Thread Tools | Display Modes |
#1 | Link |
RipBot264 v1.14.5 - Simple and easy to use GUI -> IPOD . PSP . CONSOLES . BLURAY
This small app written in Delphi is specially for people looking for something simple without exotic filters and unnecessary settings.
Download .7z -> http://www.mediafire.com/file/ddkzn2...t264v1.14.5.7z ![]() Common problems: 1) Error message in Media Player Classic or other decoding problem (avs2avi.exe crashes) Uninstall all codec packs and then reinstall AviSynth , Haali Media Spliter , ffdshow. XP users also must install Windows Media Player 11! 2) x264 crashes check cpu stability in LinX. check memory in memtest86 3) FLAC conversion is not available for DTS-MA More help in \tools\ax\ArcSoft DTS Decoder\Readme.txt Q: What does 4.1 profile do over 4.0 and would 4.1 be better for working with HD DVD/Blu Ray discs? A: According to wiki maximum bitrate in 4.0 high profile is limited to 25Mbps. 4.1 is limited to 62.5Mbps. That's all! Changelog Code:
v1.14.5 Added: RipBot264 will force XviD decoder for Divx files in ffdshow. (libavcodec sometimes causes audio sync problems) Fixed: Demuxed FLAC from MKV had wrong format (OGG instead of RAW FLAC) Fixed: PCM audio sometimes was not accepted by TSmuxer. (Added extra conversion wav->w64 before muxing) Updated: BDSup2Sub 3.9.8 , eac3to 3.17 , MediaInfo 0.7.23 , MKVToolnix 2.9.8 , x264 r1292M v1.14.4 Added: RipBot264 will force ffdshow as prefferd Xvid and Divx 4/5 decoder in Windows 7 Changed: Avi files will be decoded via DirectShowSource instead of OpenDMLSource (Reason: OpenDMLSource does not work well with Windows 7 RTM) Changed: Avs files wiil be imported via Import() instead of DirectShowSource Changed: Lossless audio is automatically selected instead of first audio stream in Demuxing window Changed: Bitmap based suptitles are also allowed for none-standard resolutions (MKV) Fixed: Blu-ray subtitles were not resized if user changed resolution after adding subtitles Fixed: FLAC will be decoded by madFLAC instead of BassAudio due to weird problems on Windows 7 RTM (Avs script hangs if bassaudio.dll is loaded) Fixed: temporary files will not be automatically stored on non-NTFS drives (external usb drive for example) Fixed: 24fps subtitles were automatically converted to 23.976fps due to missing /fps:keep option Updated: x264 r1251M, NicAudio 2.0.4, MediaInfo 0.7.21, Yadif 1.6, BDSup2Sub 3.9.7 v1.14.3 Added: Inverse Telecine function in Deinterlace section Added: --min-keyint (fps) and --keyint (fps*10) and --fps (24000/1001 for example) to x264 commandline Added: fraction will be used in script instead of rounded values (24/1.001 instead of 23.976 for example) Added: --title switch for mkv container (based on output filename without extension) Changed: x264 command line syntax according to changes introduced in r1177 (old profiles may not work!) Fixed: Only Subtitles (PGS) will be shown in GUI. Reason: Subtitles (SRT) do not work. Fixed: incorrect height in custom resize with locked aspect ratio (for example 1280x532 instead of ...x534) Fixed: too big undersize for mkv Update: BDSup2Sub 3.9.6 , DGIndex 1.5.5 , ffmpeg r19159 , MediaInfo 0.7.20 , MP4Box 0.4.6 , x264 r1195M v1.14.2 Added: DTS Master Audio and Hi-Res conversion to wave or FLAC (ArcSoft DTS Decoder required! More help in \tools\ax\ArcSoft DTS Decoder\Readme.txt) Added: Blu-Ray subtitles (.Sup) are now supported in Properties -> Subtitles section (Hardcoded subtitles) Added: Demuxing all subtitles at once Fixed: DTS size calculation for AVCHD Fixed: if order in job list was changed during conversion checkboxes were not assigned to current encoding job Fixed: incorrect --sar values if source had aspect ratio higher than 1.33 and lower than 1.56 (for example 624x464) Fixed: All empty temp folders will be removed Fixed: .avs scripts did not work in RipBot264 with AviSynth 2.5.8 Fixed: AVCHD incompatible resolution error even if video has correct resolution Update: DGindex 1.5.5, BDSup2Sub 3.9.3, MediaInfo 0.7.17, x264 r1169 v1.14.1 Added: PCM, TrueHD and EAC3 can be optionally converted to FLAC Added: muxing flac into .mkv Fixed: Incorrect audio duration in uncompressed audio Update: x264 r1162 v1.14.0 Added: Job queue can be modified during conversion. It is also possible to skip current job. Added: real-time preview during croping Added: support for wave64 Added: muxing .wav/.w64 to AVCHD structure Added: muxing DVD subtitles (idx/sub) to matroska Added: Blu-Ray subtitles (.sup) will be automatically converted to VobSub (.sub) if mkv container was selected Added: Blu-Ray subtitles will be automatically resized to proper resolution if AVCHD was selected (1080p->720p for example) Added: srt to sup conversion for 576p/480p (Warning: 576p subtitles are not visible on PS3!) Added: warning message if resolution is not compatible with AVCHD Added: FFdshow will be automatically set as preffered directshow decoder for H.264/VC-1/MPEG-2 in Windows 7 (thanks clsid for help with SetACL) Added: OSD and subtitles in FFDShow will be automatically disabled Changed: PCM, TrueHD and EAC3 will be always converted to .w64 Changed: Status color to dark blue Changed: x264.exe renamed to x264_x86.exe (GUI won't kill x264.exe) Fixed: script error if video had wav audio Fixed: correct sar values were not applied for 704x576 and 704x480 Update: DGAVCDec 1.0.9, BDSup2Sub 3.8.2 eac3to 3.16, MediaInfo 0.7.16, MKVToolnix 2.9.0, Oggenc 2.85 aoTuVb5.7, TSMuxer 1.10.6, x264 r1158M [FULL LOG] Last edited by Atak_Snajpera; 16th October 2009 at 17:29. |
#2 | Link |
н∂-αиαтι’
^ nice going mate!
![]() will check it out as i need to do a few vids for ps3. just noticed, u must have ffdshow? i don't really want to install ffdshow as i prefer separate codecs. any way around this? EDIT: just tried it on a lil sample, i wasn't asked to install ffdshow, just started the process. very easy prog to use! Last edited by ~bT~; 3rd July 2007 at 03:51. |
#3 | Link |
Very nice GUI,easy to use.
Why not making the first pass faster,like this: Code:
x264.exe --pass 1 --bitrate 800 --stats ".stats" --bframes 3 --filter 0,0 --subme 1 --analyse none --vbv-maxrate 25000 --me dia --thread-input --progress --no-psnr --no-ssim --aq-strength 0 --aq-sensitivity 0 --output NUL "hh.avs" @echo+ x264.exe --pass 2 --bitrate 800 --stats ".stats" --ref 3 --mixed-refs --bframes 3 --subme 5 --b-pyramid --bime --weightb --filter 0,0 --analyse all --8x8dct --vbv-maxrate 25000 --thread-input --progress --no-psnr --no-ssim --aq-strength 0 --aq-sensitivity 0 --output "hh.mkv" "hh.avs" Last edited by Jerry_Sm@rt; 3rd July 2007 at 12:05. |
#4 | Link | |||
Jerry_Sm@rt: Quote:
RipBot264 - Simple and easy to use GUI -> iPOD . iPhone . AppleTV . PSP . PS3 . XBOX360 . BluRay Mediainfo - Simple GUI with basic command line support Last edited by Atak_Snajpera; 3rd July 2007 at 12:25. |
#6 | Link |
@Atak_Snajpera
Maybe some psnr loss,but I really can not tell the differences between a fast 1st pass encoded movie and a normal 1st pass encoded movie(same bitrate).If I got a faster cpu, I would not care about it. What's your psp version?3.5?I'm still running 2.71se |
#8 | Link | |
н∂-αиαтι’
EDIT: Those keys are still there. ![]()
#9 | Link |
Ripbot264 fail to open any supported format & display an error message : '25.0000' is not a valid floating point value. Even if try to open NTSC file ('29.9700' is not.... in this case)
Avisynth v2.57, HaliMediaSpliter, FFdshow & .Net runtime v2.0 are installed properly (i'm using other GUIs with no problems) |
#11 | Link |
Problem with decimal symbol has been fixed in new version (v.1.0.1)
RipBot264 - Simple and easy to use GUI -> iPOD . iPhone . AppleTV . PSP . PS3 . XBOX360 . BluRay Mediainfo - Simple GUI with basic command line support Last edited by Atak_Snajpera; 4th July 2007 at 01:01. |
#12 | Link |
1- Not all of us are using the MT version of Avisynth, so why do you put SetMode(2) to the script when Deinterlace is activated ?! with official version, your script fail.
2- Tdeint don't give the optimal result with mthreshL=0. In most cases, Tdeint( order=0 or 1, full=false) can produce a good picture (this is my personal opinion). 2- The PC Profile is very slow (i don't try the 2 others), can you add a "balanced" profile. Keep the good work. |
#14 | Link | |||
http://forum.doom9.org/showthread.php?t=127423 http://forum.doom9.org/showthread.ph...99#post1003599 Quote:
RipBot264 - Simple and easy to use GUI -> iPOD . iPhone . AppleTV . PSP . PS3 . XBOX360 . BluRay Mediainfo - Simple GUI with basic command line support Last edited by Atak_Snajpera; 4th July 2007 at 03:30. |
#17 | Link |
This is one of the prettiest apps I've ever seen! Amazing interface look.
![]() And it just worked w/o problems first time I tried it. Firrst off I think it really needs user-customizable profiles. I think everyone here has some favourite switches and would like to tweak an option or two... However, I like your simple design and minimalistic look very much and would hate to see it bloated and cluttered in any way. It would be great if you could keep this simple elegant feel while adding new options. |
#18 | Link | ||
| Tags |
| appletv, avchd, bluray, gui, iphone, ipod, ps3, psp, ripbot264, xbox360 |
| Thread Tools | |
| Display Modes | |
