Old 22nd February 2008, 00:30   #1  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
VAQ: Making Xvid's Adaptive Quantization Not Suck
I was bored, so I spent 15 minutes and wrote this patch to port x264's new VAQ to Xvid.
I haven't tested it much (only on this video), but it seems to work surprisingly well, despite MPEG-4 ASP's drastic limitations on quantizer deltas.
Patch [updated with minor fixes]
Xvidcore.dll [updated with latest patch]
To use it with Virtualdub or any VfW interface, just overwrite the XvidCore.dll in your /Windows/System32 or similar with the one I have provided.
To activate VAQ, just check off the Adaptive Quantization box; it replaces the normal luminance masking.
Note that I could not get it working correctly with mencoder; for some reason libavcodec seems to have its own lumimasking library that's overriding my patch. It works with xvid_encraw and VfW though...
Have fun!
Old 22nd February 2008, 01:29   #2  |  Link
squid_80
If people want, I can add it to my xvid_encraw as a new option. Unfortunately I have no time to do my own tests at the moment.
squid_80 is offline   Reply With Quote
Old 22nd February 2008, 02:03   #3  |  Link
Dark Shikari
x264 developer
In the patch's current form it overwrites lumimasking, so one would need a separate version (it uses the same commandline as lumimasking).
Old 22nd February 2008, 02:23   #4  |  Link
Zep
can you link to the without patch encode for comparison?
Zep is offline   Reply With Quote
Old 22nd February 2008, 03:26   #5  |  Link
elguaxo
elguaxo's Avatar
elguaxo is offline   Reply With Quote
Old 22nd February 2008, 03:29   #6  |  Link
Dark Shikari
x264 developer
That is the x264 version of the video
Do Xvid test encodes yourself.
Old 22nd February 2008, 03:33   #7  |  Link
Ranguvar
Ranguvar's Avatar
Awesome!
But I SO wish you had done this before I backed up a bunch of stuff to Xvid
Squid_80, please do. I will test if I get any time, which is most likely as I have this week off.
Dark Shikari, can this Xvidcore be used against any version of the Xvid codec? I have a recent build of 1.2.-127.
Ranguvar is offline   Reply With Quote
Old 22nd February 2008, 03:37   #8  |  Link
Dark Shikari
x264 developer
Originally Posted by Ranguvar View Post
Awesome!
This is the latest CVS snapshot of Xvid + my patch.
Old 22nd February 2008, 08:10   #9  |  Link
squid_80
The beauty of the xvid's plugin system - I can add however many plugins I want to encraw and xvidcore.dll doesn't need to be updated.
Old 22nd February 2008, 09:46   #10  |  Link
G_M_C
I was bored, so I spent 15 minutes and wrote this patch to port x264's new VAQ to Xvid[...]
OMG
I'd allmost wish you'd be bored more often.
.... But on the other hand ...
If you do things like these VAQ-patches for X264 & Xvid while bored ... i'd hate to think of things you could do while really interested
Anyway,just a question; Could this same patch / idea be ported to Hank's HCEnc MPEG2 encoder ? I use that one quite often to make (author) DVD's.
I use Hanks luminance-adative code, wich works surprisingly well. But that code works only on "darker" scenes, not on flat(ter) scenes like the VAQ does. I would be really interested in such a feature
G_M_C is offline   Reply With Quote
Old 22nd February 2008, 10:55   #11  |  Link
Dark Shikari
x264 developer
I don't see why not...
All I need is a link to the source.
Well x264's took quite a while--but once I had it working I can easily port it to any other similar encoder with very little work.
Old 22nd February 2008, 16:35   #12  |  Link
hank315
HCenc author
I'm already working on it for some time, the general idea is about the same, variance based.
Will be in the next HCenc release.
Just had a look at the implementation in Xvid, well, I'm a C n00b but when I do something like this in Fortran it will overflow on high luminance values:
  for (k = 0; k < 16; k++)
      for (l = 0; l < 16; l++)
             int val = ptr[k*data->current.stride[0] + l];
             sum += val;
             sum_of_squares += val * val;
  /* Variance = SSD - SAD^2 / (numpixels) */
  int variance = sum_of_squares - sum * sum / 256;
HCenc at: http://hank315.nl
hank315 is offline   Reply With Quote
Old 22nd February 2008, 17:09   #13  |  Link
elguaxo
elguaxo's Avatar
Edit: I accidentally left a debug statement in there, so if you're using xvid_encraw... well... you might notice "THISISATEST" constantly printing
I'm using xvid_encraw. I have no idea how to compile this myself. Could you or somone else post a binary without the debug text? Thanks in advance!
Old 22nd February 2008, 17:37   #14  |  Link
TheRyuu
warpsharpened
I think that patch isn't really proper (at least it didn't work for me).
After some slight editing of it though I managed to get it to work (with a fuzz with the last hunk, but I checked the luminance_masking.c and everything was patched correctly)
Now off to test. I think the patch doesn't have that debug line Dark was talking about so I'll post a build in a bit I guess and see if that helps (it's only a debug line though so does it really matter?)
Edit:
Build:
http://www.fileducky.com/qRILYtae/
It's built with pthreads enabled.
TheRyuu is offline   Reply With Quote
Old 22nd February 2008, 17:58   #15  |  Link
Dark Shikari
x264 developer
Yes, I removed the debug line in the patch so that people didn't accidentally include it Only my build has it.
Old 22nd February 2008, 18:00   #16  |  Link
Dark Shikari
x264 developer
             sum += val;
The maximum value that sum_of_squares can reach is (255 * 255 * 256), or a bit under 2^24, so it is not a problem.
The maximum value that sum can reach is 255*256... so yes, you are right; sum*sum could overflow a signed integer.
The correction would be to make sum and ssd unsigned integers.
Old 22nd February 2008, 18:54   #17  |  Link
squid_80
If the product is going to be divided by 256, why not bitshift before the multiply?
Old 22nd February 2008, 18:58   #18  |  Link
Dark Shikari
x264 developer
Rounding error. Same problem occurred in x264; that was the fix between 0.46 and 0.47.
Old 22nd February 2008, 19:07   #19  |  Link
squid_80
Divide by 256, with rounding:
(x+128)>>8
No good?
Last edited by squid_80; 22nd February 2008 at 19:12. Reason: oops, that's just plain rounding. Rounding upwards would be +251.
Old 22nd February 2008, 19:10   #20  |  Link
Dark Shikari
x264 developer
Divide by 256, rounding upwards:
(x+128)>>8
No good?
It won't give the same result as multiplying before shifting, IIRC.
Patch updated with unsigned fix.
xvid aq, xvid vaq
