Old 2nd January 2009, 21:16   #841  |  Link
ultratoto14
Ok thanks
ultratoto14 is offline
Old 3rd January 2009, 13:23   #842  |  Link
crypto
@DVBPortal
crypto's Avatar
Yes. You need to resize anamorphic video in your Avisynth script.
Or, from the quality aspect, it would be better to keep it this way and flag the recode as anamorphic.
crypto is offline
Old 4th January 2009, 11:38   #843  |  Link
jonathonsunshine
the following were my results from encoding a 1080p avc stream croppped at resized to 1280x528 (via avisynth). I did it the three different ways that I know, of dgAVCdec , dgAVCdecNV and finally, wrapping the stream in the matroska container and loading it with directshowsource
The stream was 20 seconds and had an average bitrate of 30 and a max of 41
I am encoding with 2gb ddr2 ram, 1066mhz, a Intel CPU, Q6600 / GeForce 8800GS 384mb DDR3 ram.
1st pass 2nd pass
dgAVCdec 100a26
14.61 fps 7.55 fps
dgAVCdecNV 108
23.76 fps 8.11 fps
ffdshow-libav
19.73 fps 7.65 fps
to be quite frank, I was really expecting a bit more...
So um... I'm not a programmer but are there any plans for down the line, having the GPU handle cropping and resizing as well ?
I took the encoded 1280x528 steam, indexed and encoded it the three different ways without any resizing and got the following results.
1st pass 2nd pass
dgAVCdec 100a26
26.52 fps 9.98 fps
dgAVCdecNV 108
30.19 fps 10.14 fps
ffdshow-libav
26.96 fps 10.00 fps
So it would appear to me that offsetting the decoding of the stream itself bears very little benefit but if it could be used also to handle resizing of the image, then that would result in a 30% speed increase.
On another note, (and I did 1st do a search of the thread for "saver" and didn't find anything but i'm sure this has point has been raised before), I have had to disable the screensaver.
Last edited by jonathonsunshine; 4th January 2009 at 11:42. Reason: i had a nice little table made up of the different FPS, but on the board, all the spaces were taken out.
jonathonsunshine is offline
Old 4th January 2009, 13:25   #844  |  Link
Selur
Selur's Avatar
@jonathonsunshine: "to be quite frank, I was really expecting a bit more..." Why? Decoding normally is not the major work that needs to be done during reencoding to h264. If you use high speed settings with (--me hex, --subme 1,..) speed difference might be higher, since decoding speed will become a greater factor.
Selur is offline
Old 4th January 2009, 14:16   #845  |  Link
Audionut
As can be seen from the first pass encoding times. Much greater difference.
Audionut is offline
Old 4th January 2009, 14:24   #846  |  Link
yesgrey
I've noticed two small errors in DGAVCIndex (and NV) User Manuals, in the DGV Format section:
1-"DGAVCIndexProjectFile" should be "DGAVCIndexFile" or "DGAVCIndexFileNV"
2-"AUD 80,c0" should be "AUDIO 80,c0"
yesgrey is offline
Old 4th January 2009, 14:46   #847  |  Link
yesgrey
The d2v files included the colorimetry info. Is this information also included in the dga files? It's shown in the info dialog during the project creation, but I cannot find it in the dga file...
yesgrey is offline
Old 4th January 2009, 15:07   #848  |  Link
rack04
Originally Posted by jonathonsunshine View Post
dgAVCdec 100a26
Why are you using such and old version?
http://neuron2.net/dgavcdec/dgavcdec108.zip
Well Frank, it might serve you well to read this.
On some machines there may be a small performance improvement, but the main purpose of using CUDA is to get correct decoding for the streams that are not handled by libavcodec, and to access some of the post-processing capabilities of CUDA.
rack04 is offline
Old 4th January 2009, 16:02   #849  |  Link
And to get a VC-1 source filter that supports random access.
Guest is offline
Old 4th January 2009, 16:09   #850  |  Link
I'm not a programmer but are there any plans for down the line, having the GPU handle cropping and resizing as well?
Thanks for your test results and the information about screensavers. I will ask Nvidia about your question above.
Guest is offline
Old 4th January 2009, 16:09   #851  |  Link
Thank you for pointing these out.
Guest is offline
Old 4th January 2009, 16:10   #852  |  Link
It's not in the DGA file but it is in the log file.
Guest is offline
Old 4th January 2009, 17:27   #853  |  Link
yesgrey
Thanks. I think it would be safer to also put it in the dga, in case we delete the log... but ok, I just have to be carefull and only delete the log after all the work has been done.
yesgrey is offline
Old 4th January 2009, 18:39   #854  |  Link
hajj_3
has development started on an ATI version of this app yet neuron or are you waiting for their equivalent of CUDA to improve or waiting for API's that will allow you to create an ATI version?
This app is looking very nice indeed.
hajj_3 is offline
Old 4th January 2009, 19:04   #855  |  Link
How do you expect me to do anything in the absence of an API?
Guest is offline
Old 4th January 2009, 19:17   #856  |  Link
hajj_3
ahh, didnt realise they hadn't released the API's, are they planning to release them or have they not released any info about their plans with API's?
hajj_3 is offline
Old 4th January 2009, 19:22   #857  |  Link
Off topic for this thread and you'd have to ask them. I am not privy to their business plan.
Guest is offline
Old 6th January 2009, 09:24   #858  |  Link
Chefkoch_ico
regarding license.
I just donated and got the license.
I am going to return my new graphics card and get a different one ("Point of View" vs EVGA, both 9600GT) since its too loud and the fan not controlable. Not automatic or by software.
Do I need a new license for it afterwards?
Best regards
Chefkoch_ico is offline
Old 6th January 2009, 14:49   #859  |  Link
You won't need a new license.
BTW, my BFG 9600GT was making noise too, but it was a subtle "chirping". It turned out to be a small piezoelectric speaker intended to alarm an undervoltage condition. I'm sure there was no undervoltage. Anyway, I just covered the little exit hole of the speaker and it's inaudible now.
Guest is offline
Old 9th January 2009, 21:39   #860  |  Link
Version 1.0.9
1. Added support for the new audio types found on BluRay disks.
2. Improved the audio delay calculation.
3. Removed the Treat I as IDR option as it is now always enabled.
4. Machine ID now not tied to system partition, so machine ID changes will be rare.
5. Updated the CUVID server to 1.0.3.
http://neuron2.net/dgavcdecnv/dgavcdecnv.html
Guest is offline
