Thread Tools Display Modes
Old 25th January 2008, 01:25   #1  |  Link
roman76r
smartLabs tsMuxeR: Transport Stream muxer
Supported output formats:
- TS
- M2TS
- Blu-ray
Supported video codecs:
- H.264
- VC-1
- MPEG2
Supported audio codecs:
- AAC
- AC3 / E-AC3(DD+)
- Dolby True HD (for streams with AC3 core only)
- DTS/ DTS-HD
- LPCM
Supported subtitles:
- M2TS Presentation graphic stream
- SRT text subtitles
Supported containers and formats:
- elementary stream
- Transport stream TS and M2TS
- Program stream EVO/VOB/MPG
- Matroska MKV/MKA
Additional features currently implemented:
* Ability to set muxing fps manually and automatically
* Ability to change level for H.264 streams
* Ability to shift a audio and subtitle tracks
* Ability to extract DTS core from DTS-HD
* Ability to extract AC3 core from Dolby True HD
* Ability to join files.
* Ability to change fps for a subtitle tracks.
* Ability to convert between Blu-ray LPCM format and WAVE files.
* Writing language information to the Blu-ray disk and to the TS/M2TS language descriptor.
* Ability to cut source files
* Ability to split output file
* Ability to detect audio delay for TS/M2TS/MPG/VOB/EVO sources
* Ability to remove pulldown info from stream
* Ability to open Blu-ray playlist (MPLS) files
* Ability to convert SRT subtitles to PGS
Current Version 1.8.4(b)
Version 1.8.4(b) - Windows
Version 1.7.3(b) - Linux (console only)
History
* Version 1.8.4(b)
- Ability to convert SRT to PGS added.
- Some minor bugfixes.
* Version 1.7.6(b)
- Ability to open Blu-ray playlist (MPLS) files added. Also, when MPLS file is opened, chapters list automatically imported.
When MPLS is processed, "Clean Break" for connection_condition=5 correctly processed. It is actually for large playlists (10 M2TS files and more).
- bug fixed: some H.264 streams in version 1.7.1/2/3 did not work in PS3. It is the same problem it was corrected in version 1.7.3. Fixed again.
- bug fixed: Issue with muxing PGS stream from several source files (i.e. append mode) fixed.
* Version 1.7.3(b)
- Improved M2TS splitting in Blu-ray mode
- bug fixed: some H.264 streams in version 1.7.1/1.7.2 did not work.
* Version 1.7.2(b)
- Issue with demuxing PGS to SUP format fixed.
* Version 1.7.1(b)
- Bug fixed: Now pulldown info correctly processed.
- Ability to remove pulldown info from stream added. All video codecs are supported: H.264, VC-1, MPEG2.
- Some small bug fixes and improvements. Also tsMuxeR package size is decreased and dependings to other libraries have been removed.
* Version 1.6.3(b)
-Bug fixed: PTS/DTS timing for MPEG2 streams without GOP headers filled wrong
-Bug fixed: CBR muxing mode since version 1.6 worked wrong
-Bug fixed: trim function did not work for minutes measure unit
-Ability to detect audio delay for TS/M2TS/MPG/VOB/EVO sources added
-Drag&drop for GUI added
* Version 1.6.1(b)
- Option to split output file added.
- Option to cut source files added.
- Bug fixed: TS PTS/DTS timing filled wrong for some progressive H.264 streams, if frame data was ahead SPS/PPS data in source stream.
* Version 1.5.1(b)
- Issue with TRUE-HD tracks demuxing fixed.
* Version 1.5.0(b)
- Added LPCM support
* Version 1.4.6(b)
- Fixed a bug with synchronization of a H.264 stream and audio. This bug was appear on some streams only. When there was this bug, In a log were printed many messages "B-pyramid level 2 detected","B-pyramid level 3 detected" e.t.c.
* Version 1.4.5(b)
- Fixed blu-ray folders names
- Added chapters for Blu-ray muxing
* Version 1.4.4(b)
- Added Blu-ray muxing mode
- Added demuxing mode
- Added Presentation Graphic stream support
- Added language descriptor support
* Version 1.2.9
- Fixed MKV parsing module. Some MKV files did not work (lace sice invalid detected for xiph laces, this cause access violation error)
* Version 1.2.8
- Fixed AC3 stream detection. Some AC3 streams were not recognized (broken in version 1.2.6 only)
* Version 1.2.6
- Added Dolby True HD support
- Added MPEG audio layer 1/2/3 support
- Fixed a bug in the M2TS parsing module. Sometimes TS frames were lost.
- Fixed a bug in the Matroska parsing module. Short NAL unit len codes for H.264 tracks did not work.
* Version 1.2.0:
- Added M2TS muxing
- Fixed stream type detection function (sometimes some audio/video streams were not found)
* Version 1.1.5
- The first release
roman76r is offline   Reply With Quote
Old 25th January 2008, 02:12   #2  |  Link
tyee
Looks nice, Roman. I'll have to give it a try! Thanks!
You are the author I assume!!
tyee is offline   Reply With Quote
Old 25th January 2008, 09:14   #3  |  Link
yonta
This is the muxer I've been looking for!
Thank you.
a quick test result with EVO/M2TS to TS remuxing
1. DTS/DTS-HD tracks in EVO are not recognized.
2. some DTS tracks in EVO are recognized as mono AAC 96 KHz.
3. DTS/DTS-HD in m2ts is correctly recognized and processed.
4. VC-1 in m2ts is not recognized.
I will test more with elementary stream muxing and report the result.
yonta is offline   Reply With Quote
Old 25th January 2008, 10:23   #4  |  Link
roman76r
Originally Posted by yonta View Post
This is the muxer I've been looking a quick test result with EVO/M2TS to TS remuxing
My tests EVO/M2TS files work fine. Can you give me example (30-50Mb) of your problem M2TS and EVO file?
Old 25th January 2008, 11:19   #5  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Where can I find documentation in english? Provided readme.txt is in russian.
BTW. It would be awesome if we could mux directly to M2TS
Old 25th January 2008, 12:16   #6  |  Link
yonta
please check your pm.
Old 25th January 2008, 15:15   #7  |  Link
hm10
we can to add subtitles?
or you can add support in subs
thx
hm10 is offline   Reply With Quote
Old 25th January 2008, 16:59   #8  |  Link
fbd
roman76r
Could you send me readme.txt in english please?
I have mux some mkv files with h264/ac3 and works fine
Regards
Franck
fbd is offline   Reply With Quote
Old 25th January 2008, 17:01   #9  |  Link
The1n
@Roman
I nearly love u ... this is the tool lots of people have been waiting for THANK YOU!!
The1n
Norway
The1n is offline   Reply With Quote
Old 25th January 2008, 19:12   #10  |  Link
Zow
Thanks roman76r!
Is there a way to do subtitles with this?
If not, any chance of implementing it sometime soon?
Zow is offline   Reply With Quote
Old 25th January 2008, 23:26   #11  |  Link
menlvd
Great tool
menlvd is offline   Reply With Quote
Old 26th January 2008, 00:08   #12  |  Link
The1n
*wrong post* sry
Old 26th January 2008, 00:11   #13  |  Link
roman76r
Zow
I plan to add a subtitles, m2ts muxing, output file splitting and stream demuxing at nearest time.
Old 26th January 2008, 00:26   #14  |  Link
Atak_Snajpera
m2ts muxing should be implemented in first place. Whole PS3 scene is waiting for this BTW Excellent tool! You are a hero!
Old 26th January 2008, 00:33   #15  |  Link
klas
It its possible to convert to bluray and to see in ps3?
klas is offline   Reply With Quote
Old 26th January 2008, 00:47   #16  |  Link
The1n
Zow
This is very promising. Hopefully we'll see muxing of lpcm, dolby true hd in the future.
Old 26th January 2008, 01:05   #17  |  Link
Olebrumm71
Problems with playback of remuxed DTS soundtrack on PS3
Hello!
I just tried to use this new 'tsMuxer' application to mux a H.264/AVC elementary stream (made using HRD patched X264) with a 1536kbit/sec DTS audio track.
The resulting TS file plays well on my computer.
I then ran this TS file through TSRemux 0.18 creating a BluRay output. The resulting .m2ts file (in the STREAM folder) also plays well on my PC.
I then transfer this .m2ts file (renaming it though to .mpg ) to the HD of my PS3. When playing this file on the PS3 the video is perfect, but there is NO audio at all. The control panel in the PS3 XMB video player shows no audio codec at all for the file?
And I think that I have seen other people have reported that the PS3 is capable of playing back MPEG-2 transport streams with H.264/AVC video streams and DTS audio-tracks? (or is this limited to MPEG-2 transport streams with MPEG-2 video and DTS audio tracks ? )
Olebrumm71 is offline   Reply With Quote
Old 26th January 2008, 01:11   #18  |  Link
roman76r
Yes.
Atak_Snajpera
OK.
Tomorrow I shall make updating with m2ts support.
Old 26th January 2008, 01:12   #19  |  Link
Atak_Snajpera
Renaming is not necessary!
Audio must be transcoded to AC3!
Oh my god! You are really fast!
Old 26th January 2008, 02:04   #20  |  Link
survivant001
did someone try this feature ?
I think we should still continue to generate a h264 4.1 and mux it with this tool.
survivant001 is offline   Reply With Quote
tsmuxer
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
