Old 6th April 2010, 13:58   #821  |  Link
AnonCrow
Ditto, init decoder failed, on Intel P-III (Coppermine).
AnonCrow is offline   Reply With Quote
Old 6th April 2010, 14:07   #822  |  Link
juGGaKNot
juGGaKNot's Avatar
I have a sempron to test ...
Originally Posted by Dark Shikari View Post
If they can beat x264 in visual quality on ordinary test clips without postprocessing, I'll eat my hat.
juGGaKNot is offline   Reply With Quote
Old 6th April 2010, 14:31   #823  |  Link
Firebird
Unit decoder failed on Athlon XP.
Firebird is offline   Reply With Quote
Old 6th April 2010, 16:37   #824  |  Link
schweinsz
Ok, I made a mistake. Try the new one now.
The Next Generation Internet Video Codec project.
DiAVC, World's Fastest H.264 High profile Software Decoder.
http://di-avc.com/.
schweinsz is offline   Reply With Quote
Old 6th April 2010, 16:54   #825  |  Link
sneaker_ger
Crashes on Athlon XP, producing 0 byte files on the first three samples. "Tempete" produces a 888 byte file.
Old 6th April 2010, 17:16   #826  |  Link
horvathd
Running without any problem on Intel Celeron M (Banias), but it supports sse2.
d:\Letöltések\mmxtest>win32.exe mobilecalendar_720x576.264 mobilecalendar_720x576.yuv
99 frames decoded totally.
4827292 counters used by decoder and 8436200 counters used by others.
Decoding speed: 73 fps
d:\Letöltések\mmxtest>win32.exe husky_704x576.264 husky_704x576.yuv
5592124 counters used by decoder and 10880964 counters used by others.
Decoding speed: 63 fps
d:\Letöltések\mmxtest>win32.exe foreman_cif_24.264 foreman_cif_24.yuv
175 frames decoded totally.
2685747 counters used by decoder and 1648374 counters used by others.
Decoding speed: 233 fps
d:\Letöltések\mmxtest>win32.exe tempete_cif_24.264 tempete_cif_24.yuv
5605009 counters used by decoder and 1451401 counters used by others.
Decoding speed: 111 fps
d:\Letöltések\mmxtest>pause
A folytatáshoz nyomjon meg egy billentyűt . . .
horvathd is offline   Reply With Quote
Old 6th April 2010, 17:23   #827  |  Link
Selur
Selur's Avatar
Just wondering: Any news on 64bit support?
Cu Selur
Old 6th April 2010, 17:31   #828  |  Link
littleD
littleD's Avatar
Same on sempron
littleD is offline   Reply With Quote
Old 6th April 2010, 17:56   #829  |  Link
AnonCrow
On P-III , a 0 byte file produced by all; mobilecalendar and foreman without crashing, but zero output.
husky and tempete crash (command at address 0x55575653 tried to access memory at address 0x55575653 - couldn't be read)
Old 6th April 2010, 19:22   #830  |  Link
clsid
Same here on AMD Athlon Thunderbird, same addresses as well. Just tempete_cif_24.yuv has 888 byte size.
Old 6th April 2010, 23:35   #831  |  Link
schweinsz
Cu Selur
It is in plan, but after the end of the month I will start to work on it.
http://di-avc.com/.
Old 6th April 2010, 23:38   #832  |  Link
schweinsz
Fix another error, try this new one now.
http://di-avc.com/.
Old 6th April 2010, 23:48   #833  |  Link
sneaker_ger
Working fine on Athlon XP.
Old 7th April 2010, 00:39   #834  |  Link
AnonCrow
Works on the P-III (850 MHz) as well.
10309900 counters used by decoder and 26493441 counters used by others.
Decoding speed: 34 fps
11193810 counters used by decoder and 17650245 counters used by others.
Decoding speed: 31 fps
5722239 counters used by decoder and 7101862 counters used by others.
Decoding speed: 109 fps
10072194 counters used by decoder and 2839728 counters used by others.
Decoding speed: 62 fps
Old 7th April 2010, 07:56   #835  |  Link
schweinsz
Greatly! I managed to finish the mmx version.
http://di-avc.com/.
Old 7th April 2010, 10:36   #836  |  Link
travolter
@schweinsz
Do you have plans to create a Di(VC-1) decoder?
support for wmv(VC-1).
The porn industry has implemented this codec as default to release HD videos.. and these VC-1 videos need lot of cpu to move in comparison to videos with AVC codec
Probably people will think that Im crazy... that porn videos in bluray are encodec into AVC.. and yes .. they are right but think that there are two porn industries:
.- the one that release porn in bluray (AVC format)
.- the one that release videos in websites using VC-1 format
People consume more VC-1 than AVC bluray (cause its more private download a video instantly from a site to your HD than buy a bluray and wait it to arrive... maybe your wife is on the door to take the package so.. thats the cause VC-1 is becoming so popular in HD videos
travolter is offline   Reply With Quote
Old 7th April 2010, 12:37   #837  |  Link
clsid
Does it use pure MMX or also MMXext?
Old 7th April 2010, 13:16   #838  |  Link
schweinsz
It should be MMXExt, I have no plan to support very old cpu. I modify the original SSE2 assembly code to MMX code, the instructions used are same for most cases.
http://di-avc.com/.
Old 7th April 2010, 13:18   #839  |  Link
schweinsz
Originally Posted by travolter View Post
@schweinsz
After I finished all works about DiAVC including 64-bit, all post-processing, etc, I perhaps consider of it.
http://di-avc.com/.
Old 7th April 2010, 14:26   #840  |  Link
elguaxo
elguaxo's Avatar
Does the trial version already have the MMX code?
elguaxo is offline   Reply With Quote
avc, diavc, fastest decoder, h.264, software
