Old 5th April 2011, 19:07   #1281  |  Link
setarip_old
setarip_old's Avatar
@rayparkerjr
Hi!
Instead, you might try "tsMuxeR (GUI)"...
setarip_old is offline   Reply With Quote
Old 6th April 2011, 19:41   #1282  |  Link
rayparkerjr
Can tsMuxer process files without PAT/PMT ?
Originally Posted by setarip_old View Post
@rayparkerjr
Hi!
tsMuxer can't process some of these files because they are not ISO3818 compliant. Have you used it with the raw files which don't have PMT/PAT ?
It also has issues with some of the DTS tracks.
rayparkerjr is offline   Reply With Quote
Old 6th April 2011, 20:49   #1283  |  Link
SeeMoreDigital
Life looks better in HD
SeeMoreDigital's Avatar
So you run non ISO3818 compliant captures through TSremux first and then though TSmuxerGUI...
Old 7th April 2011, 07:01   #1284  |  Link
rayparkerjr
tsremux skip issues
I had tried that chain of events. However once tsremux has modified the PCR timestamps, tsmuxer doesn't fix them.
Have none of you experienced this issue ?
Old 7th April 2011, 11:36   #1285  |  Link
SeeMoreDigital
I think the underlying issue here is determing why your TS streams don't have any PMT/PAT data!
What application was used to capture these streams?
Old 8th April 2011, 00:53   #1286  |  Link
poisondeathray
Apparently it's from a camcorder
I've been using tsremux to process HD Transport Stream files and my camcorder's HD files
Old 8th April 2011, 16:51   #1287  |  Link
SeeMoreDigital
Actually he says: ...and my camcorder's HD files.
So what about the non camcorder files?
Old 9th April 2011, 03:05   #1288  |  Link
poisondeathray
You're right ! Sorry
Here I was thinking I was so observant ...
Damn my illiterate @$$!
Old 28th April 2011, 01:48   #1289  |  Link
rayparkerjr
Sorry for the late reply but I was out on the road.
Some of the files come from Canon Pixia HD
Others are OTA HD Transport Streams
Old 12th November 2011, 19:30   #1290  |  Link
BizarroTerl
I seem to have found a problem using this application. When run from the command line, IE tsremux somepath\video.mpg somepath\video.m2ts it works fine. If either of the paths have an embedded space it crashes.
BizarroTerl is offline   Reply With Quote
Old 12th November 2011, 19:46   #1291  |  Link
tebasuna51
tebasuna51's Avatar
Isn't a tsremux problem, but OS behaviour.
Use:
tsremux "somepath\video.mpg" "somepath\video.m2ts"
Old 11th March 2012, 12:02   #1292  |  Link
someone89
Does anyone of you has the TsRemux Source TsRemux0.21.2src.zip?
All links I found are down.
someone89 is offline   Reply With Quote
Old 14th May 2012, 16:40   #1293  |  Link
Cedvano
Source code with Exe file.
Cedvano is offline   Reply With Quote
Old 15th May 2012, 18:47   #1294  |  Link
someone89
Can you give me the link?
Old 17th May 2012, 18:39   #1295  |  Link
Cedvano
Download the last version of tsRemuxer.
Old 16th October 2012, 16:53   #1296  |  Link
phuocpham
Can you give the link again? It's not here anymore.
thanks.
phuocpham is offline   Reply With Quote
Old 23rd October 2012, 15:21   #1297  |  Link
Darksoul71
Can you blush ?
Darksoul71's Avatar
Google is your friend :-)
http://www.videohelp.com/download/TsRemux0.23.2.exe
Darksoul71 is offline   Reply With Quote
