11th November 2007, 11:08 | #161 | Link | |
12th November 2007, 20:28 | #162 | Link |
Version 1.5.0 beta 13
* Fixed problem whereby the automatic PID setting for transport streams used the last audio stream encountered instead of the first.
* Added an MRU list to the File menu. http://neuron2.net/dgmpgdec/dgmpgdec150b13.zip This version also contains a new feature. The first person to find it gets a brownie point. Then I will add it to the change list. Just for some fun! Last edited by Guest; 12th November 2007 at 22:05. |
12th November 2007, 20:42 | #163 | Link | |
*Space Reserved*
--- The ability to quickly navigate to a previously opened file (i.e., bookmarking) with Recent file list? Last edited by Terranigma; 12th November 2007 at 20:51. |
12th November 2007, 22:54 | #165 | Link |
Turkey Machine
Mmm, tasty!
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld |
13th November 2007, 00:43 | #167 | Link |
Turkey Machine
My bad.
17th November 2007, 02:19 | #169 | Link |
Novice x264 User
Just a bit curious, do you make any changes to dgdecode.dll for the betas? I replace them each time I check out a new build just in case, but if I don't have to, that'll save me a good 2 seconds of time .
18th November 2007, 13:46 | #171 | Link |
Turkey Machine
Question for Donald, or anybody who could help. I'm having trouble with noticable interlacing lines on the picture, and I have no idea how to deal with them. Encoding it progressive, it'll look horrible, encoding it interlaced I'm not willing to do unless absolutely necessarily. Sample: http://rapidshare.com/files/70550171/FieldSample.zip. Please assist!
18th November 2007, 18:59 | #174 | Link |
Pig on the wing
Don,
could you please check what is causing the problems when using SetMTMode(2) with tsp's Avisynth build that has multithreading support? http://forum.doom9.org/showthread.ph...01#post1065701
18th November 2007, 19:11 | #175 | Link |
Life's clearer in 4K UHD
Sadly the detail in many NTSC TV shows often get completely destroyed when converted to PAL. Especially if the original NTSC source was interlaced to begin with
19th November 2007, 01:33 | #176 | Link |
Analyze Sync
I'm not sure if this is specific to the beta or not. I noticed a "new to me" feature, not sure when it showed up, Tools->Analyze Sync. I just decoded a vobset with multiple audio streams, all of which show delays of 0 in their output filenames, but when I ran track 1 through the Analyze Sync tool, the output log file showed delay on every entry, except the first. I'm not sure what to make of that, so I'm wondering a couple things.
1: Does the analyze sync tool do what I think it does or am I misunderstanding? It seems to do a frame-by-frame check of audio sync to video. Is that accurate? 2: If that's what it's doing and it's finding delay, should I/how would I use this info to get proper sync with my video and audio after encoding to a different format? Average all the reported delays perhaps? |
19th November 2007, 01:39 | #178 | Link | ||
"This tool allows the user to create a log of the audio delay values that would be generated if the project were to be started at all the I frames of the stream. ... Note that for a displayed delay value to be usable and correct, you must start your project at the corresponding I frame." Quote:
