#2821 | Link | |
Extracted them, and appended -4.4.1 to the end of each. Put them in /bin. cd x264 CC=gcc4.4.1 ./configure (or CC=gcc4, doesn't matter) No working C compiler found. Neither does it work if I unpack them without renaming to /gcc4 and add an entry to fstab that points there. Still no working C compiler. Like kemuri-_9 said, you have to constantly rename the gcc bin files back and forth for which one you want to use at the time, or use full pathnames (and CC= and --cross-prefix are not the solutions to that). I knew that already, which is why I said separate installations are the easiest to deal with. Then no renaming is necessary - just fire up your GCC 4.4.x-enabled installation, or your GCC 3.4.5-enabled one, which don't talk to each other at all and have a complete MSys each that's are all their own. Cygwin and MSys may both be Unix-like, but MSys =/= Cygwin. If you want to explain how you got multiple GCC versions working under a single install of MSys without having to rename anything and only calling CC= or --cc=, then I'd be more than happy to hear it. But from where I'm standing (including wasting all of this morning trying to no avail), it's not possible. *I even grabbed komisar's GCC 4.4.2 build and extracted it out to the empty /mingw directory and pointed it there - still no dice. |
#2822 | Link |
CC=gcc-sjlj ./configure works4me.
Is gcc actually called "gcc4.4.1.exe" or "gcc4.exe"? I think I just extracted the 4.2.1 archives (from mingw) into the my mingw folder and they just worked. They already had the -sjlj suffix.
x264 log explained || x264 deblocking how-to preset -> tune -> user set options -> fast first pass -> profile -> level Doom10 - Of course it's better, it's one more. |
#2823 | Link |
Compiling Encoder
if you only download the different gcc and don't have the libs and include files in the new gcc's search path,
you can cheat by adding the library and include paths from your full installation to the commandline, i.e.: CC=gcc-blah ./configure --extra-cflags=-I/mingw/include --extra-ldflags=-L/mingw/lib where there's a full installation at /mingw and the CC you give is only the compiler (no runtime and no headers in its search path) you won't have to do this if you extract the gcc to the same prefix as your current installation (granted the executable names are different and won't overwrite anything) |
#2826 | Link |
My x264 r1376 builds.
GCC 4.5.0 (experimental) builds Generic (fprofiled) Patch used: x264_hrd_pd_interlace.16_r1369.diff -march=core2 (fprofiled) Patch used: x264_hrd_pd_interlace.16_r1369.diff (NEW) GCC 3.4.6 build Generic (fprofiled) Patch used: x264_hrd_pd_interlace.16_r1369.diff ICC 11.1.051 builds Thanks to MasterNobody and XhmikosR. Generic (fprofiled) Patches used: x264_icc_r1373.diff and x264_hrd_pd_interlace.16_r1369.diff /QaxSSSE3 /O3 (fprofiled) Patches used: x264_icc_r1373.diff and x264_hrd_pd_interlace.16_r1369.diff /QxSSSE3 /O3 (fprofiled) Patches used: x264_icc_r1373.diff and x264_hrd_pd_interlace.16_r1369.diff Last edited by [ReX]; 16th December 2009 at 15:50. Reason: GCC 3.4.6 build added |
#2827 | Link |
Strictly Rhythm
x264_x86_r1376_vanilla_gcc_techouse
GCC 4.4.2 20091019 (x86.generic.Komisar), unpatched, generic, fprofiled x264_x64_r1376_vanilla_gcc_techouse GCC 4.4.2 20091019 (x86_64.generic.Komisar), unpatched, generic, fprofiled --------------------------------------------------------- x264_x86_r1376_gcc_techouse | INFO GCC 4.4.2 20091019 (x86.generic.Komisar), generic, fprofiled x264_x64_r1376_gcc_techouse | INFO GCC 4.4.2 20091019 (x86_64.generic.Komisar), generic, fprofiled Patches used: x264_hrd_pd_interlace.16_r1369.diff --------------------------------------------------------- x264_x86_r1376_vanilla_icc_techouse Intel C++ Compiler 11.1.051, almost unpatched, -QxSSSE3 -O3, fprofiled x264_x64_r1376_vanilla_icc_techouse Intel C++ Compiler 11.1.051, almost unpatched, -QxSSSE3 -O3, fprofiled Patches used: x264_icc_13_win.diff --------------------------------------------------------- x264_x86_r1376_icc_techouse | INFO Intel C++ Compiler 11.1.051, -QxSSSE3 -O3, fprofiled x264_x64_r1376_icc_techouse | INFO Intel C++ Compiler 11.1.051, -QxSSSE3 -O3, fprofiled Patches used: x264_icc_13_win.diff x264_hrd_pd_interlace.16_r1369.diff
#2828 | Link | |
Strictly Rhythm
#2833 | Link |
x264 developer
Download this clip, open it in VLC or MPC-HC, and seek anywhere in the video. Oh and it has no keyframes.
I am no longer at Doom9. You will find me at x264's new home, doom10.org. |
#2835 | Link | |
x264 developer
More importantly, combined with other changes, this allows: 1. Zero encoder, decoder, and buffer latency. 2. Error resilience up to 20-25% packet loss rates, using one-slice-per-packet. 3. No keyframes beyond the first, so constant or capped framesize are both possible. 4. Realtime HD encoding at zero latency. In other words, x264 is now the greatest encoder in the world for realtime video applications, like videoconferencing, and anyone who uses anything else needs to have their head examined
#2836 | Link |
Software Developer
I see. But I guess we won't use that for "movie" encodes with (almost) unrestricted key-frame interval and no "zero latency" requirement, right?
BTW: The DivX H.264 Decoder crashes when seeking in that stream
#2837 | Link | |
Now we just need to make a good RT workflow that will mux audio and put it into a container ![]() TE Last edited by TEB; 25th December 2009 at 17:29. |
#2838 | Link |
That looks and sounds awesome. That feature is part of the extended profile, is it? Would it be possible to refresh in different patterns than from top to bottom? Like in an interlaced pattern?
And do you know of any software using x264 for streaming? Like a videoconference app? |
#2839 | Link | ||
x264 developer
| Tags |
| h.264, x264, x264 builds, x264 patches, x264 unofficial builds |
| Thread Tools | |
| Display Modes | |
