#21 | Link | |
![]() Thanks a lot to both of you for the work you do.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. |
#24 | Link |
OK, what am I doing wrong?
- put a new key into txt file ProcessingDeviceKeysSimple.txt as the only entry w/o spaces; - started vid.exe and got the correct VID from Matrix 3; - started aacskeys with the drive letter and VID from vid.exe in the command line. No matter what I am getting "Error opening Media Key file f:\AACS\MKBROM.AACS". I am using aacskeys.exe 2.6. And yes, I enter the correct VID in the command line, I am pretty sure. Totally drives me nuts. Suggestions are welcome, thanks. Last edited by Galileo2000; 31st May 2007 at 00:17. |
#25 | Link | |
arnezami Last edited by arnezami; 31st May 2007 at 00:25. |
#26 | Link | |
I did it on the new, pretty fresh system I've assembled not too long ago and Toshiba UDF 2.5 drivers weren't installed. Installed drivers, rebooted, everything works like a charm now
#28 | Link | |
I really don't see how them releasing their key helps them in any way, and seeing as theirs is a comercial operation, it's not reasonable to expect them to release keys just to be nice to us. Mal |
#29 | Link | |
You need to use verbose mode, and then you don't need VID (on my machine). With normal mode or w/o parameter on my machine (XP SP2) I am getting exception trying to run it with "n" parameter or without any parameters, with or without VID in the command line. Arnezami, let me know if you want more details, but IMHO this exception error does not matter at the moment. |
#30 | Link | |||
#31 | Link |
So, when does it end?
Not to beat a dead horse or anything, but how many cycles of revoking and releasing new keys will we go through before AACS is deemed as insecure and not worth fixing as CSS?
My guess the upper limit is 340,282,366,920,938,463,463,374,607,431,768,211,456 cycles, but hopefully one or two more before the AACS LS decides it's not really effective protection. |
#32 | Link | |
Verbose mode itself is not important: but you need to choose a mode: n, v or s when inputting the VID. arnezami Last edited by arnezami; 31st May 2007 at 08:13. |
#33 | Link | |
The same is true for us: if they release their key (ehm program) we should use that one. We shoud find one on our own but use theirs. But since it is not known which key they are using its simlply a guess: its possible we find a different Processing Key then they have which (if posting that one) would be a waste: two players instead of one player would be instructed to harden their product. In order to make sure we release the same key either Slysoft has to tell someone (privately) over here from where they got their key (they wouldn't have to give it away) or we have to ask SlySoft privately whether our to be released key is the same as theirs or we have to figure it out ourselves. Which would take extra time. This would indeed benefit both us and them. To prevent multiple keys from being out there. On the other hand: the ACCS LA pretty much revoked all players this time so they may do this the next time aswell. But not all players will be ordered to harden themselves so I think this is an important issue. Maybe we should talk with SlySoft about this .Of course if next time we find the key(s) first this won't be an issue at all .Regards, arnezami PS. A program cannot hide which Device/Processing Key(s) its using. Not from the AACS LA anyway. Last edited by arnezami; 1st June 2007 at 09:29. |
#34 | Link | ||
Mal |
#36 | Link | |
It will be interesting what they have to say. What could they say? New version: instantly opened. How do wrap that in a few PR sentences? ![]() arnezami |
#37 | Link | |
#38 | Link | ||
#39 | Link |
I think they're factored in a fair few revokations into the costs of maintaining AACS, however it is not this issue that is affecting the effectiveness of AACS. It seems to be the players not being hardened enough (with Bus encryption) etc. I can't see any Windows software player being hardened enough unless the OS blocks access to the program's memory! Maybe Microsoft want WinDVD and PowerDVD to be revoked entirely so that they can sell their own future player as the only one available for Windows LOL!
However hardware players will probably see hypervisor-style hardening soon if players keep being compromised at this rate! Last edited by bourke; 31st May 2007 at 14:02. |
#40 | Link |
According to the Freedom to Tinker article entitled "AACS Updated, Broken Again", the main problem currently faced by the LA is the length of time that it takes to blacklist or revoke. Licence terms require player manufacturers are given at least 90 days notice before new disks can be released, and even if that was reduced, manufacturing and distribution times mean a delay cannot be totaly eliminated. Slysoft and others are not constrained by delays like that, and can put their updates out as soon as they are ready.
As regards hardware solutions, it would appear that they are not currently looking at that. If you look at the Movielabs site, where the studios have a joint enterprise making grants for technological developments, they are looking for ways to hide cryptographic keys in software players without needing harware assist, as they put it. See http://www.movielabs.com/Challenge/h...aphickeys.html Also, they have other problems looming. There are allegations that aacs itself violates cryptographic patents held by Certicom. And although not directly in point, there are also allegations that technology used in Blu-Ray disks violates patents held by Target Technology. |
| Thread Tools | |
| Display Modes | |
