Thread Tools Display Modes
Old 12th February 2009, 11:18   #981  |  Link
~bT~
н∂-ƒαиαтι¢
^ i'm a 100% sure it didn't coz i was waiting for the overwrite confirmation to pop up.
or is it card dependant? i have 8600gs.
Old 12th February 2009, 11:49   #982  |  Link
squid_80
Originally Posted by squid_80
All nvidia driver versions AFTER 181.20 should include nvcuvid.dll.
squid_80 is offline   Reply With Quote
Old 12th February 2009, 11:56   #983  |  Link
~bT~
н∂-ƒαиαтι¢
^ lol, gotcha. so we are both correct
Old 12th February 2009, 14:08   #984  |  Link
Audionut
Originally Posted by squid_80 View Post
All nvidia driver versions after 181.20 should include nvcuvid.dll.
They don't. I've installed 181.21, 181.22 and an old 185.xx beta.
None have included it.
I will give some thought to a solution that doesn't require multiple copies and doesn't overwrite the version installed by the Nvidia driver install. Ideas are welcome.
My l33t programing skills are showing here.
Can you include the dll into the exe's?
Aren't you combing all 3 decodeNV's into the same exe? Then you would only have the 1 exe and 1 dll.
Can you run a check on the version of the dll in system32 folder and overwrite with your copy if newer?
Create installers. Overwrite dll in install folder if its older than the new decodenv being installed.
I really don't see the problem though. Download zip, Extract, run exe.
http://www.7-zip.org/
Old 12th February 2009, 14:21   #985  |  Link
menlvd
what can be wrong
last dgavcdecnv
sys win7 x64
drv 181.22
using 2 pass encoding
1 pass processed fine, but 2 even start (w/o manual close and starting again CUVIDServer.exe)
in sys wxp-sp3 32 everything is fine
menlvd is offline   Reply With Quote
Old 12th February 2009, 14:40   #986  |  Link
neuron2
_
neuron2's Avatar
What encoder and encoding GUI do you use?
neuron2 is offline   Reply With Quote
Old 12th February 2009, 14:57   #987  |  Link
menlvd
latest x264 1109 x64
not using gui
simple run from scrip or run from cmd
sample
"D:\minep\me_gui\tools\x264\avs2yuv.exe" -raw "D:\temp\bd-taken\taken.dga.avs" - | "D:\minep\me_gui\tools\x264\x264.1109.kMod.core2.x64.exe" --pass 1 --bitrate 11000 --vbv-maxrate 40000 --vbv-bufsize 62500 --keyint 240 --min-keyint 1 --ref 5 --bframes 3 --deblock -3,-3 --partitions all --8x8dct --me umh --trellis 2 --subme 9 --weightb --mixed-refs --no-fast-pskip --threads 6 --no-psnr --no-ssim --level 4.1 --progress --aq-mode 1 --aq-strength 1.7 --psy-rd 1.1:0.1 --b-adapt 2 --output "d:\123.mkv" --sar 1:1 --direct auto --no-dct-decimate --b-pyramid --qpmax 35 --qcomp 1 --qpmin 5 --ratetol 3 --merange 24 --pbratio 1.2 --ipratio 1.3 --stats "d:\stats.stats" - 1920x816
and then try to start second pass but no progress w/o restart cuvidsrv
will try install latest forceware 182.05, but i'll don't think thats solve problem
Old 13th February 2009, 02:36   #988  |  Link
neuron2
_
neuron2's Avatar
Version 1.0.12
1. When serving video, replace copies of leading orphaned B frames with copies of the first decodable frame.
2. Fixed blocking on seeks with deinterlace=1.
3. Fixed false sync lock for M2TS files.
4. Fixed problem where stepping by GOP backward could wrap from the start of the file to the end of the file.
5. Closing the window while a play/preview is running caused a CUVID popup error. Fixed.
6. Enable "Disable Display" option only after a file is loaded. This prevents a crash scenario.
7. Fixed nvcuvid.dll memory leak.
8. Update CUVID Server to version 1.0.4.
http://neuron2.net/dgavcdecnv/dgavcdecnv.html
Old 13th February 2009, 02:40   #989  |  Link
neuron2
_
neuron2's Avatar
@menlvd
I don't have win7 x64 so I'm not sure how to help you.
What happens without the avs2yuv.exe silliness? In other words, just open the script directly with x264.
Old 13th February 2009, 03:15   #990  |  Link
squid_80
Hmm seems I missed noticing 181.22 had jumped from beta to offical. So any official drivers after 181.22 should include nvcuvid.dll.
I don't know where you've got the 185.xx beta from, sounds wrong to me since the beta driver released earlier this week is 182.05.
Old 13th February 2009, 06:06   #991  |  Link
menlvd
@menlvd
w/o avs2yuv.exe run only x86 x264.exe - but no problem
seems to be a avsyuv produce bug that can cause broblem with cuvidsvr
Old 13th February 2009, 08:21   #992  |  Link
xopowo
Unfortunately, I just replaced everything with the new version(s) and the memory leak is still incredibly bad
Here is the AVS script I'm using ...
LoadPlugin("C:\encode\Dlls\DGAVCDecodeNV.dll")
AVCSource("1.dga")
selecteven()
That's it. Nothing more when doing a 720p source to bring it back to 29.97fps from 59.97
OS - Windows 7 (64-bit) Build 7000
CPU - Intel Xeon x3360
Memory - 4GB DDR2 800
Video - nVidia GeForce 9600 GSO (768mb)
Avisynth - 2.57
VirtualDubMod 1.5.10.2 (virtualdub doesn't work for me)
7 minutes into the encode, and CUVIDServer.exe went from 23772k (at launch) to 644040k.
Longer encodes, the server crashes (when it eats about 1.7gb of memory). There is a dialogue box that pops up that just says "server" and an 'OK' button (nothing legible).
I don't know what to tell you other than even with the new version, it still leaks badly.
nvcuvid.dll has to be located in \Windows\System\ in order for it to work for me (as opposed to \system32\)
Let me know if you need more information.
I just tested the same exact avs file with VirtualDub version 1.8.8 (32-bit version) and the same exact results. CUVIDServer.exe crashed on that one 18:47 into the encode with memory at 1,688,596K ... yikes!
xopowo is offline   Reply With Quote
Old 13th February 2009, 10:36   #993  |  Link
meatwad
meatwad's Avatar
xopowo, I believe it's a Windows 7 problem. I experienced the same thing with the 32 bit version. The same jobs in XP went through without a hitch.
meatwad is offline   Reply With Quote
Old 13th February 2009, 14:27   #994  |  Link
neuron2
_
neuron2's Avatar
Me too. I'll mention it to Nvidia to see what they think.
Old 13th February 2009, 17:00   #995  |  Link
laserfan
Aging Video Hobbyist
I just had an unexpected result in an encoding: I had used eac3to to make an .mkv file, indexed it with v1.0.11 and re-encoded with x264, and my encode is "off" by 3 frames from the original, messing-up the I-frames I'd specified and thus my chapter marks. Puzzling over this I noticed my XP Pro x64 setup has your updated nvcuvid.dll in my SysWOW64 directory, but an older version from 16-Dec-08 in my system32 folder. Brand-new to 64-bit OS, I'd read that (counterintuitively) 32-bit dlls were to go into SysWOW64 and 64-bit into system32 (so the older nvcuvid.dll must likely be from my Nvidia 9600display card driver installation).
Should I have placed the 08-Feb-09 (new) nvcuvid.dll into system32 instead, replacing the one that's there? Trying to sort this before I re-run my encoding (8 hours) with the newer 1.0.12...
UPDATE: Well I put DG's nvcuvid.dll into system32 and rebooted and it didn't crash. Realized also that I run CUVID Server from its own directory so tried using procexp to ID which dll it was using. Can't tell--neither the Dec version nor DG's identifies itself in any way that I can tell. Guess if no one has advice for me I'll try 1.0.12 and do it again (hell I dunno if this has anything to do with frames being "off" anyway)...
UPDATE2: And in fact it doesn't seem to be the problem--I still am "off" by 3 frames. Going to start-over from scratch, extracting as .h264 not .mkv.
Still, would appreciate if someone knows if replacing nvcuvid.dll everywhere (sysWOW64, system32, every tool location) is the right thing to have done. That's where I'm at now.
laserfan is offline   Reply With Quote
Old 14th February 2009, 01:00   #996  |  Link
neuron2
_
neuron2's Avatar
Everybody please re-download 1.0.12. It had a bad bug in DGAVCDecodeNV.dll.
Old 14th February 2009, 01:27   #997  |  Link
neuron2
_
neuron2's Avatar
@laserfan
Put my nvcuvid.dll into the same directory as DGAVCIndexNV.exe. Also, put it in the same directory as CUVIDserver.exe, if that differs from the former. Then you won't have to put it in a system directory.
Regarding your three-frame discrepancy, redownload 1.0.12 and try with that. If it still occurs tell me how to duplicate it, providing a stream if necessary.
Old 14th February 2009, 02:08   #998  |  Link
laserfan
Thanks--I suspected maybe the .exes would take the "path of least resistance" to find the .dll but wasn't sure.
Re: 3 frames off, I have a couple other things to try (along w/your fixed version) and appreciate your offer of help!
Old 14th February 2009, 08:31   #999  |  Link
jj666
The 185.20 driver was alpha quality and not officially released, there's a comment from a mod here that says it is not recommended for use by Nvidia due to broken functionality:
http://www.nvnews.net/vbulletin/show...1&postcount=28
Cheers,
-jj-
jj666 is offline   Reply With Quote
Old 14th February 2009, 20:24   #1000  |  Link
laserfan
My "3 frames off at start" problem is no more. Thanks for making this available on a Friday night!
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
