Old 24th April 2008, 17:33   #41  |  Link
burfadel
With a non-grainy source, any chance of a film grain threshold? Adaptive strength based on threshold? That would be particularly useful for mixed videos!
I have noticed with the couple of clips I did the file size increased significantly, but I guess thats expected! (the results are great).
I read somewhere that the b-frame decision of x264 could be improved, is this true? Would that affect the FGO? Would storing the main film grain in b-frames and using the principles of your grain optimiser plugin actually work, in an effort to reduce the output size impact (maybe as a different mode to fgo)?
Old 24th April 2008, 19:10   #42  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
If we can get a good measurement of film grain that doesn't have false positives (this method, for example, would get a high "noise" value on a very sharp edge, which would be a problem for very clean sources), that might be possible.
Yes.
You mean storing the grain in P-frames? That's actually already done in a sense since the B-frames often simply take the grain from the neighboring P-frames instead of re-encoding their own new grain. FGO makes this much more likely, since the bidirectional mode, which generally gives the best RD score, tends to blur out grain (making FGO less likely to select it).
Old 24th April 2008, 20:10   #43  |  Link
MfA
Hell, someone is being paid this summer to work on improving the b-frame decision ... someone we know?
MfA is offline   Reply With Quote
Old 24th April 2008, 20:13   #44  |  Link
Dark Shikari
x264 developer
Its a GSOC project; Robert Deaton will be the student responsible for B-frame decision improvement.
Old 24th April 2008, 20:32   #45  |  Link
donis
Awesome news
donis is offline   Reply With Quote
Old 25th April 2008, 04:53   #46  |  Link
cestfait
cestfait's Avatar
on fgo:
I've never liked the flat matrix so much. Always wanted to use it, but it was too prone to banding and blocking.
This patch is a keeper. Spectacular work, Dark Shikari.
cestfait is offline   Reply With Quote
Old 25th April 2008, 11:06   #47  |  Link
bokonon
Originally Posted by Sagittaire View Post
Decoder (hardware and software) must be compatible with FGM. As far I know it's not the case for libavcodec, coreavc ...
Does anyone know if it is supported by the sigma decoder in Network Media Tanks such as Popcorn Hour
bokonon is offline   Reply With Quote
Old 25th April 2008, 11:38   #48  |  Link
MfA
Originally Posted by McCauley View Post
the problem is that there's no way to remove the grain without loosing any details
There is no way to do lossy compression without loosing any detail either, there is going to be a crossover point where the saved bits provide a net gain.
Old 25th April 2008, 16:31   #49  |  Link
Razorholt
Cyberspace Citizen
Razorholt's Avatar
@DS: I remember you say to enable p4x4 with GrainOptimizer. Do you recommend to do the same with FGO?
Thanks,
- Dan
Razorholt is offline   Reply With Quote
Old 25th April 2008, 16:37   #50  |  Link
Dark Shikari
x264 developer
Thanks,
- Dan
No, they're totally different; no benefit here to p4x4 really.
Old 25th April 2008, 16:51   #51  |  Link
bokonon
anyone tried it on a mixed source? (i.e.scenes with varying amounts of grain)
Old 25th April 2008, 19:08   #52  |  Link
ToS_Maverick
x264 Tester
as I stated above, I got VERY good results with FGO at preventing x264 from banding! If you like i could post some screens...
ToS_Maverick is offline   Reply With Quote
Old 25th April 2008, 19:18   #53  |  Link
dbzgundam
Hates all his encodes
dbzgundam's Avatar
I'll have to try this with older cel-style anime... The grain present often gets turned into flat blocking.
http://thevideophile.blogspot.com/ Watch and be amazed by my frustration over the video world!
dbzgundam is offline   Reply With Quote
Old 25th April 2008, 19:41   #54  |  Link
bokonon
please do!
include the source caps if possible
Old 25th April 2008, 20:40   #55  |  Link
bokonon
Source: x264 r830 GIT (git://git.videolan.org/x264.git)
Applied patches (current versions):
x264_2pass_vbv.7.diff
x264_fix_win_stdin.diff
x264_FGO.diff (fixed by Dark Shikari & techouse)
x264.gaussian.cplxblur.01.diff
x264_hrd_pulldown.04_interlace.diff
x264_me-prepass_DeathTheSheep.diff
http://techouse.project357.com/build...30_techouse.7z
Old 25th April 2008, 22:33   #56  |  Link
Tack
Freevo Developer
The patch truly does wonders for grain, but the resulting bitrate increase was a bit disappointing (even if not unexpected). VAQ+prestige still satisfies my eyes and the bitrate is quite manageable. I count myself lucky not to be among those tuned into the style of artifacting caused by prestige that others have pointed out.
When the h264 user/developer community sorts out FGM, then I'll launch fireworks from my balcony.
Tack is offline   Reply With Quote
Old 26th April 2008, 08:42   #57  |  Link
Yoshiyuki Blade
Novice x264 User
Yoshiyuki Blade's Avatar
Looks interesting ! Do you think this will work well on clear sources with artificially-added grain (via avisynth filters)? I'm curious to try that out.
Yoshiyuki Blade is offline   Reply With Quote
Old 26th April 2008, 08:54   #58  |  Link
Dark Shikari
x264 developer
Sure, it'll work for any sort of noise.
Old 27th April 2008, 02:41   #59  |  Link
desta
Does fgo need to be enabled during the first pass of a 2-pass encode, as obviously this would require using --subme 6 and --b-rdo?
desta is offline   Reply With Quote
Old 27th April 2008, 02:47   #60  |  Link
Dark Shikari
x264 developer
It doesn't need to; I'm not sure what benefit it would have.
