#261 | Link |
ATM I've not the energy (a really bad flu', can't concentrate) to cut through all the stuff posted on the last few pages.
Not sure if it's to rate as "tragedy" or "comedy" ... In any case, lots of nonsense has been posted. There've been really screwed-up findings & correlations about blocksizes, bogus inventions like "detection thresholds", funny alternate filters (dfttest with default tbsize=1 versus fft3dfilter with bt=5 ... hell, you cannot compare that!), instances of non-functional functions, even posted to the wiki (Sagekilla, do you actually try your own stuff? MVAnalyse has no argument "ov", only "overlap", and why is "ov" responsible for "blocksize"), backwards-evolutions of proven concepts (in the longer-ago past, the biggest complain about MVDenoise was blockyness due to not-yet implemented block-overlap modes ... nowadays block overlapping is hardcoded'ly taken away because of performance...welcome in stoneage), and what not else. Back to sick bed, crying in silence.
#262 | Link |
*Space Reserved*
Welcome back Didée. Hope you get well soon, and then you can explain to us about some of the nonsense that was posted (I know that i'm responsible for most of it.
![]() ![]() Last edited by Terranigma; 17th February 2008 at 19:44. |
#264 | Link |
ангел смерти
![]() Join Date: Nov 2004
It's not so much that blocksize 4 is stronger, it's that it has a higher chance of making bad correlations and subsequently denoising places that shouldn't by rights have been affected. Meaning smudgier details and edges in random places. blocksize 8 or 16 with a soft threshold, as Didée's been asking for forever, would be a better improvement.
#265 | Link | |
#266 | Link | |||
Welcome back Didée.
Please explain to me the differents if any between 1 and 2: Quote:
Thank you.
Greece PAL User... Last edited by Nikos; 18th February 2008 at 04:03. |
#267 | Link |
ангел смерти
Strongest and fastest, but least accurate. On the other hand, it can be more accurate on some edges. Using large blocksizes in most areas and progressively smaller ones in occulded areas is the best way, as x264 does, but what can you do at the moment, y'know? This was discussed in the mvtools thread a while back.
#268 | Link |
Thank you foxyshadis for the reply. Yoy mean that 1 and 2 are strongest and fastest but least accurate than 3 in my understanding.
What's the differents between 1 and 2? Both of them are correct or only one?
Greece PAL User... |
#269 | Link |
ангел смерти
Sorry, that was a reply to Zanejin.
You always have to use a new idx when you use a new source (unless you use pel=1, then idx doesn't offer a speedup). So you have one idx for MV with source, and another idx for MV on NR1. |
#270 | Link | |
Thank you foxyshadis for the explain.
With simple words the right script is the 2 with idx=2. Quote:
#271 | Link |
Sleepy overworked fellow
@ Didée
From what you said... I guess/hope you'll rewrite the script to correct everything and I was wondering if you could add (or simply explain how to do it) a function to use dfttest and fft3dfilter at the same time. Maybe it's just a bad idea to use 2 denoisers... but the source I have requires additional chroma denoise with specific s2/3/4 values with fft3d to be clean. I tweaked the parameters of dfttest in the TemporalDegrain.avsi and I got pretty good results, but couldn't find a way to add fft3d... hope you'll be willing to help me. |
#272 | Link |
scribe
Just tried sagekilla's TemporalDegrain() on a very grainy old film transfer: "I am a Fugitive from a Chain Gang" (1932), and I am very impressed with the results (See attachments). The grain on the original transfer was extremely heavy, and other degrain combinations never got close to the results I got with TD... Slow...YES, (even with an E6700, I only got about 2 fps) but well worth the wait.
I have also tried this on a couple of other older films, with similar results - grain virtually gone, but excellent detail retention. Very nice script! I only wish there was a way to speed it up a bit with MT ![]() Original clip: http://www.mediafire.com/?mi11znznz3r TD clip: http://www.mediafire.com/?its3m3z9yud stills: Last edited by archaeo; 26th February 2008 at 17:46. |
#273 | Link |
I read an old Didee's post in another forum and i replace the prefilter with this:
soft = hqdn3d(source).bicubicresize(source.width/4/4*4,source.height/4/4*4).bicubicresize(source.width,source.height,1,0) filter=mt_lutxy( source, soft, "x y = x x x y - abs 1 + 1 2 / ^ x y - x y - abs / * - ?", U=2, V=2 ) I use MVDegrain2 and MT(2,2). The quality in my eyes was the same, but i want an opinion from experienced user. Any idea for another correct "spat" filter? Didee help us ![]()
Greece PAL User... Last edited by Nikos; 28th February 2008 at 02:05. |
#274 | Link |
Several issues.
1) The string in lutxy is wrong. That syntax was for YV12lutxy() of old MaskTools v1. For mt_Lutxy of MaskTools v2, the string has to be "x y == ..." (TWO equal signs. Try to retun "filter" with your current syntax, you'll immediately see that something's wrong.) 2) With that order of filters, you're actually nullifying the effect of HQDN3D. In this case, the more reasonable ordering is Code:
soft = source.bicubicresize(source.width/4/4*4,source.height/4/4*4).bicubicresize(source.width,source.height,1,0) filter=mt_lutxy( source, soft, "x y == x x x y - abs 1 + 1 2 / ^ x y - x y - abs / * - ?", U=2, V=2 ).hqdn3d() 4) That combo is a very speedy trick-filter. It might work out for the most part, but there'll be cases where it bites you back. Dumb filters can destroy the motion of rather smooth regions (e.g. close-up of smooth faces + head-movement) strong enough so that MVTools won't reckognize motion anymore. BTW, HQDN3D is generally not fully safe in this respect. 4) We have about one thousand different denoising filters or -scripts. If source has strong grain, the pre-filtering should be barely strong enough to make static areas calm. Which filter that is or could be, depends on the source. If you're going to ask about all thousand possibilities, this thread will become long. ![]()
#275 | Link |
Thanks Didée for the correction. That syntax was for YV12lutxy(). The reverse polish notation is a little difficult. What's the different beetween the "==" and "="? These days i read your old post to find out solutions for my problems
![]() If you want translate in simple maths the function. I need a speedy prefilter whith acceptable (not high) quality with for High Definition sources with moderate or low noise. The prefilter must be spatial, temporal, or spatiotemporal; I must put the spatial first or the temporal; The FFT3DGPU is suitable for prefilter? It's a good idea to write a "magic" script for prefilter in MVDegrain with options for heavy, medium or light denoise ![]() Any help.....
Greece PAL User... Last edited by Nikos; 28th February 2008 at 15:20. |
#276 | Link | |||
"=" is an assignment, whereas "==" means "is equal to" in logical expressions.
a = 3 # assign the value "3" to the variable "a" a == 4 # this is "TRUE" if "a" has the value "4", and is "FALSE" if "a" has ar value other than "4". The syntax used by MaskTools v1 ever was wrong in that respect. MaskTools v2 now has it correct. Quote:
"x y == x x x y - abs 1 + 1 2 / ^ x y - x y - abs / * - ?" reads in english IF (x is equal to y) THEN (use x) ELSE (apply the square root of (difference between x and y, plus 1) to x) Quote:
- We´re at the beginning of the end of mankind´s childhood - My little flickr gallery. (Yes indeed, I do have hobbies other than digital video!) Last edited by Didée; 28th February 2008 at 17:17. |
#277 | Link |
Now with your help i begin to understand the mask tool and the Reverse Polish notation.
Now i am going for practice. I will be back soon with more serious questions ![]() Thanks for your time to answer my questions.
#278 | Link | |
Didée, could you please rewrite the lime part in a normal (infix) notation? Thank you. |
#279 | Link |
In infix notation it is
(x == y) ? x : x - ( sqrt( abs( x - y ) + 1 ) * ( x - y ) / abs( x - y ) ) That's very basic math. Everyone once has used something like clip1 = last clip2 = clip1.blur(1) result = clip1 .merge( clip2, 0.4 ) What is this? It is: apply a filter to your source (here: blur filter), but use only 40% of the result. (Or the resulting effekt). That's trivial, isn't it? From a slightly different angle, it is this: calculate something, but instead of just using the resulting difference, multiply the difference by 0.4 before using it. That's a linear function: F(diff) = diff * p Now, what the initial code does is just this: instead of using a linear function to reduce the effect, it uses a square root function: F(diff) = sqrt(diff) That's all, and hardly worth all the babbling. ![]()
#280 | Link |
Actually, thank you for "babbling." Not everyone is at the same level, and I learned some things from it. A good explanation goes a long way to helping people open doors they thought were locked.
BTW, to further on what archaeo said, I ran TemporalDegrain() on a somewhat noisy cable tv capture and the results were stunning. (I didn't know how noisy it was until after it was cleaned.) I only get 1.8fps on my dual core machine, but I haven't seen anything at any speed that comes close to that quality, especially true if I follow it with LSF. So to you and sagekilla I say thanks. |
