8th April 2009, 08:22 | #3162 | Link | |
http://forum.doom9.org/showthread.php?t=134104&page=153 |
8th April 2009, 11:02 | #3167 | Link |
1st thanks for the excelent muxer, needed this tool badly for my PCH for playing over a nfs-share, ffmpeg created ts files often stuttered.
Now I was adding dvb-based teletext subtitles, demuxed with projectx, to srt format which play fine on the PCH, but NOT with mplayer under linux. I discovered that a file muxed from raw mpa mpv files, made by projectx, always starts with time code of about 600. So the srt is 10min ahead of what is displayed. Playing the mpv with the srt is OK. The PCH doesn't seem to care. An older Windows-version of tsMuxeR began time-code with 4200 as far as I remember. Is there any reason for this, or am I doing something wrong? |
8th April 2009, 12:39 | #3168 | Link | |
I try with w64 files generated by eac3to, BeHappy, Soundout and Audacity. Always the same message: "Can't detect stream type. File name: D:\x\test.w64"
8th April 2009, 15:36 | #3170 | Link |
New error message in 1.9.2 :-( Its not in 1.8.24
The Bourne Trilogy (Box Set) Bourne Ultimatum Some tracks not recognized! In this m2ts file there are 3 VC1 tracks , one is 1920*1080p and the other 2 are 720*480p, could that be the problem in the latest version. like I say its not in the 1.8.24 version And there are also 1 DTS-HD MA, 2 DTS and 1 AC3 track. And a few PGS stream Last edited by piratburner; 8th April 2009 at 15:52. |
8th April 2009, 20:20 | #3172 | Link |
Life's clearer in 4K UHD
Bummer..... Looks like you forgot: -
8th April 2009, 23:38 | #3174 | Link | |
New version of tsMuxeR: http://www.smlabs.net/tsMuxer/tsMuxeR_1.9.4(b).zip
Change list: - fixed problem with interlace VC1 streams (stream was not detected). SeeMoreDigital I changed this in the last version 1.9.4 tebasuna51 Quote:
9th April 2009, 00:31 | #3175 | Link |
Last used linux versions tsMuxeR_static_1.8.35(b).tar.gz tsMuxeR_1.9.1(b).tar.gz can't mux for PCH anymore, am I the only one ?
Mediainfo says video Delay : 10mn 0s 0ms audio Delay : 10mn 0s 0ms see former post of me. Muxing same streams with MP4Box are played well on the PCH |
9th April 2009, 00:42 | #3176 | Link | |
regards |
9th April 2009, 08:43 | #3177 | Link |
Version 1.8.8 creates a playable file for the PCH, although also wit weird delay info.
Both audio and video according to mediainfo have a delay of 1h 9mn 59s 0ms Info on the PCH gives 21845fps for progressive material and 43690 for interlaced. |
9th April 2009, 09:08 | #3178 | Link | |
9th April 2009, 11:55 | #3179 | Link | |
http://bluray.highdefdigest.com/1708...rtifiable.html |
tsmuxer |
