Old 10th September 2007, 21:11   #141  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Is it vfr?
Myrsloik is offline   Reply With Quote
Old 11th September 2007, 08:03   #142  |  Link
Lele-brz
Lele-brz's Avatar
Hi, thanks for answering
this are the specs of the video in question:
Filename: D:\testNewFormats\TVFINT_383_CONTENT.wmv
Container: asf
Extended: asf format
Bitrate: 1073198
Duration: 00:43:30
Video Codec: vc1
Audio Codec: wmav2
Video Size: 640 x 480
Video fps: 25
Audio channels: 2
Audio sample rate: 44100
Lele-brz is offline   Reply With Quote
Old 11th September 2007, 10:44   #143  |  Link
Myrsloik
Myrsloik's Avatar
But is it vfr?
Old 11th September 2007, 12:30   #144  |  Link
Lele-brz
Lele-brz's Avatar
sorry, I don't know, the tool I use for retrieving information is ffmpeg and it doesn't tell me if is varaible framerate...
thanks
Old 11th September 2007, 20:57   #145  |  Link
Myrsloik
Myrsloik's Avatar
Hint: timecodes=...
Old 12th September 2007, 20:17   #146  |  Link
TheFluff
Excessively jovial fellow
In my experience, WMV in the .wmv/ASF container is almost always VFR or some kind. vOv
Old 14th September 2007, 23:45   #147  |  Link
Myrsloik
Myrsloik's Avatar
New version. All colorspace conversions should finally work correctly (a bug in libavcodec's camtasia decoder made the testing very confusing). It's also possible to use ffmpegsource as a simple image reader with seekmode=-1. Animated gifs only seem to return the first frame though.
Old 15th September 2007, 07:06   #148  |  Link
Mtz
Mtz's Avatar
I'm trying to use AutoMKV and buzzqw recommended me to unpack the ffmpegsource dlls to system32. After I made this, when I'm trying to open VirtualDubMod 1.5.4.1 I always have this error:
When I overwrited the dlls, I remember that the latest dll was from spring of 2007 (don't remember the date)
enjoy,
Mtz
Mtz is offline   Reply With Quote
Old 15th September 2007, 07:43   #149  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
You're picking up an older version of ffmpegsource, I think. The latest version doesn't have that import. Check that no avsi files are loading older copies, for instance.
Old 15th September 2007, 11:33   #150  |  Link
Mtz
Mtz's Avatar
I used the 1.12 version. Until this update, VDM worked very well for me and I had some older dlls in system32 like avcodec-51.dll.
Old 15th September 2007, 11:51   #151  |  Link
buzzqw
HDConvertToX author
search for all avcodec-51.dll in your disk and delete all BUT this correct dll in windows\system32
on of these dll could be on a windows path directory
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 15th September 2007, 12:58   #152  |  Link
Mtz
Mtz's Avatar
Deleted, but the same problem. Before updating to 1.11 or 1.12 I neverhad problems, even if I had old dlls on system.
Old 20th September 2007, 21:34   #153  |  Link
Mtz
Mtz's Avatar
Can somebody give me a link with an old version (from spring) of the ffmpegsource? I want to test the old avcodec-51.dll.
Old 21st September 2007, 07:27   #154  |  Link
buzzqw
HDConvertToX author
look here http://www.64k.it/andres/dettaglio.php?sez=avisynth
BHH
Old 21st September 2007, 19:54   #155  |  Link
Mtz
Mtz's Avatar
Thanks! Tried all versions and no luck. I think I'll reinstall my OS.
Old 6th October 2007, 21:03   #156  |  Link
Myrsloik
Myrsloik's Avatar
New version with some minor fixes for timecodes and flv video.
Old 18th October 2007, 08:28   #157  |  Link
Lele-brz
Lele-brz's Avatar
my 2 cents about ffmpeg libraried dlls.
Would it be possible to use the statically compiled version of them, so the ffmpegsource.dll will be self-contained.
What I noticed is that sometimes if on the machine there are other ffmpeg dlls it can link against them.
thanks
bye
Old 19th October 2007, 00:25   #158  |  Link
Myrsloik
Myrsloik's Avatar
I hope you understand technobabble because that's what you just asked for...
Statically compiling with vs2005 is impossible, it doesn't use the same runtime library as mingw. Going back to vc6 isn't much fun either but it could work. I don't feel like doing all the work to find out but the source is available if anyone really wants to try it.
The other alternative is to use mingw. But then it has to be converted to a "c" plugin which in my last attempt failed miserably. Mostly since _fseeki64 and its friends only exists in msvcr80.dll and it didn't want to link it properly. For even more obscure reasons it didn't seem to fully appreciate haali's code either. But it was all statically linked and annoying to debug.
Then there's the lesser evil kind of solution. Link the ffmpeg dlls by symbol names instead of by ordinal. This would in theory make it possible to replace all dlls without recompiling and share the same set between all programs (major version changes excluded). This is however greatly discouraged and done by no one since the generated import libraries on windows link by ordinal. Fortunately I don't use my own plugins that much so why bother...
Farewell cruel world?
Old 19th October 2007, 09:19   #159  |  Link
akupenguin
x264 developer
akupenguin's Avatar
Is there a difference between _fseeki64 and fseeko64? The latter works in mingw.
Old 19th October 2007, 18:18   #160  |  Link
Myrsloik
Myrsloik's Avatar
I guess the difference is that one is microsoft approved and the other isn't. One day I really should learn this C (with and without ++) stuff.
