#3521 | Link | |
turbojet
Please, try new version: www.smlabs.net/tsMuxer/tsMuxeR_1.10.5.zip Now I began to use information from Alpha channel of source PGS stream. It is solves 1-st problem. Also, I've chaned behaviour of "bottom-offset" option in scaling mode: now this options interpreted as addition vertical offset from original subs position. Quote:
#3522 | Link | ||
As for the colored subs the orange background is gone but the letters have red spots on them which makes it hard to read Quote:
Also since there is still 1 possibly 2 players that can't have that pesky AUXDATA directory is there a chance for an option to remove CERTIFICATE/BDJO/JAR/META directories? Maybe a checkbox defaulted off to the right of demux? |
#3524 | Link |
They should be solid yellow.
The same issue came up in BDSup2Sub awhile back and I believe it had to do with Cr/Cb One other, I think simple, feature request I had from a few weeks ago is having an input command for tsmuxergui in CLI. Example: 'tsmuxergui test.mkv' opens tsmuxergui and loads test.mkv My main reason for this is open with working correctly like so many other windows gui's do. Is something like this possible? Last edited by turbojet; 10th May 2009 at 21:28. |
#3525 | Link |
Life looks better in HDTV
Out of interest... How difficult would it be to include the ability to convert DVD style "idx/sub" subtitles to Blu-ray "sup" subtitles?
Still confused about anamorphic images? Then look here! | Main Encoding Interests: Hardware device playback | My Gear | |
#3530 | Link | |
turbojet
Now, I've find a bug with color subtitles. Please, try again: www.smlabs.net/tsMuxer/tsMuxeR_1.10.6.zip Quote:
All I plan to add ASS/SSA and DVD subs as next feature. |
#3531 | Link | |
There are actually 4 folders I must need to delete before powerdvd9 play output from tsmuxer 1.8.4: BDJO+JAR+META+AUXDATA. i'm using powerdvd 9.0.1501 ultra. |
#3532 | Link |
You're most definitely "the man"...
#3533 | Link |
h264enc & xvidenc author
that's awesome. I've been waiting for DVD subs support for quite some time
openSUSE Linux 64-bit - h264enc - xvidenc - divxenc Fedora & openSUSE repo: http://download.opensuse.org/reposit...me:/microchip8 |
#3534 | Link | ||
DVD subs are dvd sup files? Is vobsub input possible? Dp you have any thoughts on 'strict AVCHD output' option which deletes the empty directories for a few players? Also I see vertical offset affects sup files too, this could have some unwanted results for sup files. Would it be possible to split srt and sup vertical offsets and set sup offset to 0 by default? Quote:
#3538 | Link | |||
turbojet
#3539 | Link |
As far as I'm concerned, the quality of a subtitle only needs to be such that I can read it, can't say I'm that bothered if the edges of the letters don't blow me away with their sharpness.
If you're making custom subs, DVD subtitles are much easier to create and are more likely to have been created already by someone else saving a lot of time. OK, so the quality might not be great but who cares if it's only 10-20 captions throughout the whole film. Also, it's just a feature, it's not like you have to use it! If you don't need it or don't like it, fine but that isn't a reason to not give others the option. |
#3540 | Link | ||
Sort of unrelated is there currently isn't a direct BD sup -> DVD sup tool, let alone a tool that can encode BD to something playable in DVD players. It would be very useful for enthusiasts that are planning to upgrade to BD but not quite ready and currently buying DVD because they can only play it. Or people that already own a BD player but they also want to be able to play the movie on DVD players. I realize menus are more less impossible to convert but I'm surprised there's no movie only tool yet. Last edited by turbojet; 11th May 2009 at 17:58. |
| Tags |
| tsmuxer |
| Thread Tools | |
| Display Modes | |
