Old 23rd October 2008, 04:14   #581  |  Link
Things are still bubbling. The thing is that ideally I'd like to be able to support a script like this:
a=AVCDecode("file.dga").reverse()
b=AVCDecode("file.dga")
interleave(a,b)
...which with a file of frames 0-95 would give:
95 0 94 1 93 2 92 3 ...
In other words, a script should support multiple independent AVCSource() instances. The script above worked with earlier versions of nvcuvid.dll when opening with VirtualDub. But now there are two problems:
1. Doing this with the latest nvcuvid.dll crashes. Nvidia has been informed.
2. It never worked with the managed apps like MEGUI, which crashed when trying to instantiate a second decoder instance.
Assuming that Nvidia can fix 1 leaves us still with 2. 2 can be fixed either with the server model (working fine) or the floating context model (working with issues probably solvable). But both these solutions preclude ever doing the multiple independent decodes, because only one decoder is ever instantiated.
It seems like a big loss to give up multiple instantiation. So I'm tempted to hold off on the server model rollout and work the issues 1 and 2 some more in hopes of solving them. But then users won't have a MEGUI solution in the meantime.
Or I can rollout the server now and perhaps have to abandon it later. One advantage of the server model is that the decoder code is always in one place and fixing bugs there, or adding features there, fixes all applications that use it. And the server model is simple and robust. So there's something to be said for the server model.
So I don't know what to do. Your thoughts will be appreciated. Is it really so bad to lose multiple instantiation?
Guest is offline
Old 23rd October 2008, 04:17   #582  |  Link
Sagekilla
x264aholic
Why would you have to abandon the server model though? It seems like it has no disadvantages.
Sagekilla is offline
Old 23rd October 2008, 04:21   #583  |  Link
I'd abandon it if issues 1 and 2 were solved because it cannot support more than one AVCSource() in a script (i.e., cannot support multiple instantiation). You could not do this, for example:
AVCSource("fileA.dga")++AVCSource("fileB.dga")
There is a way to support that with the server model by forcing every GetFrame() call to do a full decoder reset. But the performance would be horrible.
Guest is offline
Old 23rd October 2008, 04:28   #584  |  Link
Sagekilla
x264aholic
Well #1 seems like it could be, or should be, a very simple fix -- something that nvidia can resolve for us (hopefully). MeGUI on the other hand.. Perhaps we can work with the developers to make it not crash.
Both seems completely solvable, just requires someone to actually do it. I wish I knew enough code to help on #2
Old 23rd October 2008, 04:39   #585  |  Link
It's not MEGUI's fault. It's something to do with managed code. It's still a mystery.
Guest is offline
Old 23rd October 2008, 05:46   #586  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
hmmm.....
the server model works for megui for a single instantiation call, but not for several and the 'normal' method (once fixed) supports multiple instantiation....
then how viable would it be to have both?
Seeing at how there are the people who would like to do complicated multiple instantiation and then the megui users.
probably hitting an over generalization here:
but i would say that the multiple instantiation users will probably encode the file to a lossless with filtering they will perform, which they will then use that in megui
- removing the necessity for DGAVCDecodeNV withing megui.
and then the megui users generally want to straight-shot convert a single video.
- without multiple instantiation capability.
sure if they both worked simultaneously people would be foaming out of the mouth in joy,
but hey if it absolutely requires two versions, i think people could live with that; we should be happy to get anything at all.
As for the file concatenating idea, what cuda restrictions are there in place to prevent you from doing
so within the project .dga and only having one AVCSource() call (like DGAVCIndex and DGIndex)?
is there any chance of getting it worked out with nvidia, or is it an absolute no-go?
- mp4box's stream concatenation feature can be used for files that have the same properties as a workaround for that if it doesn't ever work out....
.... geh, what a wall of text :<
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline
Old 23rd October 2008, 06:39   #587  |  Link
tre31
Originally Posted by kemuri-_9 View Post
hmmm.....
Different solutions for different problems, perhaps once you do get a working nvcuvid.dll again, just have that for people who want multiple instancing, and they can encode manually via cmd line, and for the MeGUI folk use the server model.
Alternatively perhaps keep the code managed so that both can be contained within the same app even but selection via options/preferences too keep it all in one app rather than dividing it up based on what the end user wants too do, better too keep it in one imho (but may mean some code repetition - but honestly who's worried about memory/storage space these days on recent machines).
Just an idea...
edit: Just make sure that its documented (hell even well tool-tipped) what the difference's are and whats best for what use.
tre31 is offline
Old 23rd October 2008, 07:09   #588  |  Link
Quark.Fusion
Quark.Fusion's Avatar
Storage is still matters — shadow copies for example can eat space pretty fast if you will do massive writes. That requires separate storage for temporary data — it's not something that comes for free.
Memory also heavily matters in 32-bit apps, fft3dgpu for example eat allocation space in that way, so it's not possible to use it two times on HD content. If you add memory requirement for encoding and decoding, mvtools processing, etc — you will suffer from insufficient address space. (Sorry for my english)
Quark.Fusion is offline
Old 23rd October 2008, 09:15   #589  |  Link
tre31
Your english is fine, however I think you misunderstood what I meant, what I actually meant was - the size of the executable will increase, hence it will initially consume more memory as it has too be loaded into memory too be executed, as for the actual size of memory it consumes that won't really change as it is only executing either one or the other options (one being multi-instancing, the other being server based).
Anyway its up too neuron2, I was just offering an idea that encompases both, since both seem too be valid solutions too different problems.
tre31 is offline
Old 23rd October 2008, 15:48   #590  |  Link
Actually, it turns out that AVCSource()++AVCSource() works fine with the server because the uses of the decoder are serialized. It's only when you interleave their usage that problems arise. So I'll go ahead and release the server version tonight.
Guest is offline
Old 23rd October 2008, 23:47   #591  |  Link
Sagekilla
x264aholic
How odd.. I don't suppose most people would realistically use two sources interleaved, would they?
Old 24th October 2008, 00:28   #592  |  Link
Quark.Fusion
Overlay? Can be used in game video recordings for example. (using x264 instead of lossless as intermediate format before editing)
Old 24th October 2008, 05:23   #593  |  Link
Version 1.0.5: Server implementation fixes MEGUI operation
OK, I'm rolling out the server version. Nvidia already fixed problem 1 described above but problem 2 remains intractable for now. Some notes:
* I strongly recommend killing the MEGUI preview before starting the encode. You can leave it open if you want to be perverse, but if you navigate in it after starting encoding, kiss your life goodbye. And don't say I didn't warn you.
* DGAVCIndexNV still uses a built-in GPU decoder; the server does not have to be active. But again for the same reason as above, kill DGAVCIndexNV before trying to execute scripts.
* Don't even think about writing a script that in any way interleaves access to multiple instances of AVCSource(). It's OK if they are serialized, e.g., AVCSource()++AVCSource(). Note that normal PureVideo bobbing without multiple instances is coming.
* The server is licensed, so either put it in the same directory as DGAVCIndexNV.exe, or put a copy of your license.txt file with its executable.
* Tomorrow I will release a basic server client with source code, so that you can use the server in your own applications.
http://neuron2.net/dgavcdecnv/dgavcdecnv.html
Guest is offline
Old 24th October 2008, 20:27   #594  |  Link
blubberbirne
great work. but i have some problem with megui. i encode some sample file. the encoded file don't play smooth. it lags
blubberbirne is offline
Old 24th October 2008, 20:35   #595  |  Link
What have you done to try to diagnose your problem? I ask because you've given me nothing to go on. I doubt it has anything to do with DGAVCDecNV.
Guest is offline
Old 24th October 2008, 22:26   #596  |  Link
blubberbirne
oh sorry, have many work at the moment will test it more tomorrow.
I test some small Premiere HD Stream. I only load the dga project in avs script an encode it with dxva hq profile in megui. source file playes finde. but the encoded one has terrible lags.
and sorry about my english
Old 24th October 2008, 22:35   #597  |  Link
Post a link to a sample of the encoded video that shows the lag. I want to see if it plays cleanly on my (fast) system.
Guest is offline
Old 25th October 2008, 02:11   #598  |  Link
CUVID Sample Client Application version 1.0.0
I've released the sample client package with source code. It works with the CUVID Server contained in DGAVCDecNV 1.0.5. The package contains documentation for the CUVID Server interface. I would be interested in any ideas for improving the interface.
Guest is offline
Old 25th October 2008, 10:44   #599  |  Link
crypto
@DVBPortal
crypto's Avatar
Thanks for making this available. I like the server concept and find it extremely interesting. Wouldn't this also be ideal to recombine the NV and non-NV lines of dgavcindex?
crypto is offline
Old 25th October 2008, 11:21   #600  |  Link
Inventive Software
Turkey Machine
No, because the license models are different.
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline
