3rd August 2008, 15:07 | #1 | Link |
Spinner Plugin
Spinner: This plugin rotates a frame or selected part of it through any desired angle. The rotation axis coordinates and angle of rotation can be in floating point. Option for varying parameters linearly along clip and specify a rectangular area to undergo rotation is available. Precision may be nearest neighbour, bilinear or bicubic interpolation. If a thin rectangle outside axis of rotation is specified , it appears as cartwheeling.
I read sometime back that the test for good rotation technique is to rotate image several times (say 60 degrees each time for 6 times) and compare with original by subtract. I got surprising results. Nearest neighbour option resulted in random noise as output. Bilinear has in the difference strong elements of the image. Bicubic has the strongest image elements. Possibly this is to be expected, but still gives the impression that bicubic is the worst of the lot. Either my understanding is not correct or my implementation is defective? Last edited by vcmohan; 4th August 2008 at 11:05. Reason: Changed plugin name at the suggestion of Fizick |
3rd August 2008, 16:32 | #2 | Link |
Avisynth language lover
Putting the case for the defence, ...
you could interpret the results another way - nearest neighbour adds random noise to the 'correct' result, while the others are more highly correlated with the original, with bicubic best of all! I'm just speculating, I don't know what you should expect theoretically. The real test of course is - which of the three looks more like the original? |
3rd August 2008, 19:49 | #3 | Link |
AviSynth plugger
vcmohan,
Please rename your plugin. I have Rotate plugin too. It is confused.
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
3rd August 2008, 22:28 | #4 | Link |
Just thinking out loud... how about using OpenGL for something like this(and other things)?.
Anyway it sure would be great with an OpenGl Plugin.
DVD slideshow GUI(Freeware). |
4th August 2008, 16:28 | #7 | Link |
AviSynth plugger
Thanks!
I will look to it. I tryed set some compatibility. Can anybody make a speed test of various rotation plugins?
4th August 2008, 19:15 | #8 | Link |
Resize Abuser
Speed/Quality Test Code
a = ColorBars(1024,768).Trim(0,99) Animate(0, a.framecount()-1, "Angle", a, float(-500), 0, a, float(510), 0) last + Animate(0, a.framecount()-1, "Angle", a, float(510), 0, a, float(520), 0) last + Animate(0, a.framecount()-1, "Angle", a, float(-500), 1, a, float(510), 1) last + Animate(0, a.framecount()-1, "Angle", a, float(510), 1, a, float(520), 1) last + Animate(0, a.framecount()-1, "Angle", a, float(-500), 2, a, float(510), 2) last + Animate(0, a.framecount()-1, "Angle", a, float(510), 2, a, float(520), 2) last + Animate(0, a.framecount()-1, "Angle", a, float(-500), 3, a, float(510), 3) last + Animate(0, a.framecount()-1, "Angle", a, float(510), 3, a, float(520), 3) last + Animate(0, a.framecount()-1, "Angle", a, float(-500), 4, a, float(510), 4) last + Animate(0, a.framecount()-1, "Angle", a, float(510), 4, a, float(520), 4) last + Animate(0, a.framecount()-1, "Angle", a, float(-500), 5, a, float(510), 5) last + Animate(0, a.framecount()-1, "Angle", a, float(510), 5, a, float(520), 5) last + Animate(0, a.framecount()-1, "Angle", a, float(-500), 6, a, float(510), 6) last + Animate(0, a.framecount()-1, "Angle", a, float(510), 6, a, float(520), 6) last + Animate(0, a.framecount()-1, "Angle", a, float(-500), 7, a, float(510), 7) last + Animate(0, a.framecount()-1, "Angle", a, float(510), 7, a, float(520), 7) Function Angle(clip c, float a, int mode) { b = (Round(abs(a)*1000)%360000)/1000.0 d = a < 0 ? 1-(b/360.0) : b/360.0 b = a < 0 ? -b : b c mode == 0 ? Subtitle("Orginal (no rotation) " + String(a),align=5) : \ mode == 1 ? Zoom(angle=string(a)).Subtitle("Zoom " + String(a),align=5) : \ mode == 2 ? Freeframe("C:\Program Files\AviSynth 2.5\plugins\PetePanSpinZoom.dll",false,0.5,0.5,d,0.2).Subtitle("PetePanSpinZoom " + String(d),align=5) : \ mode == 3 ? EffectRotation(id=-a, cc=$000000).Subtitle("EffectRotation " + String(-a),align=5) : \ mode == 4 ? Rotate(a).Subtitle("Rotate " + String(a),align=5) : \ mode == 5 ? Spinner(angle=a,check=false,bg=false,q=2).Subtitle("Spinner Q=2 " + String(a),align=5) : \ mode == 6 ? Spinner(angle=a,check=false,bg=false,q=1).Subtitle("Spinner Q=1 " + String(a),align=5) : \ Spinner(angle=a,check=false,bg=false,q=0).Subtitle("Spinner Q=0 " + String(a),align=5) } Freeframe() w/ PetePanSpinZoom EffectRotation() Rotate() Spinner() Speed None: 28fps FreeFrame: 16fps Rotate: 13fps Spinner Q=0: 12fps Zoom: 7fps Spinner Q=1: 6fps EffectRotation: 5fps Spinner Q=2: 4fps Rotate has the best picture quality hands down. Everything else is ok
Mine: KenBurnsEffect/ZoomBox CutFrames Helped: DissolveAGG ColorBalance LQ Animation Fixer Last edited by mikeytown2; 6th August 2008 at 03:43. Reason: Fix my DUMB code for EfectRotation |
5th August 2008, 01:12 | #9 | Link | |
- What is the purpose of the second assignment to b? Its value doesn't seem to be used (only a and d are). - it's a bit unfair on Zoom to call it this way; since the angle is fixed for each invocation, you should just use: Code:
Zoom(angle=string(a)) - The figures may be misleading wrt the relative speeds because there is a constant overhead of Animate + function call and Subtitle. How about adding a mode 0 which is just Code:
Subtitle("Original", align=5) Last edited by Gavino; 5th August 2008 at 01:15. |
5th August 2008, 01:32 | #10 | Link |
Resize Abuser
b was for the original EffectRotation() because it only took ints as input.
Re-ran Zoom, no speed difference. This code came from KBE()
Mine: KenBurnsEffect/ZoomBox CutFrames Helped: DissolveAGG ColorBalance LQ Animation Fixer |
5th August 2008, 08:01 | #11 | Link | |
Regarding speed test by miketown2 , I am not surprised as I have no mmx optimization or any assembler code. I will be shortly adding a couple of options for quality and possibly speed enhancements. Also animate may not be used with Spinner or effectRotation as there are animations within them and are much faster. |
5th August 2008, 09:05 | #12 | Link |
Zoom also has internal animation using the expression string, but I haven't noticed it being faster than 'Animate'ing a fixed value (though I haven't done any formal comparisons). The expression string is obviously more convenient when you want non-linear variation.
6th August 2008, 02:52 | #13 | Link | |
Originally Posted by mikeytown2
For some reason mickeytown2 post does not have the 'quote' button. |
6th August 2008, 03:48 | #14 | Link |
Resize Abuser
My orginal post had round() in the code for EffectRotation. It's now fixed, sorry about that vcmohan! Q=2 works correctly as well!
Round 2 - "Built in" code. Code:
a = ColorBars(1024,768).Trim(0,99) x=-500.0 y=510.0 z=520.0 Animate(0, a.framecount()-1, "Angle", a, float(x), 0, a, float(y), 0) last + Animate(0, a.framecount()-1, "Angle", a, float(y), 0, a, float(z), 0) last + a.Zoom(angle="spline(n, " + String(0) + "," + String(x) + ", " + String(a.framecount()-1) + "," + String(y) + ", false)", show=true).Subtitle("Zoom " + String(x) + " to " + String(y),align=5) last + a.Zoom(angle="spline(n, " + String(0) + "," + String(y) + ", " + String(a.framecount()-1) + "," + String(z) + ", false)", show=true).Subtitle("Zoom " + String(y) + " to " + String(z),align=5) last + Animate(0, a.framecount()-1, "Angle", a, float(x), 2, a, float(y), 2) last + Animate(0, a.framecount()-1, "Angle", a, float(y), 2, a, float(z), 2) last + a.EffectRotation(id=-x, cc=$000000, fd=-y).Subtitle("EffectRotation " + String(x) + " to " + String(y),align=5) last + a.EffectRotation(id=-y, cc=$000000, fd=-z).Subtitle("EffectRotation " + String(y) + " to " + String(z),align=5) last + a.Rotate(angle=x,start=0,end=a.framecount()-1,endangle=y).Subtitle("Rotate " + String(x) + " to " + String(y),align=5) last + a.Rotate(angle=y,start=0,end=a.framecount()-1,endangle=z).Subtitle("Rotate " + String(y) + " to " + String(z),align=5) last + a.Spinner(angle=x,eangle=y,check=false,bg=false,q=2).Subtitle("Spinner Q=2 " + String(x) + " to " + String(y),align=5) last + a.Spinner(angle=y,eangle=z,check=false,bg=false,q=2).Subtitle("Spinner Q=2 " + String(y) + " to " + String(z),align=5) last + a.Spinner(angle=x,eangle=y,check=false,bg=false,q=1).Subtitle("Spinner Q=1 " + String(x) + " to " + String(y),align=5) last + a.Spinner(angle=y,eangle=z,check=false,bg=false,q=1).Subtitle("Spinner Q=1 " + String(y) + " to " + String(z),align=5) last + a.Spinner(angle=x,eangle=y,check=false,bg=false,q=0).Subtitle("Spinner Q=0 " + String(x) + " to " + String(y),align=5) last + a.Spinner(angle=y,eangle=z,check=false,bg=false,q=0).Subtitle("Spinner Q=0 " + String(y) + " to " + String(z),align=5) Function Angle(clip c, float a, int mode) { b = (Round(abs(a)*1000)%360000)/1000.0 d = a < 0 ? 1-(b/360.0) : b/360.0 b = a < 0 ? -b : b c mode == 0 ? Subtitle("Orginal (no rotation) " + String(a),align=5) : \ mode == 1 ? Zoom(angle=string(a)).Subtitle("Zoom " + String(a),align=5) : \ mode == 2 ? Freeframe("C:\Program Files\AviSynth 2.5\plugins\PetePanSpinZoom.dll",false,0.5,0.5,d,0.2).Subtitle("PetePanSpinZoom " + String(d),align=5) : \ mode == 3 ? EffectRotation(id=-a, cc=$000000).Subtitle("EffectRotation " + String(-a),align=5) : \ mode == 4 ? Rotate(a).Subtitle("Rotate " + String(a),align=5) : \ mode == 5 ? Spinner(angle=a,check=false,bg=false,q=2).Subtitle("Spinner Q=2 " + String(a),align=5) : \ mode == 6 ? Spinner(angle=a,check=false,bg=false,q=1).Subtitle("Spinner Q=1 " + String(a),align=5) : \ Spinner(angle=a,check=false,bg=false,q=0).Subtitle("Spinner Q=0 " + String(a),align=5) } Everything else works great! Speed None: 28fps Rotate: 17fps - Disqualified though... Spinner Q=0: 17fps FreeFrame: 16fps Zoom: 8fps Spinner Q=1: 6fps EffectRotation: 6fps Spinner Q=2: 2fps
Mine: KenBurnsEffect/ZoomBox CutFrames Helped: DissolveAGG ColorBalance LQ Animation Fixer Last edited by mikeytown2; 6th August 2008 at 04:00. |
6th August 2008, 11:16 | #15 | Link | |
Zoom(angle="spline(n, 0, x, a.framecount()-1, y, false)", show=true) The use of show=true could affect the speed though. Last edited by Gavino; 6th August 2008 at 11:22. Reason: formatting |
10th August 2008, 13:02 | #16 | Link |
I have modified the code extensively. Now Spinner accepts YUY2 format also. A new parameter p is added with which one can specify the location accuracy. (1/4 pixel to 1/5000) pixel. For quality Lagrange and Lanczos interpolation are now available. Both have 4 and 6 point options.
I got hold of Rotate plugin from warpenterprises site. Oct 2007 dated. I did some comparison of quality. The script used is : Code:
im1 = imagereader("E:\images\canyon.jpg", end = 361).converttoRGB32() im1 = reduceby2(im1) a = 2 b= 60 c= 120 d= 400 e = 1000 s0 = Spinner(im1,q = a, angle = b, eangle = c, check = false, p =d, bg = false, color = 0) s1 = Spinner(s0,q = a, angle = b, eangle = c, check = false, p =d, bg = false, color = 0) s2 = Spinner(s1,q = a, angle = b, eangle = c, check = false, p =d, bg = false, color = 0) s3 = Spinner(s2,q = a, angle = b, eangle = c, check = false, p =d, bg = false, color = 0) s4 = Spinner(s3,q = a, angle = b, eangle = c, check = false, p =d, bg = false, color = 0) s5 = Spinner(s4,q = a, angle = b, eangle = c, check = false, p =d, bg = false, color = 0) rt0= Rotate(im1,angle = b) rt1= Rotate(rt0,angle = b) rt2= Rotate(rt1,angle = b) rt3= Rotate(rt2,angle = b) rt4= Rotate(rt3,angle = b) rt5= Rotate(rt4,angle = b) sb1=Subtract(s5,im1).Levels(127,1,129,0,255) sb2=Subtract(rt5,im1).Levels(127,1,129,0,255) sh1 = stackhorizontal(s5,sb1) sh2 = stackhorizontal(rt5,sb2) stackvertical(sh1,sh2) The result is as below. On top row left is Spinner output with Lagrange 4 point interpolation, on its right is subtract from original. Bottom row is corresponding Rotate output. Even for lowest quality q = 0, IMO Spinner appears far superior. I request mikeytown2 to do a speed test again. As there are initial overheads for the first frame, animate may not give correct speed measurement. Probably over 1000 or more frames in a run to be measured. Lanczos 6 pt (q = 5) should give better results. |
10th August 2008, 22:37 | #17 | Link |
Resize Abuser
Here is a quality test code block. Thanks vcmohan for inspiring this.
ImageReader("wikipediamiamisunset200ke5.jpg") ColorBars() lr=130 tb=210 im1=last.ConvertToRGB32().BicubicResize(640,480).AddBorders(lr,tb,lr,tb).Trim(0,-1) a= 2 b= 60 c= 60 d= 5000 lr=lr tb=tb Spinner(im1,q = a, angle = b, eangle = c, check = false, p =d, bg = false, color = 0) Spinner(q = a, angle = b, eangle = c, check = false, p =d, bg = false, color = 0) Spinner(q = a, angle = b, eangle = c, check = false, p =d, bg = false, color = 0) Spinner(q = a, angle = b, eangle = c, check = false, p =d, bg = false, color = 0) Spinner(q = a, angle = b, eangle = c, check = false, p =d, bg = false, color = 0) s5 = Spinner(q = a, angle = b, eangle = c, check = false, p =d, bg = false, color = 0).Crop(lr,tb,-lr,-tb) Rotate(im1,angle = b) Rotate(angle = b) Rotate(angle = b) Rotate(angle = b) Rotate(angle = b) rt5= Rotate(angle = b).Crop(lr,tb,-lr,-tb) Function StackComparer(clip x, clip y, string s) { sb1=Subtract(x,y) sb1=Overlay(sb1.Levels(128,1,130,0,255), \ sb1.Levels(126,1,128,0,255).PointResize(640*4,480*4).ConvertToYUY2().Invert("y").ConvertToRGB32().PointResize(640,480) \ ,mode="add").Levels(23,1,255,0,255).Subtitle("Black pixels means less/no change") s5=Compare(x,y).Subtitle(String(s), Align=4) stackhorizontal(s5,BlankClip(1,1,480,color=$FFFFFF),BlankClip(1,1,480,color=$000000),BlankClip(1,1,480,color=$FFFFFF),sb1) } sh1=StackComparer(s5,im1.Crop(lr,tb,-lr,-tb),"Spinner Q=" + String(a) + " P=" + String(d)) sh2=StackComparer(rt5,im1.Crop(lr,tb,-lr,-tb),"Rotate") sh3=StackComparer(im1.Crop(lr,tb,-lr,-tb),im1.Crop(lr,tb,-lr,-tb),"Orginal") stackvertical(sh1,BlankClip(1,1283,1,color=$FFFFFF),BlankClip(1,1283,1,color=$000000),BlankClip(1,1283,1,color=$FFFFFF),sh2 \ ,BlankClip(1,1283,1,color=$FFFFFF),BlankClip(1,1283,1,color=$000000),BlankClip(1,1283,1,color=$FFFFFF),sh3) image from wikipedia In my previous comparisons I was looking at the aliasing, it appears that Rotate() has built in AA, which is why I preferred it in my previous post. When using Rotate() multiple times AA hurts the final output. So in terms of Quality (PSNR) Spinner wins, but there are some issues. It doesn't handle solid colors correctly as you can see with the ColorBars() test when P is set above 16. Also if it had an Edge AA option that would be nice feature. Here is a speed test between Rotate and Spinner Code:
a = ColorBars(1024,768).Trim(0,999) x=-500.0*20 y=510.0 z=520.0 a.trim(0,-1) Animate(0, a.framecount()-1, "Angle", a, float(x), 0, a, float(y), 0) last + Animate(0, a.framecount()-1, "Angle", a, float(y), 0, a, float(z), 0) last + Animate(0, a.framecount()-1, "Angle", a, float(x), 4, a, float(y), 4) last + Animate(0, a.framecount()-1, "Angle", a, float(y), 4, a, float(z), 4) last + a.Spinner(angle=x,eangle=y,check=false,bg=false,q=2,p=5000).Subtitle("Spinner Q=2 P=5000 " + String(x) + " to " + String(y),align=5) last + a.Spinner(angle=y,eangle=z,check=false,bg=false,q=2,p=5000).Subtitle("Spinner Q=2 P=5000 " + String(y) + " to " + String(z),align=5) last + a.Spinner(angle=x,eangle=y,check=false,bg=false,q=2,p=4).Subtitle("Spinner Q=2 P=4 " + String(x) + " to " + String(y),align=5) last + a.Spinner(angle=y,eangle=z,check=false,bg=false,q=2,p=4).Subtitle("Spinner Q=2 P=4 " + String(y) + " to " + String(z),align=5) last + a.Spinner(angle=x,eangle=y,check=false,bg=false,q=1,p=5000).Subtitle("Spinner Q=1 P=5000 " + String(x) + " to " + String(y),align=5) last + a.Spinner(angle=y,eangle=z,check=false,bg=false,q=1,p=5000).Subtitle("Spinner Q=1 P=5000 " + String(y) + " to " + String(z),align=5) last + a.Spinner(angle=x,eangle=y,check=false,bg=false,q=1,p=4).Subtitle("Spinner Q=1 P=4 " + String(x) + " to " + String(y),align=5) last + a.Spinner(angle=y,eangle=z,check=false,bg=false,q=1,p=4).Subtitle("Spinner Q=1 P=4 " + String(y) + " to " + String(z),align=5) last + a.Spinner(angle=x,eangle=y,check=false,bg=false,q=0,p=5000).Subtitle("Spinner Q=0 P=5000 " + String(x) + " to " + String(y),align=5) last + a.Spinner(angle=y,eangle=z,check=false,bg=false,q=0,p=5000).Subtitle("Spinner Q=0 P=5000 " + String(y) + " to " + String(z),align=5) last + a.Spinner(angle=x,eangle=y,check=false,bg=false,q=0,p=4).Subtitle("Spinner Q=0 P=4 " + String(x) + " to " + String(y),align=5) last + a.Spinner(angle=y,eangle=z,check=false,bg=false,q=0,p=4).Subtitle("Spinner Q=0 P=4 " + String(y) + " to " + String(z),align=5) Function Angle(clip c, float a, int mode) { b = (Round(abs(a)*1000)%360000)/1000.0 d = a < 0 ? 1-(b/360.0) : b/360.0 b = a < 0 ? -b : b c mode == 0 ? Subtitle("Orginal (no rotation) " + String(a),align=5) : \ mode == 1 ? Zoom(angle=string(a)).Subtitle("Zoom " + String(a),align=5) : \ mode == 2 ? Freeframe("C:\Program Files\AviSynth 2.5\plugins\PetePanSpinZoom.dll",false,0.5,0.5,d,0.2).Subtitle("PetePanSpinZoom " + String(d),align=5) : \ mode == 3 ? EffectRotation(id=-a, cc=$000000).Subtitle("EffectRotation " + String(-a),align=5) : \ mode == 4 ? Rotate(a).Subtitle("Rotate " + String(a),align=5) : \ mode == 5 ? Spinner(angle=a,check=false,bg=false,q=2).Subtitle("Spinner Q=2 " + String(a),align=5) : \ mode == 6 ? Spinner(angle=a,check=false,bg=false,q=1).Subtitle("Spinner Q=1 " + String(a),align=5) : \ Spinner(angle=a,check=false,bg=false,q=0).Subtitle("Spinner Q=0 " + String(a),align=5) } Results: None: 28.0fps Rotate: 13.65 - Big Angle 13.00 - Small Angle Spinner: 5.35 - BA,q=2,p=5k 5.30 - SA,q=2,p=5k 5.45 - BA,q=2,p=4 5.40 - SA,q=2,p=4 9.80 - BA,q=1,p=5k 9.85 - SA,q=1,p=5k 10.0 - BA,q=1,p=4 9.95 - SA,q=1,p=4 15.20 - BA,q=0,p=5k 15.35 - SA,q=0,p=5k 16.16 - BA,q=0,p=4 16.30 - SA,q=0,p=4
11th August 2008, 13:13 | #18 | Link |
Thanks for the effort. On seeing the color bars comparison I could locate the source for this error. I now corrected it. The quality should improve further.
As for speed. I just tried the colorbars() and got on my system very near 30fps. When I added the lines Code:
cb = ColorBars().Trim(0,9999)
a=2
b= 60
c= 420
d= 400
e = 1000
s0 = Spinner(cb,q = 1,x = -100, ex = 600, angle = b, eangle = c, check = false, p =d, bg = false, color = 0)
return(s0)
Something is not right. Using vdub rendering fps may not correctly indicate speed. I recollect some plugin timer or some such named. Possibly it does a better estimate. |
11th August 2008, 19:37 | #19 | Link |
Resize Abuser
Using Spinner.dll with timestamp of August 11, 2008, 5:12:00 PM, with my above code slightly modified here is output with p=16 and p=17
I'll look into other FPS measurement methods. Just a heads up, I used ColorBars(1024,768) with the speed test.
12th August 2008, 03:30 | #20 | Link |
Thanks for the test. The parameter p has very insignificant effect on the speed of processing. It was only provided for sake of 'effects' if some one needs. As such one may not use lower values if one needs quality. It however calls for higher requirement of memory. For example at p = 5000 and q = 3 or 5 , it requires an additional 240kb( present day standards negligible) while at p=16, q = 1 it just needs 128 bytes extra.
Therefore pl test for quality with p as high as possible. Similarly q =3 or 5 gives higher quality. Ofcourse they are the slowest. One needs to make conscious compromises. I have checked with q = 1, in the manner I did earlier and compared with Rotation plugin. In this mode it is bilinear interpolation, which is also used by Rotation and so spinner should give comparable quality to that of Rotation. Even here Spinner output looks better than that of Rotation. May be Fizick can comment on this. |
