#1 | Link |
h264enc & xvidenc author
h264enc for Linux
h264enc is a rather advanced shell script which can help you to encode video files or DVDs to the H.264 video format. It has built-in quality presets (34 so far), supports a lot of video (pre/postprocessing) filters and a few audio filters as well. Further it supports 9 different audio codecs and has a (limited) batch encoding capability. Muxing is also supported for the MKV, MP4 and OGM containers. h264enc by default outputs to AVI and then remuxes it to the chosen container. h264enc heavely relies on MEncoder and MPlayer as it uses both to do the whole setup/encoding
at http://h264enc.sourceforge.net is a FAQ about h264enc, so if anyone is interested, just go put up some coffee and read it through h264enc is also available from my openSUSE build service repo http://download.opensuse.org/reposit...me:/microchip8
openSUSE Linux 64-bit - h264enc - xvidenc - divxenc Fedora & openSUSE repo: http://download.opensuse.org/reposit...me:/microchip8 Last edited by froggy1; 26th April 2009 at 23:44. |
#2 | Link |
Cool.
THX. Simple translation and presentation. http://www.movie2digital.de/thread.p...e7d#post467704 |
#5 | Link |
Fighting spam with a fish
The only problem is, if you make one mistake, you have to start all over again.
FAQs:Bond's AVC/H.264 FAQ,Bond's MPEG-4 ASP FAQ Sites:Adubvideo,MeGUIWiki,MeGUI Ipod Conversion Guide |
#6 | Link |
then don't make a mistake and keep awake :P ... seriously, i've never made a mistake with it, especially when using the presets
openSUSE Linux 64-bit - h264enc - xvidenc - divxenc Fedora & openSUSE repo: http://download.opensuse.org/reposit...me:/microchip8 |
#7 | Link |
No, I mean when entering the values. If you are not experienced with the script, and you enter a wrong value, you end up having to start all over again.
#8 | Link |
yes this is true, but after some time one gets used to it. I think this is the same with all scripts that operate like h264enc, especially those that offer a variety of options
#9 | Link |
ChangeLog for version 8.1.8
- Export testing condition to the batch file for the output of MEncoder and for the output directory as well - Changed FPS naming for Silent Speed to Silent Film - Added support for automatic brightness/contrast control - Bugfix: Only ask for deletion of the AVI file if the user has chosen to remux it to one of the supported containers - Removed duplicate $quiet variable in the video_deinterlace_func() function when deinterlacing with a frame doubler - Modified the -iso option to use 'pv' for DVD ISO dumping instead of 'dd'. 'pv' provides us with a nice progress bar which is useful as it takes a long time to dump a DVD, so the user can follow the progress. 'dd' provides no such thing. - Updated the -iso option to support dual-layer DVD discs (~8.54 GB) - Added support for setting the subtitle alignment - Added support for setting the subtitle Gaussian variance strength when hardcoding subtitles into the movie - Use $IDXFILE variable for the MP4SUB and MKVSUB variables - Tweaks to the HD presets. Increased VBV buffer size to 14475 and set keyint to 14 and keyint_min to 2 for the SD/HD presets. Also increased b-frames usage from 3 to 6 - Various small code improvements - Updated the man page
#10 | Link |
ChangeLog for version 8.1.9
- Updated the DVD chapters code to support the latest SVN version of MPlayer/MEncoder - Small improvements to the cropping code - Fall back to 'dd' for ISO dumps if 'pv' is not available on the user's system - Set default noise pattern to be Luma + temporal instead of Luma & Chroma + temporal - Added support for the lossless format of the Sonic audio codec - Added the X-Men 3 matrix, Q matrix, Q2 matrix, Soulhunter V1 matrix, Soulhunter V2 matrix, MP4Guy's low bitrate matrix, Audionut high bitrate matrix and Audionut general matrix to the package. Thanks to Audionut, MP4Guy and Soulhunter - Bugfix: the ivtc/telecine process should check for the $deintfilter variable instead of the $deintfps one. ivtc/telecine is mutually exclusive with deinterlacing - Improvements to the MP4 muxing part when exporting the options to the batch file. From now on, the FPS needed for MP4Box is directly taken from the AVI file. This approach is much more reliable and the user no longer needs to edit the FPS value for MP4Box when exporting the options of NTSC content to the batch file. - Added one Anime high-quality preset (anihq) - Updated the presets_keyint_func() function - Added support for the Tfields deinterlacer @ original frame speed and Tfields + fast/medium/slow/slowest Mcdeint @ original frame speed - Replaced a few 'if' conditionals with 'case' conditionals - Updated the README.matrices file - Typo fixes - Updated the man page
#12 | Link |
Mainly a bugfix/code clean up release. ChangeLog for 8.2.0
- Fixed a bug in the deint_custom_fps_func() function. Variable deintfsp for NTSC @ 59.94 fps should be deintfps - Fixed a bug in option 8 of the $dfilter variable which was using a invalid underscore. Should be -field-dominance 1 instead of -field_dominance 1 - Clean ups of old commented out code - Reordered the deinterlacing menu. Separated the normal deinterlacers from the frame doubling ones - Small improvements to the audio_channels_func() function - Renamed variable $ss to $softscale - Added two iPod Classic presets for iPods that support only H.264 @ Level 1.3 (icvp and ichqvp) - Updated the README.h264enc file - Updated the man page
#13 | Link |
ChangeLog for version 8.2.1
- Removed the 'user defined' option from the deint_custom_fps_func() function as it can confuse users who don't really know what to enter there - Added support for different audio resampling modes - Added support for the 'lavcresample' audio resample filter - Made the audio_resample_func() function to be menu driven - Converted the MKV/MP4/OGM code to base its decision on variable $audiocodec instead of variable $audcodec. Makes the code less complicated - Updated the 'preset.cfg' file. Custom presets now support the following additional options: ratetol, vbv_maxrate, vbv_bufsize, vbv_init and cqm and me_prepass - Preparations for the motion estimation prepass patch - Added support for automatic detection of the video aspect - Don't continue if MEncoder exits with a non-zero status - Added two Black & White/Gray presets for BW movies (bw and bwhq) - Small improvements to the custom_matrix_func() function - Small improvements to the DVD titles scanning code - Small improvements to the check_diskspace_func() function. Patch by Gunter Ohrner - Updated the -sc option - Variable renamings and clean ups - Updated the man page
#14 | Link |
ChangeLog for version 8.2.2
- Added support for calculating the video bitrate when encoding with the NOSOUND audio option - Added support for calculating the video bitrate when using the PCM audio codec - Converted the code for the bicubic software scaler parameters to be menu driven - Added one 'Insane High Quality' preset (ihq) which uses the Hadamard-based motion estimation algorithm - Enabled AAC audio support for the Matroska container. Please upgrade your mkvtoolnix to the latest SVN version! - Notify the user that the frame rate will change when using the inverse telecine/telecine filters - Clean ups in the MP4 muxing code - Improvements to the batch exporting code - Updated the man page
#16 | Link |
ChangeLog for version 8.2.3
- Added support for doing 60p -> 30p, 60p -> 24p and 50p -> 25p FPS conversion. Useful for HD content that runs at 59.94 or 50 fps. This option is mutually exclusive with interlacing and frame doubling deinterlacing filters - Added two Nokia S60 presets (nkvp and nkhqvp). Thanks to Matteo Croce (mp4tools) for the device info - Colorized automatic actions/info/menus - Fixed a small bug in the manual codec configuration where calculating of the keyint_min value fails - Updated the man page
#17 | Link |
ChangeLog for version 8.2.4
- Bugfix: forgot to add tinterlace before the detc filter for 60p -> 24p FPS conversion - Removed the '-p help' option as it is not very useful. --help displays everything one needs to know - Added more 60p -> 24p FPS conversion filters and set default filter to framestep=2,filmdint=fast=0 which gives the best results - Disabled colorspace conversion when interlacing, telecining or when doing FPS conversion as some of the filters (most?) don't like it. Also disabled colorspace conversion for the Nokia S60 presets - Made the script to use unique temporary directories to store the config/parsing files. That way, one can run multiple instances of h264enc at the same time without interference - Modified the batch exporting code to work with unique directories - Updated the man page
#19 | Link | |
| Tags |
| h264enc, ipod, mencoder, ps3, xbox360 |
| Thread Tools | |
| Display Modes | |
