4th February 2008, 09:25 | #21 | Link |
IgorC especialy for Low Bitrate scenarios the New AQ is important for mixed type of sources and Mainconcepts Encoder would have problems in many scenes holding the quality constant but that's also the difference between Mainconcept and Ateme and now to a degree X264 they have been designed for Broadcasting.
Mainconcepts own Encoder wasn't designed for that it is the most efficient and fastest HD-DVD and Blu-Ray Encoder, but in Broadcasting it would loose currently versus it's competition and X264 in this regards is with Dark Shikaris AQ very well balanced for both Scenarios , tough Ateme is still some Generations ahead of X264 and Mainconcept/Elecard in R&D especialy everything that has todo with low bitrate psychovisual optimizations (those are esential for Broadcasting).
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
4th February 2008, 09:33 | #22 | Link |
Dark Shikari QNS should make the picture not so blurry anymore right (more like the input)?
4th February 2008, 09:35 | #23 | Link | |
x264 developer
Try it and see, though right now the 4x4 artifacting somewhat obscures its real effect. If I had to guess what Elecard's three "quant modes" are, I would guess Deadzone, Trellis, and QNS, respectively. Last edited by Dark Shikari; 4th February 2008 at 09:41. |
4th February 2008, 14:13 | #26 | Link | |
But in medium or fast modes MC is better for the same speed. To match the same speed x264 with MC should low subme from 6/7 to 5. And that's where x264 is worse than MC. And AQ won't help. Not everyone want +0.5-1 SSIM at cost of 2-3x (or even more) speed lost. Try for yourself last MC or Elecard with all fasts enabled and compare it to x264 at the same speed with AQ and other bleeding edge new stuff. Why don't optimize x264 at fast speed? It has nothing to do with AQ and other last Pengvado's and Dark Shikari's improvements. That's why MC is a good to compare to it. We are talking about two different directions of development which in conjunction will be very good. Speed and Quality. Just think: fast encoder and very high quality. Last edited by IgorC; 4th February 2008 at 14:20. |
4th February 2008, 14:29 | #27 | Link | |
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 4th February 2008 at 14:37. |
4th February 2008, 14:44 | #29 | Link |
yes and that's why i say X264 is very good balanced and improves steadily in both directions and doesn't shift only in 1 direction, and you should know that first come the features and stability and then comes the speed optimizations
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 4th February 2008 at 14:50. |
4th February 2008, 16:32 | #30 | Link |
Testeur de codecs
Mainconcept/Elecard core codec have AQ implementation. AQ is simply not actived in Mainconcepts Reference H.264 Encoder Gui. You can set lumi/contrast/complexity AQ with Mainconcept/Elecard encoder (with Sonic Scenarist Gui for example).
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 |
4th February 2008, 16:47 | #31 | Link |
x264 developer
QNS is now working. A bit faster than before, but still drastically slower than it should be. Next steps are to optimize speed and tweak the parameters.
Edit: Diff updated to fix bug with artifacting at high QPs. Last edited by Dark Shikari; 4th February 2008 at 23:13. |
4th February 2008, 17:16 | #32 | Link |
Very user friendly indeed you pay 490/1790 € for no AQ option, the cheapest Nero Recode has that and it cost's alot less than that
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 4th February 2008 at 17:22. |
2nd April 2008, 09:57 | #39 | Link |
Testeur de codecs
Here some Developement if you want that x264 became professional tool for high bitrate encoding like VC1 from CinevisionPSE or H264 from Mainconcept.
- Black level normalisation: use 3D filtering for denoise/degrain in dark area [16-40]. It's a psy filtering pre-process (use with dark AQ is a good psy way) - Dark area improvement: use AQ with dark masking for improve dark area quantisation (use with dark filtering is a good psy way)
2nd April 2008, 17:46 | #40 | Link |
Sagittaire under which viewing conditions (calibration) do you rate X264 Visual subjective Quality in Dark areas?
