Thread Tools Display Modes
Old 12th January 2009, 23:38   #241  |  Link
rica
Nothing to say anything else but just
I don't see anything wrong with asking for the demuxing to extract core audio if possible. I'll look into it, just as I am looking into supporting MKV. I'm open to any and all feature requests and appreciate all feedback.
rica is offline   Reply With Quote
Old 20th January 2009, 22:56   #242  |  Link
resonator
Searched the thread but couldn't find anything about that, but -- Is there something EXTRA that HAS to be installed NVidia-wise? I've tried to get it working on a Macbook Pro (Bootcamp XP) with a 8600M GT which should be working according to the PureVideoHD table, yet, I still get only an error message.
EDIT: In case there is, maybe we should quick-summarize the setup.
resonator is offline   Reply With Quote
Old 20th January 2009, 23:14   #243  |  Link
neuron2
_
neuron2's Avatar
You have to install the latest Nvidia drivers. You have to put nvcuvid.dll in your search path.
What error message are you getting?
neuron2 is offline   Reply With Quote
Old 21st January 2009, 15:18   #244  |  Link
resonator
Hmm, installed the latest "notebook drivers" from NVidia site. Now, by search path, do you mean the set variable "path"? (like set path=so and so in the DOS days, now found in I did add the path to DGVC1Dec folder (where nvcuvid.dll is residing), still I get "GPU decoder: Failed to create video decoder [100]".
Tried an elementary VC1 stream, demuxed from an HD-DVD EVO file by EVODemux. Should I try a different demuxer?
Old 21st January 2009, 15:53   #245  |  Link
neuron2
_
neuron2's Avatar
I mean put the DLL in your system32 directory.
What is Bootcamp XP and what is a Macbook? If this is not running on stock Windows I'm afraid you are on your own. CUVID requires standard DirectShow stuff.
Old 21st January 2009, 16:02   #246  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
What is Bootcamp XP
Bootcamp is Apple's utility to install Windows on a Mac (mainly a fancy bootloader + some drivers because Macs don't have a BIOS)...
Some fancy notebook with a logo of an apple that someone took a bite out of already...
Well, it IS a standard Windows installation...
now playing: [artist] - [track] ([album])
Leak is online now   Reply With Quote
Old 21st January 2009, 16:20   #247  |  Link
neuron2
_
neuron2's Avatar
Put nvcuvid.dll into the sytem32 directory and install the latest Nvidia drivers. If that doesn't work run the CUVID sample decoder from the CUVID SDK. If that doesn't run contact Nvidia for support. If it does, post again to let me know.
Old 22nd January 2009, 14:57   #248  |  Link
resonator
After doing some research it seems as if the problem lies with XP and notebook graphics. I had problems like that before audio-wise (I use DAWs a lot, both Cubase and Pro Tools), but so far nothing in terms of simple video-playback. Anyway, I was advised to install Vista, but I'll use the opportunity to install the Windows 7 Beta. I'll let you know if that changes anything.
Old 24th January 2009, 20:20   #249  |  Link
Sharc
Just an observation:
When the CUVID server is being used for an encode (application 1) and at the same time by another application 2 (e.g. mpc for viewing) both outputs get garbled (the encode and the playback), or CUVID may even crash.
Old 24th January 2009, 21:26   #250  |  Link
neuron2
_
neuron2's Avatar
You shouldn't do that.
Old 1st February 2009, 15:34   #251  |  Link
neuron2
_
neuron2's Avatar
MKV support
Here's a test version for MKV container support.
http://neuron2.net/dgvc1decnv/dgvc1denv104test.zip
Old 1st February 2009, 18:08   #252  |  Link
rica
It is working, thanks a lot.
Now i've been transcoding it with MeGui
Old 1st February 2009, 22:46   #253  |  Link
rica
This is the transcoded file with MeGui, served with DGVC1NV-test:
http://www.sendspace.com/file/f94axk
_ _ _ _ _
Old 2nd February 2009, 01:02   #254  |  Link
~bT~
н∂-ƒαиαтι¢
what do you mean?
Old 2nd February 2009, 19:08   #255  |  Link
rica
Originally Posted by ~bT~ View Post
what do you mean?
either am i
You're right; it is not clear.
I meant "transcoding the original media"
Here is the way i go:
Getting dgv via DGVC1NV and frameserving to MeGui over CUVIDServer.
_ _ _ _ _
Old 6th February 2009, 00:06   #256  |  Link
~bT~
н∂-ƒαиαтι¢
what is this error?
for encoding to continue, i must click ok.
Old 6th February 2009, 01:02   #257  |  Link
neuron2
_
neuron2's Avatar
It means that your stream has a problem. Is it at the beginning, end, or in the middle?
Old 6th February 2009, 01:10   #258  |  Link
~bT~
н∂-ƒαиαтι¢
looking at the progress, i see its stopped @ frame 152170 out of 185957.
Old 6th February 2009, 01:25   #259  |  Link
neuron2
_
neuron2's Avatar
May I ask what the stream is?
Old 6th February 2009, 01:26   #260  |  Link
~bT~
н∂-ƒαиαтι¢
its the bluray of the matrix revolutions.
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
