#942 | Link |
_
![]() Join Date: Jan 2002
I'd really appreciate it if you'd say if you think there's a problem and what it is.
You may need to download it again as I updated it shortly after posting the new version. The demuxed .flac plays fine in WinAmp. Be aware that I demux to raw flac, while mkvextract by default puts it into an ogg wrapper. Do you need it to be in an ogg wrapper or are you drawing my attention to something else? |
#946 | Link |
_
Version 1.0.11 rc1
* Fixed a bug in the handling of multiple slice frames. This affected the stream provided by rica, so update to this version for proper handling of the stream.
* Added CLI support for audio demuxing for MKV files. * Updated the users manuals. http://neuron2.net/dgavcdecnv/dgavcdecnv1011rc1.zip |
#949 | Link | |
Thanks snow; dtsHD-HR and dtsHD-MA is supported by mkvmergegui. Here is the method i used: Demux/remux video to mkv and demux audio to dts with eac3to 3.0.5 and remux to mkv with mkvmergegui 2.4.2. Here are the results: Code:
General
Complete name : C:\Users\rica\Desktop\TEST\video_dtsHD.mkv
Format : Matroska
File size : 37.0 MiB
Duration : 8s 50ms
Overall bit rate : 38.6 Mbps
Encoded date : UTC 2009-01-31 19:13:05
Writing application : mkvmerge v2.4.2 ('Oh My God') built on Jan 18 2009 17:30:28
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Container profile=Unknown@0.0
Codec ID : V_MPEG4/ISO/AVC
Duration : 8s 41ms
Bit rate : 34.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Standard : NTSC
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.684
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : HRA
Codec ID : A_DTS
Duration : 8s 50ms
Bit rate mode : Constant
Bit rate : 3 045 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
General
Complete name : C:\video_dtsMA.mkv
Format : Matroska
File size : 23.2 MiB
Duration : 9s 426ms
Overall bit rate : 20.6 Mbps
Encoded date : UTC 2009-01-31 20:00:47
Video
Format : AVC
Format settings, ReFrames : 2 frames
Duration : 9s 416ms
Colorimetry : 4:2:0
Audio
Format : DTS
Format profile : MA
Codec ID : A_DTS
Duration : 9s 426ms
Bit rate mode : Variable
dtshd-HR: http://www.mediafire.com/?sharekey=a...5965eaa7bc68bc dtshd-MA: http://www.sendspace.com/file/g9fzhm Previous test version extracts those audio files. Here it is: (you have to put your own licence.txt instead of the fake one i put.) [link deleted] while 1.0.11 rc1 can not. _ _ _ _ Last edited by neuron2; 1st February 2009 at 01:40. Reason: Please don't link my withdrawn test versions |
#950 | Link |
_
I fixed the problem with audio demuxing. Please redownload rc1.
http://neuron2.net/dgavcdecnv/dgavcdecnv1011rc1.zip Thanks for pointing it out, rica. |
#952 | Link |
The serial number that was generated for me when I bought the license works ... on WinXP. Now that I'm using Win7 (xp is jacked up), the same serial won't work. How does one generate a new number? Or is it just a matter of asking? I'm using the same computer, so don't know why anything would be different, but who knows.
#953 | Link | |
#954 | Link |
@neuron2, I've just added MKV demuxing to eac3to, too. You may want to peek into the eac3to thread once in a while cause users are posting funny MKV samples there to keep me busy. Just in case you're interested in collecting more strange samples...
#958 | Link |
Has anyone been able to use the GPU deinterlacer with StaxRip? The problem is that I can't alter the avs file to add the line to AVCSource. Even if I try to manually edit the avs file StaxRip still won't process it. I'll ask in the StaxRip Forum as well if no one here has been successful.
Could there possibly be an alternate form of syntax I could use to get the Nvidia Deinterlacer to work? I can easily add it in the line below it like any other function, just not on the AVCSource line: AVCSource("%source_file%") deinterlace=true Naturally that doesn't deinterlace, but it crashes if I try to alter it to this: AVCSource("project.dga", deinterlace=true) Last edited by meatwad; 6th February 2009 at 14:29. |
#959 | Link |
it's deinterlace=1
AVCSource("project.dga", deinterlace=1) http://neuron2.net/dgavcdecnv/DGAVCDecodeNVManual.html |
| Thread Tools | |
| Display Modes | |
