Old 16th April 2009, 10:38   #3341  |  Link
Discoboy
Originally Posted by turbojet View Post
Is anyone else seeing the muxing stop in TSMuxerGUI 1.9.9 when minimizing/restoring the program?
I'm using vista x64 and it happens with m2ts/mkv inputs and all possible outputs.
Yes I've just noticed the same issue on Vista x64 sp1 with m2ts inputs also
Discoboy is offline   Reply With Quote
Old 16th April 2009, 17:12   #3342  |  Link
TiVoMad
I am about to convert my HD-DVD collection to m2ts (so I can play on a Popcorn Hour). I would like to keep the hi-def audio if possible. When I use eac3to to de-mux the truehd track in its native form, TSMuxer will not accept it as input. Is this because it has no AC3 core in there? Is there a way round this or do I need to convert to lpcm to keep the quality ?
Sorry if this was already answered, it's a long thread.
TiVo.
TiVoMad is offline   Reply With Quote
Old 16th April 2009, 17:20   #3343  |  Link
SomeJoe
eac3to.exe can add the interleaved .ac3 track for BD compatibility. (The following assumes that the input HD-DVD structure contains a TrueHD track).
eac3to.exe "<input>" <title>) <track>: "<output path>.thd+ac3"
- SomeJoe
SomeJoe is offline   Reply With Quote
Old 17th April 2009, 10:06   #3344  |  Link
TiVoMad
Works a treat, thank you very much. I did not realise you could do that
Old 17th April 2009, 12:03   #3345  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
roman76r: Is there a possibility for this command line option so open with works correctly: tsmuxergui.exe <input file>
same here on win xp sp3
shon3i is offline   Reply With Quote
Old 17th April 2009, 12:25   #3346  |  Link
ACrowley
yes! i can confirm this Problem.
TSmuxer stops working/muxing as soon i minimize the gui.
Independed from Source/Output Format on Vista x64
ACrowley is offline   Reply With Quote
Old 17th April 2009, 12:44   #3347  |  Link
Octo-puss
Please update the first post with the latest version, it is getting a bit messy Thank you.
Octo-puss is offline   Reply With Quote
Old 17th April 2009, 18:23   #3348  |  Link
idbirch2
Strange, no problems with minimizing the GUI on Windows 7 x64.
idbirch2 is offline   Reply With Quote
Old 17th April 2009, 18:41   #3349  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
A possible bug report:
m2ts/ts files sometimes cannot report framerate (at all).
When tsMuxeR cannot detect fps and it is explicitly set (or detected) in .meta - file is created properly but mediainfo (not tsMuxeR itself) can detect the original FPS from the resulting m2ts/ts file.
Dean
edit: Please add a --log=filename.txt option.
Old 17th April 2009, 19:04   #3350  |  Link
Furiousflea
Originally Posted by ACrowley View Post
QUOTE=turbojet;1274548]Is anyone else seeing the muxing stop in TSMuxerGUI 1.9.9 when minimizing/restoring the program?
I can confirm same behaviour here using the gui. (vista x64\tsmuxer 1.9.9)
Furiousflea is offline   Reply With Quote
Old 17th April 2009, 19:24   #3351  |  Link
tim83
Guys,
I'm getting the follwing error when trying to generate a AVCHD from a MKV file:
Matroska parse error: Invalid EBML number size 0 at pos 1932375627
This is the tsmuxer output:
SmartLabs tsMuxeR. Version 1.9.9 http://www.smlabs.net
Decoding H264 stream (track 1): Profile: High@4.1 Resolution: 1280:536p Frame rate: 23.976
H.264 muxing fps not set. Get fps from stream.
H264 bitstream changed: insert nal unit delimiters
H264 bitstream changed: insert pict timing and buffering period SEI units
Decoding DTS stream (track 2): Bitrate: 1536Kbps Sample Rate: 48KHz Channels: 5.1
B-pyramid level 1 detected. Shift DTS to 2 frames
H264 bitstream changed: insert SPS/PPS units
Decoding PGS stream (track 3): Resolution: 1280:536 Frame rate: 23.976
Any help is appreciated! Other movies demux just fine.
tim83 is offline   Reply With Quote
Old 17th April 2009, 20:08   #3352  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
BTW. AVCHD/BD requires 1920x1080, 1280x720 , 720x576 or 720x480!
Old 17th April 2009, 20:19   #3353  |  Link
tim83
Thanks for your reply, but I don't think that this is related. Other movies with similar resolutions process just fine. tsmuxer crashes when the MKV has already been processed for 42% or so. Maybe some other thoughts on this?
Old 17th April 2009, 20:39   #3354  |  Link
schlaufer
schlaufer's Avatar
tim83: did you try to (re-)process the file with mkvmerge to ensure, that it is not damaged?
schlaufer is offline   Reply With Quote
Old 17th April 2009, 21:25   #3355  |  Link
deank
deank's Avatar
Originally Posted by tim83 View Post
Guys,
EBML is bound to have all elements with non-zero sizes. It is either a wrong segment (withing EBML E_ID size data) or tsMuxeR confuses zero length bits value with zero based length of a tag (which otherwise should have a length of 1).
It is better to send a sample to Roman.
Old 17th April 2009, 23:39   #3356  |  Link
kurt
sidekick
kurt's Avatar
yes, same here. had to start muxing like 10 times today (which sucks if u save to an external HDD)
(XP Prof SP3)
greets, kurt.
Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC
kurt is offline   Reply With Quote
Old 18th April 2009, 12:20   #3357  |  Link
moleyman69
just looking for a quick bit of advice.
All I use tsmuxer for is remuxing blu-ray m2ts files to rip out all languages I don't need. I don't create any mini Blu-Rays or anything like that.
Is there a particular "best" version for just doing this type of remuxing?
Many thanks,
Moley
moleyman69 is offline   Reply With Quote
Old 18th April 2009, 14:42   #3358  |  Link
jamos
Hey Now!
Originally Posted by belcampo View Post
SInce 1.9.1 -1.9.9 I can't produce files that my PopCornHour accepts, with h.264 and aac. The older tsMuxeR_1.8.18(b).zip although works fine.
um youd be better muxing that to a .mkv using mkvmerge if your using aac for popcorn hour (how I do aac).
Also you can use different versions of tsmuxer (I do constantly due to various bugs some versions present) on the same machine just put them in folders with the version name on it.
jamos is offline   Reply With Quote
Old 19th April 2009, 08:13   #3359  |  Link
pleinlesyeux
Hi !
I have a very small bug to report.
I demux my streams with eac3to prior to remux with tsmuxer.
I always keep english and french supscripture.
Using the GUI, i can specify the langage, which I do.
The panasonic bd55 recognises .ENG track perfectly, but displays * for the french one. So I need to set it up manually, which is not a big problem.
I just wanted to report it...
pleinlesyeux is offline   Reply With Quote
Old 19th April 2009, 09:41   #3360  |  Link
mrr19121970
can you please post a sample .meta file ?
mrr19121970 is offline   Reply With Quote
tsmuxer
