#8801 | Link | |
it works -- i can get all 6 channel of .wav and after i use Surcode to synth 6 channel of .wav to .dts, it finish successfully; but somehow, when i try to add this .dts to Tsmuxer, it doesn't recognize anything i need to do? thanks |
#8802 | Link |
I have the same issue with Tsmuxer and Ripbot264 not recognizing my .dts file. I just saw this in another post:
http://forum.doom9.org/showthread.ph...82#post1271882 He ran the .dts file through eac3to again and it's working for him. I'm going to try this myself. |
#8803 | Link |
The latest eac3to breaks Linux support via wine for me. I now get:
$ wine ~/eac3to/eac3to video "1)" 2: video.vc1 3: audio.ac3 Error reading file "video\BDMV\STREAM\00004.m2ts". This same command worked perfectly on a previous version of eac3to (can't remember which one). I think it's because eac3to uses \ instead of / characters for the path. Does anyone know how to work around this? |
#8804 | Link |
When you encode with Surcode use the .cpt (compact) format instead the .dts (padded) format. After rename to dts.
BeHappy, AviSynth audio transcoder, in Doom9 forums. NicAudio, BassAudio, audio decoders. |
#8805 | Link | |
I see what you mean. I ran it through eac3to again and it removed the padding. Now it works with TsMuxer.
Thanks, -Hoju Quote:
#8806 | Link |
I have a problem. I load the track in eac3to and select to decode it, but nothing happens... and I wait, and wait. I tried everyting: changed the version of the program with newer, reinstalled the codecs, but the problem still is the same. Usually when i load the track in the program and select to decode it, it opens CMD for a second or two and makes an analyse, then i can do my job.
What's the problem? And how can I fix it? |
#8811 | Link |
First I extract my audio track. For exmaple TrueHD (*.thd) track. I open the eac3to GUI, which has all of its plugins like SurCode DTS. Then I click on "Add Source File(s)" and input the *.thd audio track. After that I go to the next tab "Eac3to Audio" and in the upper right I choose the "Input File(s) or Folder(s)". (I just select the only file that I added earlier)
The program usually runs CMD to analyse the source file and after the analyse I can select my options and docode the audio without any problem. But this time the program minimizes and CMD doesn't pop up like usual. I runned CMD to see if it works - it works. I changed the codecs, changed the eac3to with newer but the problem still is the same and i can't decode my TrueHD tracks to DTS like I did before. I'm doing everything like before. Can you tell me what could be the problem? How can i fix it? P.S: Sorry for my English. I'm from Bulgaria. |
#8812 | Link | ||
I think is a GUI problem, if your source is from BD, the thd identifier TrueHD/AC3 (generated by eac3to) maybe is not recognized by yr_eac3to_more_gui. Try using another GUI
#8813 | Link |
Thank you for the help! I downloaded this GUI http://www.digital-digest.com/softwa...9&ssid=1&did=3 . Which isn't better then the last one and I have to write code to decode audio but the most important thing is that I can do my job right.
#8814 | Link | |
So I've used eac3to several times now to rip my bluray movies to the comp and have never encountered a problem. I was ripping the firefly bluray to my comp the other day and every episode i ripped, eac3to said:
If someone could help me out it would be appreciated. If it is indeed a RipBot264 problem, please let me know and I'll post this in the appropriate forum. Last edited by wolfbane5; 3rd May 2009 at 19:21. |
#8815 | Link | ||||||||||||||||||
Is already on the to do list.
That's clearly a false alarm. Could you please report that to the AV writers? Thanks! Quote:
There is a bug in eac3to, but I don't really think that it results in incorrectly written w64 files. I rather guess that maybe your harddisk was full? Quote:
Whenever Nero decodes to 24bit and libav decodes to 16bit, you can usually trust libav and discard Nero. Nero likes to apply dialnorm, which mutates a 16bit track into 24bit. Usually eac3to is able to convince Nero to not apply dialnorm. Maybe in your case that failed. I'd like to get a small sample of the TrueHD track, so that I can try to find out why Nero outputs 24bit. Quote:
The URL still seems to work fine for me with the current eac3to version. Quote:
But what about DTS speaker placements? There are many many different versions for 7.1 DTS tracks. In my 7.1 DTS-HD sample collection I have at least 4 different combinations of speakers. Surprsingly "L, R, C, LFE, Lss, Rss, Lsr, Rsr" seems to be the exception and not the norm. So that is a problem for me. If I switched to these names, which names should I use for 7.1? It is!? That is news to me!
#8818 | Link |
eac3to v3.16 released
http://madshi.net/eac3to.zip Code:
* added undocumented "-no2ndpass" switch to turn off 2nd pass processing * fixed: two pass processing sometimes produced superfluous sup files * fixed: MPG/EVO/VOB audio tracks with "PES extension 2" were not detected * fixed: very small W64/RF64 files were not detected correctly * fixed: when processing was aborted, log file was sometimes not created * fixed: sometimes specifying a title number addressed the wrong HD DVD title |
| Tags |
| eac3to |
| Thread Tools | |
| Display Modes | |
