Old 24th March 2010, 05:19   #801  |  Link
schweinsz
Originally Posted by ExSport View Post
Hello schweinsz.
Please can you help with finding where is the problem when using DiAVC decoder in MEncoder?
When coreavc, ffdshow, Divx or internal ffmpeg is used, encoded video is OK but when DiAVC used, video has something like badly ordered frames,it shutters like on this sample: http://www.mediafire.com/?oty1dqqm2on
Sherpya's dsnative wrapper has no problems with other decoders so I am asking, do your DiAVC something in other way than "other" decoders?
When this problem will be solved, you can expect money from me
I use MEncoder in PS3MediaServer DLNA server so encoding full HD source in realtime is necessary so every additional frame in decoding speed is big deal for realtime streaming/encoding.
Many thanks
ExSport
I am sorry that I can't connect to the mediafire. Could you upload it to multiupload?
Note that the output of badly ordered frames is an appearance of an expired trial version.
The Next Generation Internet Video Codec project.
DiAVC, World's Fastest H.264 High profile Software Decoder.
http://di-avc.com/.
schweinsz is offline   Reply With Quote
Old 24th March 2010, 06:48   #802  |  Link
ExSport
Hello
Ok, uploaded here: http://www.multiupload.com/RJ5LER1JT7
Badly ordered frames in sample is not due to expired DiAVC
Sample shows "light" shutter, not "huge one" when DiAVC is expired. You can see on example.
All other external decoders works, only DiAVC not so it seems your decoder do something in other way than others
I tested it with older not-expired version posted by you in forum...it was latest 1.0.3
Many thanks
ExSport is offline   Reply With Quote
Old 24th March 2010, 07:12   #803  |  Link
schweinsz
Hello
Many thanks
The latest trial version 1.0.3 is expired about 5 days ago.
Edit1: Could you provide me the original H.264 bitstream? That will help me with the problem.
http://di-avc.com/.
Old 27th March 2010, 12:49   #804  |  Link
hajj_3
any eta on a new version and new website?
Old 27th March 2010, 15:52   #805  |  Link
schweinsz
I have finished the error concealment, add the self-setting of threads number and colorspace in property page.
I am coding for mmx version tonight.
http://di-avc.com/.
Old 27th March 2010, 23:02   #806  |  Link
Cyber-Mav
i have a pentium 133mhz computer that doesnt have mmx support. can you make diavc work on non mmx cpus too?
Cyber-Mav is offline   Reply With Quote
Old 27th March 2010, 23:32   #807  |  Link
mp3dom
Seriously, is it a joke? That CPU is 14 years old, and I highly doubt that it could even try to play an AVC file (the iPhone is an ARM at 600+MHz). I doubt that it could also have WinXP installed (maybe the 'Foundamental for Legacy PC' version)
Old 28th March 2010, 01:26   #808  |  Link
jethro
You're clearly mistaken. I bet with the power of this oldie-but-goodie CPU all his 64x32 movies would play pefectly without skipping a single frame!
jethro is offline   Reply With Quote
Old 28th March 2010, 01:32   #809  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
You are right, it doesn't. Setup aborted immediately on my old Pentium 133 MHz machine. I think 233 MHz is the minimum requirement.
Old 29th March 2010, 15:17   #810  |  Link
roozhou
WinXP requires MMX.
roozhou is offline   Reply With Quote
Old 30th March 2010, 19:33   #811  |  Link
Cyber-Mav
its running win98 se
Old 30th March 2010, 21:56   #812  |  Link
LoRd_MuldeR
Software Developer
You really can't expect any software developer to care about Windows 98 nowadays. Also many up-to-date software won't run without MMX.
Old 4th April 2010, 12:02   #813  |  Link
eddman
Could someone post the CPU usage graphs of diavc compared to coreavc instead of these useless fps benchmarks?
eddman is offline   Reply With Quote
Old 4th April 2010, 12:04   #814  |  Link
namaiki
CPU usage graphs are even less reliable.
namaiki is offline   Reply With Quote
Old 4th April 2010, 12:36   #815  |  Link
eddman
What's the most reliable method?
Old 4th April 2010, 12:38   #816  |  Link
LoRd_MuldeR
Software Developer
Yeah, CPU usage is the worst performance measure of all. What matters is average throughput (frames per second), maybe also the minimum throughput would be interesting.
Example: I can easily add dummy threats that do nothing, but keep the CPU usage at 100% all the time. Does that improve performance? Certainly not...
http://haali.cs.msu.ru/mkv/timeCodec.exe
Either look at "dfps" (more is better) or at "real" time (lower is better). And you should use the "Null" renderer, because we wan't to benchmark the decoder, not the renderer.
(For timeCodec.exe to work, Haali Media Splitter is needed)
Old 6th April 2010, 09:31   #817  |  Link
schweinsz
Need test on old cpu without sse2, such as pentium 3, athlon 32.
Download the package and unpack it, run the now1.bat, if it finishes finely, it is correct.
I coded 46 functions with mmx, so take so long times, now it is finished. I tested on my cpu and it is correct. But I can't sure that it is correct on real old cpu.
http://di-avc.com/.
Old 6th April 2010, 12:57   #818  |  Link
sneaker_ger
"Init decoder failed" on all samples on an Athlon XP.
Old 6th April 2010, 13:01   #819  |  Link
clsid
I get "Init decoder failed" on all four samples.
Old 6th April 2010, 13:35   #820  |  Link
LigH
LigH's Avatar
I could provide a Duron, but not before weekend...
German Gleitz board
avc, diavc, fastest decoder, h.264, software
