16th May 2007, 21:46 | #81 | Link |
New version: 0.0.5
This is mostly bug fixes, no new features yet: Includes code from LuemmelBS to disable Async I/O if you get the "Insufficient Resources" error. Adds smarts to deal with corrupted streams where only a portion of a TS packet exist in a middle of a stream. Fixes PTS/DTS/PCRs that are out of sync due to combining multiple EVOs or M2TSs into a single file. (end-of-sequence removal not yet implemented) Still on the to do list in no particular order: end-of-sequence removal mkv input support adding (inmuxing) SUP streams |
16th May 2007, 22:17 | #82 | Link |
Awesome!
Anxiously waiting for the coming features, this seems to be coming along nicely!
Do you have any plans to open-source your tool? It might speed up development. Might be the first step to build a set of open-source tools for authoring Blu-ray. |
17th May 2007, 18:35 | #85 | Link |
Life's clearer in 4K UHD
Sadly, whenever I feed an MPEG-2.TS source into with v.0.0.5, I obtain the following error message: -
[img]http://img341.imageshack.us/img341/6623/tsremuxsy6.png[img] The same source works fine when fed into with v.0.0.4.... Cheers
18th May 2007, 11:16 | #87 | Link | |
Would it be possible to also include MP4 as an input? Or maybe there is already any tool that converts MP4 to transport stream? Thanx!! |
18th May 2007, 14:46 | #89 | Link | |
And a file with "0 bytes" is produced Cheers
18th May 2007, 19:31 | #91 | Link | |
19th May 2007, 00:32 | #93 | Link |
New version 0.0.6 - bug fixes for the issues mentioned here as well as preliminary support for adding subtitle (presentation graphics) streams. The streams must be in the format that SUPreader recognises as blu-ray subtitles. (You can generate those by demuxing a SUP stream in TsMuxer for example)
19th May 2007, 11:06 | #94 | Link |
Swallowed in the Sea
Hey,
1/ When I load some TS files, I've this error msg : "Sync byte missing". How to resolve this ? 2/ Once, I've got this : "l'index se trouve en dehors des limites du tableau" --> "Index figures outside the tab limits". Sounds like a NULL missing for a pointer. Last edited by Kurtnoise; 19th May 2007 at 11:08. |
19th May 2007, 14:46 | #95 | Link | |
19th May 2007, 20:04 | #97 | Link |
On version 0.0.6 when trying to remux I get the 'object reference not set to an instance of an object' error. Would be great to get this working, as I am having trouble playing my TS stream that has DTS embedded with PureVideo. Thanks! |
19th May 2007, 20:39 | #98 | Link | |
By "corrupted" I mean that there are one or more sections that have missing bytes, usually due to drop-outs etc. It can still play fine with most decoders but you migth be able to see a missing frame or two during playback. Downloading samples now. Thanks! |
19th May 2007, 20:52 | #100 | Link | |
That said, I was unable to generate a re-mux with v0.0.6. Only v0.0.4 works for me! Cheers
