Old 6th June 2007, 13:20   #1  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD Support Thread
Hi all!
Finally I have decided to share my little and very simple "creature". After some months of (very modest) programming and debugging, now I am ready to give AVStoDVD to Doom9 community. My hope is to help AVStoDVD to grow and, why not, help somebody with a very simple and easy-to-use tool.
What is AVStoDVD?
AVStoDVD is a flexible tool to convert various media formats to DVD compliant streams and burn them into a highly compatible single track (from release 1.0.0 to 1.2.3) or multi tracks (since release 2.0.0) DVD with menu creation capability (since release 2.1.0) and multi audio track support (since release 2.3.0).
Features:
- Video and Audio editing using AviSynth
- Video encoding using QuEnc/HCEnc/ReJig/FFmpeg
- Audio encoding using QuEnc/FFmpeg/Wavi/Aften
- Video/Audio muxing using ImagoMPEG-Muxer
- Subtitles encoding using SubtitlesCreator
- DVD Authoring using MuxMan/BatchMux
- ISO Image Building and DVD Burning using ImgBurn
- Internal DVD Menu Editor with customizable menus
Why AVStoDVD?
Because I find very difficult to remember all the scripts and cmd line switches needed by AviSynth, QuEnc, HCenc, MuxMan, etc.
AVStoDVD is basically a friendly GUI with very few buttons to click to quickly produce a DVD from a single A/V file.
Why another one-click solution?
Why not?
Where is AVStoDVD?
You can find the Win32 exe installer and the source code (VB6) on SourceForge.net: AVStoDVD @ SourceForge
What are the hardware requirements?
- 1 GHz CPU or more
- 10GB Hard Disk or more
- DVD Burner
What are the software requirements?
- Microsoft Windows 2000/XP/Vista (runs with Windows 95/98/Me but 100% functionality is not guaranteed)
- Microsoft DirectX 9.0 or higher
- AviSynth 2.5.7 or higher - included in the installer
- DirectShow codecs/filters needed to play media files to convert (I suggest FFDShow)
Since AVStoDVD is programmed in VB6, it does not need .NET Framework to run, and all needed DLLs and OCXs are provided with the installer package.
Please, write your impressions, suggestions and bug reports here on Doom9 forum. I really need them! Since I am not a professional software writer, please do not hit me too hard and be patient if I do not reply in real-time.
Bye
________
synthetic weed
MrC is offline   Reply With Quote
Old 7th June 2007, 09:25   #2  |  Link
ChickenMan
ChickenMan's Avatar
I tried out your new program, it installs and runs well on my Xp system. A couple of comments though, the avi I tried it on (DivX, 25fps 104min long) was going to take 3hr 40min to do the encoding phase, set to High Quality 1pass CBR. The same file only 21 min to do the encoding part using DVD2SVCD with CCE 2.70. Any chance of supporting CCE as an option ?
The final encode also had the DIVX Symbol in bottom right of the picture for the few seconds, I dont get that with any other avi to dvd converter I've tried. I know I can turn it off in the DivX Configuration, but I prefer it to be there for playback of the avi.
The audio was originally MP3 22khz and converted fine but volume level was very low. DVD2SVCD choked on this audio track completely and had to convert manually.
Cheers,
CM
ChickenMan is offline   Reply With Quote
Old 7th June 2007, 11:33   #3  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Good suggestion, I have never thought about CCE/HC support but can be an improvement. However more than 3hrs for a 104min DivX is really too much. With my old P4 Northwood 2.4GHz QuEnc usually encodes at 20/25 fps. Can you post or mail me the log file, if you saved it?
That's because AVStoDVD uses DirectShowSource() as default file input, instead of using AviSource() in the AVS script. Reason is higher compatibility.
If you use a audio DirectShow codec like ffdshow, you can modify the volume by the decoder configuration utility.
Alternatively you can edit the AVS script and insert the AmplifydB() function to the audio stream.
Thanks a lot for testing AVStoDVD beta! Your job is very very appreciated!
Bye
________
Honda XL600R
Old 7th June 2007, 16:56   #4  |  Link
ChickenMan
ChickenMan's Avatar
I stopped the encoding real early as at 3hr+ to encode, I didnt have the time. It was running around 15fps and I have a E6600 Core2 Duo.
Here is the Log file, I just edited out my file name:
START LOG OPERATIONS: 7/06/2007 5:51:11 PM
AVStoDVD PROJECT SETTINGS:
Source Video file: H:\xxxxxxx.AVI
Source Audio file: H:\xxxxxxx.AVI
DVD Video Format: PAL
DVD Video Aspect Ratio: 16:9
MPEG2 Encoding Options: High Quality (HQ, 1 pass, CBR)
DVD Video BitRate: 5593 (5593) kbps
DVD Audio Format: AC3
DVD Audio BitRate: 192 kbps
DVD Audio Language: EN - English
DVD Chapters Interval: 5 min
Delete temp process files: No
Save Log file: Yes
Shutdown system when process complete: No
Output Folder: G:\TEMP09
DVD Output Setup: DVD Folder
SOURCE FILES
Video: H:\xxxxxx.AVI
Info: AVI (DivX 5) - 958 kbps - 720x392 - 16:9 - 25 fps - 1:44:43 hours - 157078 frames
Audio: H:\xxxxxx.AVI
Info: AVI (MPEG-2 Audio layer 3) - 96 kbps - CBR - 22050Hz - 2ch - 1:44:43 hours
AVISYNTH SCRIPT
Video = DirectShowSource("H:\xxxxxx.AVI")
Audio = DirectShowSource("H:\xxxxxx.AVI")
AudioDub(Video, Audio)
ConvertToYV12
LanczosResize(720,392,0,0.5)
AddBorders(0,7,0,7)
LanczosResize(720,576,0,0.5)
SSRC(48000)
END VIDEO ENCODING OPERATIONS: 7/06/2007 5:57:03 PM
Created File: G:\TEMP09\xxxxxx_AVStoDVD.m2v (113375363 Byte)
END AUDIO ENCODING OPERATIONS: 7/06/2007 6:03:56 PM
Created File: G:\TEMP09\xxxxxx_AVStoDVD.ac3 (150806784 Byte)
END VIDEO/AUDIO MUXING OPERATIONS: 7/06/2007 6:04:12 PM
Created File: G:\TEMP09\xxxxxx_AVStoDVD.mpg (268869632 Byte)
END DVD AUTHORING OPERATIONS: 7/06/2007 6:04:17 PM
Created Folder: G:\TEMP09\xxxxxx_AVStoDVD
END LOG OPERATIONS: 7/06/2007 6:04:17 PM
Cheers,
CM
Old 7th June 2007, 18:07   #5  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Maybe your PC was running some other application meanwhile? I have set QuEnc priority level to "idle".
Bye
________
BMW K1100LT
Old 8th June 2007, 04:24   #6  |  Link
ChickenMan
ChickenMan's Avatar
Absolutely no other apps running at the time. I just checked with another avi, an NTSC 23.976 also about 100min long and with AC3 audio (so no audio conversion was happening), it also was to take 3hr+ to encode and getting around 13-14fps. I checked my CPU usage at the time and QuEnc was running at 50% (one CPU at 90% and second at 10%) as expected since its not Dual core aware.
The above avi was NTSC 23.976 but because hidden in the settings, it was set to PAL, it was encoded to PAL which is not what I wanted. Wouldnt it be simpler to encode to the format of the original avi but allowing it to be changed if required ?
Cheers,
CM
Old 8th June 2007, 08:01   #7  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
QuEnc's speed problem is very strange: a friend of mine with same CPU as yours, reports to encode at 32/35 fps with same CPU usage.... Try using ffdshow with default options instead of DivX/XviD as DirectShow codec, if you will.
The option to automatically switch (or ask the user) to source video format (PAL/NTSC) is another good "ToDo" point.
What do you think about the GUI? Is it user-friendly enough? Any suggestions how to improve it?
Tnx again
Bye
________
cloudy trichomes
Old 8th June 2007, 13:33   #8  |  Link
ChickenMan
ChickenMan's Avatar
I prefer not to install ffdshow as always in the past it has always screwed up my system. Using CCE I currently get 100 to 125 fps with D2S so reluctant to screw that up in any way, but may try later on a standalone install of XP.
GUI looks good for me, but personally I don't take much heed in looks, its functionality I'm more concerned with.
One more little request, can we have a bit-rate of 224 included for AC3. For 2 channel AC3, the most commonly used bitrate you will find on commercial dvd's is 192 & 224.
Cheers,
CM
Old 8th June 2007, 14:51   #9  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Ops, just missed it!
Bye
________
Honda CB400F
Old 8th June 2007, 23:18   #10  |  Link
ricardo.santos
ricardo.santos's Avatar
any chance of subtitle support in the future?
ricardo.santos is offline   Reply With Quote
Old 9th June 2007, 13:19   #11  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
As a matter of fact I have not yet explore this "world", but I will. Before including it, I want to be sure that the user-friendly GUI will not be heavily impacted.
Did you tried it? Did it work? How are your impressions?
Bye
________
Honda FSC600
Old 10th June 2007, 07:12   #12  |  Link
Dkruskie
I tried a small avi i had.came out ok. I like the gui nice. I think the option to choose encoders would be great, cce or hc, and maybe be able to add multiple files instead of just one.
Dkruskie is offline   Reply With Quote
Old 10th June 2007, 11:14   #13  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Thanks! Any suggestions how to improve it?
Surely I will add hc support. I'm still wondering if to add CCE because it is not free.
Good suggestion. Lots of work to handle multiple files, but, ok, it is a good point. Tnx.
Bye
________
marijuana strains
Old 10th June 2007, 11:54   #14  |  Link
Dkruskie
I like the gui the way it is..nice and simple and not confusing.
I'm looking forward to hc support. Maybe for adding the multiple files having a window something like favc has.
Old 10th June 2007, 15:47   #15  |  Link
ChickenMan
ChickenMan's Avatar
CCE Basic is US$59, thats excellent value in my books and should not be beyond anyones budget.
Cheers,
CM
Old 10th June 2007, 16:01   #16  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
I have never opened FAVC... I was thinking to leave the single-title aspect of AVStoDVD like it is and add a separate window for batch encoding a jobs list. What do you think?
Bye
________
mary jane
Old 10th June 2007, 17:43   #17  |  Link
Pyr0
Video N00b
another vote for CCE support from me too if possible (preferably with the RoBa method for encoding)
i'm currently looking to see if i can find something to replace DVD2SVCD, since it refuses to work with 4GB of mem installed
Pyr0 is offline   Reply With Quote
Old 10th June 2007, 18:11   #18  |  Link
bionic
+1 for roba, cce and subs, and a separate window for batch sounds good too me.
Havent tried it yet, but it looks very promising
bionic is offline   Reply With Quote
Old 10th June 2007, 21:00   #19  |  Link
Dkruskie
a separate window for batch sounds good too me too
Old 12th June 2007, 19:48   #20  |  Link
chaparral
chaparral's Avatar
Hi MrC, congratulations for your new project and hopes that you get all the success with him...
Now, this could sound like i'm a total newbie but the fact is i've tryied to run it on my Windows Vista Ultimate and the instalation went well, the problem is that i just don't know how to add the input files(avi,divx or xvid files) because i only see the path to add audio files...
The interface application program is very easy and i have a bit of experience in programs like this but the fact is that with this one it seems so far a bit complicated ,ehehehehehehe....
So if you could give some help on this i apreciate in order to give you my impressions about your "monster", lol...
Regards
chaparral is offline   Reply With Quote
[IMG] code is Off
