Thread Tools Display Modes
Old 13th September 2008, 14:11   #1  |  Link
neuron2
_
neuron2's Avatar
DGAVCDecNV 1.0.13: GPU decoding on Nvidia
ATTENTION: If you do not use an Nvidia graphics card 8xxx or higher, this thread is not for you!
http://neuron2.net/dgavcdecnv/dgavcdecnv.html
If you want to assess the GPU performance, please read the section "Disable Display" in the users manual. And set the playback speed to Maximum under Options/Playback Speed! I am still optimizing frame rates and CPU utilization. Be aware that when serving through AVCSource() the performance will be comparable to that obtained with the display disabled (Disable Display option enabled).
I'm also interested in finding out what streams fail with GPU decoding, so please report them, preferably with stream details and a sample.
neuron2 is offline
Old 13th September 2008, 14:29   #2  |  Link
neuron2
_
neuron2's Avatar
My results for a 1920x1080 PAFF stream from the Hauppauge HD PVR with display disabled are:
Frame rate: 46 fps
CPU utilization: 2%
My machine is Intel E8500 dual core @ 3.8GHz on ASUS Rampage Formula. Graphics card is eVGA 8500GT.
neuron2 is offline
Old 13th September 2008, 15:04   #3  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Jesus I've just bought 4850
Atak_Snajpera is offline
Old 13th September 2008, 15:09   #4  |  Link
neuron2
_
neuron2's Avatar
I might support ATI also. For now, let's get Nvidia done.
neuron2 is offline
Old 13th September 2008, 15:09   #5  |  Link
Sagekilla
x264aholic
So you're telling us.. we're going to get GPU acceleration of decoding that we can actually frame serve? I'll hop on my desktop and try this out. I have a 9800 GTX on that computer. I'll go pop in some blu-ray discs and make sure those work properly too. I'm most concerned with the performance on those, since transcoding a Blu-ray is a massive pain.
Edit: Unfortunately, I couldn't even copy nvapi.dll. It was locked by some process.. Trying to find out which one now.
Sagekilla is offline
Old 13th September 2008, 15:28   #6  |  Link
Inventive Software
Turkey Machine
Don't have an NVIDIA GPU to test this with, but I'll be watching with baited breath.
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline
Old 13th September 2008, 15:34   #7  |  Link
Selur
member of flaskmpeg.info
Selur's Avatar
@Sagekilla: "Trying to find out which one now." -> Unlocker might help
Hybrid
Selur is offline
Old 13th September 2008, 15:34   #8  |  Link
Sagekilla
x264aholic
Well I can't seem to actually figure out how to copy nvapi.dll without Windows throwing a hissy fit about it. I'm hesitant to copy the new NVApi.dll (dated Aug 2008) over the old one (Feb 2008) in my system32 directory, but I'll give it a shot I suppose. All in the name of faster decoding I suppose..
Got Unlocker working.. Unfortunately I have explorer.exe, taskeng.exe, and rundll32.exe using it on my laptop. My desktop is using it for rundll32.exe, nvsvc32.exe, and ntune.exe.
I hate dependencies.
Old 13th September 2008, 15:42   #9  |  Link
G_M_C
I was just in time to cancel my order when i read about this upcoming release.
I'll wait some time before i decide to go Nv though, and i might still get the 4850 even if DGIndex doesn't Ati support Ati, cause i think is better imho. But in the mean time i give all kudo's to Neuron2 for this step in development, and i'll keep watching progress !
G_M_C is offline
Old 13th September 2008, 15:46   #10  |  Link
neuron2
_
neuron2's Avatar
You may not have to do that. Have you tried step 1 in my post? What happened?
neuron2 is offline
Old 13th September 2008, 15:47   #11  |  Link
Sagekilla
x264aholic
Still, I'd like to see both supported -- If either side comes out on top (and I usually go with the one who has the faster card) then if that one happens to be unsupported I'm in a bit of an unfortunate position
@neuron2: On my both my computers I received the error message on simply opening DGAVCNV saying:
ERROR: cuInt failed (100)
Hit Yes to continue ....
On my desktop where I had a Blu-ray available to open with:
GPU decoder: Failed to create video decoder.
Old 13th September 2008, 15:48   #12  |  Link
neuron2
_
neuron2's Avatar
BTW, guys. You can have a secondary Nvidia card next to your ATI and still use it for decoding.
neuron2 is offline
Old 13th September 2008, 15:49   #13  |  Link
neuron2
_
neuron2's Avatar
If we can't get the DLL thing sorted, I'll contact Nvidia about it, but you can always install the CUDA driver and toolkit:
http://www.nvidia.com/object/cuda_get.html
neuron2 is offline
Old 13th September 2008, 15:50   #14  |  Link
Sagekilla
x264aholic
Is it just the CUDA driver that's needed? I tried installing the SDK and that did nothing for me.
I'm installing Driver --> toolkit now, I'd really love to get this running.
Old 13th September 2008, 15:53   #15  |  Link
neuron2
_
neuron2's Avatar
I don't know the install details yet. You need to install the CUDA driver and toolkit to do it the kosher way. I am hoping to find a way to avoid that for users.
When you install the CUDA driver say Yes when they ask if you want to replace your existing (possibly newer) driver.
neuron2 is offline
Old 13th September 2008, 15:55   #16  |  Link
neuron2
_
neuron2's Avatar
Don't know what you're trying to do here. Open what with? And open with what?
neuron2 is offline
Old 13th September 2008, 15:58   #17  |  Link
Sagekilla
x264aholic
I was using DGAVCNV to open a m2ts file ripped from a Blu-ray, after I got the first error message and I clicked "yes" to ignore this, I got the second one too. But that shouldn't be anything unusual since it already told me something failed to initialize. This was before I had the "correct" dlls btw
Old 13th September 2008, 16:02   #18  |  Link
neuron2
_
neuron2's Avatar
What is your situation now?
neuron2 is offline
Old 13th September 2008, 16:10   #19  |  Link
Sagekilla
x264aholic
Now my computer won't start up.. I'll get back to you on this, my main desktop has been having various issues for a while now. I think it's a bit overdue for a reinstall of XP.
Old 13th September 2008, 16:12   #20  |  Link
neuron2
_
neuron2's Avatar
OK, guys, let's keep it simple for now until I get definitive details about it.
Install the CUDA driver and toolkit. Then unzip DGAVCIndexNV into a directory and run it from there. That should work. Works for me!
neuron2 is offline
Thread Tools
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
