Old 9th June 2012, 00:06   #11301  |  Link
NLA
Originally Posted by NLA View Post
The supported files which can be added for a batch job differ from those that can be added individually (specifically, I'm referring to .m2ts decrypted blu-ray support). I've been waiting for some kind of batch functionality for years, and now that its here, I can't really use it. And shouldn't the batch menu have some more options for what to do with audio, ie. wave, FLAC, core, etc?
P.S. What happened to the encoder settings menu? Used to be full of fantastic, easy-to-change options, and now its basically a textbox with a button to open a text file? Bit of a step backwards, isn't it?
Bumping my unanswered post.
NLA is offline   Reply With Quote
Old 9th June 2012, 20:01   #11302  |  Link
qbass
Great app, thanks for that!
My things:
* bug? Using <SOURCE_FOLDER>\ in batch mode gives "Access violation" message for me.
* feature: ability to load batch list from file or even edit this list/richbox. To be able to use output of "dir /b /s C:\PHOTOS\*.mpg" as source of batch list.
* feature: ability to rotate movie with radiobuttons ratcher than using "Open the video file in RipBot, click on "properties", "show script" and add "video=turnleft(video)" or "video=turnright(video)" before "return video"."
* feature: ability to use creation time of source file as same in output file.
* feature: ability to keep some meta information from source file, like Tagged date
* bug: ripbot cannot find audio stream in .wma file created with ms movie maker, audio from mediaInfo:
Format : WMA
Format profile : Pro
Codec ID : 162
Codec ID/Info : Windows Media Audio
Description of the codec : Windows Media Audio 10 Professional - 128 kbps, 48 kHz, 2 channel 16 bit (A/V) 1-pass CBR
Once again thanks for app, it is just great.
qbass is offline   Reply With Quote
Old 10th June 2012, 22:59   #11303  |  Link
fantasmanegro
Originally Posted by qbass View Post
i second this...
the same thing happened
fantasmanegro is offline   Reply With Quote
Old 11th June 2012, 09:36   #11304  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
record your desktop with camstudio and send video to www.mediafire.com
Old 11th June 2012, 11:45   #11305  |  Link
Chetwood
Chetwood's Avatar
Just tried Ripbot on a 50 FPS PAL test clip that I tried to reduce to 25 FPS by "assuming 25 FPS". After encoding to x264/AAC/MKV the file was twice as long, played back in what appeared to be slow motion and had no sound despite an AAC stream being present. Is it possible that Ripbot has problems with FFV1/WAV in AVI as source? Also, how can I add my own audio profile and how about a button in the GUI to view the log of the last job? Thx.
MultiMakeMKV: MakeMKV batch processing (Win)
MultiShrink
: DVD Shrink batch processing
Offizieller ‹bersetzer von DVD Shrink deutsch
Chetwood is offline   Reply With Quote
Old 11th June 2012, 12:33   #11306  |  Link
ozok
TEncoder, TX264, TAC
ozok's Avatar
@Atak_Snajpera you can use madExcept to track down these kind of errors (Access violation etc). It is free for non-commercial purposes and supports many Delphi versions AFAIK.
ozok is offline   Reply With Quote
Old 11th June 2012, 15:55   #11307  |  Link
Atak_Snajpera
video=selecteven(video)
Old 11th June 2012, 16:01   #11308  |  Link
Atak_Snajpera
cool. thanks.
Old 12th June 2012, 07:03   #11309  |  Link
Chetwood
Chetwood's Avatar
Wow, took me some searching to find where to put this. Anyway, when I select "2.0 FHG AAC-HE 64 kbs (CBR)" as audio output, I'm getting
Error: The source file 'C:\Temp\RipBot264temp\audio.aac' could not be opened successfully, or retrieving its size by seeking to the end did not work.
Selecting "2.0 FHG AAC-LC 96 kbs (CBR)" however works although in both cases the same audio file is used?
MultiShrink
Old 12th June 2012, 20:05   #11310  |  Link
soneca
New version, thanks Atak!
soneca is offline   Reply With Quote
Old 13th June 2012, 01:55   #11311  |  Link
8ternity
8ternity's Avatar
HI Atak,
Encodingclient.exe his detected has false positive from Nod32 5.0.XXX and delete when download is completed.
I will try to submit that file to eset and give explanations.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating.
8ternity is offline   Reply With Quote
Old 13th June 2012, 02:04   #11312  |  Link
soneca
The same thing happened here, I had to disable the Nod to complete the download.
Sent for analysis but so far no answer.
Old 13th June 2012, 13:20   #11313  |  Link
defalopii
i have share the RipBot264temp, but still getting error RipBot264temp is not shared! Auto closing...
please any detail documentation how to use RipBot264 distributed encoding ??
defalopii is offline   Reply With Quote
Old 13th June 2012, 13:46   #11314  |  Link
Atak_Snajpera
have you watched this http://www.youtube.com/watch?v=jEHcj...&feature=g-upl
Old 13th June 2012, 15:03   #11315  |  Link
benjyv
benjyv's Avatar
I'll wait the next version cuz this one couldn't be DL-ed, at leats at me gaves errors
benjyv is offline   Reply With Quote
Old 13th June 2012, 15:10   #11316  |  Link
defalopii
Yes, i am using Windows Server 2003
Have 4 server on different data center, but i cant make it work for RipBot264 Distributed Encoding
Old 13th June 2012, 15:44   #11317  |  Link
Atak_Snajpera
can you open \\computer-name\ripbot264temp from servers side ?
Old 13th June 2012, 17:37   #11318  |  Link
nst6563
I'm having a similar problem with my setup. Ripbot doesn't auto-close, however all the encoding clients cycle with a message stating "x264 [error]: could not open input file `-'
encoding terminated.
I've checked the temp folder and it's shared correctly. I can access it from the remote computers. I've even turned off all firewalls. Same errors.
Any hints?
All systems are i7, 8-16gb ram, Win7 Professional, and this latest version of ripbot.
nst6563 is offline   Reply With Quote
Old 13th June 2012, 19:00   #11319  |  Link
Atak_Snajpera
close ripbot
disable x264 x64 in ripbot264.ini
usex264x64=0
remove old job and create new job again
Old 14th June 2012, 02:16   #11320  |  Link
defalopii
still not work..
can you give me detaill documentation about this Distributed Encoding ??
should i install ripbot on each of my 4 servers that spread on 4 countries?
and how to determine where should be the server and the client ??
