#6501 | Link | |
Not really, but your question has already been answered about a dozen times earlier in this thread. Just do a search for "Lossless check failed".
I've asked Mosu yesterday whether he can add a version resource to the GUI. That would solve the problem... |
#6503 | Link |
I know this used to show up on the join spots of seamless branching movies and that this wasn't a problem anymore, but this one is a single file. I see however that this isn't clear from the log or post, stupid of me. So the same "no problem" applies to non-seamless branching movies as well?
#6505 | Link |
Hi guys,
I've been making some trials for two days. Finally i can say it is possible to demux directly from BD/HD Disc to HDD with eac3to; which means lots of unwanted things won't be ripped on your disk. AnyDVD-HD is working on the back stage btw. I selected one of the most difficult ones of my collection which including many m2ts files in one playlist for test. No issues. Code:
getting playlist info: C:\>eac3to\eac3to.exe E: 1) 00056.mpls, 2:17:14 [0+2+6+8+9+12+13+15+16+19+20+21+24+25+26+28+118+119+32+33+34+37+39+40+42+43+45+46+49].m2ts - h264/AVC, 1080p24 /1.001 (16:9) - TrueHD, English, multi-channel, 48khz - DTS Master Audio, English, multi-channel, 48khz ************************** getting track info: C:\>eac3to\eac3to.exe E: 1) M2TS, 1 video track, 2 audio tracks, 20 subtitle tracks, 2:17:13 1: Chapters, 20 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: TrueHD/AC3, English, 5.1 channels, 48khz 4: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz 5: Subtitle (PGS), English **************** First Pass: C:\>eac3to\eac3to.exe E: 1) 2: G:\Out\video_BD.h264 4: G:\Out\audio.dtshd M2TS, 1 video track, 2 audio tracks, 20 subtitle tracks, 2:17:13 1: Chapters, 20 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: TrueHD/AC3, English, 5.1 channels, 48khz 4: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz 5: Subtitle (PGS), English ************** [v02] Extracting video track number 2... [a04] Extracting audio track number 4... [v02] Creating file "G:\Out\video_BD.h264"... [a04] Creating file "G:\Out\audio.dtshd"... [a04] Audio overlaps for 7ms at playtime 0:23:06. [*********************************** [a04] Audio overlaps for 10ms at playtime 2:11:04. [a04] The audio file was demuxed without making use of the gap/overlap information. [a04] Please rerun the same eac3to command line. That will correct the gaps/over laps. Video track 2 contains 197424 frames. eac3to processing took 1 hour, 13 minutes. Done. Second Pass: C:\>eac3to\eac3to.exe E: 1) 2: G:\Out\video_BD.h264 4: G:\Out\audio.dtshd M2TS, 1 video track, 2 audio tracks, 20 subtitle tracks, 2:17:13 1: Chapters, 20 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: TrueHD/AC3, English, 5.1 channels, 48khz 4: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz 5: Subtitle (PGS), English Audio gap description file detected, will be used for processing... [v02] Extracting video track number 2... [a04] Extracting audio track number 4... [a04] Realizing DTS gaps... [v02] Creating file "G:\Out\video_BD.h264"... [a04] Creating file "G:\Out\audio.dtshd"... Video track 2 contains 197424 frames. eac3to processing took 1 hour, 12 minutes. Done. Last edited by rica; 7th October 2008 at 00:18. |
#6506 | Link | |
too much lurking
#6508 | Link | |
I also asked slysoft guys. I think the problem has been solved. Why not give it a go? |
#6510 | Link | |
too much lurking
Thanks, I will! |
#6511 | Link |
I also assumed that people were just using eac3to straight from the disc with AnyDVD HD in the background! I only ever rip to HDD first when I know I'll have to do more than one pass for whatever reason. When I've had problems, ripping to HDD first has never fixed them. I think realtime AnyDVD HD must be pretty much transparent by now.
#6512 | Link |
I never intended to hold anything back, every example I've ever used always started off with eac3to d: , with d: being my Blu-ray/HD-DVD drive, I just assumed everyone was going straight from their drives. Sorry guys, I really thought everyone was just using their drive in combination with anydvd.
#6513 | Link |
Trying to demux files recorded with MythTV from digital HD cable. eac3to reports a very large time difference for the audio track, over 1000 ms. How is that possible?
E:\>eac3to E:\debate\1091_20080926180000.mpg TS, 1 video track, 3 audio tracks, 1:59:57 1: MPEG2, 1080i60 /1.001 (16:9) 2: AC3, English, 2.0 channels, 384kbps, 48khz, dialnorm: -24dB, -1150ms 3: AC3, French, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, -1092ms 4: AC3, esl, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, -1059ms http://www.sendspace.com/file/b12wpo The file is played fine by MythTV, audio and video are in sync. I demuxed the sample with eac3to and remuxed the tracks with tsMuxeR. The final result played fine, audio and video were in sync, but a chunk at the beginning of the video, about a second long, was missing - so it looks like eac3to dropped some video to compensate for the time difference. That's fine, it doesn't bother me too much. So all is well, more or less, but I'm puzzled by the size of the difference. Is that how HD is being transmitted? Or is it something that MythTV did? |
#6516 | Link |
I have an issue with Constantine and Serenity HD-DVD's. I converted the audio for both these titles to ac3 (using libav), and it appears that at some places the audio clips.
I can upload a small clip of a particular scene in Constantine where this is most prominent. The scene is a flashback when he is a kid and he sees a demon on a bus. However, I don't know how to cut this small portion out of the main mkv. Any help? |
#6517 | Link | ||
P.S: Just checked: The first video frames are in the file before the file information package. So basically in order to understand the first video frames eac3to would have to first read a part of the file to find the information package and then skip back to the beginning and reread everything. That's not how eac3to works right now. But it should be possible to do it. I'll put it on my to do list. BTW, what is that third audio track? The first two audio streams have the language identifiers "eng" (English) and "fra" (French). But the third has the language identifier "esl" which I don't know how to interpet. Quote:
#6518 | Link | |
Here is a sample: http://www.megaupload.com/?d=GLQ2UP05 deathlord |
#6519 | Link | ||
So, you're saying, that's how it comes through the cable. Well, I just recorded another show, same channel, and the values are different: Code:
E:\debate>eac3to debate2.mpg TS, 1 video track, 3 audio tracks, 1:59:55 1: MPEG2, 1080i60 /1.001 (16:9) 2: AC3, English, 2.0 channels, 384kbps, 48khz, dialnorm: -24dB, -872ms 3: AC3, French, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, -846ms 4: AC3, esl, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, -813ms Quote:
| Tags |
| eac3to |
