#1 | Link |
Matcher of fields
FFmpegSource
This thread shall begin much like one of my previous ones...
One day I got bored (again) and thought it would nice to have a plugin to open mkvs and similar things. That attempt failed miserably because it turns out that ffmpeg has just as much documentation as the average open source project. But as you all know you can't let computers win. Ever. This plugin should support decoding of all FFmpeg supported video formats with frame accurate seeking in avi, mkv and mp4 and possibly some others. Haali's parser is used for matroska since the ffmpeg one has serious issues and FFmpeg for everything else. Opening files is however a bit slow due to the required indexing. All current downloads and the source can now be found at the Google code project. This also includes TheRyuu's most recent FFmpeg-mt compiles as well as the old 1.21 version. (list deprecated downloads to make it appear) Google code project Full changelog Note: The real name is "Fabulous FM Source 2" and is in no way related to FFmpeg. The future todo list. Feel free vote for the features you want or suggest your own.
IVTC.org - Framing the debate about fields Last edited by Myrsloik; 11th August 2009 at 20:40. Reason: Improved readability greatly |
#3 | Link |
ангел смерти
![]() Join Date: Nov 2004
Very awesome. I might be able to skip DirectShowSource entirely now.
Seeking is broken on MPEG1 PS files, and when muxed into another container they just don't work at all. Well, I can continue using DGDecode on those. All other formats appear to work perfectly. One concern I have is the naming of the support files. Obviously they can't be statically linked, being different compilers, but other software uses the same libs, but incompatible. (Mediacoder for one, probably others.) Would it be possible to add a prefix/suffix to them? Even better, use loadlibrary to load them from the plugin's folder (which is rarely the same as current working folder in avisynth)? The listed improvements would be awesome, particularly timecodes. =D
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order. ~ Ed Howdershelt |
#5 | Link |
Matcher of fields
Actually I'm considering making it a c interface plugin because then I could statically link everything with gcc.
With vfr it just returns every encoded frame and sets the fps to 30.
IVTC.org - Framing the debate about fields |
#6 | Link |
Swallowed in the Sea
edit...wrong manip.
The problem, of course, is that there are many smart people in the world... Steve Jobs [my random stuff] | [Please, no MeGUI support via PM] Last edited by Kurtnoise; 17th June 2007 at 15:52. |
#7 | Link |
Actually, it returns 30 fps even with my 25 fps raw materials (at least for me). What's wrong ?
The problem, of course, is that there are many smart people in the world... Steve Jobs [my random stuff] | [Please, no MeGUI support via PM] |
#9 | Link |
Thanks for the new build.
btw, I've a request for the next releases : to be able to choose/select the video *or* audio tracks numbers. Something like that : Code:
FFmpegSource(string source, int vtrack = -1, int atrack = -1, bool forceseek = false, string timecodes)
#11 | Link |
Hi Myrsloik,
unfortunately I get a "Loadplugin: unable to load C:\Program files\AviSynth 2.5\plugins\FfmpegSource.dll" error....but apparently everything should be in order (plugins in the right place). Do you have an idea on what I'm doing wrong? |
#12 | Link |
ангел смерти
All of the support dlls have to be on the path, not in the same folder as the plugin. The simplest path is just putting them in the windows folder. (Or you can add the plugin folder to the windows path in the system control panel, but that might not be a great idea.)
#15 | Link |
AviSynth plugger
I am a little confused by this comment:
Myrsloik do you complile this "support DLL" some special way or they are standard?
My Avisynth plugins are now at http://avisynth.org.ru I usually do not provide a technical support in private messages. |
#16 | Link |
Matcher of fields
They're completely standard. The included dlls were compiled with:
./configure --enable-shared --disable-static --enable-memalign-hack --enable-swscaler --enable-gpl --disable-encoders --disable-muxers
#17 | Link |
ангел смерти
It's the configure options that are different. Mediacoder uses a totally different set, since it enables encoders and muxers.
Actually, now that I went hunting, I can't figure out what's dependant on that older avformat-51.dll. I guess it's not that important, in that case. >.>
#18 | Link |
Mushroomeur
Kurosu tried to write an ffmpeg source for avs3. He had a lot of problems with the audio. I can't remember what was the difficulty, though.
One thing to note about ffmpeg: the dev team never does any release and the api can change one day or another. So the plugin can, one day, not work anymore. |
#19 | Link |
Matcher of fields
I've looked a bit at the audio part now and everything seems to be the difficult part (unless you just want to play it linearly from one not too accurately specified point, then it's trivial).
The part about ffmpeg developers possibly changing the api one day is an exceptionally weak point if you look at how much has actually changed over the years. The sample I started with (unfortunately the only decent one in existence) from http://www.inb.uni-luebeck.de/~boehm...ec_update.html which was written exactly 3 years ago can still be compiled by only changing 3 lines or so (and by adding a few explicit casts if you use a c++ compiler). The changes were only in the names of fields containing information about the streams and the replacements were easy to locate. There were no changes in the actual decoding logic and the library still contains all deprecated functions so older programs should work with the new version after a recompile. You might as well say that one day windows will change and avisynth won't work anymore... What official releases have to do with it will remain a mystery...
#20 | Link |
Mushroomeur
ask the gstreamer developpers about the different versions of ffmpeg. For a developper it's a pain. Example : 3 or 4 days ago : they changed the options of configure. It's not 3 years at all.
The interest of a release : When compiling a program, you can check a specific version of the release. Then you know what the api is and use the correct functions, struct, etc... You might also know with a release if the abi is broken from a version to another, or not, which is also very important. windows has already changed and some programs didn't work anymore. Even with different SP of XP some programs work or not. |
| Thread Tools | |
| Display Modes | |
