Thread Tools Display Modes
Old 6th February 2009, 21:29   #8161  |  Link
laserfan
Aging Video Hobbyist
Originally Posted by laserfan View Post
...eac3to reported 51 chapters. This movie has 16 chapters so on a hunch went back to an earlier version of eac3to and sure enough, got 16 chapters. After trying subsequent versions I found that it broke going from v2.65 to v2.66...
Can you please upload the CLIPINF and PLAYLIST folders? Zipped that should only be a few KBs.
Here you go--I think 00216 is the mpls of interest and the clpi prolly 00011. Advise if I can provide any further info!
laserfan is offline   Reply With Quote
Old 6th February 2009, 21:33   #8162  |  Link
magic144
Both methods should produce similar results, as long as there are no gaps/overlaps in the video track (which is really rare). VC-1 does not depend on the container.
thanks for the reply madshi,
are you saying that one of these 2 methods does NOT remove/compensate for gaps/overlaps - I thought eac3to would always remove gaps/overlaps when demuxing a full-disc-structure title... if this is not the case, which of these 2 methods doesn't invoke eac3to's gap removal...?
or is it simply the case that eac3to does not do ANY Video gap compensation (in any mode - i.e. it just does audio) - I guess if that was the case and that ever happened, eac3to would just flag it in an info/warning message? (never seen such a warning on any of my discs to date anyway) - is it something eac3to might handle in the future?
cheers again,
m
ps - incidentally, does anybody out there know of a way to accurately frameserve (in an AviSynth script) a raw .vc1 file without going to an intermediate .mkv container? I don't think the Haali source file splitter filter will take a .vc1 file as input if I try to build such a graph in graphedit.
magic144 is offline   Reply With Quote
Old 6th February 2009, 22:49   #8163  |  Link
Thunderbolt8
better upload it externally, as getting approval can take ages.
Old 6th February 2009, 22:56   #8164  |  Link
laserfan
Wonder what this is about; the last time I attached something here no approval was needed at all afaict.
Old 6th February 2009, 23:56   #8165  |  Link
topsham
Originally Posted by nautilus7 View Post
I am trying to use the new aften build (762), but i get this error:
eac3to input.eac3 output.ac3
E-AC3, 5.1 channels, 1:42:01, 2046kbit/s, 48khz, dialnorm: -27dB
Removing dialog normalization...
Decoding with DirectShow (Nero Audio Decoder 2)...
Disabling DRC for Nero (E-)AC3 decoding...
DirectShow reports 5.1 channels, 24 bits, 48khz
Encoding AC3...
invalid number of channels
Initialization of the AC3 encoder failed.
eac3to is latest (2.30) and this happens with all libaften builds (generic, SSE3 etc). It also happens when i use as input wav or raw or ac3 files. In other words always. But if i use aften.exe and encode to ac3 outside eac3to everything works fine.
Does it seem as a libaften or an eac3to problem?
I am just starting to use eac3to and have encountered this problem. Is there a fix please?
topsham is offline   Reply With Quote
Old 7th February 2009, 07:19   #8166  |  Link
DrNein
Originally Posted by lchiu7 View Post
Sorry but can't see the relevance of those posts. I am having problems with the Nero codec, not Arcsoft.
A quick check of the DS Filter chain shows
"Nero Audio Decoder 2",{83E69A3D-56A5-4850-89C9-F6B6F003EB9B},00600000,"c:\program files\common files\ahead\dsfilter\neaudio2.ax"
Not entirely sure what else to check
And I am running Nero 7, not 8.
Sorry, I mixed up two replies. That should have been:
See post #7880 and on and particularly:
http://forum.doom9.org/showthread.ph...09#post1238209
DrNein is offline   Reply With Quote
Old 7th February 2009, 14:56   #8167  |  Link
0xdeadbeef
Author of BDSup2Sub
I wonder if eac3to considers a PAL speedup (-speedup) for the exported subtitles.
I exported video, audio and subtitles from a M2TS stream and applied the "-speedup" option to the audio tracks (23.976Hz -> 25Hz). Then I needed to convert the exported SUPs via SupRead (export options: HDDVD, 25Hz) and SubtitleCreator to SUB/IDX.
Unfortunately, audio and subtitles are getting out of sync (subtitles after audio), the more time passes by.
So I wonder: are the SUP time stamps not fixed correctly when using the "-speedup" options or does one of the other tools introduce the problem? Would it make sense to try 23.976fps in SupRead? Does this have an influence at all if converting from SUP (BD) to SUP (HDDVD)?
0xdeadbeef is offline   Reply With Quote
Old 8th February 2009, 09:57   #8168  |  Link
mrr19121970
I assume you are using tsMuxeR to build your streams back together ? You need to change the video frame rate to 25 and bind the subtitles to frame rate.
The GUI Clown_BD can do this in 1 option for you.
mrr19121970 is offline   Reply With Quote
Old 8th February 2009, 11:34   #8169  |  Link
madshi
It seems that playlists 1 and 216 are identical - except that 216 has more chapters than 1. Don't know why they made the disc that way. There's a good reason, though, why eac3to chooses the playlist with more chapters. See here:
http://forum.doom9.org/showpost.php?...postcount=6376
When there are two playlists with a different number of chapters, which should I use? There are good arguments either way...
eac3to automatically fixes audio gaps/overlaps, but it does not automatically fix video gaps/overlaps. And the only way to fix video gaps/overlaps is to modify the timestamps of a container. So if you demux video, there's nothing eac3to can do to fix the gaps/overlaps. However, the next eac3to version will at least also complain about gaps/overlaps if you demux video (older versions didn't).
Make sure you're using the latest eac3to version. If the problem still occurs then please post the eac3to log.
No. FPS changes for subtitles is not implemented yet. It's on my to do list, though...
madshi is online now   Reply With Quote
Old 8th February 2009, 11:49   #8170  |  Link
madshi
eac3to v3.07 released
http://madshi.net/eac3to.zip
* added support for MKV video tracks without sequence headers in bitstream
* added support for old style MKV AAC tracks
* added support for various MKV "A_MS/ACM" audio formats
* added support for various MKV "V_MS/VFW/FOURCC" video formats
* added warning for tracks where bitstream parsing failed
* demuxing a video track now also complains about video gaps/overlaps
* the "-check" option now also complains about video gaps/overlaps
* optimized memory allocation
* fixed: adding subtitle caption count to filenames sometimes didn't work
* fixed: subtitle caption counts in log sometimes had wrong track numbers
* fixed: all non-supported MKV tracks shared the same description
* fixed: incorrect framerate mismatch complaint was shown for pulldown sources
* fixed: FLAC tracks in MKV files don't slow down detection, anymore
* fixed: source file detection read 300MB from every source file
MKV support for those audio and video codecs which are natively supported by eac3to should be pretty complete now. MKV tracks using other video/audio codecs may demux successfully (or not), but are not officially supported by eac3to.
If you have any MKV samples with eac3to supported audio/video codecs which are not properly handled by eac3to, please upload a small sample for me. Thanks!
MKV subtitles, chapters and attachments are still not supported at all. Maybe next week...
Old 8th February 2009, 12:04   #8171  |  Link
Thunderbolt8
thanks!
Old 8th February 2009, 12:19   #8172  |  Link
0xdeadbeef
Author of BDSup2Sub
Ok, I have another problem. I tried to convert the E-AC3 soundtracks of the European King King HD-DVD to AC3 and - while I was at it - apply a PAL speedup:
eac3to.exe h:\HVDVD_TS\FEATURE_1.EVO+h:\HVDVD_TS\FEATURE_2.EVO 2: d:\dvd\kk\Chapters.txt 3: d:\dvd\kk\kk.* 4: d:\dvd\kk\en.ac3 -libav -speedup -384 7: d:\dvd\kk\de.ac3 -libav -speedup -384 11: d:\dvd\kk\en.sup 14: d:\dvd\kk\de.sup 28: d:\dvd\kk\de_forced.sup
For the original EVOs EAC3TO reported an audio delay of 1001ms only for the English sound track.
HD-DVD King Kong
1: Joined EVO file
2: Chapters, 50 chapters with names
3: VC-1, 1080p24 /1.001 (16:9) with pulldown flags
4: E-AC3, English, 5.1 channels, 1536kbps, 48khz, dialnorm: -27dB, 1001ms
5: E-AC3, French, 5.1 channels, 384kbps, 48khz, dialnorm: -27dB
6: E-AC3, Italian, 5.1 channels, 384kbps, 48khz, dialnorm: -27dB
"Italian"
7: E-AC3, German, 5.1 channels, 384kbps, 48khz, dialnorm: -27dB
8: E-AC3, Spanish, 5.1 channels, 384kbps, 48khz, dialnorm: -27dB
9: E-AC3, Japanese, 5.1 channels, 384kbps, 48khz, dialnorm: -27dB
However, after muxing the video and audio streams with TSMuxer, the audio is about 32 seconds (!) too early - and I'm not even sure if this is consistent. As converting the EVOs to M2TS with TSMuxer alone (no audio conversion) worked perfectly, I would assume that something goes wrong here with the audio conversion. I'm not quite sure what though. Any hints?
Old 8th February 2009, 13:27   #8173  |  Link
honai
Thanks madshi!
honai is offline   Reply With Quote
Old 8th February 2009, 13:52   #8174  |  Link
madshi
You forgot to speedup the video track.
Old 8th February 2009, 14:16   #8175  |  Link
0xdeadbeef
Author of BDSup2Sub
Thanks for the hint. I'm pretty sure I read somehwere (3.06 command line help?) that the "-speedup" option was only valid for audio tracks.
But ok, obviously my fault. I must admit that I used a GUI for my M2TS conversions and used the command line the frist time for the EVOs.
Old 8th February 2009, 16:07   #8176  |  Link
madshi
It's not. How is a sped up audio track supposed to sync with a non-sped up video track?
Old 8th February 2009, 16:19   #8177  |  Link
laserfan
When there are two playlists with a different number of chapters, which should I use? There are good arguments either way....
But madshi, the new versions of eac3to don't in any way expose the correct chapter list. Here's all it shows me:
D:\>eac3to h:
1) 00216.mpls, 00011.m2ts, 1:30:05
   - h264/AVC, 1080p24 /1.001 (16:9)
   - h264/AVC, 480p24 /1.001 (16:9)
   - TrueHD, English, multi-channel, 48khz
   - AC3, French, multi-channel, 48khz
   - AC3, Spanish, multi-channel, 48khz
   - AC3, Portuguese, multi-channel, 48khz
   - AC3, Thai, multi-channel, 48khz
   - AC3, English, stereo, 48khz
   - DTS Express, English, stereo, 48khz
2) 00202.mpls, 00105.m2ts, 0:26:44
   - MPEG2, 1080p24 /1.001 (16:9)
3) 00203.mpls, 00106.m2ts, 0:16:00
But then even if I force eac3to to look at 00001 it still gives me 51 chapters? Maybe it was/is another .mpls that gives 16 chapters?
D:\>eac3to h:\bdmv\playlist\00001.mpls
1) 00001.mpls, 00011.m2ts, 1:30:05
D:\>eac3to h:\bdmv\playlist\00001.mpls 1: chapter.txt
M2TS, 2 video tracks, 7 audio tracks, 15 subtitle tracks, 1:30:05, 24p /1.001
1: Chapters, 51 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: h264/AVC, 480p24 /1.001 (20:11)
4: TrueHD/AC3, English, 5.1 channels, 48khz
   (embedded: AC3, 5.1 channels, 640kbps, 48khz)
5: AC3, French, 5.1 channels, 640kbps, 48khz, dialnorm: -30dB
6: AC3, Spanish, 5.1 channels, 640kbps, 48khz, dialnorm: -30dB
7: AC3, Portuguese, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
8: AC3, Thai, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
9: AC3 Surround, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB
10: DTS Express, English, 2.0 channels, 24 bits, 192kbps, 48khz
11: Subtitle (PGS), English
12: Subtitle (PGS), English
13: Subtitle (PGS), French
14: Subtitle (PGS), Spanish
15: Subtitle (PGS), Portuguese
16: Subtitle (PGS), Chinese
17: Subtitle (PGS), Chinese
18: Subtitle (PGS), Korean
19: Subtitle (PGS), Thai
20: Subtitle (PGS), Spanish
21: Subtitle (PGS), Portuguese
22: Subtitle (PGS), Korean
23: Subtitle (PGS), Spanish
24: Subtitle (PGS), Portuguese
25: Subtitle (PGS), English
Creating file "chapter.txt"...
Done.
Still puzzled why the older version of eac3to finds-and-picks 16 chapters correctly, but the newer doesn't expose 16 chapters anywhere? In that post you linked to, at least that movie showed the feature as being in multiple playlists; this one does not.
Well, I guess this command:
D:\>eac3to h:\bdmv\playlist\ xxxxx.mpls
is giving me the main movie playlist (& incorrect 51 chapters) every time, so apparently I've not used a proper eac3to command...
EDIT: Here are the very different results when using eac3to v2.65! Apparently 00217 is the correct mpls to choose!
D:\>"c:\program files (x86)\eac3told\eac3to.exe" h:\
1) 00217.mpls, 00011.m2ts, 1:30:05
2) 00216.mpls, 00011.m2ts, 1:30:05
3) 00202.mpls, 00105.m2ts, 0:26:44
4) 00203.mpls, 00106.m2ts, 0:16:00
D:\>"c:\program files (x86)\eac3told\eac3to.exe" h:\ 1)
1: Chapters, 16 chapters
9: AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB
Old 8th February 2009, 17:01   #8178  |  Link
magic144
thanks again Madshi - and for the new version :-)
One more question then. Are you saying that doing something like this:-
eac3to L: 1) 2: video.mkv
rather than a blanket disc title demux would keep a VC1 stream in a container (.mkv, albeit a different one from its original .m2ts housing) and allow eac3 to fix video gaps/overlaps, and is that an existing feature or a future planned capability? If I remember rightly, you said the use of video gaps/overlaps is incredibly rare in source material - but you have seen it?
Cheers,
m
Old 8th February 2009, 19:32   #8179  |  Link
0xdeadbeef
Author of BDSup2Sub
Well, indeed it doesn't seem to make much sense to have a seperate speedup option for each stream, either. I guess it's highly unlikely that someone wants to speed up just some streams. This also creates confusion regarding the chapter timestamps and the subtitles.
Why don't you just make it a global option?
Old 8th February 2009, 20:01   #8180  |  Link
Snowknight26
(ノ ゜Д゜)ノ ==== ┻━━┻
eac3to.exe "G:\Movies\The Third Man\The.Third.Man.mkv"
MKV, 1 video track, 4 audio tracks, 1:45:13, 24p /1.001
1: h264/AVC, English, 1436x1080 23.976p
2: FLAC, English, 1.0 channels, 1:45:13, 16 bits, 48khz
   "FLAC 1.0 @ 202kbps"
3: VORBIS, English, 1.0 channels, 48khz
   "Commentary w/ Steven Soderbergh and Tony Gilroy"
4: VORBIS, English, 1.0 channels, 48khz
   "Commentary w/ film scholar Dana Polan"
5: VORBIS, English, 1.0 channels, 48khz
   "Abridged recording of Graham GreeneÆs treatment, read by actor Richard Clark
e"
v01 The video bitstream is encoded in a non-standard framerate.
Bitstream parsing for tracks 3-5 failed.
Demuxing these tracks may still produce correct results - or not.
The video was encoded using 23.976fps, just like all my encodes I have done. Should I be specifying 24000/1001 instead? Or does it not matter because its only a cosmetic issue?
And a small suggestion. It might be better to say "Demuxing these tracks may or may not produce correct results." instead of what you currently have. At least thats what I think.
Snowknight26 is offline   Reply With Quote
eac3to
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
