Old 12th February 2008, 23:20   #241  |  Link
jamos
Hey Now!
Originally Posted by [)370|\|470!2 View Post
http://forum.doom9.org/showpost.php?...&postcount=133
The only workaround would be to split a file before using tsmuxer. Personally, i wouldn't use it at all, it sux. Plain and simple.
just use H264TSCutter to ts then tsremux to mux the ts back into a m2ts.
jamos is offline   Reply With Quote
Old 13th February 2008, 00:53   #242  |  Link
Let's show a little patience and respect for the author. This tool is in early development.
Old 13th February 2008, 01:45   #243  |  Link
Creator1
Originally Posted by theblind View Post
Hi !
Both
In the header of the videostream: 1080i + 30p.
but the videostream is 1080p + 24p.
Why ?
I think: in the beginning of HD-DVD, Toshiba concept was: 1080i and 60 hz and the header helps the old Thosiba Hardware to convert.
Cu.
That would make sense and explain why you can use VC-1 files from HD-DVD directly with Scenarist BDA and all works fine. The file might be encoded in 24p but there are 3:2 pulldown flags present. Maybe blu-ray simply ignore those flags during playback or scenarist removes them during muxing.
Creator1 is offline   Reply With Quote
Old 13th February 2008, 10:31   #244  |  Link
LOGiC
@Roman
I have one more question or feature request, but I don't know if this is possible. I know that it is open source, but do you think it would be possible to add x264 to .ts or .m2ts muxing ability ? That would be great but due to the high amound of different variations it could be possible. This feature surely would rock.
Thanks in advance.
LOGiC is offline   Reply With Quote
Old 13th February 2008, 11:32   #245  |  Link
zeroprobe
You add nothing to the topic. Please go away, this tool works great on the PS3.
zeroprobe is offline   Reply With Quote
Old 13th February 2008, 12:39   #246  |  Link
theblind
Hi !
I think: the PS3 have a forced output in the 1080p 24p option. It ignore the 1080i flag. But if the PS3 must play 1080i, the stream stutter.
Cu.
theblind is offline   Reply With Quote
Old 13th February 2008, 14:12   #247  |  Link
n0mag!c
use 'r'
n0mag!c's Avatar
Originally Posted by dirkr View Post
it works CORRECT! Muxed 2 movies today and both are in sync!
the movies were 1080p 23.976fps MPEG-2?
Do you watching movies on PC? 'cause it's a little bit hard to see muxing bug on PC. but when watching movie on TV with enabled feature like philips' DNM (digital natural motion) then the bug is obvious - playback stutters.
I use "tsremux" and burn AVCHD disks then watch it on PS3. when I don't use "tsmuxer" and use original TS stream captured from digital tuner or M2TS from bluray, then movies plays correct. Also movies with H.264 video (VC-1 I didn't test yet) plays correct after beeing muxed with "tsmuxer".
Hope Roman fix this problem, or maybe author of "tsremux" will add correct support for .mkv files. And then I can use "mkvmerge" instead of "tsmuxer".
n0mag!c is offline   Reply With Quote
Old 13th February 2008, 18:09   #248  |  Link
phigment
@roman76r
Can you release the source code?
I would like that as well. It would be nice to have a linux port of this tool!
phigment is offline   Reply With Quote
Old 13th February 2008, 19:17   #249  |  Link
Bigmango
+1000000
Bigmango is offline   Reply With Quote
Old 15th February 2008, 23:02   #250  |  Link
adalbertoma
This is a great software and looks even more promising if subtitles and blu-ray output is implemented.
Any other word from the author? Right now it seems to me that he has quit working on this...
adalbertoma is offline   Reply With Quote
Old 15th February 2008, 23:18   #251  |  Link
jamos
Hey Now!
Yes he has been quiet.
Old 15th February 2008, 23:34   #252  |  Link
Zow
Originally Posted by Zow View Post
I have to ask a perhaps really stupid question:
I have been waiting for subtitles implementation. I assume it would mean that when I rip a Blu-Ray title to my drive as a .ts file (or .m2ts,) I'll be able to play it from the drive, with subtitles.
But, I also would like to shring the file size a bit. I've been ripping all my DVDs to H.264 MKVs, and have been very happy with the result. I'd like to be able to do the same with my BR/HD-DVD titles - shrink them to about 4-6GBs per title (drive space is cheap, but not that cheap.) I just HATE having to deal with disks.
If I can get the main title, plus selected audio, plus subtitles to a .ts or .m2ts file with smartLabs tsMuxeR, would I then be able to import this file to something like AutoMKV or RipBot, and convert to a H.264 MKV?
Can someone try to answer this. I am putting all my hopes on on this app, but maybe I am not seeing something...
Alternatively, is there another app which can do H.264 MKVs from HDDVD and Blu-Ray, and which is close to idiot-proof?
Zow is offline   Reply With Quote
Old 16th February 2008, 19:15   #253  |  Link
imrang
Guys.. I have a problem playing an m2ts file that contains 4.1 H264 stream and AC3 audio. The darn thing is totally black and just plays audio on the PS3. I am almost 100% sure of the fact that it is because the H264 elementary stream is at a resolution of 1280x536. Can anyone give me some suggestions on how to fix this.
What i did to make the file:
Mkvextractgui -> elementary h264 and ac3
h264info ->level 4.1
tsmuxer -> .ts file
tsremux ->m2ts
imrang is offline   Reply With Quote
Old 16th February 2008, 20:12   #254  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
What settings did you use to encode mkv file?
You are 100% wrong PS3 plays none standard resolutions without problems (exept bluray)
Old 16th February 2008, 21:00   #255  |  Link
imrang
I didn't re-encode... I simply demuxed the streams, reduced the H264 level to 4.1 (didnt touch any other settings in h264info) then muxed them in tsmuxer then remuxed to m2ts using tsremux
Old 17th February 2008, 00:02   #256  |  Link
Atak_Snajpera
File was encoded with too many reference frames so you may forget about playing this file without re-encoding
Old 17th February 2008, 01:23   #257  |  Link
imrang
ok this makes more sense.. can you give me a few details on what i need to do to re-encode the file to make it playable on the ps3? Is there a command line i can issue that shows no loss in quality?
Old 17th February 2008, 15:19   #258  |  Link
kurt
sidekick
kurt's Avatar
feature request
appending automatically of multiple m2ts files
coz importing of +40 m2ts-files by hand can be a pain in the a$$
greets, kurt.
Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC
kurt is offline   Reply With Quote
Old 17th February 2008, 17:15   #259  |  Link
jamos
Hey Now!
you can use megui and xolos Bluray format works well look in the mpeg4 encoder section.
Old 17th February 2008, 19:52   #260  |  Link
imrang
jamos, megui crashes everytime I try to load an elementary .h264 file to re-encode. Can you give me some help? I thought megui could re-encode .h264 elementary streams?
tsmuxer
