Old 23rd April 2008, 18:32   #1141  |  Link
roman76r
musidora
On the other hand, it supports the dvdsub. Do you plan to support this format ?
Yes, conversion to DVD and DVB sub is the next step.
Atak_Snajpera
Will be difficult to implement ANSI support as well?
No, it is not difficult. I'll add ANSI encoding today.
crazyfool30
Do the subtitles automatically output to the resolution of the video or do you recommend having different font sizes for 720p and 1080p?
The subtitles automatically output to the resolution of the video. Default font size optimal for 1080p resolution, for 720p you need to change size manually.
roman76r is offline   Reply With Quote
Old 23rd April 2008, 18:44   #1142  |  Link
Lacix
Yesss..
The only remaining big issue creating perfect AVCHD discs is the need to reencode the video because of the cropped size.
Lacix is offline   Reply With Quote
Old 23rd April 2008, 18:47   #1143  |  Link
mikegee2
Originally Posted by buggymonkey View Post
ah Man your the man ,
many thanks for that works a treat
although I did manage to combine with TSsplitter to but is not as quick
to mikegee2 I just ignore the errors muxed the video , AC3 and english PGS on each or the 2 movie streams 0000.m2ts and 00001.m2ts and then added the first , appended the second now have one complete movie stream of 27.5GB ish
plays in nero and on my media tank no problem
Worked!!!! thanks
mikegee
mikegee2 is offline   Reply With Quote
Old 23rd April 2008, 18:55   #1144  |  Link
Glorioso
Roman, i'm starting with a 4.37gb file and i end with a 4.6gb project, cant fit it in a DVD-5, can i split it? Or is there any tool to trim some of the MKV?
Glorioso is offline   Reply With Quote
Old 23rd April 2008, 19:16   #1145  |  Link
roman76r
Glorioso
You can cut several munites from beginning and ending of flie by means of tsMuxer. Use split&cut tab.
Old 23rd April 2008, 19:20   #1146  |  Link
B4tm4n
Caped Crusader
B4tm4n's Avatar
I've used a 1280x720 mkv and added srt subs. Its muxed to a blu-ray structure fine. When playing on a PS3 I can turn on and off the subs but no subs show up.
I'm using the AVCHD folder method to play from a Fat32 drive, I clicked on the split @4 GB option.
B4tm4n is offline   Reply With Quote
Old 23rd April 2008, 19:38   #1147  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
I've noticed the same problem but with Blu-Ray structure on DVD in my case. 1080p or 720p doesn't matter.
Old 23rd April 2008, 19:51   #1148  |  Link
Glorioso
Glorioso
Didn't notice the cut feature, but the Split didn't work, i choose 4.37 but the final project was 4.6gb
Old 23rd April 2008, 19:59   #1149  |  Link
Atak_Snajpera
1GiB = 1024 MB (windows MB
1GB = 1000 MB
Old 23rd April 2008, 20:02   #1150  |  Link
survivant001
I assume that the subs doesn't work yet on the PS3 ?
survivant001 is offline   Reply With Quote
Old 23rd April 2008, 20:04   #1151  |  Link
Atak_Snajpera
Simply they do not show up
Old 23rd April 2008, 20:10   #1152  |  Link
B4tm4n
Caped Crusader
B4tm4n's Avatar
The split function wont reduce the overall size, it will just split the main movie mts file into chunks of whatever size you choose.
Old 23rd April 2008, 20:23   #1153  |  Link
roman76r
B4tm4n
Can you check sub on PS3 in 1080p mode?
Old 23rd April 2008, 20:26   #1154  |  Link
B4tm4n
Caped Crusader
B4tm4n's Avatar
B4tm4n
I don't have anything in 1080p on my hard drive at the moment.
I'm in the process of redoing the 720p file again on a different machine just to make sure its not a machine issue.
But Atak_Snajpera did post saying it didn't work at 1080p either.
Old 23rd April 2008, 20:55   #1155  |  Link
roman76r
B4tm4n
Atak_Snajpera
Please, check your movies in powerDVD. Subs are visible?
Old 23rd April 2008, 20:59   #1156  |  Link
B4tm4n
Caped Crusader
B4tm4n's Avatar
B4tm4n
Atak_Snajpera
I don't have power dvd but I have downloaded a 1080p sample and I'm trying that out now.
The remux on a different machine didn't show subs either.
Damn the 1080p is cropped and that doesn't seem to play at all.
Old 23rd April 2008, 21:12   #1157  |  Link
Glorioso
B4tm4n
Atak_Snajpera
I've got the same problem, i can select the sub in PS3 but the subs wont show. Power DVD says may PS isn-t suitable for BluRay...
Old 23rd April 2008, 22:36   #1158  |  Link
Erdelamoto
Hello,
Sorry for my bad English.
I have the same problem B4tm4n
Atak_Snajpera and Glorioso.
But, I have a temporal solution for 720p Movie working with subtitles.
-Open the Mkv and the srt with tsMuxer.
-Demux the Srt in sup with tsMuxer (720p)
-Open this sup with Supread, export this sup with supread (this new sup is 1080p but the position of the subtitles are correct for 720p).
-Open again the Mkv with tsMuxer, add the new sup 1080p of supread.
-Create the BluRay structure.
-Play with PS3, the subtitles show up correctly.
This is working for me.
Erdelamoto is offline   Reply With Quote
Old 23rd April 2008, 22:52   #1159  |  Link
roman76r
Erdelamoto
Good news. This method can help me to solve a problem.
I found several minor difference between my PGS track and reference PGS track from Blu-ray disk.
version 1.8.1(b)
Also, this version allow to add .SRT tracks in both Unicode and ANSI formats.
Old 23rd April 2008, 23:00   #1160  |  Link
DoomBot
I cant download the latest version with your link roman.
DoomBot is offline   Reply With Quote
tsmuxer
