Old 31st December 2009, 04:06   #381  |  Link
Fadeout
Even with the beta there's still the "bug" with subtitles appearing 370ms or so too soon, as if the video is delayed. Same as previous versions.
Fadeout is offline   Reply With Quote
Old 31st December 2009, 04:24   #382  |  Link
leeperry
Kid for Today
Originally Posted by yesgrey3 View Post
Here are my test results using an Intel E2160@2.7GHz with 1080p material:
So the new optimizations give ~10% better performance.
how much w/ the DivX decoder?
and that'd be interesting to measure the electricity consumption w/ a wattmeter...so we'd see if CUDA really has an edge over software decoding.
Old 31st December 2009, 04:48   #383  |  Link
Fadeout
Is Graphstudio ok to measure performance? View -> Decoder Performance
With a 1080p clip at L5.1 on a Core 2 Duo E8400:
DiAVC beta: 81.3 FPS
DiAVC alpha: 72.6 FPS
CoreAVC 2: 63.0 FPS
Athlon 64 3500+:
DiAVC beta: crashes!
DiAVC alpha: 24.6 FPS
CoreAVC 2: 22.3 FPS
But on the Athlon 64 the actual use shows a very slightly lower CPU usage fore CoreAVC and it seems to behave better overall, so I don't know.
Old 31st December 2009, 07:41   #384  |  Link
schweinsz
Give my speed comparison.
Same sequences with the last comparison.
http://forum.doom9.org/showthread.ph...02#post1334702
My laptop: Core Duo T2350@1.86GHz, 1G RAM, FSB533MHz
DiAVC=DiAVC beta version 1
coreavc=coreavc2.0
timecodec, null renderer
air.mp4: 1920x1080, 5.2Mbps
DiAVC: User: 7s, kernel: 0s, total: 7s, real: 29s, fps: 286.9, dfps: 76.0
DIVX: User: 9s, kernel: 0s, total: 9s, real: 30s, fps: 245.4, dfps: 72.5
CoreAVC: User: 6s, kernel: 0s, total: 6s, real: 29s, fps: 339.5, dfps: 74.6
assembly.mp4: 1920x832, 5.5Mbps
DiAVC: User: 6s, kernel: 0s, total: 6s, real: 39s, fps: 379.3, dfps: 66.0
DIVX: User: 6s, kernel: 0s, total: 6s, real: 44s, fps: 397.5, dfps: 58.7
CoreAVC: User: 5s, kernel: 0s, total: 5s, real: 43s, fps: 450.4, dfps: 59.5
blue ray.mp4: 1920x1080, 22.9Mbps
DiAVC: User: 3s, kernel: 0s, total: 3s, real: 21s, fps: 303.3, dfps: 48.2
DIVX: User: 3s, kernel: 0s, total: 3s, real: 22s, fps: 287.2, dfps: 44.4
CoreAVC: User: 2s, kernel: 0s, total: 2s, real: 21s, fps: 381.7, dfps: 46.2
deep blue.mp4: 1440x1080, 18.9Mbps
DiAVC: User: 2s, kernel: 0s, total: 2s, real: 20s, fps: 353.1, dfps: 38.7
DIVX: User: 6s, kernel: 0s, total: 6s, real: 23s, fps: 118.0, dfps: 34.2
CoreAVC: User: 1s, kernel: 0s, total: 1s, real: 20s, fps: 469.7, dfps: 38.3
goldcurse2.mkv: 1920x1080, 29.3Mbps
DiAVC: User: 10s, kernel: 0s, total: 11s, real: 78s, fps: 278.0, dfps: 39.4
DIVX: User: 12s, kernel: 0s, total: 12s, real: 86s, fps: 250.2, dfps: 35.8
CoreAVC: User: 9s, kernel: 0s, total: 9s, real: 83s, fps: 338.0, dfps: 36.9
planet earth.mp4: 1920x1080, 11.7Mbps
DiAVC: User: 13s, kernel: 0s, total: 14s, real: 84s, fps: 295.3, dfps: 49.5
DIVX: User: 15s, kernel: 0s, total: 15s, real: 101s, fps: 264.0, dfps: 41.3
CoreAVC: User: 12s, kernel: 0s, total: 12s, real: 95s, fps: 330.9, dfps: 44.1
BillSample.mp4 (interlace): 1440x1080, 5.2Mbps
DiAVC: User: 1s, kernel: 0s, total: 1s, real: 12s, fps: 760.1, dfps: 106.7
DIVX: User: 2s, kernel: 0s, total: 2s, real: 12s, fps: 568.8, dfps: 104.6
CoreAVC: User: 1s, kernel: 0s, total: 1s, real: 12s, fps: 842.0, dfps: 110.8
withyou.mp4 (interlace): 1440x1080, 4.9Mbps
DiAVC: User: 25s, kernel: 1s, total: 26s, real: 98s, fps: 575.8, dfps: 155.2
DIVX: User: 30s, kernel: 0s, total: 30s, real: 105s, fps: 493.2, dfps: 145.3
CoreAVC: User: 20s, kernel: 0s, total: 20s, real: 98s, fps: 727.1, dfps: 154.8
kellylove.mp4 (interlace): 1920x1080, 27.4Mbps
DiAVC: User: 15s, kernel: 0s, total: 16s, real: 107s, fps: 289.4, dfps: 43.1
DIVX: User: 20s, kernel: 0s, total: 20s, real: 122s, fps: 228.8, dfps: 38.1
CoreAVC: User: 12s, kernel: 0s, total: 12s, real: 118s, fps: 375.0, dfps: 39.2
The Next Generation Internet Video Codec project.
DiAVC, World's Fastest H.264 High profile Software Decoder.
http://di-avc.com/.
schweinsz is offline   Reply With Quote
Old 31st December 2009, 08:38   #385  |  Link
hxhxd
I have a very strange result:
coreavc 2.0
User: 2s, kernel: 0s, total: 2s, real: 3s, fps: 577.1, dfps: 415.0
User: 2s, kernel: 0s, total: 2s, real: 3s, fps: 563.8, dfps: 413.3
diavc
User: 2s, kernel: 0s, total: 2s, real: 4s, fps: 533.0, dfps: 356.0
User: 2s, kernel: 0s, total: 2s, real: 4s, fps: 573.7, dfps: 358.6
ffmpeg-mt
User: 24s, kernel: 0s, total: 24s, real: 24s, fps: 62.8, dfps: 62.5
User: 24s, kernel: 0s, total: 24s, real: 24s, fps: 63.1, dfps: 62.7
divx
User: 3s, kernel: 0s, total: 3s, real: 4s, fps: 482.9, dfps: 343.4
User: 3s, kernel: 0s, total: 3s, real: 4s, fps: 462.3, dfps: 344.6
Look at the ffmpeg-mt section.
ffdshow is the svn version from xvidvideo.ru. H264 decoder is ffmpeg-mt. Why the performace is so weak?
Edit:
system is hp 380G5, 2003 ent 32bit.
hxhxd is offline   Reply With Quote
Old 31st December 2009, 08:40   #386  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Maybe multithreading isn't being activated?
Is it an interlaced sample? ffmpeg-mt won't work on PAFF H.264.
Old 31st December 2009, 08:41   #387  |  Link
ForceX
DiAVC still seems to have a lot of problem with lower level (L1.1 Baseline/Main) AVCs. Such videos in FLV give green bars/corrupted videos. But after I extracted the streams and remuxed them in MKV it was fine, however, the extraced elementary H.264 stream run through Elecard Demuxer freezes on DiAVC. DivX doesn't have such issues.
ForceX is offline   Reply With Quote
Old 31st December 2009, 08:56   #388  |  Link
hxhxd
Thanks. FFDshow's default threads is set to 1.
When set it to 8, the result is:
User: 2s, kernel: 0s, total: 2s, real: 4s, fps: 518.8, dfps: 332.9
User: 2s, kernel: 0s, total: 3s, real: 4s, fps: 508.0, dfps: 332.9
FFDshow prevents me to set thread to 0.
Old 31st December 2009, 12:11   #389  |  Link
schweinsz
CoreAVC 2: 63.0 FPS
Athlon 64 3500+:
CoreAVC 2: 22.3 FPS
The crashing on athlon64 is perhaps due to the wrong use for SSSE3.
http://di-avc.com/.
Old 31st December 2009, 14:45   #390  |  Link
ForceX
No AMD CPUs support SSSE3. Athlon64 3500+ supports upto SSE3. If some function in DiAVC relies strictly on SSSE3 code with no fallback, it'll fail on AMD CPUs.
Old 31st December 2009, 18:04   #391  |  Link
schweinsz
A new beta version is available:
changes:
Fix the bug related to low-resolution videoes
correct code for judge SSSE3
Fix a bug on parsing prefix-length sps
http://di-avc.com/.
Old 31st December 2009, 18:13   #392  |  Link
STaRGaZeR
4:2:0 hater
The beta in your link (I suppose it's the lastest) is crashing here with a Pentium M and WinXP.
Specs, GTX970 - PLS 1440p@96Hz
Originally Posted by Manao View Post
That way, you have xxxx[p|i]yyy, where xxxx is the vertical resolution, yyy is the temporal resolution, and 'i' says the image has been irremediably destroyed.
STaRGaZeR is offline   Reply With Quote
Old 31st December 2009, 18:19   #393  |  Link
schweinsz
Looks that there is a bug related to the single-thread. I will fix it as soon as possible.
http://di-avc.com/.
Old 31st December 2009, 19:45   #394  |  Link
schweinsz
Re-download it now, I added a protection to prevent the pentiumM from using SSSE3.
http://di-avc.com/.
Old 31st December 2009, 20:38   #395  |  Link
Stephen R. Savage
Stephen R. Savage's Avatar
@schweinsz: Wouldn't the correct way to handle this be to check the CPUFLAGS for the SSSE3 flag and only enable the code if it is present?
Stephen R. Savage is offline   Reply With Quote
Old 31st December 2009, 20:46   #396  |  Link
schweinsz
Previously I do this at the first release of the DiAVC beta, but two guys reports error, so I changed the code. I am not sure if the old cpu set that bit correctly.
I added a protection as follows:
__cpuid(nBuff, 0);
nHighestFeature = (u32)nBuff[0];
__cpuid(CPUInfo, 1);
nLogicalProcessors = ((CPUInfo[1] >> 16) & 0xff);
isSSSE3 = (CPUInfo[2]&0x200);
if(nProcessorType==AMD_CPU || nHighestFeature<=6) isSSSE3 = 0;
http://di-avc.com/.
Old 31st December 2009, 21:16   #397  |  Link
Fadeout
Redone tests. With a 1080p clip at L5.1 on a Core 2 Duo E8400.
DiAVC beta:
User: 2s, kernel: 0s, total: 2s, real: 18s, fps: 637.4, dfps: 79.7
User: 2s, kernel: 0s, total: 2s, real: 18s, fps: 604.0, dfps: 80.2
User: 2s, kernel: 0s, total: 2s, real: 18s, fps: 655.4, dfps: 79.7
CoreAVC2
User: 1s, kernel: 0s, total: 1s, real: 22s, fps: 770.1, dfps: 63.1
User: 1s, kernel: 0s, total: 1s, real: 23s, fps: 733.5, dfps: 62.7
User: 2s, kernel: 0s, total: 2s, real: 22s, fps: 655.4, dfps: 63.1
Still crashes on Athlon 64. And still problem with subtitles appearing too soon.
Old 31st December 2009, 23:16   #398  |  Link
schweinsz
A new version is uploaded.
The implementation of the single-thread decoding for old cpu is modified.
http://di-avc.com/.
Old 1st January 2010, 03:50   #399  |  Link
STaRGaZeR
4:2:0 hater
It still crashes here. It's curious though, MPC loads the file, starts playing it and the crash report appears instantaneously. However MPC shows "Playing" and the time counter increases normally until you accept the crash popup. Black screen in the whole process.
Old 1st January 2010, 03:53   #400  |  Link
namaiki
What's the module at fault, if it says?
namaiki is offline   Reply With Quote
avc, diavc, fastest decoder, h.264, software
