#41 | Link |
Very true, during the transfer if they cropped the picture then you would be loosing the theatrical DAR. It would be nice if there was some way of determining the DAR that DVD was authored in. Would be really helpful when you re-encode.
#42 | Link |
videographer
uhmm, yes, you crop the blacks, use the correct PAR and there you have your correct source DAR (unless the production company f*** up in conversion somehow, but you can't really be sure about that, unless you know the movie really really well...)
--- anyway, lets go the other way, for example i have done some renderings in my favorite 3d package, this are 2048x866 frames (35mm Full Screen Super 4k cineon - preset) with PAR 1:1, and for some reason i would like to do wide PAL dvd out of the animation; http://somestuff.org/resizeCalc.php?...css=&doit=true (i would crop some pixels in the bottom, so i get less error and there goes away my original DAR...) Last edited by smok3; 24th March 2008 at 20:42. |
#43 | Link |
Not only do you loose the original DAR, you also loose some part of the image. Wish things were so much easier with encoding. I think the only way one can really not have problems would be when creating the images based on what the final product would be.
#44 | Link | |
Life looks better in HDTV
I wonder who decided to place that new acronym on Wikipedia
Still confused about anamorphic images? Then look here! | Main Encoding Interests: Hardware device playback | My Gear | |
#45 | Link | |
videographer
oh, it wasn't me
![]() Quote:
(using loose conversation-purpose numbers here) Last edited by smok3; 24th March 2008 at 21:08. |
#47 | Link |
videographer
i think for D1 pal to D1 ntsc this should be simply good enough
http://somestuff.org/resizeCalc.php?...css=&doit=true (sampling matrix width in µs =53.33333 µs) or maybe http://somestuff.org/resizeCalc.php?...css=&doit=true (sampling matrix width in µs=52.14815 µs) (makes sense that there is minimum DAR error, which needs not to be fixed, although as you may figure out the active area wont match perfectly in some cases, for this kind of conversions i would recommend a manual calc method which must start with collecting all the needed data - and you have to do it correctly just once anyway) Last edited by smok3; 25th March 2008 at 09:28. |
#48 | Link | |
Quoting http://lipas.uwasa.fi/~f76998/video/conversion
#50 | Link |
I am not sure how demanding the process is but I have seen a lot of Indian movie DVDs which are PAL to NTSC transfers and are such pain to deinterlace. Apart from being a bad transfer they all have bad aspect ratio too.
#54 | Link |
There are quite a lot of 1440x1080 sources knocking around, complete with 4:3 (PAR) aspect ratio signalling, creating a displayed shape of 1920x1080 pixels...
#55 | Link |
videographer
some numbers are here;
http://developer.apple.com/documenta...section_2.html http://www.surrealroad.com/research/...a-resolutions/ DVCPRO HD (as i recall from hvx200) is either, using smaller res: ------------------------------------------------------ 960x720 (square should be 1280x720), PAR is around 1.333 (so you can use hdv preset); http://somestuff.org/resizeCalc.php?...css=&doit=true or bigger res: 1280x1080 (square should be 1920x1080), PAR is around 1.5 http://somestuff.org/resizeCalc.php?...css=&doit=true ------------------------------------------------------ this needs to be confirmed (or denied). p.s. hvx200 960x720 scaled to square 960x544 example (seems correct or very close): http://somestuff.org/flashAVC/flvpla...e-x960y544.mp4 08d .added some examples and links (no math changes) Last edited by smok3; 3rd April 2008 at 12:04. |
#56 | Link |
I am not sure but I am kind of revisiting the problem we had talked earlier. Now this was something that I see personally.
The movie DVD has been marked in the packaging with "aspect ratio 2.40:1" With the cropping resize calc displays the DAR as 2.49 http://somestuff.org/resizeCalc.php?...css=&doit=true DVD has been authored by Sony, its probably one of the first sony dvd that I am backing up ever. My question would be why is there this difference? |
#58 | Link | |
From the snapshot I should be able to tell you the movies aspect ratio...
#59 | Link |
videographer
08e
.internal release (last source code stays 08d), just some php fixes, lets see how it behaves before releasing the code. 08f .added primitive unique visitors counter, some html fixes, sources are out Last edited by smok3; 28th April 2008 at 12:41. |
#60 | Link | ||
| Thread Tools | |
| Display Modes | |
