Old 13th December 2007, 12:36   #21  |  Link
Jjeje007
Here is the updated patch for the TrueHD/mlp decoder for mplayer svn :
http://www.db-instable.org/misc/truehd-decoder.patch
It compil fine this the latest mplayer svn but how to enable it (in codecs.conf ?) ?
Jjeje007
Jjeje007 is offline   Reply With Quote
Old 19th December 2007, 16:14   #22  |  Link
rack04
Where can I get the latest ffmpeg that includes the latest patches?
rack04 is offline   Reply With Quote
Old 6th January 2008, 17:46   #23  |  Link
KpeX
KpeX's Avatar
Something like this is working here:
audiocodec ffmlp
  info "MLP"
  status buggy
  format 0x0
  driver ffmpeg
  dll "mlp"
Then playback with mplayer -demuxer lavf -ac ffmlp gives output similar to the following:
Forced audio codec: ffmlp
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
[mlp @ 0xd4b940]Extracting 2 channel downmix from substream 0. Further substreams will be skipped.
AUDIO: 48000 Hz, 2 ch, s16le, 0.0 kbit/0.00% (ratio: 0->192000)
Selected audio codec: [ffmlp] afm: ffmpeg (MLP)
KpeX
Audio FAQs: General | BeSweet | SVCD/MP2 | MP3 | Vorbis | AC3 | DTS | AAC
Linux Audio/Video FAQ
KpeX is offline   Reply With Quote
Old 24th January 2008, 10:08   #24  |  Link
qubic
hi
any video samples, with TrueHD, somewhere?
and what is the command line for mplayer?
regards qub
qubic is offline   Reply With Quote
Old 27th January 2008, 08:57   #25  |  Link
frenchglen
I can't wait for this to be finished! I am going to convert all my DVD-Audio discs to MLP and have a HD music library! No need for FLAC!
frenchglen is offline   Reply With Quote
Old 27th January 2008, 10:25   #26  |  Link
madshi
What advantage does MLP have over FLAC for your needs?
Old 27th January 2008, 12:19   #27  |  Link
frenchglen
One less step in the ripping process. Saves time, and the (always present if extremely unlikely) possibility of digital error (since I have a fair amount of discs - I'm a DVD-A fan).
+ it will let me easily tell in my media library which files are from dvd-audio and which are all my lower resolution ones. It's an added bonus to set them apart because they're very special anyway.
And essentially, MLP has quite a good compression rate already (since it was made to fit on a disc), so FLAC doesn't really become necessary if all I want to do is play these files back in my media library on a HTPC. An MLP file of 213MB becomes about a 200MB FLAC file with eac3to.
Old 27th January 2008, 17:13   #28  |  Link
madshi
Ok, makes sense.
But you cannot add meta data to MLP, right? I mean things like artist name, album name, title name etc.
Old 28th January 2008, 23:53   #29  |  Link
frenchglen
Ok, makes sense.
That's interesting, didn't think of that. That brings back a need for FLAC then. I might convert them one day but I'm liking the prospect of just ripping to MLP for now, as a first step.
But what I'm wondering and hoping, is when there will be an open source MLP encoder? It would be integrated into eac3to, but even better, dvda-author, which its coder Dave Chapman started to work on again just a few months ago. Inability to encode MLP (cheaply/freely) has been the one thing to set back DVD-A authoring the way it should be.
If the guys at FFmpeg have reverse-engineer MLP, then surely they can write an encoder for it, right? Wouldn't it be great to finally be able to burn off your own tracks to DVD-A as easily as a CD. Yeah, there's the watermarking detection in standalone players, but I've come to realise that [at least for music, at the moment], physical media is going right out and downloadable files will be the new standard - we just need the flexibility to author our own DVD-As now.
Old 29th January 2008, 05:16   #30  |  Link
bertox
bertox's Avatar
Flac is the most...but an MLP directshow decoder.., i could use it for previewing my ripped DVD-As before encoding to flac and listen with the marvellous foobar2000 KernelStreaming Output.
I wait for it.
bertox is offline   Reply With Quote
Old 29th January 2008, 09:09   #31  |  Link
madshi
I'm not aware of anyone working on such a thing.
Yeah, maybe. But someone would have to invest a lot of his free time to make this happen.
Old 29th January 2008, 15:09   #32  |  Link
bertox
bertox's Avatar
free time....jajajaj
Old 21st February 2008, 21:25   #33  |  Link
fenton06
has anyone gotten this to work on mplayer? I have the eac3 working w/o issues, now I jstu need to get the TrueHD going and I'll be set
I applied the patch, and added this to codecs.conf.:
audiocodec ffmlp
info "MLP"
status buggy
format 0x0
driver ffmpeg
dll "mlp"
I have a problem though, using:
mplayer -ac help | grep ffmlp
doesn't work
thanks!
fenton06 is offline   Reply With Quote
Old 5th July 2008, 23:19   #34  |  Link
Wilbert
well...wait a couple of days. the decoder should be committed in the svn soon.
The decoder is committed!!!
Ramiro will even make an encoder
Old 5th July 2008, 23:27   #35  |  Link
Snowknight26
TrueHD decoder in ffmpeg? <3
Snowknight26 is offline   Reply With Quote
Old 6th July 2008, 15:44   #36  |  Link
Inventive Software
Turkey Machine
Sweeeeeeeeeeeeet!
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline   Reply With Quote
Old 6th July 2008, 16:58   #37  |  Link
Snowknight26
Is it a whole new library or is it part of an existing one, say libavcodec?
Old 6th July 2008, 18:42   #38  |  Link
Inventive Software
Turkey Machine
I think it's part of libavcodec.
Old 12th October 2008, 01:59   #39  |  Link
kkloster21
has anybody actually been able to use mplayer to decode and play (stream) a trueHD track (while playing a blu-ray disc for example)?
i've tried to use
$ mplayer -aid 4352 -ac ffmlp -channels 6 -
to play from stdin, but it doesn't work. i get video but it says "NO AUDIO!"
kkloster21 is offline   Reply With Quote
Old 21st October 2008, 20:14   #40  |  Link
Jjeje007
i've tried to use
Should work better like this :
$ mplayer -demuxer lavf -aid [1-x] -ac ffmlp -channels 6 -
the -aid switch with lavf demuxer start at "1"
EDIT : And yes, i already been able to play TrueHD track
Jjeje007
