Thread Tools Display Modes
Old 11th October 2008, 18:01   #1  |  Link
Greif
New eac3to GUI: HD-DVD/Blu-Ray Stream Extractor
This project is hosted on Google code found here.
Changelog
0.8 - fixed missing THD extract options, migrated to .NET 4 Client Profile
0.7 - reduced CPU utilization for GUI, pre-selected "extract as" dropdowns, other small fixes
0.6 - fixed stream "extract as" dropdowns and audio types
0.5 - proper version tracking will commence after this release
SVN changes can be tracked here.
Description
HD-DVD/Blu-Ray Stream Extractor is a GUI for the excellent tool eac3to developed by madshi. The front-end is intended to be included with MeGUI to provide stream extraction capabilities but will also be available in a stand-alone format.
Support for the tool can be found in this thread. The tool is also incorporated into MeGUI, help can also be found on the MeGUI wiki.
If you are experiencing issues with the tool, please create a new issue and attach the logs with your bug report.
Installation
  • Download the latest stable release or the current svn using the links below
  • The .NET 4 Client Profile redistributable is a prerequisite for the tool.
  • - Download HdBrStreamExtractor and extract to eac3to folder
Downloads
Enjoy!
Greif is offline   Reply With Quote
Old 11th October 2008, 18:37   #2  |  Link
menlvd
what's wrong
menlvd is offline   Reply With Quote
Old 11th October 2008, 18:43   #3  |  Link
spida_singh
not working here either, just get an error stating program has stopped working
spida_singh is offline   Reply With Quote
Old 11th October 2008, 18:50   #4  |  Link
Greif
Sorry, it was compiled against .NET 3.5 and using a couple of extension methods.
I recompiled to .NET 2.0 and made the extension method regular old methods.
You should be ok now. Try downloading again and let me know the results.
Old 11th October 2008, 19:23   #5  |  Link
kurt
sidekick
kurt's Avatar
gui is working now. but why it can only open mpls? wouldn't it be nice to process directly from m2ts too?
greets, kurt.
Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC
kurt is offline   Reply With Quote
Old 11th October 2008, 19:36   #6  |  Link
menlvd
1. puting imput G:\Blu_Ray\Scary Movie 4
got error [22:25:58] Source file "G:\Blu_Ray\Scary" not found.
2. no manual entering extensions for extracted stream
Old 11th October 2008, 19:41   #7  |  Link
Greif
If you point it to the folder of your HD-DVD or Blu-Ray drive (while running anydvd) or to your rip folder, it should list all features found in the specified folder.
@menlvd: what do you get when you run the following at a command prompt:
eac3to.exe G:\Blu_Ray\Scary Movie 4
Old 11th October 2008, 19:47   #8  |  Link
menlvd
prog needs put this line too ""
Old 11th October 2008, 19:49   #9  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Ok, now works thanks
I quicktested, and i get error when tryed to demux HDDVD when i press streams button, program just closed.
On bluray sources everything working fine for now.
I noticed small bug in filenames
and small suggestion, for video stream you should add support for extract to raw streams instead MKV
shon3i is offline   Reply With Quote
Old 11th October 2008, 20:07   #10  |  Link
rica
Further processing of VC1mkvs on TSMuxer is always a big problem. So extracting raw media is a better idea.
rica is offline   Reply With Quote
Old 11th October 2008, 20:38   #11  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Agree, it's better to add both options and user choose what need.
Old 11th October 2008, 21:34   #12  |  Link
Greif
Thanks for the input. I'll have an update out soon.
Old 11th October 2008, 23:59   #13  |  Link
Greif
Updated:
- BUG: spaces in path
- ADD: video extract type(s)
- ADD: feature number in extract filename
Old 12th October 2008, 00:13   #14  |  Link
menlvd
Updated:
need file ext for audio .w64 and .AGM
Old 12th October 2008, 00:23   #15  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
I still get crash for HDDVD titles when press streams button
Old 12th October 2008, 00:31   #16  |  Link
Greif
Updated:
- ADD: audio extract types: AGM, RF64, W64
Old 12th October 2008, 00:34   #17  |  Link
Greif
could you provide the output from eac3to for whichever feature you're trying to get streams for?
eac3to.exe [source] [feature#])
Old 12th October 2008, 00:40   #18  |  Link
saint-francis
too much lurking
saint-francis's Avatar
It seems to work well with the one stream I have currently tested it with. But not being able to see the details of the different playlists at once is a big problem for some sources. Eac3toGUI does a really good job of displaying all of the playlists.
All in all it's a pretty good straight forward tool.
saint-francis is offline   Reply With Quote
Old 12th October 2008, 00:56   #19  |  Link
Greif
For choosing features based on duration, angles, or version (eg Director's Cut)... yeah, I need to think about how to better display this information.
I could display a feature grid with all the relevant information. Would that work?
Old 12th October 2008, 01:01   #20  |  Link
saint-francis
too much lurking
feature grid
Could you explain this term a little more?
eac3to, hdbrstreamextractor
Thread Tools
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
