Old 24th May 2007, 21:05   #121  |  Link
changomacanaz
Originally Posted by SeeMoreDigital View Post
Hi dmz01, puppydg68's post has just reminded me of something...
When generating .TS re-muxes with v0.0.7, I have noticed that the PCR is placed on PID 0x1001, the video stream is placed on PID 0x1011 and the audio stream placed on PID 0x1100.
Whereas applications such as MPEG2Repair and HDTVtoMPEG2, place the PCR on PID 0x11, the video stream on PID 0x11 and the audio stream on PID 0x14.
When it comes to playing .TS files in "hardware" devices, the latter PID assignments seem to be more compatible.
Cheers
According to the blu-ray specification, video, audio, and PCR must be placed in those PIDs. Hardware devices shouldn't have problems with any assigned PIDs... after all, they get that information from PMTs.
changomacanaz is offline   Reply With Quote
Old 25th May 2007, 00:33   #122  |  Link
dmz01
Cheers
Ahh, this brings back memories...
The entire standard of PMT on pid 0x10, PCR/Video on pid 0x11 and audio on 0x14 started with the piece of hardware called "Dish 5000 Modulator" which would modulate the currently watched channel on the dish 5000 satellite receiver into ATSC Channel 3 output. You could then use any ATSC HDTV tuner card and capture the HDTV versions of HBO, SHO etc.... Yes that device was the one responsible for those pid numbers. However with the modulator being dead for a couple of years now TsRemux follows a new standard - Blu-Ray.
dmz01 is offline   Reply With Quote
Old 25th May 2007, 04:04   #123  |  Link
moshmothma
Originally Posted by moshmothma View Post
Latest version elimates the green screen for me. However, playback is choppy on most remuxes now. Thanks again
Got some egg on my face. The new streams play fine. Problem was new version of kmplayer. Keep up the good work.
moshmothma is offline   Reply With Quote
Old 25th May 2007, 10:57   #124  |  Link
mattmarsden
Would it be possible to release a version that could mux together 2 elementary streams? That would be really good
mattmarsden is offline   Reply With Quote
Old 25th May 2007, 13:47   #125  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Originally Posted by dmz01 View Post
....However with the modulator being dead for a couple of years now TsRemux follows a new standard - Blu-Ray.
Okay, I understand...
I will run a few MPEG-2 with AC3 .TS sources thru' TSremux to see how well they play in my hardware players and report back.
Cheers
Old 25th May 2007, 15:16   #126  |  Link
dmz01
Of all the features I would like to add to the product, this would be the hardest one. The reason being is that TsRemux does not generate new stream clock (PCR). It re-uses the existing one. It's very hard to generate it from scratch, and I don't fully understand how I would do it correctly.
Old 25th May 2007, 22:39   #127  |  Link
dmz01
New version 0.0.8.
No new features. Just major bug fixes. There were two nasty bugs, one in demuxing elementary streams and one in remuxing that would only show up from time to time in some streams. This bug (now fixed) for example caused the remuxed Casino Royale to be corrupted etc. I do want to make this more stable before adding all the cool new features. Hopefully this version is it. Let me know.
dmz
Old 26th May 2007, 01:14   #128  |  Link
Zagolski
Zagolski's Avatar
dmz01
Yes, in a version 008 the bugs of the spoiled image disappeared and demux now
normally! :vodka:
And is it possible to do replacement of sound-tracks ac3 or DTS? That into place is it possible it was
one to insert other? For example, in place of the English track to insert the track of other language.
Do please, that after remux the choice of DTS was accessible audio. Audio DTS not evidently and not heard, it is present although...
Thank you comrade!
Zagolski is offline   Reply With Quote
Old 26th May 2007, 21:33   #129  |  Link
Haali
dmz01: You can generate PCR from video timestamps. PCR is only used to recover remote encoder clock during live playback, it's irrelevant for file playback since local clock is used in this case.
Haali is offline   Reply With Quote
Old 27th May 2007, 11:31   #130  |  Link
PepsiLee2001
I use TSRemux 0.0.8 to convert .evo (from decrypted HD-DVD) to .ts and .m2ts, and play .ts by Haali splitter(07.04.28 version).
Haali splitter can't splitter audio track correct.
Original .EVO have DD+, TrueHD sound tracks.
PepsiLee2001 is offline   Reply With Quote
Old 27th May 2007, 16:02   #131  |  Link
R_no
Hello, thank you for your hard work.
With the 0.0.8 release, I can perfectly demux TS files ( I give a try on SW ep1 H264 with DE+EN audio track) whereas I had always error messages with the previous releases.
It would be great if we can add an external AC3 audio track in the TS file.
But I still can't demux .evo file from a HD-DVD rip. I get an error message about lack of ressources to finish the process. I have 2GB of DDR2 and a C2D E6600.
R_no is offline   Reply With Quote
Old 27th May 2007, 17:20   #132  |  Link
dmz01
did you try with async I/O turned off (unchecked)?
Old 27th May 2007, 18:26   #133  |  Link
R_no
I've unchecked async I/O and now it works perfectly
thx
Old 27th May 2007, 19:19   #134  |  Link
Zagolski
Zagolski's Avatar
I found a method: it is needed to use Sonic HD Demuxer, that was accessible DTS. It does not depend on TSRemux.
Old 27th May 2007, 22:37   #135  |  Link
dmz01
Originally Posted by PepsiLee2001 View Post
Haali splitter can't splitter audio track correct. Original .EVO have DD+, TrueHD sound tracks.
sonic and nero are the only two spitters that I know of, that can split all the new audio tracks correctly
Old 27th May 2007, 22:53   #136  |  Link
dmz01
this still leaves me with question as to how to generate pts and especially dts - I don't believe all the elementary streams have the appropriate clocks? do they?
Old 28th May 2007, 09:58   #137  |  Link
trilko
Unknown video file 0
I want to convert some VOB files from DVDs to TS, and for first few VOBs it works ok, and for the others I get message "Unknown video format 0". Is there problem with TsRemux or with my VOB files? These are VOBs from orignal DVD so I guess they should be ok.
Another problem I have is that I often get messages "Insufficient system resources exist to complete the requested services." (when Use async I/O is on) or "The process cannot access the file 'VTS_01_1.VOB' because it is being used by another process." (when Use async I/O is off). Then I restart TsRemux, try again, if it doesn't work restart it again, as many times as necessary, and then after few times it works. Any idea? Sometimes it also helps if I open any other VOB that works, and then the one which I couldn't open before works...
Tnx guys :-)
trilko is offline   Reply With Quote
Old 28th May 2007, 15:20   #138  |  Link
PepsiLee2001
I try sonic 4.2 decoder package (Sonic HD Demuxer + Sonic Cinemaster Video Decoder + Sonic Cinemaster Audio Decoder) to play .EVO & .TS(converted from TSRemuxer 0.0.8).
Original .EVO contain VC1 track track & DTS-HD, DD+ audio track.
Sonic 4.2 package can play .EVO currect, but still can NOT splitter audio track correctly.
Old 28th May 2007, 17:28   #139  |  Link
Alkasar
Hello,
after years of reading this forum, i found with this topic a good reason to register, wait 5 days, and post for the first time
Many of us in France have a set top box, called FreeboxHD, supplied by our internet provider. This device can play HD video, but can only read AVI and TS files. It decodes many codecs, including mpeg2, h264 and vc1 video and ac3,aac,dts audio. no eac3.
The most popular format we would like to play is MKV(h264+ac3).
We found some interesting ways to remux MKV into TS and make them playable.
For those of you who read french :
- here is the topic where we discuss this
- here is a site to downlad the tool mkv2ts (still in dev) base on directshow filters
- here is a site with samples of TS videos playabe on freeboxHD
TSremux is a very promising tool, among the few able to mux h264 into TS. The exciting new possibility to play hd dvd / BD on our preferred box is getting closer
Some questions about TSRemux future :
- any chance that TSremux could remux an MKV to TS ?
- any chance TSRemux could mux elementary streams in TS ?
(this would allow us to demux EVO or other in elementary streams, convert audio to ac3 and remux into TS)
- any chance TSRemux could convert on the fly eac3 to ac3 to remux a EVO(vc1 + Eac3) --> TS(vc1 + ac3) in one step?
Thanks for the work and long life to TSRemux!
Alkasar is offline   Reply With Quote
Old 28th May 2007, 20:05   #140  |  Link
dmz01
if you can make a small sample available to me I will be able to fix it.
