Thread Tools Display Modes
Old 6th February 2009, 01:29   #261  |  Link
neuron2
_
neuron2's Avatar
If you can provide a cut with that error in it I can investigate.
neuron2 is offline   Reply With Quote
Old 6th February 2009, 01:30   #262  |  Link
rica
Why not uploading the problematic section?
rica is offline   Reply With Quote
Old 6th February 2009, 01:36   #263  |  Link
~bT~
н∂-ƒαиαтι¢
how to provide exactly that section?
Old 6th February 2009, 02:17   #264  |  Link
rica
152170/185957= approx 82% of the movie.
If the movie is -say- 30GB then 30*0.82=24.6 GB.
So cut it roughly first with DGSplit between 24-25GB.
After you may make a precise cut in the second step.
Old 6th February 2009, 02:32   #265  |  Link
~bT~
н∂-ƒαиαтι¢
^ i'm checking the file with eac3to.. may be a re-rip is needed.
edit: the m2ts is 23.8 GB..
what do i enter in dgsplit?
edit2: this .m2ts file has 2 video streams, could that be an issue?
Old 6th February 2009, 05:47   #266  |  Link
neuron2
_
neuron2's Avatar
Select segment mode and set the starting and ending byte offsets in the file.
No.
Old 6th February 2009, 11:56   #267  |  Link
~bT~
н∂-ƒαиαтι¢
that's what i don't know, what values to enter?
Old 6th February 2009, 15:12   #268  |  Link
neuron2
_
neuron2's Avatar
It depends on what part of the movie you want to extract. For example, suppose your file size is 2000000 bytes. If you want the third quarter of the file, then you'd enter:
start = 1000000
end = 1500000
Old 6th February 2009, 16:00   #269  |  Link
neuron2
_
neuron2's Avatar
Version 1.0.4
* Added Matroska file support.
http://neuron2.net/dgvc1decnv/dgvc1decnv.html
Old 6th February 2009, 23:17   #270  |  Link
rica
Don.
Old 7th February 2009, 01:41   #271  |  Link
~bT~
н∂-ƒαиαтι¢
start = 1000000
end = 1500000
its proving too difficult for me. i can provide u the problematic vc1 sample in mkv.
edit: here it is, looks like an issue ~ frame 150..
http://www.mediafire.com/?sharekey=3...db6fb9a8902bda
Old 7th February 2009, 02:55   #272  |  Link
neuron2
_
neuron2's Avatar
I'm not interested in anything you've re-encoded/re-muxed. I'm interested only in the original file from the disk. Sorry.
Old 7th February 2009, 13:31   #273  |  Link
Snake91
I have opened the dgv with Notepad and I have seen these errors (thsi is an example
SEQ 902175582 !INTERLACE PULLDOWN
ENTRY 902175607 !BROKEN CLOSED
Will I have problems in encoding? Is the stream broken? (The stream comes from Journey to the Center of Earth BD)
Snake91 is offline   Reply With Quote
Old 7th February 2009, 14:51   #274  |  Link
neuron2
_
neuron2's Avatar
They are not errors:
http://neuron2.net/dgvc1decnv/DGVC1I...html#AppendixA
Old 7th February 2009, 19:34   #275  |  Link
Snake91
Thanks, I would have read before the manual before asking
PS Can I ask if MPEG2 version is still in your 8future) plans? I think it's worth for purevideo deinterlacer
Old 8th February 2009, 01:42   #276  |  Link
neuron2
_
neuron2's Avatar
I had a little regression for transport streams in 1.0.4. I've just updated the ZIP file rather than make a new release. Please re-download it. GOP stepping was not working good for transport streams.
Old 9th February 2009, 10:18   #277  |  Link
~bT~
н∂-ƒαиαтι¢
just a lil request: will it be poss for you to rename readmefirst.html (or any other extra files) in future releases pls to vc1readmefirst.html and avcreadmefirst.html?
thanks.
Old 13th February 2009, 03:20   #278  |  Link
neuron2
_
neuron2's Avatar
Version 1.0.5
1. Fixed GOP stepping for transport streams.
2. Fixed blocking on seeks with deinterlace=1.
3. Fixed false sync lock for M2TS files.
4. Fixed problem where stepping by GOP backward could wrap from the start of the file to the end of the file.
5. Closing the window while a play/preview is running caused a CUVID popup error. Fixed.
6. Enable "Disable Display" option only after a file is loaded. This prevents a crash scenario.
7. Fixed nvcuvid.dll memory leak.
8. Updated CUVID Server to version 1.0.4.
Old 13th February 2009, 05:34   #279  |  Link
neuron2
_
neuron2's Avatar
No problem. Thank you for the suggestion. It's implemented in the releases just made.
Old 13th February 2009, 10:06   #280  |  Link
~bT~
н∂-ƒαиαтι¢
tyvm for the updates Don!
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
