak for just about everyone else here...
So much thanks Bro.... and BTW, I've nolt had any bugs to report, thus why I haven't posted too much lately on this thread.... all my back-ups are movie only BD-9s...
And lastly, focuspuller made a gramatical error... he meant to add those two 1's together..... '11' is what he should've rated it since I don't see anyone else stepping up to offer such a great software as you have to all for free, hope he donated atleast 'something' for your efforts...
MBK
MikeyBK is offline   Reply With Quote
Old 23rd August 2009, 01:48   #4739  |  Link
Furiousflea
Not sure dude, I downloaded a "pack" off rapidshare linked somewhere on this part of the forum. Only 1 of the versions of "VC1 Tweaker" in that pack worked. The rest either just hung on the encoding stage with no error, or gave a "memory access violation" error dialogue box.
In the pack there were 32\64 bit versions for each one with a batch file included you just double click to install as well as an uninstaller for each one too...
do a search typing "tweaker" or somethin and have a rummage in the threads
Old 23rd August 2009, 02:33   #4740  |  Link
focuspuller
Yes I am, and yes I did. And it's not free if you pay for it.
If you're going to bring it up then you should explain further. I rated 6 of 10 for Ease Of Use, 1 of 10 for Functionality (based on the fact that the program stopped working completely on all projects), 1 of 10 for Value For Money (for the same reason), and 4 of 10 for Overall Score. I wrote the following review:
"While it's a wonderful program, it has one major flaw. It does not support Windows 7. This will be a huge problem going forward and may not change any time soon given the comments of it's creator."
The fact stated is that you don't support Windows 7, you don't, as you have said yourself. You have also stated that "90% of the cases where you are running into an issue and you are using Windows 7, Windows 7 is the cause".
The rest is opinion, but clearly one that matters to you since you choose to address it.
Let me be clear. My comments were made (both here and videohelp.com) as a Windows 7 user, and is directed to such users. When I wrote those number ratings I based them on the fact that BD rebuilder stopped working. This fact has changed, and as things stand now, everything works with the exception of one disc. To be fair, I number scored the way I did mostly out of frustration and the assuption that BD Rebuilder wouldn't work again on Windows 7 based on your statements. If I wrote that review now, the number score would be higher, but the statement would be the same.
You say that you don't support Windows 7, and that problems related to using BD Rebuilder ("90%") are Windows 7's fault, therefore the two should not be expected to work together.
But when a user states essentially the same thing and criticizes your program, you get on the defensive. You can't have it both ways.
Your adversarial comments aside, I like this program very much. I like what it does, how it does it, and I applaud your hard work. It was not my intention to make you feel defensive. But I will not shy from saying that something doesn't work, when it doesn't (which I thought was the point of this thread, and hopefully helpful to you). I will also not apologize for being part of a growing number of users to an operating system that comes out about a month or two from now, and, in all likelihood will be the largest group of Blu-ray users/copiers.
You may have the only BD shrink program out there. But how long will that last? And how will your strategy change when the time comes?
As for "holding my breath" for help, why? Because you've been so warn, fuzzy, and helpful so far? Don't worry, I'm sure that after dropping you a donation (which I have done) that I will receive the same excellent treatment.
In closing, despite the statements I have made regarding this program's issues (which is the point of this thread) I am a fan of this program and the work that goes into it. I am one of the people you make this program for. So pick another battle because there is no battle here.
p.s. If you need details regarding my donation let me know.
focuspuller is offline   Reply With Quote
