#284 | Link |
Sagekilla, Thats one amazing script that works extremely well on SD material, and heck, even on old VHS it does wonders.
So thanks to both you and Didee ![]() I'm currently using Temporal Degrain V1.18 (Feb 14, 2008), but cannot seem to get any joy from MT, CPU doesn't go above 60% usage, no matter where I put SetMTmode(2) in a simple script. For instance Code:
SetMemoryMax(512) LoadPlugin("C:\Program Files\AviSynth\plugins\DGDecode.dll") LoadPlugin("C:\Program Files\AviSynth\plugins\mpasource.dll") Import("C:\Program Files\AviSynth\plugins\TemporalDegrain2.avs") SetMTmode(2) video = mpeg2source("D:\DVB-T\test1.d2v", cpu=4, iPP=true, idct=3) audio = MPASource("D:\DVB-T\test1 T01 DELAY 0ms.mpa", normalize = false) AudioDub(video, audio) ConvertToYV12(interlaced=true) AssumeTFF() SeparateFields() TemporalDegrain() Weave() Crop(8,8,-8,-8,align=true).Addborders(8,8,8,8) One thing I have tried, as I have a powerful GPU (8800GT), that gained me 13fps from 3fps to 16fps with out any perceived loss in quality, is to modify your function as follows Change all FFT3D entries to FFT3dGPU, changing BT=5 to BT=4, as the GPU version doesn't support 5, and blksize from 8 to 16. Huge speedup, and I couldn't see any difference in quality. Many thanks for this function, it's amazing. ![]() |
#285 | Link | |
scribe
Try MT("TemporalDegrain()"). It worked well for me - I am seeing 90% plus usage on my Core2 |
#286 | Link |
Pig on the wing
I wonder if MVAnalyse/MVDegrain plays nice with MT..nobody ever tested it IIRC.
#290 | Link | |
![]() A strange thing I found with MVTools was this Code:
SetMemoryMax(512) LoadPlugin("C:\Program Files\AviSynth\plugins\RemoveGrainSSE2.dll") LoadPlugin("C:\Program Files\AviSynth\plugins\MVTools.dll") LoadPlugin("C:\Program Files\AviSynth\plugins\DeGrainMedian.dll") LoadPlugin("C:\Program Files\AviSynth\plugins\DGDecode.dll") LoadPlugin("C:\Program Files\AviSynth\plugins\mpasource.dll") SetMTmode(2) video = mpeg2source("D:\VHS\90sadverts.d2v", cpu=6, iPP=true, idct=3) audio = MPASource("D:\VHS\90sadverts T01 DELAY 0ms.mpa.d2a", normalize = false) AudioDub(video, audio) source=ConvertToYV12(interlaced=true).Crop(10,4,-10,-10,align=true).Addborders(10,7,10,7) fields=source.AssumeTFF().SeparateFields().DeGrainMedian(mode=0,interlaced=false).RemoveGrain(mode=2) lbda=512 blk=16 ol=8 sch=2 pel=1 backward_vec2 = fields.MVAnalyse(isb=true, search=sch, truemotion=true, lambda=lbda, delta=2, pel=pel, blksize=blk, overlap=ol, sharp=1, idx=1) backward_vec1 = fields.MVAnalyse(isb=true, search=sch, truemotion=true, lambda=lbda, delta=1, pel=pel, blksize=blk, overlap=ol, sharp=1, idx=1) forward_vec1 = fields.MVAnalyse(isb=false, search=sch, truemotion=true, lambda=lbda, delta=1, pel=pel, blksize=blk, overlap=ol, sharp=1, idx=1) forward_vec2 = fields.MVAnalyse(isb=false, search=sch, truemotion=true, lambda=lbda, delta=2, pel=pel, blksize=blk, overlap=ol, sharp=1, idx=1) fields.MVDegrain2(backward_vec1,forward_vec1,backward_vec2,forward_vec2,thSAD=800,idx=1).MVDenoise(backward_vec2,backward_vec1,forward_vec1,forward_vec2,tht=10,thSAD=800) Weave() Cheers to maxisvk, that worked well. Next, to look at a cheap quad core upgrade ![]() |
#291 | Link | |
... and the result was 100% garbage.
For interlaced YV12, that is MUST NOT. Never, never, never ever. If you do, you're changing chroma phase, i.e. luma and chroma are no more temporally aligned.
#292 | Link | ||
![]() Quote:
How would one, by Didee's standards, crop off the shite on a Interlaced VHS cap. I'm listening, o Great one ![]() Last edited by ChrisW77; 3rd March 2008 at 21:42. Reason: add interlace |
#293 | Link |
Sleepy overworked fellow
Basic rule of MT : Look at the time it takes, not the CPU usage!
Also, I think setmtmode(2) for MVtools would be better since: 1- In the guide, there is this info: # Note: SetMTMode(2) mode of multithreaded AviSynth is also supported since MVTools v.1.8.4.1 (beta testing) 2-MT("filter()") splits the frames in multiple parts (depending on the # of threads)... and unless you use a HUGE overlap, the motion vectors won't be as accurate as if you had used the complete frame (which is done by setmtmode(2)) If you didn't know, setmtmode(2) separates the frames temporally (so it's always the complete frame that is processed), while MT() separates them spatially. |
#294 | Link | |
SetMTMode(2,0) , 50% Cpu -> encoded 120 frames, 1.61 fps, 855.64 kb/s SetMTMode(2,3) , 65% Cpu -> encoded 120 frames, 1.64 fps, 855.64 kb/s SetMTMode(2,4) , 90/100% Cpu -> encoded 120 frames, 2.15 fps, 855.64 kb/s i also noticed that using only Mvdegrain and not TemporalDegrain best result are stuck with SetMTMode(2,3), Why?..., I really did not know! |
#295 | Link |
Because Temporaldegrain uses a predenoised reference clip for motion vector search... so it takes more computer ressources and it's very possible your hard drive disk can't handle the high number of reads and writes. That's why there's a peak with speed. You can "solve" that by doing the reference clip yourself with FFT3Dfilter.
If you only want to denoise, use this: 1 - Create a simple script to create your reference clip, it doesn't really matter if you lose some details and it looks a tad overdenoise since it's only a clip used for motion vector search: whateversource("yoursource") FFT3DFilter(your favorite parameters... check the documentation for more info) 2 - Process through Direct Stream Copy in virtualdubmod. If you have another HDD, save it on this one. The file'll be HUGE. 3 - create another script with temporaldegrain using the source clip that is on the other HDD source = whateversource("youroriginalclip") denoised = avisource("thereferenceclip") temporaldegrain(source, denoised) About your speedtest... it's OBVIOUS that using more threads will increase the speed. SetMTmode(2) is always the best choice since it'll set the number of threads to the # of available processors. When I say to look at speed instead of CPU usage, it's with the same # of CPUs. The thing is, when you have a more complex script, MT may not help (I have a script that runs @ 1fpm with 750MB of RAM and 25% CPU usage (100% of 1 processor on my Quad-core) and it's a LOT slower with MT and uses 3GB of RAM). |
#296 | Link |
ангел смерти
![]() Join Date: Nov 2004
Eh, no matter how slow a script is, writing part of it to disk and reading it back will always be slower. Whether you're going to make another lossless encode from the final output, or use it in a one-pass encoding, by the time you're done you'll have put much more effort into it and it will have taken longer overall. Memory overflow and disk swapping is about the only way that partial scripting can be faster. TemporalDegrain can't even remotely cause a hard drive bottleneck anyway, even with uncompressed sources it takes about a hundred times as long to filter as read.
On the other hand, if you have a second computer handy, running fft3dfilter on that and using TCPSource can really speed things up, as long as the second computer's fast enough to keep up. I'd also say that your conclusion that SetMTmode(2) is best is mistaken; after all, you just said more threads was faster, and speed is all that matters, as long as the final encoder's thread is included rather than just the avisynth script measured. In some scripts 4 threads will be faster, others 1, though I suppose yours might be swapping like crazy once it gets there. Always measure though, never take a forum poster's word. ![]() |
#297 | Link |
Oh well, seems like I was lucky on my first try using the method I described before... I ran some other tests to show how effective it was, but everything I got looked like crap.
Dunno why it worked once (and there were actually great speed improvement by outputting the reference clip on another HDD and then call it in the script using temporalgrain as "denoise", from 53 mins total (complete script) to 13 mins total (split script) for the same amount of frames) and I'm sorry for posting it before running more tests... but heh, I'm learning! Also, about my statement regarding setmtmode(2), I had in mind that it was regarding MVtools usage (and from what I understood from its documentation, it's the most appropriate mode). My bad for not being clear. Last edited by thetoof; 5th March 2008 at 09:08. |
#298 | Link | |
If you are only getting 2 FPS like me you for sure want to save out a lossless during the first pass else you are stuck doing it all again on the second pass. resize, decimation, MVtools, fft3dfilter, etc... I go from 2 FPS on the first pass to 14 FPS on the second pass and this is now with the real encoding being done also. (it would be only about .75 FPS on pass 2 if I didn't do this) huge time savings on 2 pass encodes. no I would not do it like thetoof did it since you want the lossless (I use VBLE cause it is fast and thus little CPU overhead) made the same time as first pass stats are being made ![]() |
#299 | Link | |
Posts: n/a
My very first Function
TemporalDegrain looks really nice, but my PC is way to slow to run this thing practically. So I used Didee's limiting approach and wrote something that required less MV operations with very good results IMHO. Let me know what you think!
#300 | Link | |||
With your sequence of crop+addborders, this is what happens to an interlaced YV12 source: ![]() In contrast, with correct treatment you get: ![]() Quote:
This has nothing-at-all to do with "my standards". ----- Generating script: (yeah, it's not elegant) ![]() Code:
base = blankclip(width=704,height=576,pixel_type="YV12",fps=50.000,color=$408080) base = base.subtitle("This is some scrolling text ...",size=40,x=128,y=480) interleave( base, base.crop(0,16*1,-0,-0).addborders(0,0,0,16*1,color=$408080), \ base.crop(0,16*2,-0,-0).addborders(0,0,0,16*2,color=$408080), \ base.crop(0,16*3,-0,-0).addborders(0,0,0,16*3,color=$408080), \ base.crop(0,16*4,-0,-0).addborders(0,0,0,16*4,color=$408080), \ base.crop(0,16*5,-0,-0).addborders(0,0,0,16*5,color=$408080), \ base.crop(0,16*6,-0,-0).addborders(0,0,0,16*6,color=$408080), \ base.crop(0,16*7,-0,-0).addborders(0,0,0,16*7,color=$408080), \ base.crop(0,16*8,-0,-0).addborders(0,0,0,16*8,color=$408080), \ base.crop(0,16*9,-0,-0).addborders(0,0,0,16*9,color=$408080), \ base.crop(0,16*10,-0,-0).addborders(0,0,0,16*10,color=$408080), \ base.crop(0,16*11,-0,-0).addborders(0,0,0,16*11,color=$408080), \ base.crop(0,16*12,-0,-0).addborders(0,0,0,16*12,color=$408080), \ base.crop(0,16*13,-0,-0).addborders(0,0,0,16*13,color=$408080), \ base.crop(0,16*14,-0,-0).addborders(0,0,0,16*14,color=$408080), \ base.crop(0,16*15,-0,-0).addborders(0,0,0,16*15,color=$408080) ) vid_50p = last vid_50i = assumeTFF().SeparateFields().SelectEvery(4,0,3).Weave() # the wrong way: #--------------- vid_50i crop(0,4,-0,-10) addborders(0,7,0,7) wrong = last # the better way: #--------------- vid_50i crop(0,4,-0,-12) addborders(0,8,0,8) better = last result_wrong = stackhorizontal( wrong.subtitle("interlaced after non-MOD4 cropping or addborders",y=20), \ stackvertical( wrong.SeparateFields().selecteven().subtitle("--> top field",y=20), \ wrong.SeparateFields().SelectOdd().Subtitle("--> bottom field",y=20) ) ) result_better = stackhorizontal( better.subtitle("interlaced after correct (MOD4) cropping or addborders",y=20), \ stackvertical(better.SeparateFields().selecteven().subtitle("--> top field",y=20), \ better.SeparateFields().SelectOdd().Subtitle("--> bottom field",y=20) ) ) result_wrong #result_better return( last )
