Old 14th May 2012, 11:57   #11201  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
1) already implemented in my unfinished 1.17.2
time to finally increase number of supported servers to 8
Old 14th May 2012, 14:52   #11202  |  Link
Ryushin
Now this is just wrong. Now I'll have to go build more computers to use up all 8 slots. This is starting to get expensive.
Ryushin is offline   Reply With Quote
Old 14th May 2012, 16:15   #11203  |  Link
burt123
This question has probably been asked & answered many times, but what operating system needs to be on the client servers, for the Distributed Encoding ???
Can it be something really basic, with only a small hard drive for that operating system, as long as there is an IP address (and a nic, of course)
If it's "ONLY" using the processor (as such), it's shouldn't need to be anything special, right ???
Cheers
burt123 is offline   Reply With Quote
Old 14th May 2012, 18:40   #11204  |  Link
Atak_Snajpera
xp , vista , 7 , 8 . it does not matter.
however there is one rule. if client is running on x64 os other servers must be also running on x64.
Old 14th May 2012, 23:44   #11205  |  Link
JimmyK814
1) this is exactly what i decided to implement this morrning. new version will save encoding progress immediately after number of encoded chunks increases.
2) yep something has to be done in this case. some warning ... i don't know yet.
That's awesome. Thanks!
JimmyK814 is offline   Reply With Quote
Old 14th May 2012, 23:46   #11206  |  Link
JimmyK814
I cheated on this by using Usex264x64=0 even on the 64bit machines... but that doesn't mean something isn't wrong that I haven't noticed. I just tried this yesterday for the first time.
Old 15th May 2012, 03:52   #11207  |  Link
burt123
A reply from the man, himself!
Old 15th May 2012, 04:57   #11208  |  Link
hdboy
I'd like to ask a couple of requests:
1) drag and drop to add file to queue. I always have Directory Opus (explorer replacement) running, and I have the video files right there already. It'd be so much easier to drag and drop rather than click Add and navigate through the open dialog.
2) have a button or checkbox for "output to same folder". Click it and it automatically fills in output field. No need to browse for folder. At least it should remember the last folder you chose. It always defaults to the desktop, but I don't think I ever want to put video files on the desktop!
I feel like I'm asking for water and a straw at a 4 star restaurant, but sometimes it's the simplest things
Win 7 x64, AMD Phenom II X6 1075T, nvidia 430GT, mpc-be x86
hdboy is offline   Reply With Quote
Old 15th May 2012, 07:58   #11209  |  Link
sreemv
Atak,
Any chance of adding D.E for .avs input in 1.17.2? Thanks in advance!
sreemv is offline   Reply With Quote
Old 15th May 2012, 08:55   #11210  |  Link
slalom
slalom's Avatar
Edit Ripbot.ini
I use a different HDD for output, It's must faster when muxing
slalom is offline   Reply With Quote
Old 17th May 2012, 00:38   #11211  |  Link
AMED
AMED's Avatar
i've noticed a incorrect link on the missing components screen of Ripbot v1.17.1.
the link to Haali Media Splitter is incorrect and should be
http://haali.su/mkv/
A Man Eating Duck
AMED is offline   Reply With Quote
Old 17th May 2012, 09:30   #11212  |  Link
flebber
Practising Schemer
It seems ripbot is overcropping my source when using automatically.
Complete name                    : C:\Video\DARK_CITY\title00.mkv
Format                           : Matroska
Source
Video
Format                           : MPEG Video
Format version                   : Version 2
Format profile                   : Main@Main
Format settings, BVOP            : No
Format settings, Matrix          : Custom
Codec ID                         : V_MPEG2
Codec ID/Info                    : MPEG 1 or 2 Video
Duration                         : 1h 47mn
Bit rate mode                    : Variable
Bit rate                         : 4 533 Kbps
Maximum bit rate                 : 8 400 Kbps
Width                            : 720 pixels
Height                           : 576 pixels
Display aspect ratio             : 16:9
Frame rate                       : 25.000 fps
Ripbot Crop
#MT
#VideoSource
video=DirectShowSource("C:\Video\DARK_CITY\title00.mkv",audio=false).ConvertToYV12()
#Deinterlace
#Decimate
#Crop
video=Crop(video,174,234,-42,-72)
Megui Crop
FFVideoSource("C:\Video\DARK_CITY\title00.mkv", threads=1)
#deinterlace
crop(0, 70, 0, -72)
Spline36Resize(720,432) # Spline36 (Neutral)
flebber is offline   Reply With Quote
Old 17th May 2012, 10:57   #11213  |  Link
Atak_Snajpera
dark city probably has too many dark scenes for autocrop to detect black borders.
Old 17th May 2012, 11:42   #11214  |  Link
flebber
Practising Schemer
Would there be any way to generate an error for these films where it can't detect, suggest to user to review?
Old 17th May 2012, 13:00   #11215  |  Link
Atak_Snajpera
You should always use preview. This also helps to detect any a/v issues (which can be fixed with audio delay BTW)
Old 17th May 2012, 15:46   #11216  |  Link
omegaman7
omegaman7's Avatar
This is interesting. BD rebuilder has a similar issue when removing black borders. Why don't the programs choose a more obvious dimension (aspect ratio/pixel dimensions), and stick to that first choice? Rather than determining it multiple times.
Only one rooster, need be in the hen house...
omegaman7 is offline   Reply With Quote
Old 17th May 2012, 16:16   #11217  |  Link
Atak_Snajpera
v1.17.2 BETA update
Added: Encoding Client now supports 8 servers
Added: Encoding Progress in DE mode is saved immediately when number of encoded chunks increases
Fixed: EncodingServer not visible while using remote desktop
Fixed: Problems with illegal decimal symbol
Fixed: chapters were incorrectly modified with inverse telecine function
Fixed: not detected languages in mkv container with mkvtoolnix 5.3.0+
Fixed: missing chapters for AVCHD after speed conversion
Fixed: error message while demuxing DVD subtitles with more than 16 languages
Fixed: Ripbot264 was showing Demuxing error instead of Decoding error
http://www.mediafire.com/?l4xw11disreaxwm
Old 17th May 2012, 17:18   #11218  |  Link
soneca
I can not download it, a problem with Mediafire.
Ok now.
soneca is offline   Reply With Quote
Old 17th May 2012, 21:04   #11219  |  Link
Hobbe
How do you encode all the episodes from a tvshow dvd? and not just the longest...
And do you plan to support dvd iso?
Hobbe is offline   Reply With Quote
Old 18th May 2012, 17:24   #11220  |  Link
NLA
Bug!
The supported files which can be added for a batch job differ from those that can be added individually (specifically, I'm referring to .m2ts decrypted blu-ray support). I've been waiting for some kind of batch functionality for years, and now that its here, I can't really use it. And shouldn't the batch menu have some more options for what to do with audio, ie. wave, FLAC, core, etc?
P.S. What happened to the encoder settings menu? Used to be full of fantastic, easy-to-change options, and now its basically a textbox with a button to open a text file? Bit of a step backwards, isn't it?
NLA is offline   Reply With Quote
